Nordic not reflashable suddenly
Nordic,
We've been using the nRF52832 for many years now.  We have a custom board that uses SWCLK and SWDIO to flash our NRF52.  We're getting set for production and I am working on our automated manufacturing rig.  We have a python script that flashes a nordic with a soft device, bootloader, and then application.  Some of the GPIO go to LEDs, so I can see what state the chip is in after programming.  It had been working great then I started getting this problem where the LEDs didn't show up in the right state.  I'd go to reflash the device, and then the SWD won't connect, and I could not erase the chip.  I can hit our reset button, tied to the RESET pin on the IC, and nothing happens.  Normally this button does a hard reset, where the LED goes away and (I believe) the chip loses power.  Upon release of the reset, the board should initialize into the bootloader and the LED blinks red marking as such.  But for these 'bricked' boards, the LED stays on throughout the reset button press.   These two things: not able to reset the chip, and not being able to reflash the chip, these are quite alarming.
One piece of good news is the current drawn seems to be about 1 mA like when the Nordic is in low power state.
I've spent most all day going through devzone forums trying things, hoping to recover or at least explain my freeze-up.
When I go back into J Flash Lite, I can no longer ERASE the chip.  Now it says
Connecting to J-Link...
Connecting to target...
ERROR: Could not connect to target.
Done.
Fine, I can try from the command utility.  I use the jlink.exe tool, and go through the regular steps to connect and then try to erase.  This also doesn't work:
J-Link>connect
Device "NRF52832_XXAA" selected.
Connecting to target via JTAG
InitTarget() start
InitTarget() end
TotalIRLen = ?, IRPrint = 0x..000000000000000000000000
InitTarget() start
InitTarget() end
InitTarget() start
InitTarget() end
InitTarget() start
InitTarget() end
Cannot connect to target.
Ok, now I try to use the nrfjprog tool.  For reference I look up the version as
nrfjprog version: 10.15.1 external
JLinkARM.dll version: 7.58b
Then I do all kinds of commands to try and talk to my board.  Here are some
>nrfjprog --recover --log
ERROR: [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
ERROR: [ nRFXX] - Device does not have an ARM debug port.
ERROR: nrfjprog could not identify the target device. This may be due to an
ERROR: invalid family argument, a problem with your device, or nrfjprog may
ERROR: not yet support your device.
ERROR: Please check the family argument passed, or upgrade nrfjprog to a more
ERROR: recent version.
>nrfjprog -e
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
>nrfjprog -d --family nrf52 --log
ERROR: Unable to connect to a debugger.
ERROR: [ nRF52] - Debug probe is not connected to an NRF52 series device.
ERROR: The --family option given with the command (or the default from
ERROR: nrfjprog.ini) does not match the device connected.
I know the segger and cables and everything are correct, I HAD been able to program this and other boards.  But during development of the python script, I've 'bricked' 5 of my boards.  I only have 2 left.  So I need to get to the bottom of this.
I don't understand how something could ever make the SWCLK SWDIO not able to erase the chip.  What am I missing, please help.
environment:  windows 10
  • We just confirmed with nrfjprog --memrd 0x10001200 that they are both set to 0x15, which is 21.  Which is what we want, we think.  We do have CONFIG_GPIO_AS_PINRESET in the make file, which again is what we want.  One more confirm is that we do a printout of those two pins on the startup, and we see them as 0x15,0x15.
    But still when we remove the 3V from the pin, the board bricks.
    How do we do your test?  When and what would we write to force this pin to be a pull-up?
    Also, how do we know what build code our setup is?
    Thanks for your help!
  • Abbreviation Definition and implemented codes
     N52/nRF52 nRF52 Series product
     832 Part code
     <PP> Package variant code
     <VV> Function variant code
     <H><P><F> Build code
                          H - Hardware version code
                          P - Production configuration code (production site, etc.)
    The Build code is in the part number; (old notes:)not sure if this is readable from the MCU, I have 'F':
        ARCHITECTURE bits[19:16] Reads as 0xF, see About the CPUID scheme on page B4-644
    Always run following code on power-up, but outside the reset() #if stuff; worth a try:
        // If the code gets here, enable the Reset pin pull-up to hold the pin inactive for a brief time on reset
    #define PULLNONE   (0UL <<  2) // Bit 3..2: Pin Pull Disabled
    #define PULLDOWN   (1UL <<  2) // Bit 3..2: Pin Pulldown
    #define PULL_NA    (2UL <<  2) // Bit 3..2: Pin Pull n/a
    #define PULLUP     (3UL <<  2) // Bit 3..2: Pin Pullup
        NRF_P0->PIN_CNF[21] = (PULLUP);
        // Software Disable APPROTECT - only use duriing development
        // AAAA 0x41414141 AAAA
        // AAAC 0x41414143 AAAC
        // AABA 0x41414241 AABA
        // AABB 0x41414242 AABB
        // AAB0 0x41414230 AAB0
        // ABB0 0x41424230 ABB0
        // AAE0 0x41414530 AAE0
        // ABE0 0x41424530 ABE0
        // AAGB 0x41414742 AAGB <== HwDisable Access Port protection
        // ABGB 0x41424742 ABGB <== HwDisable Access Port protection
        // AAG0 0x41414730 AAG0 <== HwDisable Access Port protection
        // ABG0 0x41424730 ABG0 <== HwDisable Access Port protection
        if ((NRF_UICR->APPROTECT & 0xFF) == 0xFF) // && (NRF_FICR->INFO.VARIANT == 0xnnGn))
            NRF_UICR->APPROTECT = 0x5A;   // HwDisable Access Port protection  - write once only
        #if defined (CONFIG_GPIO_AS_PINRESET)
            if (((NRF_UICR->PSELRESET[0] & UICR_PSELRESET_CONNECT_Msk) != (UICR_PSELRESET_CONNECT_Connected << UICR_PSELRESET_CONNECT_Pos)) ||
                ((NRF_UICR->PSELRESET[1] & UICR_PSELRESET_CONNECT_Msk) != (UICR_PSELRESET_CONNECT_Connected << UICR_PSELRESET_CONNECT_Pos))){
                NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen << NVMC_CONFIG_WEN_Pos; // Write Enable
                while (NRF_NVMC->READY == NVMC_READY_READY_Busy){}
                NRF_UICR->PSELRESET[0] = 21;
                NRF_UICR->PSELRESET[1] = 21;
                NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren << NVMC_CONFIG_WEN_Pos; // Read-only Enable
                // UICR changes require a reset to be effective
                NVIC_SystemReset();
  • Ah, found an update:
    Table 137: Function variant codes
     <VV> Flash (kB) RAM (kB) Access port protection
     AA 512 64 Controlled by hardware
     AB 256 32 Controlled by hardware
     AA-G 512 64 Controlled by hardware and software
     AB-G 256 32 Controlled by hardware and software
    Maybe you now have the new 'AAG0' device when before you used the AAE0; AAG0 has the different mechanism I describe above
  • I'm at my house now, so I can't try any new code.   But I did look up and found our parts are all NRF52832-QFAA-R7.  So it should all be hardware, right?
    This still doesn't address how this happened and how to confirm it won't happen again.
  • Can't tell from that code; might have an AAGB or AAG0 - try:
       char ch, VarientStr[4+1] = "----";
       if (isprint(ch = (NRF_FICR->INFO.VARIANT>> 0u & 0xFF))) VarientStr[3] = ch;
       if (isprint(ch = (NRF_FICR->INFO.VARIANT>> 8u & 0xFF))) VarientStr[2] = ch;
       if (isprint(ch = (NRF_FICR->INFO.VARIANT>>16u & 0xFF))) VarientStr[1] = ch;
       if (isprint(ch = (NRF_FICR->INFO.VARIANT>>24u & 0xFF))) VarientStr[0] = ch;
       snprintf(mBuffer, sizeof(mBuffer), "Var %lX (%s)", NRF_FICR->INFO.VARIANT, VarientStr);
    Well, I have AAE1 which isn't even listed! It's in a module .. hmm see 0x41414531-not-listed-in-datasheet
