Application won't boot when bootloader and app are using 32kHz RC oscillator. When using MPSL (BLE and IEEE802.15.4 raw) or usb_cdc.
We're having a problem that our application will hang when using the 32 kHz RC oscillator in the mcuboot bootloader and the Zephyr application. We encountered this problem when we updated from NCS 1.5.1 to 1.8.0.
We have looked at https://devzone.nordicsemi.com/f/nordic-q-a/81418/bug-in-ncs-v1-7-1-with-32khz-rc-oscillator-and-mcuboot-enabled and https://github.com/zephyrproject-rtos/zephyr/issues/40538 but that does not seems to fix our issue or is not included in release 1.8.0
In the supplied files is a markdown file with steps how to reproduce the problem.
What could be a temporary fix?
What is the prospect of a permanent fix?
Maarten
rc_oscillator_problem_files.zip
  • Hi Hung Bui,
    I've some extra info,
    during debuging the debugger is stuck in: static void lfclk_spinwait(enum nrf_lfclk_start_mode mode);
    Additionally after some time the non working example seems to sync its clock and run the application when I've build them myself.
    This behaviour is very intermittent and for our product the watchdog will reset before the clocks have synced.
    I've tried to install the Nordic toolchain manager on Linux but that does not work.
    I've also tried the cut xtal traces (SB1 and SB2) with your hex which works but when I build mine and flash it the bootloader won't boot.
    As I've setup a clean environment on Linux I'm a bit out of options how to reproduce the working hex.
    Maybe if you build example 3 it will reproduce the problem on your side. (see line below)
    west build -p -b nrf52840dk_nrf52840\
    -- -DDTC_OVERLAY_FILE=console.overlay\
    -DOVERLAY_CONFIG=radio.conf\
    -Dmcuboot_OVERLAY_CONFIG=$(realpath mcuboot.conf)\
    -DPICOO_RADIO=ON && west flash
    Lastly I want to underscore that the issue is intermittent and a show stopper for updating at this point.
    Maarten
  • Hi Maarten,
    Could you clarify:
    - If you run my hex file, would it work all the time ?
    - If you build the blinky example without mcuboot, would it works with the 32kHz RC configuration ?
    - Have you tested with other DK ?
    My test here with the MPSL\timeslot example showed that the application hang when using:
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION=y
    CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_MAX_SKIP=0
    It doesn't hang when I remove CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_MAX_SKIP=0
    It's definitely a bug with our Softdevice controller because if I use CONFIG_BT_LL_SW_SPLIT=y (Zephyr controller) then it worked.
    But if I use
    CONFIG_BOOTLOADER_MCUBOOT=y
    It also worked fine. So it doesn't seem (at least on my setup) there is an issue with MCUBoot when using 32kHz RC without using CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_MAX_SKIP=0.
    Attached is the project and the hex file that you can try.
  • Hi Martijn and Maarten,
    I have reproduced the issue here and have reported it to our team. They are looking into the issue, I will keep you updated.
  • Just a quick update:
    We found that the issue was due to MCUboot doesn't clean up the clock before jumping to the application.
    The easy fix is https://github.com/nrfconnect/sdk-mcuboot/commit/7efbda6a58ac619506c0db2fc8ff16bec9620836
    But in your case it may not be possible as you can't update the MCUboot. So we will need to find a way to stop the LFCLK and HFCLK before starting the clock in the application. Will let you know when we have a solution.
  • Hi guys,
    Good news, we have a workaround.
    By adding the following code in main.c the clock stopping function will be executed before the kernel and can stop the clock from MCUBoot after that the application can start and use the clock source of its own.
    static int stop_clocks()
    { 	nrf_clock_int_disable(NRF_CLOCK, 0xFFFFFFFF);
        nrf_clock_task_trigger(NRF_CLOCK, NRF_CLOCK_TASK_LFCLKSTOP);
        nrf_clock_task_trigger(NRF_CLOCK, NRF_CLOCK_TASK_HFCLKSTOP);
    	while (nrf_clock_lf_is_running(NRF_CLOCK));
    	return 0;
    SYS_INIT(stop_clocks, PRE_KERNEL_1, 0);
  • Hi Hung,
    Thanks for all the help so far, I have verified that the work around works for the devkit example. We will go and implement the work around in our application. I needed to adapt the example code to take a const device struct* as parameter:
    static int stop_clocks(const struct device* dev)
        return 0;
    If we have any followup questions we will post them.
    Maarten
  • These solutions didn't work for me. Do you have any other ideas?
