How to enable QSPI 4-4-4 on nRF52840/SDK17.1.0
I'm struggling to get a Micron MT25QU128ABA (https://media-www.micron.com/-/media/client/global/documents/products/data-sheet/nor-flash/serial-nor/mt25q/die-rev-a/mt25q_qlhs_u_128_aba_0.pdf) in QSPI mode. I'm positive all the pins are correctly configured and can read and write to the NOR Flash using fewer data lines
If I set #define QSPI_CONFIG_READOC 4 and #define QSPI_CONFIG_WRITEOC 3 in sdk_config.h, I can write just fine, but when reading back the data, it's shifted by 2 bytes (and the initial 2 bytes are 0x88). Which seems to be a misconfiguration of the NOR FLash registers. In order to fix it, I need to set #define QSPI_CONFIG_READOC 3, and everything works, but not in 4-4-4 mode.
In order to enable 4-4-4 mode on the Micron chip, I need to set the correct bit in the volatile or non-volatile registers (different from how the NOR chip on the PCA10056 board works. But as soon as I enable the volatile register for 4-4-4, I cannot communicate with the chip anymore. It looks as if the CPU is sending commands on just one or 2 data lines and not really in 4-4-4 mode
I attached a logic analyzer [...]. EDIT: I now realize that the trace I included is not really representative (leaving it anyway for context). See next answer for more info.  Please let me know if you need a specific trace and, if so, which commands and data would help
How can I enable 4-4-4? What am I doing wrong?
  • Hi
    Thanks for sharing your findings. The difference between 1-1-4 and 1-4-4 is larger than the difference between 1-4-4 and 4-4-4, but again the difference is not very large if you use longer transactions.
    Alternatively you could just ignore the 0x88 bytes in software, but this won't work if you plan to use XIP.
    Best regards
    Torbjørn
