using spi_write() & spi_read() not behaving the same as spi_transceive() for spi data in provided spi sample
I tried running an spi sample program with code as in below, shorted the MOSI and MISO pins and data was visibly received in print statement:
#include <zephyr.h>
#include <sys/printk.h>
#include <drivers/spi.h>
#include <drivers/gpio.h>
uint32_t freq = 4000000;
static const struct spi_config spi_cfg = {freq,(SPI_WORD_SET(8) | SPI_TRANSFER_MSB),0,nullptr};
const device * spi_dev;
static void spi_init(void)
const char* spiName = "SPI_1";
//const char* const spiName = "spi1";
spi_dev = device_get_binding(spiName);
if (spi_dev == NULL) {
printk("Could not get %s device\n", spiName);
return;
void spi_test_send(void)
int err;
static uint32_t tx_buffer[1]={0x05};
//static uint8_t tx_buffer = 128;
//static char tx_buffer[3]={'D','s','s'};
static uint32_t rx_buffer[1];
//static uint8_t rx_buffer;
const struct spi_buf tx_buf = {
.buf = tx_buffer,
.len = sizeof(tx_buffer)
const struct spi_buf_set tx = {
.buffers = &tx_buf,
.count = 1
struct spi_buf rx_buf = {
.buf = rx_buffer,
.len = sizeof(rx_buffer),
const struct spi_buf_set rx = {
.buffers = &rx_buf,
.count = 1
err = spi_transceive(spi_dev, &spi_cfg, &tx, &rx);
if (err) {
printk("SPI error: %d\n", err);
} else {
/* Connect MISO to MOSI for loopback */
printk("TX sent: %d\n", tx_buffer[0]);
printk("RX recv: %d\n", rx_buffer[0]);
void main(void)
printk("SPIM Example\n");
spi_init();
while (1) {
spi_test_send();
k_sleep(K_SECONDS(1));
While in the same code if i use spi_write( ) & spi_read( ) apis, which inturn call spi transceive, I am not receiving any data, code as in below:
#include <zephyr.h>
return;
int err;
.buf = tx_buffer,
.buffers = &tx_buf,
.count = 1
.buf = rx_buffer,
.buffers = &rx_buf,
.count = 1
err = spi_write(spi_dev, &spi_cfg, &tx);
err = spi_read(spi_dev, &spi_cfg, &rx);
if (err) {
} else {
void main(void)
spi_init();
while (1) {
spi_test_send();
I am getting just -1 in receive buffer.
Kindly suggest what i can do to make spi_write & spi_read work..?
  • Clearly, for the above code, master board (BL653) is transmitting the data just fine, along with controlling the cs, as in channel-2, channel-1 is MOSI & channel 0 is clock.
    Hello  ,
    Clearly master board it is doing, I think something work with slave board or slave pin out config.
    Can you have a look at slave code, config and kindlu suggest.
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    CONFIG_DEBUG=y
    CONFIG_GPIO=y
    CONFIG_SPI=y
    #CONFIG_SPI_1=y
    CONFIG_PRINTK=y
    CONFIG_POLL=y
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    SLAVE:************************************
    Thanks.
    P0.01 is default setup to be one of the inputs of the external 32k crystal:
    https://infocenter.nordicsemi.com/topic/ps_nrf52833/pin.html?cp=4_1_0_6_0_1#wlcsp
    I would recommend that you choose another GPIO for the CSN pin.
    There's a couple of samples available here with both SPIM and SPIS:
    https://github.com/sigurdnev/ncs-playground/tree/master/samples
    Håkon
  • Hello ,
    This does not suffice my requirement as everywhere here only spi_transceive is being used, while I am supposed to evaluate spi_read & spi_write.
    And
    Thank you for the kind suggestion, I used P0.11 and after a couple of resets I was able to print 0x1234(data sent via master)
    on slave as in below:
    Need your help in understanding why the -116 (-ETIMEOUT) error is still persistent with the call to SPI_Read( ).
    I need to eliminate this error.
    For your kind reference, attaching the master board code & slave board code with configs.
    Master (BL653):
    prj.conf:
    CONFIG_DEBUG=y
    CONFIG_GPIO=y
    CONFIG_SPI=y
    #CONFIG_SPI_1=y
    CONFIG_PRINTK=y
    CONFIG_POLL=y
    bl653_dvk.overlay:
     * Copyright (c) 2019 Callender-Consulting, LLC
    &spi1 {
    	compatible = "nordic,nrf-spi";
    	status = "okay";
    	sck-pin = <41>;
    	mosi-pin = <40>;
    	miso-pin = <4>;
    	cs-gpios = <&gpio0 23 0>;
    main.c:
     * Copyright (c) 2019 - Callender-Consulting. LLC
     *   You should have received a copy of the GNU General Public License.
     *   see <https://www.gnu.org/licenses/>.
    #include <string.h>
    #include <errno.h>
    #include <zephyr.h>
    #include <device.h>
    #define STACKSIZE 1024
    #define PRIORITY 99
    #define SPI_MASTER_BUS_NAME     		DT_INST_0_NORDIC_NRF_SPI_LABEL
    #define SPI_MASTER_GPIOS_NAME    		DT_ALIAS_GPIO_0_LABEL
    #define SPI_MASTER_GPIO_IRQ_PIN  		DT_ALIAS_SPI_0_CSN_PIN
    /* Needs to be aligned with the SPI master buffer size */
    #define SPI_MAX_MSG_LEN         255
    typedef struct spi_master_msg {
    	uint32_t       length;
        uint8_t        data [SPI_MAX_MSG_LEN];
    } spi_master_msg_t;
    int spi_master_write(struct device * spi,
                         struct spi_config * spi_cfg,
                         uint16_t * data)
        struct spi_buf bufs = {
                .buf = data,
                .len = 2
            .buffers = &bufs
        tx.count = 1;
        return spi_write(spi, spi_cfg, &tx);
    int spi_master_read(struct device * spi,
                        uint16_t * data)
                .buf = data,
                .len = 2
            .buffers = &bufs
        rx.count = 1;
        return spi_read(spi, spi_cfg, &rx);
    void spi_master_init(void)
        struct device * spi;
        struct spi_config spi_cfg;
        struct spi_cs_control cs_ctrl;
        uint16_t tx_data = 0x1234;
        uint16_t rx_data = 0;
        printk("SPI Master example application\n");
        printk("rx_data buffer at %p\n", &rx_data);
        spi = device_get_binding("SPI_1");
        if (!spi) {
            printk("Could not find SPI driver\n");
            return;
        cs_ctrl.gpio_dev = device_get_binding("GPIO_0");
        cs_ctrl.gpio_pin = 23;
        cs_ctrl.delay = 0;
         *  SPI controller configuration structure for the nRF52 series.
         *  param frequency is the bus frequency in hertz
         *  param operation is a bit field with the following parts:
         *     operational mode  [ 0 ]       - master or slave.
         *     mode              [ 1 : 3 ]   - Polarity, phase and loop mode.
         *     transfer          [ 4 ]       - LSB or MSB first.
         *     word_size         [ 5 : 10 ]  - Size of a data frame in bits.
         *     lines             [ 11 : 12 ] - MISO lines: Single/Dual/Quad/Octal.
         *     cs_hold           [ 13 ]      - Hold on the CS line if possible.
         *     lock_on           [ 14 ]      - Keep resource locked for the caller.
         *     cs_active_high    [ 15 ]      - Active high CS logic.
         *  param master is the master number from 0 to host controller master limit.
         *  param cs is a valid pointer on a struct spi_cs_control is CS line is
         *        emulated through a gpio line, or NULL otherwise.
        /* Note: Implicid Mode-0; e.g. CPOL=0, CPHA=0 -- the only mode supported */
        /* Note: The nRF52 series doesn't support CS pin configuration */
        memset(&spi_cfg, 0, sizeof(spi_cfg));
        spi_cfg.operation = SPI_WORD_SET(8) | SPI_OP_MODE_MASTER
        //                    | SPI_MODE_CPOL | SPI_MODE_CPHA
                            | SPI_LINES_SINGLE;
        spi_cfg.frequency = 1000000;
        spi_cfg.cs = &cs_ctrl;
        printk("%s: master config @ %p:"
                " wordsize(%u), mode(%u/%u/%u)\n", __func__, &spi_cfg,
                SPI_WORD_SIZE_GET(spi_cfg.operation),
                (SPI_MODE_GET(spi_cfg.operation) & SPI_MODE_CPOL) ? 1 : 0,
                (SPI_MODE_GET(spi_cfg.operation) & SPI_MODE_CPHA) ? 1 : 0,
                (SPI_MODE_GET(spi_cfg.operation) & SPI_MODE_LOOP) ? 1 : 0);
        while (1)  { //for (int i=0; i < 2; i++) {
            spi_master_write(spi, &spi_cfg, &tx_data);
            printk("Sent: 0x%02X\n", tx_data);
            spi_master_read(spi, &spi_cfg, &rx_data);
            printk("Received: 0x%02X\n", rx_data);
            printk("Response is %s\n",  (rx_data == 0x5678) ? "correct" : "incorrect");
            k_sleep(K_SECONDS(2));
        printk("done\n");
    void spi_master_thread(void * id, void * unused1, void * unused2)
        printk("%s\n", __func__);
        spi_master_init();
        while(1) { /* spin */}
    K_THREAD_DEFINE(spi_master_id, STACKSIZE, spi_master_thread,NULL, NULL, NULL, PRIORITY, 0, 0);
    Slave (nRF52833_dk):
    prj.conf:
    # nothing here
    CONFIG_DEBUG=y
    CONFIG_GPIO=y
    CONFIG_SPI=y
    CONFIG_SPI_SLAVE=y
    CONFIG_PRINTK=y
    nrf52833dk_nrf52833.overlay:
    &spi0 {
    compatible = "nordic,nrf-spis";
    status = "okay";
    sck-pin = <27>;
    mosi-pin = <26>;
    miso-pin = <29>;
    csn-pin = <11>;
    def-char = <0xFF>;
    main.c:
     * Copyright (c) 2012-2014 Wind River Systems, Inc.
    #include <string.h>
    #include <errno.h>
    #include <zephyr.h>
    #include <device.h>
    #define SPI_SLAVE_BUS_NAME     			DT_INST_0_NORDIC_NRF_SPIS_LABEL
    #define SPI_SLAVE_GPIOS_NAME    		DT_ALIAS_GPIO_0_LABEL
    #define SPI_SLAVE_GPIO_IRQ_PIN  		DT_ALIAS_SPI_0_CSN_PIN
    #define PRIORITY 99
    void spi_slave_init(void);
    int spi_slave_write(struct device * spi,
                        uint16_t * data)
                .buf = data,
                .len = 2
            .buffers = &bufs
        tx.count = 1;
    int spi_slave_read(struct device * spi,
                       uint16_t * data)
                .buf = data,
                .len = 2
            .buffers = &bufs
        rx.count = 1;
        uint16_t tx_data = 0x5678;
        printk("SPI Slave example application\n");
        spi = device_get_binding("SPI_0");
        if (!spi) {
            return;
         *  param slave is the slave number from 0 to host controller slave limit.
        spi_cfg.operation = SPI_WORD_SET(8) | SPI_OP_MODE_SLAVE;
        spi_cfg.slave = 1;
        printk("%s: slave config @ %p:"
        while (1) {
            int err = spi_slave_read(spi, &spi_cfg, &rx_data);
            if (rx_data == 0x1234) {
                spi_slave_write(spi, &spi_cfg, &tx_data);
            printk("err: %d ,Received: 0x%04X -- %s \n",err, rx_data,
                   (rx_data == 0x1234) ? "ok" : "wrong");
    void spi_slave_thread(void * id, void * unused1, void * unused2)
        spi_slave_init();
        while (1) { /* spin */}
    K_THREAD_DEFINE(spi_slave_id, STACKSIZE, spi_slave_thread,
    And also the master's captured waveforms:
    Kindly suggest,
    Could you please test those examples for SPIM + SPIS to see if they work?
    Håkon
  • Hello Hakan,
    I mean to say, no where in those examples spi_read( ) & spi_write( ) are being used.
    And i need to work with spi_read( ) & spi_write( ), which I am able to currently with these example,
    Master (BL653):
    Except for this, towards which I need your help:
    Do you suggest i lower the frequency and check again..?
    Thanks
