Receivd corrupt data on 52833dk with lpuart sample
I am running the lpuart sample to connect nrf9160dk <-> nrf52833dk.
The only change in source is added code to print out the data received from RX.
And I enalbe the console log and NRF_SW_LPUART_INT_DRIVEN, here is the proj.conf:
CONFIG_NRF_SW_LPUART=y
# CONFIG_USE_SEGGER_RTT=n
CONFIG_LOG=y
CONFIG_NO_OPTIMIZATIONS=y
CONFIG_ASSERT=y
# Comment this section for debugging
# CONFIG_CONSOLE=n
# CONFIG_UART_CONSOLE=n
# Uncomment to use lpuart using interrupt driven API
CONFIG_NRF_SW_LPUART_INT_DRIVEN=y
When running the sample, everything looks fine on 9160 side.
I can see the char 0xFF sent by uart_poll_out() and {1, 2, 3, 4, 5} sent by uart_fifo_fill().
read 1 bytes
  - byte 0: ff
read 5 bytes
  - byte 0: 01
  - byte 1: 02
  - byte 2: 03
  - byte 3: 04
  - byte 4: 05
But on the 52833 side, the received data is corrupted.
read 1 bytes
  - byte 0: fe
read 2 bytes
  - byte 0: 20
  - byte 1: 80
read 1 bytes
  - byte 0: ff
(... not repeated same data, randomly ...)
I use LA to check the data on the 52833 RX pin, it looks fine. The 9160 did send the correct data.
Any advice is appreciated, thanks.
