I followed all the steps from the readme instruction and struggle at:
## Compiling pc-ble-driver from source
Step 1. Install vcpkg dependencies is running succesfull
Step 2. cmake -G Ninja .. returns with errors
D:\GIT_REPOSITORIES\FIRMWARE\POWER_BLUE\NORDIC\pc-ble-driver\build>cmake -G Ninja ..
-- NRF_BLE_DRIVER_VERSION not specified, setting it to 0.0.0
-- CONNECTIVITY_VERSION not specified, setting it to 0.0.0
-- The C compiler identification is GNU 10.2.1
-- The CXX compiler identification is GNU 10.2.1
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - failed
-- Check for working C compiler: D:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 5.40c/bin/cc.exe
-- Check for working C compiler: D:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 5.40c/bin/cc.exe - works
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - failed
-- Check for working CXX compiler: D:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 5.40c/bin/cc.exe
-- Check for working CXX compiler: D:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 5.40c/bin/cc.exe - works
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Architecture not set, using native 64-bit toolchain.
-- Building with build type: .
-- Found Git: C:/Program Files/Git/cmd/git.exe (found version "2.29.1.windows.1")
-- Check if the system is big endian
-- Searching 16 bit integer
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of unsigned short
CMake Error at D:/Program Files/CMake/share/cmake-3.21/Modules/CheckTypeSize.cmake:139 (try_compile):
Cannot copy output executable
to destination specified by COPY_FILE:
'D:/GIT_REPOSITORIES/FIRMWARE/POWER_BLUE/NORDIC/pc-ble-driver/build/CMakeFiles/CheckTypeSize/CMAKE_SIZEOF_UNSIGNED_SHORT.bin'
Unable to find the executable at any of:
D:/GIT_REPOSITORIES/FIRMWARE/POWER_BLUE/NORDIC/pc-ble-driver/build/CMakeFiles/CMakeTmp/cmTC_8a2e1.exe
D:/GIT_REPOSITORIES/FIRMWARE/POWER_BLUE/NORDIC/pc-ble-driver/build/CMakeFiles/CMakeTmp/Debug/cmTC_8a2e1.exe
D:/GIT_REPOSITORIES/FIRMWARE/POWER_BLUE/NORDIC/pc-ble-driver/build/CMakeFiles/CMakeTmp/Development/cmTC_8a2e1.exe
I have no idea why its going wrong.
Compiling the C compiler identification source file "CMakeCCompilerId.c" failed. Compiler: D:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 5.40c/bin/cc.exe Build flags: Id flags: The output was: 1 D:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 5.40c/bin/cc.exe: error: -o option required Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" failed. Compiler: D:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 5.40c/bin/cc.exe Build flags: Id flags: The output was: 1 D:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 5.40c/bin/cc.exe: error: -o option required Detecting C compiler ABI info failed to compile with the following output: Change Dir: D:/GIT_REPOSITORIES/FIRMWARE/POWER_BLUE/NORDIC/pc-ble-driver/build/CMakeFiles/CMakeTmp Run Build Command(s):C:/ProgramData/chocolatey/bin/ninja.exe cmTC_78816 && [1/2] Building C object CMakeFiles/cmTC_78816.dir/CMakeCCompilerABI.c.obj D:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 5.40c/gcc/arm-none-eabi/bin/cc1 -fmessage-length=0 -fno-diagnostics-show-caret -march=armv4t -mlittle-endian -mfloat-abi=soft -mthumb-interwork -mtp=soft -mno-unaligned-access -nostdinc -isystemD:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 5.40c/include -I. -D__SIZEOF_WCHAR_T=4 -D__ARM_ARCH_4T__ -D__SES_ARM -D__HEAP_SIZE__=1024 -D__SES_VERSION=54003 -D__GNU_LINKER -quiet -std=gnu99 -fomit-frame-pointer -fno-dwarf2-cfi-asm -fno-builtin -ffunction-sections -fdata-sections -fno-short-enums -fno-common D:/Program Files/CMake/share/cmake-3.21/Modules/CMakeCCompilerABI.c -o CMakeFiles/cmTC_78816.dir/CMakeCCompilerABI.c.asm D:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 5.40c/gcc/arm-none-eabi/bin/as --traditional-format -I. -march=armv4t -mlittle-endian -mfloat-abi=soft -mthumb-interwork CMakeFiles/cmTC_78816.dir/CMakeCCompilerABI.c.asm -o CMakeFiles/cmTC_78816.dir/CMakeCCompilerABI.c.obj rm CMakeFiles/cmTC_78816.dir/CMakeCCompilerABI.c.asm [2/2] Linking C executable cmTC_78816.exe no linker script, memory map file or section placement segments specified Cannot copy output executable '' to destination specified by COPY_FILE: 'D:/GIT_REPOSITORIES/FIRMWARE/POWER_BLUE/NORDIC/pc-ble-driver/build/CMakeFiles/3.21.4/CMakeDetermineCompilerABI_C.bin' Unable to find the executable at any of: D:/GIT_REPOSITORIES/FIRMWARE/POWER_BLUE/NORDIC/pc-ble-driver/build/CMakeFiles/CMakeTmp/cmTC_78816.exe D:/GIT_REPOSITORIES/FIRMWARE/POWER_BLUE/NORDIC/pc-ble-driver/build/CMakeFiles/CMakeTmp/Debug/cmTC_78816.exe D:/GIT_REPOSITORIES/FIRMWARE/POWER_BLUE/NORDIC/pc-ble-driver/build/CMakeFiles/CMakeTmp/Development/cmTC_78816.exe Detecting CXX compiler ABI info failed to compile with the following output: Change Dir: D:/GIT_REPOSITORIES/FIRMWARE/POWER_BLUE/NORDIC/pc-ble-driver/build/CMakeFiles/CMakeTmp Run Build Command(s):C:/ProgramData/chocolatey/bin/ninja.exe cmTC_9498f && [1/2] Building CXX object CMakeFiles/cmTC_9498f.dir/CMakeCXXCompilerABI.cpp.obj D:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 5.40c/gcc/arm-none-eabi/bin/cc1plus -fmessage-length=0 -fno-diagnostics-show-caret -fno-exceptions -fno-rtti -march=armv4t -mlittle-endian -mfloat-abi=soft -mthumb-interwork -mtp=soft -mno-unaligned-access -nostdinc -isystemD:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 5.40c/include -I. -D__SIZEOF_WCHAR_T=4 -D__ARM_ARCH_4T__ -D__SES_ARM -D__HEAP_SIZE__=1024 -D__SES_VERSION=54003 -D__GNU_LINKER -quiet -std=gnu++98 -fomit-frame-pointer -fno-dwarf2-cfi-asm -fno-builtin -ffunction-sections -fdata-sections -fno-short-enums -fno-common D:/Program Files/CMake/share/cmake-3.21/Modules/CMakeCXXCompilerABI.cpp -o CMakeFiles/cmTC_9498f.dir/CMakeCXXCompilerABI.cpp.asm D:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 5.40c/gcc/arm-none-eabi/bin/as --traditional-format -I. -march=armv4t -mlittle-endian -mfloat-abi=soft -mthumb-interwork CMakeFiles/cmTC_9498f.dir/CMakeCXXCompilerABI.cpp.asm -o CMakeFiles/cmTC_9498f.dir/CMakeCXXCompilerABI.cpp.obj rm CMakeFiles/cmTC_9498f.dir/CMakeCXXCompilerABI.cpp.asm [2/2] Linking CXX executable cmTC_9498f.exe no linker script, memory map file or section placement segments specified Cannot copy output executable '' to destination specified by COPY_FILE: 'D:/GIT_REPOSITORIES/FIRMWARE/POWER_BLUE/NORDIC/pc-ble-driver/build/CMakeFiles/3.21.4/CMakeDetermineCompilerABI_CXX.bin' Unable to find the executable at any of: D:/GIT_REPOSITORIES/FIRMWARE/POWER_BLUE/NORDIC/pc-ble-driver/build/CMakeFiles/CMakeTmp/cmTC_9498f.exe D:/GIT_REPOSITORIES/FIRMWARE/POWER_BLUE/NORDIC/pc-ble-driver/build/CMakeFiles/CMakeTmp/Debug/cmTC_9498f.exe D:/GIT_REPOSITORIES/FIRMWARE/POWER_BLUE/NORDIC/pc-ble-driver/build/CMakeFiles/CMakeTmp/Development/cmTC_9498f.exe
The system is: Windows - 10.0.19042 - AMD64 Compiling the C compiler identification source file "CMakeCCompilerId.c" succeeded. Compiler: D:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 5.40c/bin/cc.exe Build flags: Id flags: -c The output was: 0 Compilation of the C compiler identification source "CMakeCCompilerId.c" produced "CMakeCCompilerId.o" The C compiler identification is GNU, found in "D:/GIT_REPOSITORIES/FIRMWARE/POWER_BLUE/NORDIC/pc-ble-driver/build/CMakeFiles/3.21.4/CompilerIdC/CMakeCCompilerId.o" Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" succeeded. Compiler: D:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 5.40c/bin/cc.exe Build flags: Id flags: -c The output was: 0 Compilation of the CXX compiler identification source "CMakeCXXCompilerId.cpp" produced "CMakeCXXCompilerId.o" The CXX compiler identification is GNU, found in "D:/GIT_REPOSITORIES/FIRMWARE/POWER_BLUE/NORDIC/pc-ble-driver/build/CMakeFiles/3.21.4/CompilerIdCXX/CMakeCXXCompilerId.o" Determining if the C compiler works passed with the following output: Change Dir: D:/GIT_REPOSITORIES/FIRMWARE/POWER_BLUE/NORDIC/pc-ble-driver/build/CMakeFiles/CMakeTmp Run Build Command(s):C:/ProgramData/chocolatey/bin/ninja.exe cmTC_3a5e1 && [1/2] Building C object CMakeFiles/cmTC_3a5e1.dir/testCCompiler.c.obj [2/2] Linking C executable cmTC_3a5e1.exe no linker script, memory map file or section placement segments specified Determining if the CXX compiler works passed with the following output: Change Dir: D:/GIT_REPOSITORIES/FIRMWARE/POWER_BLUE/NORDIC/pc-ble-driver/build/CMakeFiles/CMakeTmp Run Build Command(s):C:/ProgramData/chocolatey/bin/ninja.exe cmTC_0d3ce && [1/2] Building CXX object CMakeFiles/cmTC_0d3ce.dir/testCXXCompiler.cxx.obj [2/2] Linking CXX executable cmTC_0d3ce.exe no linker script, memory map file or section placement segments specified Determining if the include file sys/types.h exists passed with the following output: Change Dir: D:/GIT_REPOSITORIES/FIRMWARE/POWER_BLUE/NORDIC/pc-ble-driver/build/CMakeFiles/CMakeTmp Run Build Command(s):C:/ProgramData/chocolatey/bin/ninja.exe cmTC_2097e && [1/2] Building C object CMakeFiles/cmTC_2097e.dir/CheckIncludeFile.c.obj [2/2] Linking C executable cmTC_2097e.exe no linker script, memory map file or section placement segments specified Determining if the include file stdint.h exists passed with the following output: Change Dir: D:/GIT_REPOSITORIES/FIRMWARE/POWER_BLUE/NORDIC/pc-ble-driver/build/CMakeFiles/CMakeTmp Run Build Command(s):C:/ProgramData/chocolatey/bin/ninja.exe cmTC_0026d && [1/2] Building C object CMakeFiles/cmTC_0026d.dir/CheckIncludeFile.c.obj [2/2] Linking C executable cmTC_0026d.exe no linker script, memory map file or section placement segments specified Determining if the include file stddef.h exists passed with the following output: Change Dir: D:/GIT_REPOSITORIES/FIRMWARE/POWER_BLUE/NORDIC/pc-ble-driver/build/CMakeFiles/CMakeTmp Run Build Command(s):C:/ProgramData/chocolatey/bin/ninja.exe cmTC_7dc33 && [1/2] Building C object CMakeFiles/cmTC_7dc33.dir/CheckIncludeFile.c.obj [2/2] Linking C executable cmTC_7dc33.exe no linker script, memory map file or section placement segments specified
