Custom Board Not Running Code
I have a program that runs great on the dev kit, however after uploading the code to a custom board based on the nRF52810, it does not seem to run.
I upload the code by connecting SWIO, SWCLK, Vdd, GND, VTG->Vdd, and GND_Detect->GND, and running:
nrfjprog -f nrf52 --program SOFTDEVICE_HEXDIR --chiperase --verify --log
nrfjprog -f nrf52 --program CUSTOMPROGRAM_HEXDIR --restart --verify --log
These commands complete without error, and the dev kit keeps running the old code, so I'm reasonable certain that uploading is working properly.
However, my test program (which just toggles some pins) seems to not run, and all pins seem to remain in high impedance state.
Initially, I had thought that it was because I'm using the nReset pin, however after manually removing that connection and leaving nReset floating, I get the same behavior.
This thread mentions a similar issue, which was resolved by changing the 32Mhz crystal. I am currently using this 8pF crystal with 12pF caps on each line, which I think is correct.
I also tried using the high frequency clock as the low frequency clock source, as is mentioned in this thread, which didn't seem to affect anything
