Counter using timer
I am using timer 3 as a counter for my capacitor discharge time. Currently, the value of is always problematic because it shows with too many deviation values ​​sometimes 15837, but other times 239 while the environment for the hr202 sensor remains unchanged. I am using nrf_drv_timer_capture() function to get that time value. So what am I encountering here?
this is my code and may schematic. Can someone help me?
void timer_event_handler(nrf_timer_event_t event_type, void *p_context) {}
const nrf_drv_timer_t TIMER = NRF_DRV_TIMER_INSTANCE(3);
static void config_timer()
    uint32_t err_code = NRF_SUCCESS;
    nrf_drv_timer_config_t timer_cfg;
    timer_cfg.frequency = NRF_TIMER_FREQ_1MHz;
    timer_cfg.mode = NRF_TIMER_MODE_TIMER;
    timer_cfg.bit_width = NRF_TIMER_BIT_WIDTH_16;
    timer_cfg.interrupt_priority = 6;
    timer_cfg.p_context = NULL;
    err_code = nrf_drv_timer_init(&TIMER, &timer_cfg, timer_event_handler);
static void human_begin_read(uint8_t type)
    nrf_gpio_cfg_output(HUMI_PIN);
    nrf_gpio_cfg_output(REF_PIN);
    nrf_gpio_cfg_output(READ_PIN);
    // clear pin
    nrf_gpio_pin_write(HUMI_PIN, 0);
    nrf_gpio_pin_write(REF_PIN, 0);
    nrf_gpio_pin_write(READ_PIN, 0);
    nrf_delay_ms(1);
    humi_state = HUMI_NORMAL;
    ovf_count = 0;
    humi_time = 0;
    nrf_gpio_cfg_input(READ_PIN, NRF_GPIO_PIN_NOPULL);
    if (type == REF)
        nrf_gpio_cfg_default(HUMI_PIN);
        nrf_gpio_pin_write(REF_PIN, 1);
        nrf_gpio_cfg_default(REF_PIN);
        nrf_gpio_pin_write(HUMI_PIN, 1);
    uint32_t time_ticks = nrf_drv_timer_ms_to_ticks(&TIMER, 1000);
    nrf_drv_timer_extended_compare(
        &TIMER, NRF_TIMER_CC_CHANNEL0, time_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
    nrf_drv_timer_enable(&TIMER);
    while (nrf_gpio_pin_read(READ_PIN) == 0)
    humi_time = nrf_drv_timer_capture(&TIMER, NRF_TIMER_CC_CHANNEL0);
    nrf_drv_timer_clear(&TIMER);
    nrf_drv_timer_disable(&TIMER);
    humi_state = HUMI_SUCCESS;
    // clear pin
    nrf_delay_ms(1);
