I am new to BLE. I am currently working on a beacon application. I have used the beacon example code from SDK and modified it. I am using SDK-17.1.0 controller is nrf52832 with softdevice 132. My Beacon mode is working fine. Now I am using button interrupt to put my device into config mode. But as soon as I enter into the advertising init function My device gets restarted. When debugged found that it was showing error code 4. I have gone through one of the post but could not able to solve the error. In my beacon mode, I am directly transmitting my raw data over BLE.
void advertising_init(void)
ret_code_t err_code;
uint8_t adv_flags;
ble_advertising_init_t init;
adv_flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.include_appearance = true;
init.advdata.flags = adv_flags;
init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
init.advdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_whitelist_enabled = false;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_interval = APP_ADV_FAST_INTERVAL;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
init.config.ble_adv_slow_enabled = false;
init.error_handler = ble_advertising_error_handler;
void BC_advertising_init(void)
uint32_t err_code;
// ble_advdata_t advdata;
// uint8_t flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
ble_gap_addr_t device_addr;
memset(&m_adv_params, 0, sizeof(m_adv_params));
m_adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED; //BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
m_adv_params.p_peer_addr = NULL; // Undirected advertisement.
m_adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
m_adv_params.interval = NON_CONNECTABLE_ADV_INTERVAL;
m_adv_params.duration = 0; // Never time out.
sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE); // DCDC enabled
sd_ble_gap_addr_get(&device_addr);
BC_advertData[MAC_1]=device_addr.addr[5]; //MAC ADDRESS
BC_advertData[MAC_1+1]=device_addr.addr[4];
BC_advertData[MAC_1+2]=device_addr.addr[3];
BC_advertData[MAC_1+3]=device_addr.addr[2];
BC_advertData[MAC_1+4]=device_addr.addr[1];
BC_advertData[MAC_1+5]=device_addr.addr[0];
err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV,NULL,0);
if(err_code == NRF_SUCCESS)
NRF_LOG_INFO("sd_ble_gap_adv_set_configure init successful !");
}else
NRF_LOG_INFO("sd_ble_gap_adv_set_configure init failed !");
void change_to_app_ble_advertising_init(void)
bool erase_bonds;
gap_params_init();
gatt_init();
advertising_init();
services_init();
conn_params_init();
advertising_start(erase_bonds);
static void button_event_handler(uint8_t pin_no, uint8_t button_action)
#if DEBUG_INTERRUPT
write_uart_data((unsigned char *)("\n in button_event_handler "),0);
write_uart_integer(button_action);
write_uart_integer(pin_no);
switch (pin_no)
case SWITCH_INTERRUPT:
if(button_action==1)
#if DEBUG_INTERRUPT
write_uart_data((unsigned char *)("\n button_action 1:"),0);
Config_key_timer_start();
else if(button_action==0)
#if DEBUG_INTERRUPT
write_uart_data((unsigned char *)("\n button_action 0:"),0);
//CONFIG KEY CHECK============================================================
Config_key_timer_stop(); //stop configuration timer
if((gb_Config_key_ctr.counts==THREE_SEC_PRESS || gb_Config_key_ctr.counts>=THREE_SEC_PRESS+1) && gb_Config_key_ctr.counts<FIVE_SEC_PRESS)
write_uart_data((unsigned char *)("\n ************In 1**************"),0);
if(gb_Button_Tap.Device_state==DEVICE_OFF) //only applicable if device is turned off first
write_uart_data((unsigned char *)("\n ************In 2**************"),0);
//Mode of Operation
if(gb_Tag_Mode.Data_Mode)
write_uart_data((unsigned char *)("\n ************MOVE THE DEVICE IN CONFIG MODE**************"),0);
gb_Tag_Mode.Data_Mode=0; //Clear Data mode flag
gb_Tag_Mode.Config_Mode=1; //Move the device in configuration mode
Broadcast_Timer_Stop(); //stop Broadcasting the Data Timer
change_to_app_ble_advertising_init();
nrf_delay_ms(200);
advertising_start(0);
General_Timer_Start(); //for configuration LED blinks
LED_Timer_Start(Configuration_Mode); //Start LED timer
else if(gb_Tag_Mode.Config_Mode)
write_uart_data((unsigned char *)("\n ************MOVE THE DEVICE IN DATA MODE**************"),0);
gb_Tag_Mode.Config_Mode=0; //Clear Config mode flag
gb_Tag_Mode.Data_Mode=1; //Move the device in Data mode
BC_advertising_init(); //Init stack for Non connectable broadcasting
General_Timer_Start(); //start timer for Measurement and Datalogging
Broadcasting_Timer_Start(); //Start Broadcasting timer
Meas_start_sequence();
LED_Timer_Start(Normal_Mode); //Start LED timer for normal mode
}//device off
}//three secs key pressed
else if (gb_Config_key_ctr.counts==FIVE_SEC_PRESS || gb_Config_key_ctr.counts>=FIVE_SEC_PRESS+1)
write_uart_data((unsigned char *)("\n FIVE_SEC_PRESS"),0);
gb_Config_key_ctr.counts=0; //Clear counting for configuration key press
if(gb_Button_Tap.First_Tap==0)
gb_Button_Tap.First_Tap=1;
key_timer_start();
write_uart_data((unsigned char *)("\n First tap:"),0);
else if(gb_Button_Tap.First_Tap ==1 && gb_Button_Tap.Second_Tap==0)
gb_Button_Tap.Second_Tap=1;
write_uart_data((unsigned char *)("\n Second tap:"),0);
if(gb_Button_Tap.First_Tap ==1 && gb_Button_Tap.Second_Tap ==1)
gb_Button_Tap.First_Tap=0;
gb_Button_Tap.Second_Tap=0;
write_uart_data((unsigned char *)("\n DOUBLE TAP RECEIVED>>>>>>>>>>>>>>>>>>>>>>>"),0);
if(gb_Button_Tap.Device_state==DEVICE_ON)
write_uart_data((unsigned char *)("\n Device is ON.. Turn it OFF"),0);
Multi_Blink_LED(IOID_RED_LED,100,0,1);
gb_Button_Tap.Device_state=DEVICE_OFF; //change device state
General_Timer_Stop(); //stop timer for Measurement and Datalogging
Data_Counter=0; //clear data counter
else// DEVICE_OFF
write_uart_data((unsigned char *)("\n Device is OFF.. Turn it ON"),0);
gb_Button_Tap.Device_state=DEVICE_ON; //change device state
Multi_Blink_LED(IOID_BLUE_LED,100,0,1);
DELAY_MS(1000);
twi_master_init();
INIT_SPI_pins();
test_sensors(); //test all sensor
Set_pin_to_defalut(); // uninitialized I2C & SPI pins
//Meas_start_sequence();
#if DEBUG_INTERRUPT
write_uart_data((unsigned char *)("Send button default"),0);
APP_ERROR_HANDLER(pin_no);
}// end of function button_event_handler(uint8_t pin_no, uint8_t button_action)
bool erase_bonds;
//Initialize.
nrf_delay_ms(1000); //Power ON delay
#if 1
//log_init();
timers_init();
#ifndef DISABLE_MY_UART
uart1_init(); //Initialize UART for the first time
write_uart_data((unsigned char *)("UART init"),0);
ble_stack_init();
gap_params_init();
gatt_init();
//advertising_init();
services_init();
conn_params_init();
peer_manager_init();
// Start execution.
NRF_LOG_INFO("Bond Management example started.");
Init_GPIO(); // GPIO initialization
Init_all_peripherals(); // Initialize peripherals for measurement
power_management_init();
//Enter in Measurement mode on startup
Read_Battery_Init(); // configure ADC for Battery measurement
Process_Measurement(); //check timer and process measurement
gb_FCONFIG_DATA.FSensor_Advertising_time=10;
gb_FCONFIG_DATA.FSensor_Advertising_count=1;
gb_FCONFIG_DATA.FSensor_Advertising_Delay=4000;
gb_FCONFIG_DATA.FDatalogging_status=0x01;
gb_FCONFIG_DATA.FBroadcasting_status=0x01;
gb_Button_Tap.Device_state = DEVICE_ON;
gb_FCONFIG_DATA.FSesnor_ScanTime= 10;
gb_Timer_Flags.Start_Meas = TRUE;
// Init_Saved_Configurations(); // Load the
Broadcasting_Timer_Start(); //Start Advertising timer (30 seconds)
//Key Initializations
Button_init(); // Configure Button
Init_key_timer(); //Double tap timer
Init_Config_key_timer(); //config timer
/* Configuration flag for HTU21d to read temp & humidity*/
gb_FCONFIG_DATA.FSensor_Temp=0x01;
gb_FCONFIG_DATA.FSensor_Hum=0x01;
write_uart_data((unsigned char *)("Bond Management example started."),0);
// Enter main loop.
for (;;)
if(gb_Tag_Mode.Data_Mode) //check if data mode activated
if( gb_GENERAL_FLAGS.BATTERY_LOW==1) //INDICATE BATTERY LOW 20%
if(gb_Timer_Flags.LED_time == TRUE)
LED_Timer_Start(Battery_Low_Mode); //Start LED timer
Multi_Blink_LED(LED_RED,100,0,1);
if(gb_Timer_Flags.LED_time == TRUE) //ELSE NORMAL INDICATION
}//data mode
else if(gb_Tag_Mode.Config_Mode) //check if it is in config mode
Multi_Blink_LED(LED_BLUE,100,0,1);
// Display_print0(dispHandle, 0, 0, "Inside Config Mode");
// Meas_Timer_Stop(); // stop Measurement timer and measurement
//Data_Counter=0; //start datalogging again
memset(Raw_Param_Data,0xff,Raw_Param_len); //clear the buffer for datalog
idle_state_handle();
}// End of main()
kindly suggest what to do for switching into config mode.... I haven't added any services yet but in future will be added.
Thank You
