I would like to use MCK as a clock for adc CLK 4Mhz.
Could i enable & configure all registers without I2S or PDM peripheral activation?
Is there a sample code for MCLK configuration?
Thank you for your feedback.
i did it with I2S activation, without nominate LRCK,SCLK,DATA, juste MCLK.
Here is the code
#include <nrf.h>
#include <zephyr.h>
#include <device.h>
#include <sys/printk.h>
#include <stdbool.h>
#include <string.h>
#include <nrfx_i2s.h>
static void i2s_clk_init(void);
// a modifier
#define I2S_MCK_PIN 15 // MCLK pin is GPIO2
#define I2S_DATA_BLOCK_WORDS 512 //How many numbers do we want. time reorded = DATA_BLOCK_WORDS / freq
static uint32_t m_buffer_rx32u[I2S_DATA_BLOCK_WORDS];
static nrfx_i2s_buffers_t i2s_initial_buffers;
// I2S ISR handler
ISR_DIRECT_DECLARE(i2s_isr_handler)
nrfx_i2s_irq_handler();
ISR_DIRECT_PM(); // PM done after servicing interrupt for best latency
return 1; // We should check if scheduling decision should be made
// I2S event handler
static void i2s_data_handler(nrfx_i2s_buffers_t const *p_released, uint32_t status)
if (NRFX_I2S_STATUS_NEXT_BUFFERS_NEEDED == status)
nrfx_i2s_next_buffers_set(&i2s_initial_buffers);
* Function: i2s_clk_init
* Description: provide 2.1333333 MHz. reference clock to audio ADC
* Parameters: none
* Returns: nothing
// the audio clock defaults to 12.288MHz, so we don't need to adjust it
// configure I2S
IRQ_DIRECT_CONNECT(I2S0_IRQn, 0, i2s_isr_handler, 0);
i2s_initial_buffers.p_rx_buffer = m_buffer_rx32u;
nrfx_i2s_config_t i2s_cfg = NRFX_I2S_DEFAULT_CONFIG(NRFX_I2S_PIN_NOT_USED, NRFX_I2S_PIN_NOT_USED, I2S_MCK_PIN, NRFX_I2S_PIN_NOT_USED, NRFX_I2S_PIN_NOT_USED);
i2s_cfg.clksrc = NRF_I2S_CLKSRC_PCLK32M ; // audio clock
i2s_cfg.mck_setup = NRF_I2S_MCK_32MDIV15;
i2s_cfg.enable_bypass = false; // bypass division, so we get the raw audio clock
nrfx_err_t err_code = nrfx_i2s_init(&i2s_cfg, i2s_data_handler);
if(err_code != NRFX_SUCCESS)
printk("Error initializing I2S\n");
return;
void MCLK_Start(void)
nrfx_err_t err_code;
i2s_clk_init();
// start i2s
err_code = nrfx_i2s_start(&i2s_initial_buffers, I2S_DATA_BLOCK_WORDS, 0);
if (err_code != NRFX_SUCCESS)
printk("I2S start error\n");
void MCLK_stop(void)
// stop i2s
nrfx_i2s_stop();
juste be carful to add the necessary in CMakeLists file
