The use of SPI with Zephyr for 52840dk
I am attempting to use SPI and I just wanted to trial the transceiver option however I am not having any luck. I have tried it three ways but as you’ll see I’ve made no progress.
Firstly, utilizing the SPI sample from NCS playground I imported it all into my ncs/v1.7.1/nrf/samples/ folder and I then opened it in VSCode. I ran it and I obtained errors. Assuming that I built it incorrectly I tried running west through command line and I obtained the same two errors as shown below:
Therefore, I removed CONFIG_DEPRECATED_ZEPHYR_INT_TYPES=y and CONFIG_SPI_1=y and ran the build again, this time successfully.
Unfortunately, the outcome wasn’t the one I was predicting, I shorted the MISO and MOSI lines to have a loop-back but on the RX line I get ff, which I assume is the initial dummy value sent? Can someone please explain why this is occurring and what can be done to remedy this, I want to read the TX that is being sent.
The code utilized is linked here: https://github.com/sigurdnev/ncs-playground/tree/master/samples/spi_test
Below is also my prj.conf before and after the changes for the build as well as the code found in main of spi_test.
# Copyright (c) 2020 Nordic Semiconductor ASA
# SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
# CONFIG_BOARD_ENABLE_CPUNET=n
CONFIG_SPI=y
CONFIG_MAIN_STACK_SIZE=4096
# CONFIG_SPI_0=y
# UART, SPIM, and I2C are shared peripherals on nrf9160
# therefore we choose SPI3
CONFIG_SPI_1=y
CONFIG_SPI_NRFX=y
#WORKING PROJ.CONF
CONFIG_SPI=y
# CONFIG_SPI_0=y
CONFIG_SPI_NRFX=y
* Copyright (c) 2012-2014 Wind River Systems, Inc.
#include <zephyr.h>
#include <sys/printk.h>
#include <drivers/spi.h>
#define DT_DRV_COMPAT nordic_nrf_spim
struct spi_cs_control spi_cs = {
	.gpio_pin = DT_GPIO_PIN(DT_DRV_INST(0), cs_gpios),
	.gpio_dt_flags = GPIO_ACTIVE_LOW,
	.delay = 0,
static struct spi_config spi_cfg = {
	.operation = SPI_WORD_SET(8) | SPI_TRANSFER_MSB |
		     SPI_MODE_CPOL | SPI_MODE_CPHA,
	.frequency = 4000000,
	.slave = 0,
	.cs = &spi_cs,
const struct device * spi_dev;
static void spi_init(void)
	spi_cs.gpio_dev = device_get_binding(DT_GPIO_LABEL(DT_DRV_INST(0), cs_gpios));
	if (spi_cs.gpio_dev == NULL) {
	    printk("Could not get gpio device\n");
	} else {
		printk("GPIO device: %s\n", DT_GPIO_LABEL(DT_DRV_INST(0), cs_gpios));
	spi_dev = device_get_binding(DT_LABEL(DT_DRV_INST(0)));
	if (spi_dev == NULL) {
		printk("Could not get %s device\n", DT_LABEL(DT_DRV_INST(0)));
		return;
	} else {
		printk("SPI Device: %s\n", DT_LABEL(DT_DRV_INST(0)));
		printk("SPI CSN %d, MISO %d, MOSI %d, CLK %d\n",
	       DT_PROP(DT_DRV_INST(0), miso_pin),
	       DT_PROP(DT_DRV_INST(0), mosi_pin),
	       DT_PROP(DT_DRV_INST(0), sck_pin));
void spi_test_send(void)
	int err;
	static uint8_t tx_buffer[32];
	static uint8_t rx_buffer[32];
	const struct spi_buf tx_buf = {
		.buf = tx_buffer,
		.len = sizeof(tx_buffer)
	const struct spi_buf_set tx = {
		.buffers = &tx_buf,
		.count = 1
	struct spi_buf rx_buf = {
		.buf = rx_buffer,
		.len = sizeof(rx_buffer),
	const struct spi_buf_set rx = {
		.buffers = &rx_buf,
		.count = 1
	err = spi_transceive(spi_dev, &spi_cfg, &tx, &rx);
	if (err) {
		printk("SPI error: %d\n", err);
	} else {
		/* Connect MISO to MOSI for loopback */
		printk("TX sent: %x\n", tx_buffer[0]);
		printk("RX recv: %x\n", rx_buffer[0]);
		tx_buffer[0]++;
void main(void)
	printk("SPIM Example\n");
	spi_init();
	while (1) {
		spi_test_send();
		k_sleep(K_MSEC(1000));
DM
    Well, after throwing everything at it to see what sticks here’s what I found out:
    1. I had MOSI on pin 6 which was already being used for something else.
    2. It works on Pin 47 (P1.15) and Pin 35 (P1.03)
    3. The only item necessary in prj.conf is CONFIG_SPI=y it seems, ill need confirmation why the following aren’t necessary if its not too much to ask:
    • #CONFIG_SPI_NRFX=y
    • #CONFIG_NRFX_SPIM1=y
    • #CONFIG_NRFX_SPI1=y
    There’s something odd about the pins, for example according to the user guide v1.2, P0.17 shouldn’t work because its connected to memory, and that’s certainly the case, I couldn’t get it working, however, P0.16 should be connected to LED4, but it does work? Funnily enough it turns the led on while I connect it, I gather then it can handle both operations? I’m no expert but I guess when TX sends a value (high) the LED lights up and the pin reads as the RX simultaneously because they’re wired together? Yet that isn’t the case for P0.17.
    Could I get clarifications on the above, no hurry I’ll be messing around with this for a while now it works, very happy.
    DM
    Configuration options containing nrfx would use nrfx SPI driver directly. However, you do not need to use nrfx driver in this way. You can use Zephyr SPI port driver instead and Zephyr driver would then do all the work for you. Enabling CONFIG_SPI automatically enables CONFIG_SPI_NRFX.
    You can take a look at the following devzone case
    devzone.nordicsemi.com/.../how-to-use-spi-interface-in-a-zephyr-sample-example
    Pin P0.17 is connected to the memory and you cannot use it while it is connected to the memory. When connected to the memory, solder bridge SB13 is closed (shorted) and SB23 is open. If you would like to disconnect P0.17 from the memory and have it available for GPIO use, you would need to cut SB13 and bridge (close) SB23. Then you would lose connection to the memory, but could use GPIO pin P0.17.
    Pin P0.16 is by default connected to the LED4. There is a connection from the chip to both GPIO pin P0.16 and LED4. If you want to disconnect LED4, you could cut the solder bridge SB8. After that you would still be able to use pin P0.16 normally.
    Dejan
  • Hello Dejans,
    Thanks for clarifying.
    DM
