Which Example should i use for BLE mesh which support the OTA?
Hi Everone..
I want to know for my project Which Example should i use for BLE mesh which support the OTA
I have nRF52832 DK, and several other custom board  which is based on nrf52840.  I have working on BLE mesh sdk version 5.0
I want to make BLE mesh in that node, relay node, Border node for communicate with server.
Node_1(Adc_reading) (boolean_ value) (SPI) --------> relay_Node---->Border_Node------->(Through UART)-----> send data to Server(Cloud).
Please give me tutorial and what would be the flow for this using nRF52832 BLE mesh. It will use making smart socket project.
Thanks in Advance.
    The example is from SDK v4.0 and to be used with SDK v16 so there is some slightly changed needed. I would suggest to have a look and check for the change that I made (you can use diff or use a compare tool in Notepad++ for example) and apply the same change to SDK v17 and the example in SDK v5.0.
    All in all, I would suggest to get familiar with the co-exist example without any modification first before you move to anything else.
    As per your suggestion i go through the co-exist example only. its working fine.
    thank you so much friend.
    But,
    could you do me a favour...?
    could you please send me the code "ble_app_uart_coexist_GATT".
    which support the nrf SDk 17.0.2 with nrf MESH 5.0
    besacuse i am unable to do changes in your code which you send me last time.
    if u do it for me i'll be very thankful to you..
    thanks.
    Please find the application for SDK v5.0
    Please make sure you have defined the SDK_ROOT and MESH_ROOT in SES correctly, pointed to the right SDK.
    What I edit is marked with "//GATT_EDIT********************"
    7536.ble_app_uart_coexist_GATT_SDK5.0.zip
  • hi,
    i got your code...  "ble_app_uart_coexist_GATT".
    its working with nrf sdk v17.0 and mesh v5.0
    its build without any issue... thank you so much..
    but,
    by this also i am unable to provision with mobile app "Nrf Mesh"
    while scanning in app it is showing only the server kit name with ( nrf5x light) BUT not showing the "Nordic Uart" Do you know why...?
    AND
    i also go through the ble_app_uart_coexist example also...
    i used a another nrf kit to do provision (i do not use mpbile here)
    but when i open tera term to give input it is not working...
    i checked the correct COM port and baudrate also.. but it is not taking any input through keyboard.. and showing nothing..
    please help to solve it.
    please suggest.. is it a better idea if i use j-link RTT viewer instead of tera term (Uart)
    what is better thing between these two.
    thanks.
  • Please add
     #define MESH_FEATURE_PB_GATT_ENABLED (1)
    #define MESH_FEATURE_GATT_PROXY_ENABLED (1)
    into nrf_mesh_config_app.h that was missing in my code.
    Also please do a chip erase before testing to avoid the chip already being provisioned before you test.
    If you want to provision from a COM Port you need to follow this guide.
