Thingy 52 SoftDevices: S132,
Can i ask if thingy 52 is able to use Immediate Alert Client Application (https://infocenter.nordicsemi.com/index.jsp?topic=%2Fsdk_nrf5_v17.1.0%2Fble_sdk_app_ias_c.html) ? Which allows sending of alerts to the remote device (for example, a smartphone).
  • Hi, yes you can run the nRF5 SDK examples on the Thingy52!
    Stian
  • Hello ! thank you for your reply.
    can i ask something else at here or do i need to open a new ticket?
    my question will be can thingy 52 itself be used as a location tracker, from Received Signal Strength Indicator(RSSI) . Does it have this function ? If it does, may i check is there any example for this ?
    Thank you so much!!!
  • Hi, the Thingy52 is just a development platform for the nRF52 series SoCs. So whatever feature is present on the nRF52 will also be present on the Thingy52. The nRF52 can read the RSSI, and this is exposed to the user through the SoftDevice API (sd_ble_gap_rssi_get). Whether or not this value can be used to track the location of the device depends on the application, and the required accuracy. Maybe you can check out the proximity application?
  • Hello !! THANK YOU SO MUCH FOR YOUR REPLY.
    I managed to did RSSI on PCA10040 using this : https://devzone.nordicsemi.com/f/nordic-q-a/38457/can-a-peripheral-device-know-the-rssi-for-a-connected-central .
    But i am thinking if i am able to apply this code into thingy52. Because I really need this function in thingy.
    proximity application also able to combine with thingy FW ? I do have the example of the proximity example which is only for PCA10040 :
     * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_app_proximity_main main.c
     * @ingroup ble_sdk_app_proximity_eval
     * @brief Proximity Application main file.
     * This file contains is the source code for a sample proximity application using the
     * Immediate Alert, Link Loss and Tx Power services.
     * This application would accept pairing requests from any peer device.
     * It demonstrates the use of fast and slow advertising intervals.
    #include <stdint.h>
    #include <string.h>
    #include "ble_advertising.h"
    #include "nordic_common.h"
    #include "nrf.h"
    #include "nrf_soc.h"
    #include "nrf_drv_saadc.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_err.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_tps.h"
    #include "ble_ias.h"
    #include "ble_lls.h"
    #include "ble_bas.h"
    #include "ble_conn_params.h"
    #include "sensorsim.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "app_timer.h"
    #include "ble_ias_c.h"
    #include "app_util.h"
    #include "bsp_btn_ble.h"
    #include "ble_db_discovery.h"
    #include "peer_manager.h"
    #include "peer_manager_handler.h"
    #include "fds.h"
    #include "ble_conn_state.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define DEVICE_NAME                     "Nordic_Prox"                           /**< Name of device. Will be included in the advertising data. */
    #define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
    #define BATTERY_LEVEL_MEAS_INTERVAL     APP_TIMER_TICKS(120000)                 /**< Battery level measurement interval (ticks). This value corresponds to 120 seconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(500, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.5 seconds).  */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(1000, UNIT_1_25_MS)       /**< Maximum acceptable connection interval (1 second). */
    #define SLAVE_LATENCY                   0                                       /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory timeout (4 seconds). */
    #define APP_ADV_INTERVAL                40                                       /**< The advertising interval (in units of 0.625 ms. This value corresponds to 25 ms). */
    #define APP_ADV_DURATION                18000                                    /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                   /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                  /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
    #define SEC_PARAM_BOND                  1                                       /**< Perform bonding. */
    #define SEC_PARAM_MITM                  0                                       /**< Man In The Middle protection not required. */
    #define SEC_PARAM_LESC                  0                                       /**< LE Secure Connections not enabled. */
    #define SEC_PARAM_KEYPRESS              0                                       /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
    #define SEC_PARAM_OOB                   0                                       /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE          7                                       /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE          16                                      /**< Maximum encryption key size. */
    #define INITIAL_LLS_ALERT_LEVEL         BLE_CHAR_ALERT_LEVEL_NO_ALERT           /**< Initial value for the Alert Level characteristic in the Link Loss service. */
    #define TX_POWER_LEVEL                  (-8)                                    /**< TX Power Level value. This will be set both in the TX Power service, in the advertising data, and also used to set the radio transmit power. */
    #define ADC_REF_VOLTAGE_IN_MILLIVOLTS   600                                     /**< Reference voltage (in milli volts) used by ADC while doing conversion. */
    #define ADC_PRE_SCALING_COMPENSATION    6                                       /**< The ADC is configured to use VDD with 1/3 prescaling as input. And hence the result of conversion is to be multiplied by 3 to get the actual value of the battery voltage.*/
    #define DIODE_FWD_VOLT_DROP_MILLIVOLTS  270                                     /**< Typical forward voltage drop of the diode . */
    #define ADC_RES_10BIT                   1024                                    /**< Maximum digital value for 10-bit ADC conversion. */
    #define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    /**@brief Macro to convert the result of ADC conversion in millivolts.
     * @param[in]  ADC_VALUE   ADC result.
     * @retval     Result converted to millivolts.
    #define ADC_RESULT_IN_MILLI_VOLTS(ADC_VALUE)\
            ((((ADC_VALUE) * ADC_REF_VOLTAGE_IN_MILLIVOLTS) / ADC_RES_10BIT) * ADC_PRE_SCALING_COMPENSATION)
    APP_TIMER_DEF(m_battery_timer_id);                      /**< Battery measurement timer. */
    BLE_TPS_DEF(m_tps);                                     /**< TX Power service instance. */
    BLE_IAS_DEF(m_ias, NRF_SDH_BLE_TOTAL_LINK_COUNT);       /**< Immediate Alert service instance. */
    BLE_LLS_DEF(m_lls);                                     /**< Link Loss service instance. */
    BLE_BAS_DEF(m_bas);                                     /**< Battery service instance. */
    BLE_IAS_C_DEF(m_ias_c);                                 /**< Immediate Alert Service client instance. */
    NRF_BLE_GATT_DEF(m_gatt);                               /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                 /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                     /**< Advertising module instance. */
    BLE_DB_DISCOVERY_DEF(m_ble_db_discovery);               /**< DB discovery module instance. */
    NRF_BLE_GQ_DEF(m_ble_gatt_queue,                        /**< BLE GATT Queue instance. */
                   NRF_SDH_BLE_PERIPHERAL_LINK_COUNT,
                   NRF_BLE_GQ_QUEUE_SIZE);
    static volatile bool m_is_high_alert_signalled;         /**< Variable to indicate whether a high alert has been signalled to the peer. */
    static volatile bool m_is_ias_present = false;          /**< Variable to indicate whether the immediate alert service has been discovered at the connected peer. */
    static nrf_saadc_value_t adc_buf[2];
    static ble_uuid_t m_adv_uuids[] =                       /**< Universally unique service identifiers. */
        {BLE_UUID_IMMEDIATE_ALERT_SERVICE, BLE_UUID_TYPE_BLE},
        {BLE_UUID_BATTERY_SERVICE, BLE_UUID_TYPE_BLE},
        {BLE_UUID_TX_POWER_SERVICE, BLE_UUID_TYPE_BLE},
        {BLE_UUID_LINK_LOSS_SERVICE, BLE_UUID_TYPE_BLE}
    static void on_ias_evt(ble_ias_t * p_ias, ble_ias_evt_t * p_evt);
    static void on_lls_evt(ble_lls_t * p_lls, ble_lls_evt_t * p_evt);
    static void on_ias_c_evt(ble_ias_c_t * p_lls, ble_ias_c_evt_t * p_evt);
    static void on_bas_evt(ble_bas_t * p_bas, ble_bas_evt_t * p_evt);
    static void advertising_init(void);
    static void advertising_start(bool erase_bonds);
    /**@brief Callback function for asserts in the SoftDevice.
     * @param[in] line_num   Line number of the failing ASSERT call.
     * @param[in] file_name  File name of the failing ASSERT call.
    /**@brief Function for handling Service errors.
     * @param[in] nrf_error   Error code containing information about what went wrong.
    static void service_error_handler(uint32_t nrf_error)
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    static void pm_evt_handler(pm_evt_t const * p_evt)
        pm_handler_on_pm_evt(p_evt);
        pm_handler_flash_clean(p_evt);
        switch (p_evt->evt_id)
                advertising_start(false);
    /**@brief Function for handling the ADC interrupt.
     * @details  This function will fetch the conversion result from the ADC, convert the value into
     *           percentage and send it to peer.
    void saadc_event_handler(nrf_drv_saadc_evt_t const * p_event)
            nrf_saadc_value_t adc_result;
            uint16_t          batt_lvl_in_milli_volts;
            uint8_t           percentage_batt_lvl;
            uint32_t          err_code;
            adc_result = p_event->data.done.p_buffer[0];
            err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, 1);
            batt_lvl_in_milli_volts = ADC_RESULT_IN_MILLI_VOLTS(adc_result) +
                                      DIODE_FWD_VOLT_DROP_MILLIVOLTS;
            percentage_batt_lvl = battery_level_in_percent(batt_lvl_in_milli_volts);
            err_code = ble_bas_battery_level_update(&m_bas, percentage_batt_lvl, BLE_CONN_HANDLE_ALL);
            if ((err_code != NRF_SUCCESS) &&
                (err_code != NRF_ERROR_INVALID_STATE) &&
                (err_code != NRF_ERROR_BUSY) &&
                (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
                APP_ERROR_HANDLER(err_code);
    /**@brief Function for handling database discovery events.
     * @details This function is callback function to handle events from the database discovery module.
     *          Depending on the UUIDs that are discovered, this function should forward the events
     *          to their respective services.
     * @param[in] p_event  Pointer to the database discovery event.
    static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
        ble_ias_c_on_db_disc_evt(&m_ias_c, p_evt);
    /**@brief Function for configuring ADC to do battery level conversion.
    static void adc_configure(void)
        ret_code_t err_code = nrf_drv_saadc_init(NULL, saadc_event_handler);
        nrf_saadc_channel_config_t config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_VDD);
        err_code = nrf_drv_saadc_channel_init(0, &config);
        err_code = nrf_drv_saadc_buffer_convert(&adc_buf[0], 1);
        err_code = nrf_drv_saadc_buffer_convert(&adc_buf[1], 1);
    /**@brief Function for handling the Battery measurement timer timeout.
     * @details This function will be called each time the battery level measurement timer expires.
     *          This function will start the ADC.
     * @param[in] p_context   Pointer used for passing some arbitrary information (context) from the
     *                        app_start_timer() call to the timeout handler.
    static void battery_level_meas_timeout_handler(void * p_context)
        UNUSED_PARAMETER(p_context);
        ret_code_t err_code;
        err_code = nrf_drv_saadc_sample();
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module. This creates and starts application timers.
    static void timers_init(void)
        // Initialize timer module.
        err_code = app_timer_init();
        // Create battery timer.
        err_code = app_timer_create(&m_battery_timer_id,
                                    APP_TIMER_MODE_REPEATED,
                                    battery_level_meas_timeout_handler);
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
        err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_GENERIC_KEYRING);
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
        // Prepare wakeup buttons.
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
                NRF_LOG_INFO("Fast advertising.");
                break; // BLE_ADV_EVT_FAST
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
                break; // BLE_ADV_EVT_IDLE
     * @details Encodes the required advertising data and passes it to the stack.
     *          Also builds a structure to be passed to the stack when starting advertising.
        ble_advertising_init_t init;
        init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance      = true;
        init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    /**@brief Function for initializing the Queued Write module.
    static void qwr_init(void)
        nrf_ble_qwr_init_t qwr_init_obj = {0};
        qwr_init_obj.error_handler = nrf_qwr_error_handler;
        err_code = nrf_ble_qwr_init(&m_qwr, &qwr_init_obj);
    /**@brief Function for initializing the TX Power Service.
    static void tps_init(void)
        ble_tps_init_t tps_init_obj;
        memset(&tps_init_obj, 0, sizeof(tps_init_obj));
        tps_init_obj.initial_tx_power_level = TX_POWER_LEVEL;
        tps_init_obj.tpl_rd_sec = SEC_JUST_WORKS;
        err_code = ble_tps_init(&m_tps, &tps_init_obj);
    /**@brief Function for initializing the Immediate Alert Service.
    static void ias_init(void)
        ble_ias_init_t ias_init_obj;
        memset(&ias_init_obj, 0, sizeof(ias_init_obj));
        ias_init_obj.evt_handler  = on_ias_evt;
        ias_init_obj.alert_wr_sec = SEC_JUST_WORKS;
        err_code = ble_ias_init(&m_ias, &ias_init_obj);
    /**@brief Function for initializing the Link Loss Service.
    static void lls_init(void)
        ble_lls_init_t lls_init_obj;
        // Initialize Link Loss Service
        memset(&lls_init_obj, 0, sizeof(lls_init_obj));
        lls_init_obj.evt_handler         = on_lls_evt;
        lls_init_obj.error_handler       = service_error_handler;
        lls_init_obj.initial_alert_level = INITIAL_LLS_ALERT_LEVEL;
        lls_init_obj.alert_level_rd_sec = SEC_JUST_WORKS;
        lls_init_obj.alert_level_wr_sec = SEC_JUST_WORKS;
        err_code = ble_lls_init(&m_lls, &lls_init_obj);
    /**@brief Function for initializing the Battery Service.
    static void bas_init(void)
        ble_bas_init_t bas_init_obj;
        memset(&bas_init_obj, 0, sizeof(bas_init_obj));
        bas_init_obj.evt_handler          = on_bas_evt;
        bas_init_obj.support_notification = true;
        bas_init_obj.p_report_ref         = NULL;
        bas_init_obj.initial_batt_level   = 100;
        bas_init_obj.bl_rd_sec        = SEC_OPEN;
        bas_init_obj.bl_cccd_wr_sec   = SEC_OPEN;
        bas_init_obj.bl_report_rd_sec = SEC_OPEN;
        err_code = ble_bas_init(&m_bas, &bas_init_obj);
    /**@brief Function for initializing the immediate alert service client.
     * @details This will initialize the client side functionality of the Find Me profile.
    static void ias_client_init(void)
        ble_ias_c_init_t ias_c_init_obj;
        memset(&ias_c_init_obj, 0, sizeof(ias_c_init_obj));
        m_is_high_alert_signalled = false;
        ias_c_init_obj.evt_handler   = on_ias_c_evt;
        ias_c_init_obj.error_handler = service_error_handler;
        ias_c_init_obj.p_gatt_queue  = &m_ble_gatt_queue;
        err_code = ble_ias_c_init(&m_ias_c, &ias_c_init_obj);
    /**@brief Function for initializing the services that will be used by the application.
        qwr_init();
        tps_init();
        ias_init();
        lls_init();
        bas_init();
        ias_client_init();
    /** @brief Database discovery module initialization.
    static void db_discovery_init(void)
        ble_db_discovery_init_t db_init;
        memset(&db_init, 0, sizeof(ble_db_discovery_init_t));
        db_init.evt_handler  = db_disc_handler;
        db_init.p_gatt_queue = &m_ble_gatt_queue;
        ret_code_t err_code = ble_db_discovery_init(&db_init);
    /**@brief Function for handling a Connection Parameters error.
        cp_init.disconnect_on_fail             = true;
        cp_init.evt_handler                    = NULL;
    /**@brief Function for the Signals alert event from Immediate Alert or Link Loss services.
     * @param[in] alert_level  Requested alert level.
    static void alert_signal(uint8_t alert_level)
        switch (alert_level)
            case BLE_CHAR_ALERT_LEVEL_NO_ALERT:
                NRF_LOG_INFO("No Alert.");
                err_code = bsp_indication_set(BSP_INDICATE_ALERT_OFF);
                break; // BLE_CHAR_ALERT_LEVEL_NO_ALERT
            case BLE_CHAR_ALERT_LEVEL_MILD_ALERT:
                NRF_LOG_INFO("Mild Alert.");
                err_code = bsp_indication_set(BSP_INDICATE_ALERT_0);
                break; // BLE_CHAR_ALERT_LEVEL_MILD_ALERT
            case BLE_CHAR_ALERT_LEVEL_HIGH_ALERT:
                NRF_LOG_INFO("HIGH Alert.");
                err_code = bsp_indication_set(BSP_INDICATE_ALERT_3);
                break; // BLE_CHAR_ALERT_LEVEL_HIGH_ALERT
                // No implementation needed.
    /**@brief Function for handling Immediate Alert events.
     * @details This function will be called for all Immediate Alert events which are passed to the
     *          application.
     * @param[in] p_ias  Immediate Alert structure.
     * @param[in] p_evt  Event received from the Immediate Alert service.
        switch (p_evt->evt_type)
            case BLE_IAS_EVT_ALERT_LEVEL_UPDATED:
                if (p_evt->p_link_ctx != NULL)
                    alert_signal(p_evt->p_link_ctx->alert_level);
                break; // BLE_IAS_EVT_ALERT_LEVEL_UPDATED
    /**@brief Function for handling Link Loss events.
     * @details This function will be called for all Link Loss events which are passed to the
     *          application.
     * @param[in] p_lls  Link Loss structure.
     * @param[in] p_evt  Event received from the Link Loss service.
            case BLE_LLS_EVT_LINK_LOSS_ALERT:
                alert_signal(p_evt->params.alert_level);
                break; // BLE_LLS_EVT_LINK_LOSS_ALERT
    /**@brief Function for handling IAS Client events.
     * @details This function will be called for all IAS Client events which are passed to the
     *          application.
     * @param[in] p_ias_c  IAS Client structure.
     * @param[in] p_evt    Event received.
    static void on_ias_c_evt(ble_ias_c_t * p_ias_c, ble_ias_c_evt_t * p_evt)
            case BLE_IAS_C_EVT_DISCOVERY_COMPLETE:
                // IAS is found on peer. The Find Me Locator functionality of this app will work.
                err_code = ble_ias_c_handles_assign(&m_ias_c,
                                                    p_evt->conn_handle,
                                                    p_evt->alert_level.handle_value);
                m_is_ias_present = true;
                break; // BLE_IAS_C_EVT_DISCOVERY_COMPLETE
            case BLE_IAS_C_EVT_DISCOVERY_FAILED:
                // IAS is not found on peer. The Find Me Locator functionality of this app will NOT work.
                break; // BLE_IAS_C_EVT_DISCOVERY_FAILED
            case BLE_IAS_C_EVT_DISCONN_COMPLETE:
                // Disable alert buttons
                break; // BLE_IAS_C_EVT_DISCONN_COMPLETE
    /**@brief Function for handling the Battery Service events.
     * @details This function will be called for all Battery Service events which are passed to the
     |          application.
     * @param[in] p_bas  Battery Service structure.
     * @param[in] p_evt  Event received from the Battery Service.
            case BLE_BAS_EVT_NOTIFICATION_ENABLED:
                // Start battery timer
                err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
                break; // BLE_BAS_EVT_NOTIFICATION_ENABLED
            case BLE_BAS_EVT_NOTIFICATION_DISABLED:
                err_code = app_timer_stop(m_battery_timer_id);
                break; // BLE_BAS_EVT_NOTIFICATION_DISABLED
        ret_code_t err_code = NRF_SUCCESS;
                NRF_LOG_INFO("Disconnected.");
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected.");
                // Assign connection handle to the Queued Write module.
                err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr, p_ble_evt->evt.gap_evt.conn_handle);
                // Discover peer's services.
                err_code = ble_db_discovery_start(&m_ble_db_discovery,
            } break;
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for the Peer Manager initialization.
    static void peer_manager_init(void)
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
     * @param[in]   event   Event generated when button is pressed.
    static void bsp_event_handler(bsp_event_t event)
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_ias_c.conn_handle,
            case BSP_EVENT_KEY_0:
                if (m_is_ias_present)
                    if (!m_is_high_alert_signalled)
                        err_code =
                            ble_ias_c_send_alert_level(&m_ias_c, BLE_CHAR_ALERT_LEVEL_HIGH_ALERT);
                        err_code = ble_ias_c_send_alert_level(&m_ias_c, BLE_CHAR_ALERT_LEVEL_NO_ALERT);
                    if (err_code == NRF_SUCCESS)
                        m_is_high_alert_signalled = !m_is_high_alert_signalled;
                    else if (
                        (err_code != NRF_ERROR_RESOURCES)
                        (err_code != NRF_ERROR_NOT_FOUND)
            } break;
            case BSP_EVENT_KEY_1:
                NRF_LOG_INFO("Alert Off.");
        bsp_event_t startup_event;
        err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
            nrf_pwr_mgmt_run();
    /**@brief Clear bond information from persistent storage.
    static void delete_bonds(void)
        NRF_LOG_INFO("Erase bonds!");
        err_code = pm_peers_delete();
        if (erase_bonds == true){
            delete_bonds();
            // Advertising is started by PM_EVT_PEERS_DELETE_SUCEEDED event.
    /**@brief Function for changing the tx power.
    static void tx_power_set(void)
        ret_code_t err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, TX_POWER_LEVEL);
    /**@brief Function for application main entry.
        bool erase_bonds;
        // Initialize.
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        adc_configure();
        gap_params_init();
        gatt_init();
        advertising_init();
        db_discovery_init();
        services_init();
        conn_params_init();
        peer_manager_init();
        // Start execution.
        NRF_LOG_INFO("Proximity example started.");
        advertising_start(erase_bonds);
        tx_power_set();
        // Enter main loop.
        for (;;)
            idle_state_handle();
  • Hi, the FW should run on both the pca10040 and the Thingy, you just need to map the right GPIOs to the buttons and LEDs you are using (if any). Are you able to flash anything to the Thingy52 at all? Do you need help with programming the FW in general, or is it just this specific FW that you can't get to work on the thingy?
