i2c receive event
* @brief TWI master driver event types.
typedef enum
NRF_DRV_TWI_EVT_DONE, ///< Transfer completed event.
NRF_DRV_TWI_EVT_ADDRESS_NACK, ///< Error event: NACK received after sending the address.
NRF_DRV_TWI_EVT_DATA_NACK ///< Error event: NACK received after sending a data byte.
} nrf_drv_twi_evt_type_t;
is there any event triggers when i receive the data?
     * Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup blinky_example_main main.c
     * @ingroup blinky_example
     * @brief Blinky Example Application main file.
     * This file contains the source code for a sample application to blink LEDs.
    #include <stdbool.h>
    #include <stdint.h>
    #include "nrf_delay.h"
    #include "boards.h"
    #include "DAC.h"
    #include "stdio.h"
    //#include "main.h"
    #include "nrf_drv_spi.h"
    #include "nrf_gpio.h"
    #include <string.h>
    //#include "nrf_twi.h"
    //#include "nrfx_twi.h"
    #include "nrf_drv_twi.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
     //#define TWI_ADDRESSES      127
     #define EEPROM_ADDR          0xA0
    #define SPI_INSTANCE   0 /**< SPI instance index. */
    nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
     bool spi_xfer_done;
     #define TWI_INSTANCE  1
      nrf_drv_twi_t twi =  NRF_DRV_TWI_INSTANCE(TWI_INSTANCE);
     bool  m_xfer_done = false;
    void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
                           void *                    p_context)
        spi_xfer_done = true;
      //  NRF_LOG_INFO("Transfer completed.");
      /*  if (m_rx_buf[0] != 0)
            NRF_LOG_INFO(" Received:");
            NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
    void Spi0_init(void)
        nrf_drv_spi_config_t spi_config ;
        spi_config.ss_pin   = SPI_SS_PIN;
        spi_config.miso_pin = SPI_MISO_PIN;
        spi_config.mosi_pin = SPI_MOSI_PIN;
        spi_config.sck_pin  = SPI_SCK_PIN;
        spi_config.frequency = NRF_SPI_FREQ_4M;
        spi_config.mode = NRF_SPI_MODE_0;
        spi_config.bit_order = NRF_SPI_BIT_ORDER_MSB_FIRST;
        APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, NULL, NULL));
    void twi_event( nrf_drv_twi_evt_t const * p_event_twi ,void *p_context_twi)
       switch(p_event_twi->type)
         case NRF_DRV_TWI_EVT_DONE :
         m_xfer_done = true;
    void I2C_1_init(void)
        uint32_t err_code;
        nrf_drv_twi_config_t const config = {
           .scl                = ARDUINO_SCL_PIN,
           .sda                = ARDUINO_SDA_PIN,
           .frequency          = NRF_TWI_FREQ_400K,
           .interrupt_priority = APP_IRQ_PRIORITY_LOWEST,
           .clear_bus_init     = false,
       err_code = nrf_drv_twi_init(&twi,&config,NULL,NULL);
       nrf_drv_twi_enable(&twi);
     * @brief Function for application main entry.
          uint32_t err_code;
          // uint8_t address;
          // uint8_t sample_data;
           uint8_t Tx_buffer[3] = {0};
           uint8_t Rx_buffer[3] = {0};
        bool detected_device = false;
        /* Configure board. */
       // Spi0_init();
        I2C_1_init();
       /*    err_code = nrf_drv_twi_rx(&twi, EEPROM_ADDR, &sample_data, sizeof(sample_data));
            if (err_code == NRF_SUCCESS)
                detected_device = true;
                NRF_LOG_INFO("TWI device detected at address 0x%x.", address);
            NRF_LOG_FLUSH();
        if (!detected_device)
            NRF_LOG_INFO("No device was found.");
            NRF_LOG_FLUSH();
           Tx_buffer[0] = 0x00;
           Tx_buffer[1] = 0x00;
           Tx_buffer[2] = 0x12;
          err_code = nrf_drv_twi_tx(&twi, (EEPROM_ADDR >> 1), Tx_buffer, 3,0);
                NRF_LOG_INFO("TWI device detected at address 0x%x.", EEPROM_ADDR);
            NRF_LOG_FLUSH();
            NRF_LOG_FLUSH();
          nrf_delay_ms(1000);
          err_code = nrf_drv_twi_tx(&twi, (EEPROM_ADDR >> 1), Tx_buffer, 2,0);
          err_code = nrf_drv_twi_rx(&twi, (EEPROM_ADDR >> 1), Rx_buffer, 1);
                NRF_LOG_INFO("TWI device detected at address 0x%x.",EEPROM_ADDR );
            NRF_LOG_FLUSH();
            NRF_LOG_FLUSH();
        /* Toggle LEDs. */
        while (true)
          /*  for (int i = 0; i < LEDS_NUMBER; i++)
                bsp_board_led_invert(i);
                nrf_delay_ms(500);
         /*   for(uint16_t i = 500; i <= 2500; i += 500)
    	     Dac_Input(channel_A,i);
    	     nrf_delay_ms(2000);
    when i initialise the twi with event handler transmission part works fine but receiving wont happen but if i use polling it works fine.
    is there any events triggered when i receive the data?
  • Yes,
    you should receive NRF_DRV_TWI_EVT_DONE event and handle the event to check if you received any data like this
            case NRF_DRV_TWI_EVT_DONE:
                if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
                    app_specific_data_handler(m_sample);
    Check the examples\peripheral\twi_sensor\main.c example for the reference of its usage.
  • NRF_DRV_TWI_EVT_DONE this indicates tranfer complete event right?
  • when i start receiving the data is there any intterupt will trigger?
      /** @file
      #include <stdint.h>
      #include "boards.h"
      #include "DAC.h"
      #include "stdio.h"
      //#include "main.h"
      #include <string.h>
      #include "nrf_drv_uart.h"
      #include"nrf_uart.h"
      bool spi_xfer_done;
      static volatile bool  m_xfer_done = false;
      #define UART_INSTANCE  0
      nrf_drv_uart_t uart = NRF_DRV_UART_INSTANCE(UART_INSTANCE);
      bool  uart_xfer_done = false;
      uint8_t sample_data = 12;
                           void *                    p_context)
        uint32_t err_code;
         if (p_event_twi->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
        // err_code = nrf_drv_twi_tx(&twi, (EEPROM_ADDR >> 1), Tx_buffer, 2,0);
        // err_code = nrf_drv_twi_rx(&twi, (EEPROM_ADDR >> 1), Rx_buffer, 1);
          m_xfer_done = true;
      void uart_handler(nrf_drv_uart_event_t *p_event)
        if (p_event->type == NRF_DRV_UART_EVT_TX_DONE)
            uart_xfer_done =true;
        if (p_event->type == NRF_DRV_UART_EVT_RX_DONE)
        uint32_t err_code;
       err_code = nrf_drv_twi_init(&twi,&config,twi_event,NULL);
      void UART_init(void)
       uint32_t err_code;
       nrf_drv_uart_config_t const config = {
       .pselrxd = SER_CON_RX_PIN,
       .pseltxd = SER_CON_TX_PIN,
       .pselrts = SER_CON_RTS_PIN,
       .pselcts = SER_CON_CTS_PIN,
       .baudrate = NRF_UART_BAUDRATE_115200,
       .hwfc = NRF_UART_HWFC_DISABLED,
       .parity = NRF_UART_PARITY_INCLUDED,
       .interrupt_priority = 6,
       err_code = nrf_drv_uart_init(&uart,&config,uart_handler);
    void Mem_Read(void)
         uint32_t err_code;
          NRF_LOG_FLUSH();
            NRF_LOG_FLUSH();
      void Mem_Write(void)
      uint32_t err_code;
      NRF_LOG_FLUSH();
      NRF_LOG_FLUSH();
      nrf_delay_ms(1000);
        uint32_t err_code;
       // Spi0_init();
        I2C_1_init();
        UART_init();
        Mem_Write();
        Mem_Read();
        NRF_LOG_FLUSH();
            NRF_LOG_FLUSH();
          nrf_delay_ms(1000);
          NRF_LOG_FLUSH();
            NRF_LOG_FLUSH();
        err_code = nrf_drv_uart_tx(&uart,&sample_data,sizeof(sample_data));
        /* Toggle LEDs. */
        while (true)
                nrf_delay_ms(500);
                 nrf_delay_ms(2000);
          //  err_code = nrf_drv_uart_rx(&uart,&sample_data,1);
    when i initialise the twi with twi handler data transfer works fine but data receive not working? but when i intialise the twi with NULL for event handler it works fine
  • I do not see anything in your twi_event that will make it behave different than when not using the event handler at all.
    Can you share SDK version you using? can it be reproduced on the DK?
