Hi DevZone,
What I am working with:
I am working on a project using nRF Connect SDK with VS Code, and I am also using the nRF Connect extension for it.
My issue:
I am trying to make my VS Code project register my local folder for custom boards so I can use the board when creating a build configuration with the "Add Build Configuration" option in VS Code.
I can do this with an absolute path as shown below in line 29, and as you can see in the images above, I can select "Custom Boards":
{ "folders": [ { "path": "myfirstapp" }, { "name": "minimalTest", "path": "minimalTest" }, { "name": "ThreadsTest", "path": "ThreadsTest" }, { "name": "HelloWorldTest", "path": "HelloWorldTest" }, ], "settings": { "nrf-connect.topdir": "c:\\nRFConnectSDK\\v1.7.0", "nrf-connect.toolchain.path": "c:\\nRFConnectSDK\\v1.7.0\\toolchain", "nrf-connect.applications": [ "d:\\GIT\\GettingStartedNCS\\myfirstapp", "d:\\GIT\\GettingStartedNCS\\minimalTest", "d:\\GIT\\GettingStartedNCS\\ThreadsTest", "d:\\GIT\\GettingStartedNCS\\HelloWorldTest" ], "nrf-connect.boardRoots": [ "d:\\GIT\\GettingStartedNCS\\myfirstapp" ], } }
However, I want the path in "nrf-connect.boardRoots" to be either relative to the Workspace Folder, or use an environment variable to make the contents of the .code-workspace
not be dependent on absolute paths of my PC file structure. I can do this with the "nrf-connect.applications" setting as seen below in line 9 with "${workspaceFolder}".
I have added line 17 to show the difference between it and line 16:
{ "folders": [ { "path": ".." }, ], "settings": { "nrf-connect.applications": [ "${workspaceFolder}" ], "nrf-connect.topdir": "c:\\nRFConnectSDK\\v1.7.0", "nrf-connect.toolchain.path": "c:\\nRFConnectSDK\\v1.7.0\\toolchain", "nrf-connect.boardRoots": [ "d:\\GIT\\GettingStartedNCS\\myfirstapp" //"${workspaceFolder}" ], }
Could you tell me if it is possible to make the "nrf-connect.boardRoots" directory either:
- Relative to the workspace folder
- Dependent on an environment macro
- Or something else which allows me to avoid an absolute path for this setting?
Thank you for your help in advance,
Br. Casper
