nrfjprog not working on raspberry pi 4
Hi
I am trying to setup a raspberry pi 4 for flashing nrf devices. But Nrfjprog doesn't seem to work.
I am using a Raspberry Pi 4 with 2021-05-07-raspios-buster-armhf-lite
I have fetched Segger and nrfjprog deb packages using :
wget --post-data 'accept_license_agreement=accepted&non_emb_ctr=confirmed&submit=Download+software' www.segger.com/.../JLink_Linux_arm.deb
installed them using:
sudo dpkg -i ~/nRF-Command-Line-Tools_10_14_0_LinuxArm/nrf-command-line-tools_10.14.0_armhf.deb
sudo dpkg -i JLink_Linux_arm.deb
I can detect the target using JLinkExe:
but when running nrfjprog I run into this:
log file as follows:
running ldd I get the following
What am I missing ?
If you need anymore details from my setup, let me know.
  • Hi
    It seems like the JLinkarm_nrf_worker is failing to start for some reason. This could be due to the execution privileges not being correctly applied, which makes the worker non-executable here. Can you check the access rights to jlinkarm_nrf_worker?
    Simon
    I'm facing the same exact issue. This is what I get -
    $ls -l /opt/nrf-command-line-tools/bin/
    total 9372
    -rwxr-xr-x 1 root root 5263624 Aug 27 13:32 jlinkarm_nrf_worker_linux
    -rwxr-xr-x 1 root root 1802516 Aug 27 13:33 mergehex
    -rwxr-xr-x 1 root root 2521320 Aug 27 13:33 nrfjprog
  • Same here
    $ ls -l /opt/nrf-command-line-tools/bin/
    total 9372
  • I don't know if this might help but this happens when trying to connect using directly the JLinkExe binary
    $ JLinkExe
    SEGGER J-Link Commander V7.56b (Compiled Oct 18 2021 16:39:39)
    DLL version V7.56b, compiled Oct 18 2021 16:39:22
    Connecting to J-Link via USB...O.K.
    Firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Feb  2 2021 16:47:20
    Hardware version: V1.00
    S/N: 682820128
    License(s): RDI, FlashBP, FlashDL, JFlash, GDB
    VTref=3.300V
    Type "connect" to establish a target connection, '?' for help
    J-Link>r
    Target connection not established yet but required for command.
    Please specify device / core. <Default>: Unspecified
    Type '?' for selection dialog
    Device>reset
    Please specify target interface:
      J) JTAG (Default)
      S) SWD
      F) FINE
      I) ICSP
      C) C2
      T) cJTAG
    TIF>s
    Specify target interface speed [kHz]. <Default>: 4000 kHz
    Speed>4000
    /opt/SEGGER/JLink_V756b/JLinkGUIServerExe: error while loading shared libraries: libSM.so.6: cannot open shared object file: No such file or directory
    No valid device has been selected.
    J-Link>
  • Hi
    It seems like there's a missing library here. (libSM.so.6). Have you instealled the libsm6 package? It can be done with the following command:
    sudo apt install libsm6
    We might have to add this package as a dependency if this occurs by default when using .deb packages for the tools.
    Simon
