Streaming audio data from ADC with I2S
I´m working on my audio project and I try to stream some audio data (currently a 1 kHz square wave signal with 3.3 V peak) over I2S. The audio signal is sampled by an ADC in the free-running mode.
#include "app_error.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_i2s.h"
#include "nrf_drv_saadc.h"
#include "nrf_drv_timer.h"
#include "nrf_gpio.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define LED_0			17
#define BUTTON_0		13
#define BUTTON_1		14
#define TRIGGER			31
#define SAMPLES			128
static bool			IsStarted		= false;
static volatile uint32_t*	I2S_BlockToFill		= NULL;
static volatile uint32_t*	ADC_BlockToFill		= NULL;
static uint32_t			I2S_Buffer[2][SAMPLES];
static nrf_saadc_value_t	ADC_Buffer[2][SAMPLES];
static nrf_ppi_channel_t	PPI_Channel;
static const nrf_drv_timer_t	Timer = NRF_DRV_TIMER_INSTANCE(0);
void on_Timer_Handler(nrf_timer_event_t EventType, void* p_Context)
void on_SAADC_Handler(nrf_drv_saadc_evt_t const* p_Event)
    if(p_Event->type == NRF_DRV_SAADC_EVT_DONE)
        APP_ERROR_CHECK(nrf_drv_saadc_buffer_convert(p_Event->data.done.p_buffer, SAMPLES));
	ADC_BlockToFill = (uint32_t*)p_Event->data.done.p_buffer;
static void DataHandler(nrf_drv_i2s_buffers_t const* p_Released, uint32_t Status)
    // 'nrf_drv_i2s_next_buffers_set' is called directly from the handler
    // each time next buffers are requested, so data corruption is not
    // expected.
    ASSERT(p_Released);
    // When the handler is called after the transfer has been stopped
    // (no next buffers are needed, only the used buffers are to be
    // released), there is nothing to do.
    if(!(Status & NRFX_I2S_STATUS_NEXT_BUFFERS_NEEDED))
        return;
    // First call of this handler occurs right after the transfer is started.
    // No data has been transferred yet at this point, so there is nothing to
    // check. Only the buffers for the next part of the transfer should be
    // provided.
    if(!p_Released->p_tx_buffer)
        nrf_drv_i2s_buffers_t const NextBuffer = {
            .p_tx_buffer = I2S_Buffer[1],
	    .p_rx_buffer = NULL,
        APP_ERROR_CHECK(nrf_drv_i2s_next_buffers_set(&NextBuffer));
	nrf_gpio_pin_clear(TRIGGER);
        I2S_BlockToFill = I2S_Buffer[1];
        // The driver has just finished accessing the buffers pointed by
        // 'p_Released'. They can be used for the next part of the transfer
        // that will be scheduled now.
        APP_ERROR_CHECK(nrf_drv_i2s_next_buffers_set(p_Released));
        // The pointer needs to be typecasted here, so that it is possible to
        // modify the content it is pointing to (it is marked in the structure
        // as pointing to constant data because the driver is not supposed to
        // modify the provided data).
        I2S_BlockToFill = (uint32_t*)p_Released->p_tx_buffer;
void SAADC_Init(void)
    APP_ERROR_CHECK(nrf_drv_saadc_init(NULL, on_SAADC_Handler));
    APP_ERROR_CHECK(nrf_drv_ppi_init());
    APP_ERROR_CHECK(nrf_drv_timer_init(&Timer, &timer_cfg, on_Timer_Handler));
    nrf_drv_timer_extended_compare(&Timer, NRF_TIMER_CC_CHANNEL0, nrf_drv_timer_us_to_ticks(&Timer, 23), NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
    nrf_drv_timer_enable(&Timer);
    APP_ERROR_CHECK(nrf_drv_ppi_channel_alloc(&PPI_Channel));
    APP_ERROR_CHECK(nrf_drv_ppi_channel_assign(PPI_Channel, nrf_drv_timer_compare_event_address_get(&Timer, NRF_TIMER_CC_CHANNEL0), nrf_drv_saadc_sample_task_get()));
    nrf_saadc_channel_config_t Channel0 = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN1);
    Channel0.acq_time = NRF_SAADC_ACQTIME_10US;
    APP_ERROR_CHECK(nrf_drv_saadc_channel_init(0, &Channel0));
    APP_ERROR_CHECK(nrf_drv_saadc_buffer_convert(ADC_Buffer[0], SAMPLES));
    APP_ERROR_CHECK(nrf_drv_saadc_buffer_convert(ADC_Buffer[1], SAMPLES));
    APP_ERROR_CHECK(nrf_drv_ppi_channel_enable(PPI_Channel));
    SAADC_Init();
    nrf_gpio_cfg_input(BUTTON_0, NRF_GPIO_PIN_PULLUP);
    nrf_gpio_cfg_input(BUTTON_1, NRF_GPIO_PIN_PULLUP);
    nrf_gpio_cfg_output(TRIGGER);
    nrf_gpio_cfg_output(LED_0);
    nrf_gpio_pin_set(LED_0);
    nrf_drv_i2s_config_t I2S_Config = NRF_DRV_I2S_DEFAULT_CONFIG;
    I2S_Config.sdin_pin	    = NRFX_I2S_PIN_NOT_USED;
    I2S_Config.sdout_pin    = 27;
    I2S_Config.lrck_pin	    = 26;
    I2S_Config.sck_pin	    = 25;
    I2S_Config.mck_pin	    = 2;
    I2S_Config.mck_setup    = NRF_I2S_MCK_32MDIV8;
    I2S_Config.ratio	    = NRF_I2S_RATIO_96X;
    I2S_Config.channels	    = NRF_I2S_CHANNELS_STEREO;
    APP_ERROR_CHECK(nrf_drv_i2s_init(&I2S_Config, DataHandler));
    nrf_drv_i2s_buffers_t const InitialBuffer = {
	.p_tx_buffer = I2S_Buffer[0],
    while(1)
	if(nrf_gpio_pin_read(BUTTON_0) == false)
	    if(IsStarted == false)
		APP_ERROR_CHECK(nrf_drv_i2s_start(&InitialBuffer, SAMPLES, 0));
		NRF_LOG_INFO("I2S sender started...");
		IsStarted = true;
		nrf_gpio_pin_set(TRIGGER);
		nrf_gpio_pin_clear(LED_0);
	else if(nrf_gpio_pin_read(BUTTON_1) == false)
	    if(IsStarted)
		nrf_drv_i2s_stop();
		NRF_LOG_INFO("I2S sender stopped...");
		IsStarted = false;
	if(I2S_BlockToFill && ADC_BlockToFill)
	    for(uint32_t i = 0x00; i < SAMPLES; i++)
		//int16_t Sample = (int16_t)(32768 * sin(2.0 * 3.14 * (double)i / ((double)SAMPLES)));
		I2S_BlockToFill[i] = (uint32_t)(0x0000 | (ADC_BlockToFill[i] & 0xFFFF));
	if(NRF_LOG_PROCESS())
	    NRF_LOG_FLUSH();
The code from above will give a pretty poor signal when I use the ADC.
I have tried to figure out the reason for this and replaced the line
with
I2S_BlockToFill[i] = (uint32_t)(0x0000 | (i & 0xFFFF));
to produce data from a ramp signal and the signal looks much better.
So it looks like the problem is based on the ADC. I have tried to use two buffers to use the same swapping buffer system as in the I2S example.
How can I improve this result?
  • Great - I look forward to hearing your results! :)
    In the case that you do not see a noticeable difference, could you have the SAADC sample a sine wave instead, and share its raw digital output with me, along with the sine's frequency and amplitude, so I may take a closer look at what might be going wrong.
    Karl
  • Hi
    I have visualized the transmission between the nRF52 and the FPGA over I2S with my ILA. The gap and the transmissions have the same length.
    So there is a transmission gap for sure.
    Please also note that I don´t use any input signal in this case. I just sample the noise of the ADC.
  • Hello Kampino,
    Thank you for this update - this is very helpful.
    How long are each of these gaps?
    In your other ticket you mentioned seeing a performance increase when changing the SDK configuration as suggested in my previous comment - could you detail this performance increase?
    Could you also possibly provide a similar plot for the case in which you were not using the SAADC to gather the I2S output?
    Thank you for clarifying - This should not matter for the frequency of the sampling / outputted samples, but it is good to know nevertheless.
    Karl
  • Hi Karl,
    The gaps and the transmissions are around 1.5 ms long (~41.74 kHz LRCLK).
    Sorry, I forgot the screenshot. I think the signal quality has increased because the signal looks better (always the same height) and is less noisy (you can see it in the Fourier series).
    Sure. Please take a look at the following plots.
    Change the code from
    to
    Transmission captured with ILA:
    I also attach my sdk_config (just to be sure Slight smile)
    8360.sdk_config.h
  • Hi Karl,
    to
    8360.sdk_config.h
    Edit:
    I have decreased the sampling rate from us to ms by changing
    to
    nrf_drv_timer_extended_compare(&Timer, NRF_TIMER_CC_CHANNEL0, nrf_drv_timer_ms_to_ticks(&Timer, 23), NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
    Edit 2:
    I have figured out that the I2S buffer isn´t filled correctly. Only the first half is filled (I suggest because of the int16 and uint32 data types):
