Switching issue for config mode in Beacon.
          I am new to BLE. I am currently working on a beacon application. I have used the beacon example code from SDK and modified it. I am using SDK-17.1.0 controller is nrf52832 with softdevice 132. My Beacon mode is working fine. Now I am using button interrupt to put my device into config mode. But as soon as I enter into the advertising init function My device gets restarted. When debugged found that it was showing error code 4. I have gone through one of the post but could not able to solve the error. In my beacon mode, I am directly transmitting my raw data over BLE.
void advertising_init(void)
 ret_code_t     err_code;
    uint8_t        adv_flags;
    ble_advertising_init_t init;
    adv_flags                             = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.advdata.name_type                = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance       = true;
    init.advdata.flags                    = adv_flags;
    init.advdata.uuids_complete.uuid_cnt  = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids   = m_adv_uuids;
    init.config.ble_adv_whitelist_enabled = false;
    init.config.ble_adv_fast_enabled      = true;
    init.config.ble_adv_fast_interval     = APP_ADV_FAST_INTERVAL;
    init.config.ble_adv_fast_timeout      = APP_ADV_DURATION;
    init.config.ble_adv_slow_enabled      = false;
    init.evt_handler   = on_adv_evt;
    init.error_handler = ble_advertising_error_handler;
void BC_advertising_init(void)
   uint32_t      err_code;
   // ble_advdata_t advdata;
   // uint8_t       flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
   ble_gap_addr_t device_addr;
    memset(&m_adv_params, 0, sizeof(m_adv_params));
    m_adv_params.properties.type =  BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED; //BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
    m_adv_params.p_peer_addr     = NULL;    // Undirected advertisement.
    m_adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
    m_adv_params.interval        = NON_CONNECTABLE_ADV_INTERVAL;
    m_adv_params.duration        = 0;       // Never time out.
    sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE);      // DCDC enabled
    sd_ble_gap_addr_get(&device_addr);
    BC_advertData[MAC_1]=device_addr.addr[5];			 //MAC ADDRESS
    BC_advertData[MAC_1+1]=device_addr.addr[4];
    BC_advertData[MAC_1+2]=device_addr.addr[3];
    BC_advertData[MAC_1+3]=device_addr.addr[2];
    BC_advertData[MAC_1+4]=device_addr.addr[1];
    BC_advertData[MAC_1+5]=device_addr.addr[0];
    err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
    sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV,NULL,0);
    if(err_code == NRF_SUCCESS)
      NRF_LOG_INFO("sd_ble_gap_adv_set_configure init successful !");
    }else
      NRF_LOG_INFO("sd_ble_gap_adv_set_configure init failed !");
void change_to_app_ble_advertising_init(void)
	bool erase_bonds;
    gap_params_init();
    gatt_init();
    advertising_init();
    services_init();
    conn_params_init();
    advertising_start(erase_bonds);
static void button_event_handler(uint8_t pin_no, uint8_t button_action)
#if DEBUG_INTERRUPT
write_uart_data((unsigned char *)("\n in button_event_handler  "),0);
write_uart_integer(button_action);
write_uart_integer(pin_no);
    switch (pin_no)
        case SWITCH_INTERRUPT:
                    if(button_action==1)
                        #if DEBUG_INTERRUPT
            		write_uart_data((unsigned char *)("\n button_action 1:"),0);
                        Config_key_timer_start();
            	else if(button_action==0)
                        #if DEBUG_INTERRUPT
        		write_uart_data((unsigned char *)("\n button_action 0:"),0);
                         //CONFIG KEY CHECK============================================================
        		Config_key_timer_stop();			//stop configuration timer
        		if((gb_Config_key_ctr.counts==THREE_SEC_PRESS || gb_Config_key_ctr.counts>=THREE_SEC_PRESS+1) && gb_Config_key_ctr.counts<FIVE_SEC_PRESS)
                              write_uart_data((unsigned char *)("\n ************In 1**************"),0);
        			if(gb_Button_Tap.Device_state==DEVICE_OFF)	//only applicable if device is turned off first
                                    write_uart_data((unsigned char *)("\n ************In 2**************"),0);
                                      //Mode of Operation
                                      if(gb_Tag_Mode.Data_Mode)
                                          write_uart_data((unsigned char *)("\n ************MOVE THE DEVICE IN CONFIG MODE**************"),0);
                                          gb_Tag_Mode.Data_Mode=0;		//Clear Data mode flag
                                          gb_Tag_Mode.Config_Mode=1;		//Move the device in configuration mode
                                          Broadcast_Timer_Stop();		//stop Broadcasting the Data Timer
                                          change_to_app_ble_advertising_init();
                                          nrf_delay_ms(200);
                                          advertising_start(0);
                                          General_Timer_Start();		//for configuration LED blinks
                                          LED_Timer_Start(Configuration_Mode);	//Start LED timer
                                      else if(gb_Tag_Mode.Config_Mode)
                                          write_uart_data((unsigned char *)("\n ************MOVE THE DEVICE IN DATA MODE**************"),0);
                                          gb_Tag_Mode.Config_Mode=0;			//Clear Config mode flag
                                          gb_Tag_Mode.Data_Mode=1;			//Move the device in Data mode
                                          BC_advertising_init();			//Init stack for Non connectable broadcasting
                                          General_Timer_Start();			//start timer for Measurement and Datalogging
                                          Broadcasting_Timer_Start();			//Start Broadcasting timer
                                          Meas_start_sequence();
                                          LED_Timer_Start(Normal_Mode);					//Start LED timer for normal mode
        			}//device off
        		}//three secs key pressed
        		else if (gb_Config_key_ctr.counts==FIVE_SEC_PRESS || gb_Config_key_ctr.counts>=FIVE_SEC_PRESS+1)
        			write_uart_data((unsigned char *)("\n FIVE_SEC_PRESS"),0);
        		gb_Config_key_ctr.counts=0;			//Clear counting for configuration key press
        		if(gb_Button_Tap.First_Tap==0)
                              gb_Button_Tap.First_Tap=1;
                              key_timer_start();
                              write_uart_data((unsigned char *)("\n First tap:"),0);
        		else if(gb_Button_Tap.First_Tap ==1 && gb_Button_Tap.Second_Tap==0)
                              gb_Button_Tap.Second_Tap=1;
                              write_uart_data((unsigned char *)("\n Second tap:"),0);
        		if(gb_Button_Tap.First_Tap ==1 && gb_Button_Tap.Second_Tap ==1)
                          gb_Button_Tap.First_Tap=0;
                          gb_Button_Tap.Second_Tap=0;
                          write_uart_data((unsigned char *)("\n DOUBLE TAP RECEIVED>>>>>>>>>>>>>>>>>>>>>>>"),0);
                          if(gb_Button_Tap.Device_state==DEVICE_ON)
                            write_uart_data((unsigned char *)("\n Device is ON.. Turn it OFF"),0);
                            Multi_Blink_LED(IOID_RED_LED,100,0,1);
                            gb_Button_Tap.Device_state=DEVICE_OFF;			//change device state
                            General_Timer_Stop();					//stop timer for Measurement and Datalogging
                            Data_Counter=0;						//clear data counter
                          else// DEVICE_OFF
                            write_uart_data((unsigned char *)("\n Device is OFF.. Turn it ON"),0);
                            gb_Button_Tap.Device_state=DEVICE_ON;           //change device state
                            Multi_Blink_LED(IOID_BLUE_LED,100,0,1);
                            DELAY_MS(1000);
                            twi_master_init();
                            INIT_SPI_pins();
                            test_sensors();                                 //test all sensor
                            Set_pin_to_defalut();                 // uninitialized I2C & SPI pins
                            //Meas_start_sequence();
            #if DEBUG_INTERRUPT
            write_uart_data((unsigned char *)("Send button default"),0);
            APP_ERROR_HANDLER(pin_no);
}// end of function  button_event_handler(uint8_t pin_no, uint8_t button_action)
    bool erase_bonds;
    //Initialize.
    nrf_delay_ms(1000);       //Power ON delay
     #if 1
    //log_init();
    timers_init();
    #ifndef DISABLE_MY_UART
    uart1_init();								//Initialize UART for the first time
    write_uart_data((unsigned char *)("UART init"),0);
    ble_stack_init();
    gap_params_init();
    gatt_init();
    //advertising_init();
    services_init();
    conn_params_init();
    peer_manager_init();
    // Start execution.
    NRF_LOG_INFO("Bond Management example started.");
    Init_GPIO();                  //      GPIO initialization
    Init_all_peripherals();       // Initialize peripherals for measurement
    power_management_init();
   					 				//Enter in Measurement mode on startup
    Read_Battery_Init();          // configure ADC for Battery measurement
    Process_Measurement();                                 //check timer and process measurement
    gb_FCONFIG_DATA.FSensor_Advertising_time=10;
    gb_FCONFIG_DATA.FSensor_Advertising_count=1;
    gb_FCONFIG_DATA.FSensor_Advertising_Delay=4000;
    gb_FCONFIG_DATA.FDatalogging_status=0x01;
    gb_FCONFIG_DATA.FBroadcasting_status=0x01;
    gb_Button_Tap.Device_state  = DEVICE_ON;
    gb_FCONFIG_DATA.FSesnor_ScanTime= 10;
    gb_Timer_Flags.Start_Meas = TRUE;
   // Init_Saved_Configurations();					// Load the
    Broadcasting_Timer_Start();   //Start Advertising timer (30 seconds)
    //Key Initializations
    Button_init();              // Configure Button
    Init_key_timer();		//Double tap timer
    Init_Config_key_timer();	//config timer
    /* Configuration flag for HTU21d to read temp & humidity*/
    gb_FCONFIG_DATA.FSensor_Temp=0x01;
    gb_FCONFIG_DATA.FSensor_Hum=0x01;
    write_uart_data((unsigned char *)("Bond Management example started."),0);
    // Enter main loop.
    for (;;)
          if(gb_Tag_Mode.Data_Mode)                                   //check if data mode activated
                  if( gb_GENERAL_FLAGS.BATTERY_LOW==1)                    //INDICATE BATTERY LOW 20%
                    if(gb_Timer_Flags.LED_time == TRUE)
                      LED_Timer_Start(Battery_Low_Mode);							 //Start LED timer
                      Multi_Blink_LED(LED_RED,100,0,1);
                    if(gb_Timer_Flags.LED_time == TRUE)                //ELSE NORMAL INDICATION
            }//data mode
            else if(gb_Tag_Mode.Config_Mode)                            //check if it is in config mode
                Multi_Blink_LED(LED_BLUE,100,0,1);
  //          Display_print0(dispHandle, 0, 0, "Inside Config Mode");
  //          Meas_Timer_Stop();                            // stop Measurement timer and measurement
              //Data_Counter=0;                               //start datalogging again
              memset(Raw_Param_Data,0xff,Raw_Param_len);               //clear the buffer for datalog
             idle_state_handle();
}// End of main()
 kindly suggest what to do for switching into config mode.... I haven't added any services yet but in future will be added.
Thank You
