iOS-DFU-Library: Data size exceed limits error – differs from Android to iOS?
When flashing files from an iOS device I run a lot into data size errors (not always), when using the same files on Android they can be copied without a problem.
It looks a like the error comes from the library on iOS. I am using the same microcontroller for both systems.
Is there a difference in checking if a file is too large on iOS and Android and if so, how can this be changed on iOS, as this is legacy from the library?
Best
JAL
    Which versions of both libraries are you using?
    Can you provide some logs from iOS?
  • Hello Aleksander,
    thanks for your fast reply!
    we are using 4.11.0 on iOS. I don't know the number of the (working) Android version right now...
    Best JAL
    Logs from Xcode:
    2022-01-24 17:55:25.469204+0100 Calliope App[51583:22986336] MatrixConnectionViewController:154 Matrix view connecting to name: pevug, state: discovered
    2022-01-24 17:55:25.469449+0100 Calliope App[51583:22986336] CalliopeBLEDiscovery:31 calliope discovery state: discoveredAll
    2022-01-24 17:55:25.469772+0100 Calliope App[51583:22986336] CalliopeBLEDiscovery:31 calliope discovery state: connecting
    2022-01-24 17:55:25.470251+0100 Calliope App[51583:22986336] CalliopeBLEDiscovery:31 calliope discovery state: connecting
    2022-01-24 17:55:26.224710+0100 Calliope App[51583:22986675] CalliopeBLEDevice:38 calliope state: connected
    2022-01-24 17:55:26.224946+0100 Calliope App[51583:22986675] CalliopeBLEDiscovery:31 calliope discovery state: connected
    2022-01-24 17:55:26.225075+0100 Calliope App[51583:22986675] CalliopeBLEDiscovery:31 calliope discovery state: connected
    2022-01-24 17:55:26.225448+0100 Calliope App[51583:22986336] CalliopeBLEDevice:38 calliope state: evaluateMode
    2022-01-24 17:55:26.549203+0100 Calliope App[51583:22986675] CalliopeBLEDevice:135 found all of 1 required services:
    [Calliope_App.CalliopeService.dfu]
    2022-01-24 17:55:26.549395+0100 Calliope App[51583:22986675] CalliopeBLEDevice:136 found 0 of 1 optional services
    2022-01-24 17:55:26.608254+0100 Calliope App[51583:22986675] CalliopeBLEDevice:38 calliope state: usageReady
    2022-01-24 17:55:36.862061+0100 Calliope App[51583:22986336] EditorViewController:74 policy for action data:application/x-microbit-hex;base64,OjAyMDAwMDA0MDAwMEZBDQo6MTAwMDAwMDBDMDA3MDAwMEQxMDYwMDAwRDEwM…
    2022-01-24 17:55:36.873580+0100 Calliope App[51583:22986336] nil host used in call to allowsSpecificHTTPSCertificateForHost
    2022-01-24 17:55:36.873605+0100 Calliope App[51583:22986336] nil host used in call to allowsAnyHTTPSCertificateForHost:
    2022-01-24 17:55:36.908278+0100 Calliope App[51583:22986336] [LayoutConstraints] Changing the translatesAutoresizingMaskIntoConstraints property of a UICollectionViewCell that is managed by a UICollectionView is not supported, and will result in incorrect self-sizing. View: <_UIAlertControllerTextFieldViewCollectionCell: 0x101999370; frame = (0 0; 270 24); gestureRecognizers = <NSArray: 0x281640210>; layer = <CALayer: 0x28183d040>>
    2022-01-24 17:55:39.684370+0100 Calliope App[51583:22986336] Hex:160 writing file file:///var/mobile/Containers/Data/Application/EF2FB50D-92DD-451E-8519-E32623AFEB59/Documents/.hex
    2022-01-24 17:55:40.556732+0100 Calliope App[51583:22986675] CalliopeBLEDevice:383 received read response from <CBCharacteristic: 0x283cb5bc0, UUID = E95D93B1-251D-470A-A062-FA1922DFA9A8, properties = 0xA, value = {length = 1, bytes = 0x00}, notifying = NO>: Optional("00")
    2022-01-24 17:55:40.556821+0100 Calliope App[51583:22986336] CalliopeBLEDevice:311 read Optional(1 bytes) from <CBCharacteristic: 0x283cb5bc0, UUID = E95D93B1-251D-470A-A062-FA1922DFA9A8, properties = 0xA, value = {length = 1, bytes = 0x00}, notifying = NO>
    2022-01-24 17:55:40.616604+0100 Calliope App[51583:22987395] CalliopeBLEDevice:369 received write success message
    2022-01-24 17:55:40.616720+0100 Calliope App[51583:22986336] CalliopeBLEDevice:275 wrote <CBCharacteristic: 0x283cb5bc0, UUID = E95D93B1-251D-470A-A062-FA1922DFA9A8, properties = 0xA, value = {length = 1, bytes = 0x00}, notifying = NO>
    2022-01-24 17:55:40.681395+0100 Calliope App[51583:22987395] CalliopeBLEDiscovery:230 disconnected from Calliope mini [pevug])
    2022-01-24 17:55:40.681501+0100 Calliope App[51583:22987395] CalliopeBLEDiscovery:31 calliope discovery state: connected
    2022-01-24 17:55:40.681561+0100 Calliope App[51583:22987395] CalliopeBLEDevice:38 calliope state: discovered
    2022-01-24 17:55:40.683533+0100 Calliope App[51583:22986336] FirmwareUpload:225 DFU State change: DFUState
    2022-01-24 17:55:40.683992+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: Connecting to Calliope mini [pevug]...
    2022-01-24 17:55:40.684231+0100 Calliope App[51583:22987395] CalliopeBLEDiscovery:31 calliope discovery state: discoveredAll
    2022-01-24 17:55:40.688088+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: centralManager.connect(peripheral, options: nil)
    2022-01-24 17:55:42.990108+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: [Callback] Central Manager did connect peripheral
    2022-01-24 17:55:42.992361+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: Connected to Calliope mini [pevug]
    2022-01-24 17:55:42.993122+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: Discovering services...
    2022-01-24 17:55:42.993539+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: peripheral.discoverServices(nil)
    2022-01-24 17:55:43.260603+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: Services discovered
    2022-01-24 17:55:43.262603+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: Starting Legacy DFU...
    2022-01-24 17:55:43.263134+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: Connected to Calliope mini [pevug]
    2022-01-24 17:55:43.263759+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: Services discovered
    2022-01-24 17:55:43.264125+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: Legacy DFU Service found
    2022-01-24 17:55:43.264463+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: Discovering characteristics in DFU Service...
    2022-01-24 17:55:43.264916+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: peripheral.discoverCharacteristics(nil, for: 00001530-1212-EFDE-1523-785FEABCD123)
    2022-01-24 17:55:43.499251+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: DFU characteristics discovered
    2022-01-24 17:55:43.500956+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: Reading DFU Version number...
    2022-01-24 17:55:43.501526+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: peripheral.readValue(00001534-1212-EFDE-1523-785FEABCD123)
    2022-01-24 17:55:43.558935+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: Read Response received from 00001534-1212-EFDE-1523-785FEABCD123, value (0x): 0400
    2022-01-24 17:55:43.560160+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: Version number read: 0.4
    2022-01-24 17:55:43.560797+0100 Calliope App[51583:22986336] FirmwareUpload:225 DFU State change: DFUState
    2022-01-24 17:55:43.560985+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: Enabling notifications for 00001531-1212-EFDE-1523-785FEABCD123...
    2022-01-24 17:55:43.562117+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: peripheral.setNotifyValue(true, for: 00001531-1212-EFDE-1523-785FEABCD123)
    2022-01-24 17:55:43.677832+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: Notifications enabled for 00001531-1212-EFDE-1523-785FEABCD123
    2022-01-24 17:55:43.680139+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: DFU Control Point notifications enabled
    2022-01-24 17:55:43.681702+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: Writing to characteristic 00001531-1212-EFDE-1523-785FEABCD123...
    2022-01-24 17:55:43.682473+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: peripheral.writeValue(0x0104, for: 00001531-1212-EFDE-1523-785FEABCD123, type: .withResponse)
    2022-01-24 17:55:43.683052+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: Writing image sizes (0b, 0b, 146964b) to characteristic 00001532-1212-EFDE-1523-785FEABCD123...
    2022-01-24 17:55:43.683760+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: peripheral.writeValue(0x0000000000000000143e0200, for: 00001532-1212-EFDE-1523-785FEABCD123, type: .withoutResponse)
    2022-01-24 17:55:43.737216+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: Data written to 00001531-1212-EFDE-1523-785FEABCD123
    2022-01-24 17:55:43.738452+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: Start DFU (Op Code = 1, Upload Mode = 4) request sent
    2022-01-24 17:55:43.797913+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: Notification received from 00001531-1212-EFDE-1523-785FEABCD123, value (0x): 100104
    2022-01-24 17:55:43.799617+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: Response (Op Code = 1, Status = 4) received
    2022-01-24 17:55:43.801428+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: Error 4: Data size exceeds limit
    2022-01-24 17:55:43.802186+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: Writing to characteristic 00001531-1212-EFDE-1523-785FEABCD123...
    2022-01-24 17:55:43.803010+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: peripheral.writeValue(0x06, for: 00001531-1212-EFDE-1523-785FEABCD123, type: .withResponse)
    2022-01-24 17:55:44.575174+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: [Callback] Central Manager did disconnect peripheral
    2022-01-24 17:55:44.576917+0100 Calliope App[51583:22986336] FirmwareUpload:220 DFU Message: Disconnected by the remote device
    2022-01-24 17:55:44.578472+0100 Calliope App[51583:22986336] FirmwareUpload:229 DFU Error DFUError while uploading: Data size exceeds limit
