Building sample "nrf/sample/zigbee/light_bulb" gives compiler error!
I have been using NRF Connect SDK 1.6.1 with Microbit V2 to run some zigbee projects! Now when I should build some new firmwares I upgraded to SDK 1.7.1 and after that the sample gives the error below!
CMake Error at C:\Dev\Nrf\sdk\v1.7.1\nrf\drivers\mpsl\temp_nrf5\CMakeLists.txt:12 (message):
CONFIG_TEMP_NRF5 and CONFIG_TEMP_NRF5_MPSL have both been enabled, but must
not be used together.
I have driled it down to that it seems to be the clock control needed for Microbit that gives the error!
CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM=y
Any suggestions on how to proceed? An easy way to reproduce this error is to add the above compiler directive to ..\v1.7.1\zephyr\boards\arm\nrf52833dk_nrf52833\nrf52833dk_nrf52833_defconfig and build for that board.
