SDK 1.8.0 The AT#XAGPS=1,1 command doesn't working
Hello, I am using board nRF9160-dk (sdk 1.8.0).
I need to get geolocation data using AGPS, for this I use the following sequence of AT commands:
AT%XSYSTEMMODE=1,0,1,0
AT%XMAGPIO=1,0,0,1,1,1574,1577
AT%XCOEX0
AT+CEREG=5
AT+CPSMS=1
AT+CFUN=1
AT#XNRFCLOUD=1
AT#XAGPS=1,1
But always on the command AT#XAGPS=1,1 I get the answer "ERROR".
What's my mistake? And why just "AT#XGPS=1,1" works correctly.
    The #XAGPS command runs the GNSS together with the nRF Cloud A-GPS service. This requires access to nRF Cloud through the LTE network for receiving A-GPS data.
    Have you connected to nRF Cloud?
    Øyvind
    To connect to the cloud service, use the command: AT#XNRFCLOUD=1.
    In response we get:
    << OK
    << #XNRFCLOUD: {"desired":{"pairing":{"state":"paired","topics":{"d2c":"prod/669fbe44-b8e6-41e1-b298-6afb63e45691/m/d/nrf-352656108600480/d2c","c2d":"prod/669fbe44-b8e6-41e1-b298-6afb63e45691/m/d/nrf-352656108600480/c2d"}},"nrfcloud_mqtt_topic_prefix":"prod/669fbe44-b8e6-41e1-b298-6afb63e45691/"},"config":{"GPS":{"enable":false}}}
    << #XNRFCLOUD: 1,0
    I've just tested on my side. Are you using the precompiled firmware?
    In the pjr.conf of the Serial LTE Modem, you will need to enable AGPS (disabled by default).
    # nRF Cloud based location services
    CONFIG_SLM_AGPS=y
    Note that the SLM uses RTT to print the Application log, which you can access via Segger J-Link RTT Viewer.
    # Segger RTT
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_RTT_CONSOLE=y
    CONFIG_UART_CONSOLE=n
    CONFIG_LOG_BACKEND_RTT=y
    CONFIG_LOG_BACKEND_UART=n
    Øyvind
    CONFIG_SLM_AGPS=y
    # Segger RTT
    Øyvind
  • I'm using the newly downloaded "Serial lte monitor" project (for sdk 1.8).
    We use an external GPS antenna (everything is works in the simple GPS version):
    2022-02-13T15:29:38.138Z DEBUG modem >> AT+CFUN?
    2022-02-13T15:29:38.161Z DEBUG modem << 0
    2022-02-13T15:29:38.166Z DEBUG modem << OK
    2022-02-13T15:29:39.493Z DEBUG modem >> AT
    2022-02-13T15:29:39.510Z DEBUG modem << OK
    2022-02-13T15:29:58.677Z DEBUG modem >> AT%XSYSTEMMODE=0,0,1,0
    2022-02-13T15:29:58.696Z DEBUG modem << OK
    2022-02-13T15:30:14.790Z DEBUG modem >> AT%XMAGPIO=1,0,0,1,1,1574,1577
    2022-02-13T15:30:14.812Z DEBUG modem << OK
    2022-02-13T15:30:23.556Z DEBUG modem >> AT%XCOEX0
    2022-02-13T15:30:23.574Z DEBUG modem << OK
    2022-02-13T15:30:34.637Z DEBUG modem >> AT+CFUN=31
    2022-02-13T15:30:34.656Z DEBUG modem << OK
    2022-02-13T15:30:42.636Z DEBUG modem >> at#xgps=1,1
    2022-02-13T15:30:42.654Z DEBUG modem << OK
    2022-02-13T15:31:23.751Z DEBUG modem << #XGPS: 32.706002,35.172615,169.329712,32.686913,0.458134,0.000000,"2022-02-13 15:31:24"
    I checked configuration settings, CONFIG_SLM_AGPS setting is enabled. I apply all the settings from the config file:
    # General config
    CONFIG_LOG=y
    CONFIG_LOG_DEFAULT_LEVEL=3
    CONFIG_STACK_SENTINEL=y
    CONFIG_NEWLIB_LIBC=y
    CONFIG_RING_BUFFER=y
    # Segger RTT
    # Network
    CONFIG_NETWORKING=y
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_NATIVE=n
    # Modem library
    CONFIG_NRF_MODEM_LIB=y
    # Align the max FD entry to NRF_MODEM_MAX_SOCKET_COUNT(8)
    CONFIG_POSIX_MAX_FDS=8
    # Enable below for modem trace
    #CONFIG_NRF_MODEM_LIB_TRACE_ENABLED=y
    # Use GPIO
    CONFIG_GPIO=y
    CONFIG_GPIO_NRFX=y
    CONFIG_GPIO_NRF_P0=y
    # UART interface
    CONFIG_SERIAL=y
    CONFIG_UART_ASYNC_API=y
    CONFIG_NRFX_TIMER2=y
    # Stacks and heaps
    CONFIG_MAIN_STACK_SIZE=4096
    CONFIG_HEAP_MEM_POOL_SIZE=16384
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    # Device power management
    CONFIG_PM_DEVICE=y
    # FOTA
    CONFIG_HTTP_PARSER_URL=y
    CONFIG_FOTA_DOWNLOAD=y
    CONFIG_FOTA_DOWNLOAD_PROGRESS_EVT=y
    CONFIG_DFU_TARGET=y
    CONFIG_DOWNLOAD_CLIENT=y
    CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
    CONFIG_BOOTLOADER_MCUBOOT=y
    CONFIG_IMG_MANAGER=y
    # FLASH
    CONFIG_FLASH=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_FLASH_MAP=y
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    CONFIG_IMG_ERASE_PROGRESSIVELY=y
    # Settings
    CONFIG_SETTINGS=y
    CONFIG_SETTINGS_FCB=y
    CONFIG_FCB=y
    # nRF Cloud
    CONFIG_CLOUD_API=y
    CONFIG_NRF_CLOUD_MQTT=y
    CONFIG_NRF_CLOUD_FOTA=n
    CONFIG_NRF_CLOUD_AGPS=y
    CONFIG_NRF_CLOUD_PGPS=y
    CONFIG_NRF_CLOUD_CELL_POS=y
    CONFIG_NRF_CLOUD_LOG_LEVEL_INF=y
    CONFIG_DATE_TIME=y
    CONFIG_MODEM_INFO=y
    CONFIG_MODEM_INFO_ADD_DATE_TIME=n
    CONFIG_AT_MONITOR=y
    CONFIG_MODEM_JWT=y
    # Use "nrf-<IMEI>" as the default device_id format
    # Use "<device_uuid>" as the device_id format by below
    #CONFIG_NRF_CLOUD_CLIENT_ID_SRC_INTERNAL_UUID=y
    # SLM-specific configurations
    CONFIG_SLM_CUSTOMIZED=n
    CONFIG_SLM_LOG_LEVEL_INF=y
    CONFIG_SLM_EXTERNAL_XTAL=n
    CONFIG_SLM_START_SLEEP=n
    # Use UART_0 (when working with PC terminal)
    CONFIG_UART_0_NRF_HW_ASYNC_TIMER=2
    # Use UART_2 (when working with external MCU)
    #CONFIG_SLM_CONNECT_UART_2=y
    #CONFIG_UART_2_NRF_HW_ASYNC_TIMER=2
    CONFIG_SLM_AGPS=y
    CONFIG_SLM_PGPS=y
    CONFIG_SLM_CELL_POS=n
    Now I see that for the AT#XNRFCLOUD=1 command, the expected response "#XNRFCLOUD: 1.0" does not come (only "OK").
    The command for AGPS (AT#XAGPS=1,1) does not work either.
