[Please] RSSI of PCA10112 was weaker than RSSI of PC10056
Dears
Th case ID of my old question is 218372.
I were waiting for two weeks. However, nobody responded to me.
I wanted to make a BLE mesh product used NRF52840 and NRF21540. NRF21540 can extend the range to prevent
relay nodes efforts in mesh.
At your SDK connect samples. no bluetooth sample was about nrf21540_nrf52840.
At previous case, Nordic FAE told me to refer to DTM sample. But, DTM only for single direction test for radio RX nor TX, either.
So, it was easy to enable 21540 TX as testing radio TX, AND EANBLE 21540 RX as testing radio RX.
For most bluetooth application, the radio was bi-direction and controlled by your BLE controller library.
I had no idea to use API to set PA/LNA pins to BLE controller.
Best,
Jeffery
  • Hi
    Anything to update?
    If nrf21540dk is not yet  to work at sdk connect, do you have schedule to make it?
    It affects we to promote 21540. Thanks.
    Jeffery
    Jeffery said:
    As we thought and expected, if selected board  "nrf21540_nrf52840" to build bluetooth example, after flash, it
    shall work 21540 to strengthen RSSI, doesn't it?
    Yes, it should work if you build it for the nrf21540_nrf52840. Haven't had the chance to reproduce it yet, will let you know if we are able to reproduce it or not.
  • Hi
    Did you reproduce this issue at your side/
    Thanks.
    If this issue was also found at your side, could you schedule to fix it at the coming ncs version?
    Thanks.
    Jeffery
    We have been testing on both v1.8.0 and v1.9.1 of nRF Connect SDK, unfortunately we are not able to reproduce your issue. Everything is working as expected. We tested with the UART peripheral example.
    Have you made any modifications to the example before building it?
    Can you also test with the latest version of nRF Connect SDK? Do you see any difference?
  • Hi
    1. Tried latest ncs  \nrf\samples\bluetooth\peripheral_uart sample at 21540 DK. The result was unexpected.
        During advertising, I used nrf connect for mobile app at my phone to scan DK. The distance between phone
        and DK was 1 meter. If 52840DK, RSSI was -65 dBm. If 21540DK, RSSI was -86 dBm.
    2. 21540 DK version is 0.9.1.Would it be a problem?
    3. Would you mind giving me your workable hex file of 21540 DK? Let me flash it at my DK.
    4. Then, at documentation page for bluetooth sample, There was a topic "FEM Support". It seems developer shall
        set up the project to work 21540. Was it? I didn't do it since I have no idea how to follow the steps. Didn't you
        said 21540 DK board can work  fine only if we chose nrf21540_nrf52840 as board?
    Thanks
    Jeffery
