nRF52810 passkey entry
Hi Sir/Miss,
I try to implement static passkey in my project. Which is using nRF52810.
The SDK version is 17.0.2.
Softdevice is S112.
My project is based to develop on NUS.
I want to use central device to enter passkey to do pairing and bonding.
It's just like ble_app_gls example.
I refer ble_app_template example to add peer_manager and fds in project.
Reference this to do it.
#define SEC_PARAM_BOND                  1                                           /**< Perform bonding. */
#define SEC_PARAM_MITM                  1                                           /**< Man In The Middle protection required (applicable when display module is detected). */
#define SEC_PARAM_LESC                  0//1                                           /**< LE Secure Connections enabled. */
#define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_DISPLAY_ONLY                /**< Display I/O capabilities. */
#define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size. */
And, add setup static passkey code between ble_stack_init() and advertising_start()
When I use dongle to connect nrf52810 in nRF connect, it doesn't pop up passkey entry window on it. It's connected directly.
It's different with glucose example.
How do I set it up?
Thank you.
