RSSI Measurement for each single Datachannel
Dear Sir or Madam,
I would like to establish Bluetooth communication. When the Central is connected to the Peripheral, I want to measure the RSSI value of each data channel (0-36).
Is it possible with your ICs (nRF51/ nRF52) to either bypass the hopping algorithm and select a frequency directly (e.g. channel 10 for central and peripheral for the next 10 messages) or to read out the associated data channel for the measured RSSI value?
I have never programmed a Nordic uC:
Can you tell me which uC with which SDK and SoftDevice is best for this case?
Operating system: Windows 10
IDE: SES
Nordic Device: not selected yet
Many thanks for your help
Kind regards
Rebekah Walter
  • Hi Rebecca,
    I would recommend you to use the nRF Connect SDK. It has a RSSI Viewer app within the nRF Connect for Desktop application. This can be used to obtain the RSSI values. Unlike the nRF5 SDK, there is no separate SoftDevice for the nRF Connect SDK. Also, as a starting point, you can take a look at the Radio Test Sample where the supported boards are also mentioned which you can use for the same.
    Priyanka
  • Hi Priyanka, thank you very much for your help!!
    I have some more questions:
    1) When i run the RSSI Test Sample, which is not a real BLE communication (as I understood it) Is it possible to get a BLE communication running after the RSSI measurements?
    2) I downloaded the nRF connect SDK and i was able to open the Radio Test Sample on VS. I open the main and i saw that the main only initilaize the Clock. Can you shortly explain how the programm is workin and where i can find the rest for the source code. (I want to get the correct order of the commands)
    I am a beginner and i need some more support from your side.
    Tank you very much!
    Regards
    Rebecca
  • Hi Rebecca,
    No, you cannot incorporate any BLE communication into this sample as it does not follow the BLE specifications. This is a simple sample which is used to test the radio especially for regulatory certifications etc. The nRF Connect SDK is based on Zephyr RTOS and here instead of dumping everything into the main.c, we have custom files which implement the required functions, for eg, if you take the src folder inside the radio_test sample, you can see the following:
    There are two more c files- radio_cmd (for all the commands and various modes) and radio_test(for the enabling and disabling radio_test, for timers etc) which are used along with the main.c.
    In order to understand line by line, you could use a debugger but as a beginner, I would suggest you to take a look at the BLE_service_tutorial. Yes, this link is for a BLE, but the way this tutorial is written will help you understand about the custom folders, etc.
    Priyanka
