SDK 1.8.0 The AT#XAGPS=1,1 command doesn't working
Hello, I am using board nRF9160-dk (sdk 1.8.0).
I need to get geolocation data using AGPS, for this I use the following sequence of AT commands:
AT%XSYSTEMMODE=1,0,1,0
AT%XMAGPIO=1,0,0,1,1,1574,1577
AT%XCOEX0
AT+CEREG=5
AT+CPSMS=1
AT+CFUN=1
AT#XNRFCLOUD=1
AT#XAGPS=1,1
But always on the command AT#XAGPS=1,1 I get the answer "ERROR".
What's my mistake? And why just "AT#XGPS=1,1" works correctly.
  • What does the application log print?
    Stas Jis said:
    I checked configuration settings, CONFIG_SLM_AGPS setting is enabled. I apply all the settings from the config file:
    Was this enabled in the initial issue also?
  • ØyvindWhat does the application log print?
    2022-02-16T07:48:40.622Z INFO Application data folder: C:\Users\stas\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor
    2022-02-16T07:48:40.798Z DEBUG App pc-nrfconnect-linkmonitor v2.0.0 official
    2022-02-16T07:48:40.799Z DEBUG App path: C:\Users\stas\.nrfconnect-apps\node_modules\pc-nrfconnect-linkmonitor
    2022-02-16T07:48:40.799Z DEBUG nRFConnect 3.10.0, required by the app is (^3.8.0)
    2022-02-16T07:48:40.799Z DEBUG nRFConnect path: C:\Users\stas\AppData\Local\Programs\nrfconnect\resources\app.asar
    2022-02-16T07:48:40.799Z DEBUG HomeDir: C:\Users\stas
    2022-02-16T07:48:40.800Z DEBUG TmpDir: C:\Users\stas\AppData\Local\Temp
    2022-02-16T07:48:47.733Z INFO Modem port is opened
    2022-02-16T07:48:47.791Z DEBUG modem >> AT+CFUN?
    2022-02-16T07:48:54.464Z DEBUG modem << Ready
    2022-02-16T07:48:56.893Z INFO Modem port is closed
    2022-02-16T07:48:59.948Z INFO Modem port is opened
    2022-02-16T07:48:59.985Z DEBUG modem >> AT+CFUN?
    2022-02-16T07:49:00.011Z DEBUG modem << +CFUN: 0
    2022-02-16T07:49:00.031Z DEBUG modem << OK
    2022-02-16T07:49:20.369Z DEBUG modem >> AT%XSYSTEMMODE=1,0,1,0
    2022-02-16T07:49:20.394Z DEBUG modem << OK
    2022-02-16T07:49:27.696Z DEBUG modem >> AT%XMAGPIO=1,0,0,1,1,1574,1577
    2022-02-16T07:49:27.718Z DEBUG modem << OK
    2022-02-16T07:49:33.026Z DEBUG modem >> AT%XCOEX0
    2022-02-16T07:49:33.046Z DEBUG modem << OK
    2022-02-16T07:49:38.567Z DEBUG modem >> AT+CEREG=5
    2022-02-16T07:49:38.587Z DEBUG modem << OK
    2022-02-16T07:49:44.705Z DEBUG modem >> AT+CPSMS=1
    2022-02-16T07:49:44.724Z DEBUG modem << OK
    2022-02-16T07:49:50.463Z DEBUG modem >> AT+CFUN=1
    2022-02-16T07:49:50.513Z DEBUG modem << OK
    2022-02-16T07:49:52.064Z DEBUG modem << +CEREG: 2,"026F","00332521",7
    2022-02-16T07:49:53.603Z DEBUG modem << +CEREG: 5,"026F","00332521",7,,,"00011110","11100000"
    2022-02-16T07:49:53.645Z DEBUG modem >> AT+COPS=3,2
    2022-02-16T07:49:53.683Z DEBUG modem << OK
    2022-02-16T07:49:53.711Z DEBUG modem >> AT+COPS?
    2022-02-16T07:49:53.741Z DEBUG modem << +COPS: 0,2,"42502",7
    2022-02-16T07:49:53.751Z DEBUG modem << OK
    2022-02-16T07:49:53.809Z DEBUG modem >> AT%XCBAND
    2022-02-16T07:49:53.821Z DEBUG modem << %XCBAND: 3
    2022-02-16T07:49:53.828Z DEBUG modem << OK
    2022-02-16T07:49:53.856Z DEBUG modem >> AT+CGDCONT?
    2022-02-16T07:49:53.876Z DEBUG modem << +CGDCONT: 0,"IP","IBASIS.IOT","10.160.220.88",0,0
    2022-02-16T07:49:53.883Z DEBUG modem << OK
    2022-02-16T07:49:53.915Z DEBUG modem >> AT+CGACT?
    2022-02-16T07:49:53.931Z DEBUG modem << +CGACT: 0,1
    2022-02-16T07:49:53.936Z DEBUG modem << OK
    2022-02-16T07:50:04.552Z DEBUG modem >> AT#XNRFCLOUD=1
    2022-02-16T07:50:04.578Z DEBUG modem << OK
    2022-02-16T07:53:55.524Z DEBUG modem >> AT
    2022-02-16T07:53:55.550Z DEBUG modem << OK
    2022-02-16T07:54:06.952Z DEBUG modem >> AT#XAGPS=1,1
    2022-02-16T07:54:06.970Z DEBUG modem << ERROR
    2022-02-16T07:54:06.975Z ERROR Error: AT#XAGPS=1,1
     failed
    The CONFIG_SLM_AGPS configuration option was not initially enabled. After activating this option, "segger embedded studio" showed that there were changes in the project was rebuilt and flash to the board.
  • , the log output you have provided is from the LTE Link Monitor, however, there is a RTT log as well:
    2022-02-16T08:21:42.953Z INFO Modem port is opened
    2022-02-16T08:21:42.962Z DEBUG modem >> AT+CFUN?
    2022-02-16T08:21:42.979Z DEBUG modem << +CFUN: 0
    2022-02-16T08:21:42.981Z DEBUG modem << OK
    2022-02-16T08:22:04.807Z DEBUG modem >> AT%XSYSTEMMODE=1,0,1,0
    2022-02-16T08:22:04.822Z DEBUG modem << OK
    2022-02-16T08:22:11.892Z DEBUG modem >> AT%XMAGPIO=1,0,0,1,1,1574,1577
    2022-02-16T08:22:11.910Z DEBUG modem << OK
    2022-02-16T08:22:34.342Z DEBUG modem >> AT%XCOEX0
    2022-02-16T08:22:34.358Z DEBUG modem << OK
    2022-02-16T08:22:40.366Z DEBUG modem >> AT+CEREG=5
    2022-02-16T08:22:40.378Z DEBUG modem << OK
    2022-02-16T08:22:45.630Z DEBUG modem >> AT+CPSMS=1
    2022-02-16T08:22:45.643Z DEBUG modem << OK
    2022-02-16T08:22:49.719Z DEBUG modem >> AT+CFUN=1
    2022-02-16T08:22:49.764Z DEBUG modem << OK
    2022-02-16T08:22:51.120Z DEBUG modem << +CEREG: 2,"7AA9","01172803",7
    2022-02-16T08:22:52.180Z DEBUG modem << +CEREG: 1,"7AA9","01172803",7,,,"00001010","11000001"
    2022-02-16T08:22:52.186Z DEBUG modem >> AT+COPS=3,2
    2022-02-16T08:22:52.192Z DEBUG modem << OK
    2022-02-16T08:22:52.197Z DEBUG modem >> AT+COPS?
    2022-02-16T08:22:52.204Z DEBUG modem << +COPS: 0,2,"24201",7
    2022-02-16T08:22:52.206Z DEBUG modem <<
    2022-02-16T08:22:52.207Z DEBUG modem << OK
    2022-02-16T08:22:52.215Z DEBUG modem >> AT%XCBAND
    2022-02-16T08:22:52.222Z DEBUG modem << %XCBAND: 20
    2022-02-16T08:22:52.223Z DEBUG modem << OK
    2022-02-16T08:22:52.232Z DEBUG modem >> AT+CGDCONT?
    2022-02-16T08:22:52.247Z DEBUG modem << +CGDCONT: 0,"IPV4V6","telenor.iot","10.126.245.40 2A02:2121:0084:91F0:0000:0052:6EBF:5801",0,0
    2022-02-16T08:22:52.250Z DEBUG modem << OK
    2022-02-16T08:22:52.256Z DEBUG modem >> AT+CGACT?
    2022-02-16T08:22:52.266Z DEBUG modem << +CGACT: 0,1
    2022-02-16T08:22:52.267Z DEBUG modem << OK
    2022-02-16T08:23:15.543Z DEBUG modem >> AT#XNRFCLOUD=1
    2022-02-16T08:23:15.550Z DEBUG modem << OK
    2022-02-16T08:23:19.340Z DEBUG modem << #XNRFCLOUD: 1,0
    2022-02-16T08:23:27.301Z DEBUG modem >> AT#XAGPS=1,1
    2022-02-16T08:23:27.686Z DEBUG modem << OK
    From J-Link RTT Viewer
    00> *** Booting Zephyr OS build v2.7.0-ncs1  ***
    00>
    00> [00:00:00.202,575] <inf> slm: Serial LTE Modem
    00> [00:00:00.277,801] <inf> slm_at_host: at_host init done
    00> [00:01:40.352,081] <inf> slm_gnss: CLOUD_EVT_CONNECTED
    00> [00:01:41.312,957] <inf> slm_gnss: CLOUD_EVT_READY
    00> [00:01:49.659,912] <inf> slm_gnss: GNSS_EVT_AGPS_REQ
    00> [00:01:50.666,992] <inf> slm_gnss: GNSS_EVT_BLOCKED
    00> [00:01:50.756,835] <inf> slm_gnss: CLOUD_EVT_DATA_RECEIVED
    00> [00:01:50.860,656] <inf> slm_gnss: CLOUD_EVT_DATA_RECEIVED
    00> [00:01:57.842,285] <inf> slm_gnss: GNSS_EVT_UNBLOCKED
    00> [00:02:11.998,565] <inf> slm_gnss: GNSS_EVT_BLOCKED
    00> [00:02:27.469,787] <inf> slm_gnss: GNSS_EVT_UNBLOCKED
    Tested with iBasis SIM as well. Not getting any AGPS data as I'm currently located inside a building.
    2022-02-16T08:26:43.086Z INFO Modem port is opened
    2022-02-16T08:26:43.091Z DEBUG modem >> AT+CFUN?
    2022-02-16T08:26:43.107Z DEBUG modem << +CFUN: 0
    2022-02-16T08:26:43.108Z DEBUG modem << OK
    2022-02-16T08:27:19.389Z DEBUG modem >> AT%XSYSTEMMODE=1,0,1,0
    2022-02-16T08:27:19.404Z DEBUG modem << OK
    2022-02-16T08:27:25.748Z DEBUG modem >> AT%XMAGPIO=1,0,0,1,1,1574,1577
    2022-02-16T08:27:25.762Z DEBUG modem << OK
    2022-02-16T08:27:31.589Z DEBUG modem >> AT%XCOEX0
    2022-02-16T08:27:31.601Z DEBUG modem << OK
    2022-02-16T08:27:39.196Z DEBUG modem >> AT+CEREG=5
    2022-02-16T08:27:39.209Z DEBUG modem << OK
    2022-02-16T08:27:47.173Z DEBUG modem >> AT+CPSMS=1
    2022-02-16T08:27:47.185Z DEBUG modem << OK
    2022-02-16T08:27:50.851Z DEBUG modem >> AT+CFUN=1
    2022-02-16T08:27:50.897Z DEBUG modem << OK
    2022-02-16T08:27:58.321Z DEBUG modem << +CEREG: 2,"7AA9","01172803",7
    2022-02-16T08:28:01.533Z DEBUG modem << +CEREG: 5,"7AA9","01172803",7,,,"00001010","11000001"
    2022-02-16T08:28:01.539Z DEBUG modem >> AT+COPS=3,2
    2022-02-16T08:28:01.546Z DEBUG modem << OK
    2022-02-16T08:28:01.548Z DEBUG modem >> AT+COPS?
    2022-02-16T08:28:01.557Z DEBUG modem << +COPS: 0,2,"24201",7
    2022-02-16T08:28:01.558Z DEBUG modem << OK
    2022-02-16T08:28:01.562Z DEBUG modem >> AT%XCBAND
    2022-02-16T08:28:01.569Z DEBUG modem << %XCBAND: 20
    2022-02-16T08:28:01.570Z DEBUG modem << OK
    2022-02-16T08:28:01.577Z DEBUG modem >> AT+CGDCONT?
    2022-02-16T08:28:01.590Z DEBUG modem << +CGDCONT: 0,"IP","ibasis.iot","10.160.238.183",0,0
    2022-02-16T08:28:01.591Z DEBUG modem << OK
    2022-02-16T08:28:01.595Z DEBUG modem >> AT+CGACT?
    2022-02-16T08:28:01.602Z DEBUG modem << +CGACT: 0,1
    2022-02-16T08:28:01.603Z DEBUG modem << OK
    2022-02-16T08:28:09.469Z DEBUG modem >> AT#XNRFCLOUD=1
    2022-02-16T08:28:09.476Z DEBUG modem << OK
    2022-02-16T08:28:13.125Z DEBUG modem << #XNRFCLOUD: 1,0
    2022-02-16T08:28:24.979Z DEBUG modem >> AT#XAGPS=1,1
    2022-02-16T08:28:25.506Z DEBUG modem << OK
    2022-02-16T08:29:09.296Z DEBUG modem >> AT
    2022-02-16T08:29:09.302Z DEBUG modem << OK
    00>
    00> [00:00:00.202,606] <inf> slm: Serial LTE Modem
    00> [00:00:00.283,111] <inf> slm_at_host: at_host init done
    00> [00:01:38.879,791] <inf> slm_gnss: CLOUD_EVT_CONNECTED
    00> [00:01:39.788,940] <inf> slm_gnss: CLOUD_EVT_READY
    00> [00:01:52.171,783] <inf> slm_gnss: GNSS_EVT_AGPS_REQ
    00> [00:01:53.147,918] <inf> slm_gnss: CLOUD_EVT_DATA_RECEIVED
    00> [00:01:53.174,804] <inf> slm_gnss: GNSS_EVT_BLOCKED
    00> [00:01:53.250,701] <inf> slm_gnss: CLOUD_EVT_DATA_RECEIVED
    00> [00:02:01.445,404] <inf> slm_gnss: GNSS_EVT_UNBLOCKED
    00> [00:02:14.558,319] <inf> slm_gnss: GNSS_EVT_BLOCKED
    00> [00:02:30.683,837] <inf> slm_gnss: GNSS_EVT_UNBLOCKED
    This is my prj.conf of the SLM
    # Copyright (c) 2020 Nordic Semiconductor ASA
    # General config
    CONFIG_LOG=y
    CONFIG_LOG_DEFAULT_LEVEL=3
    CONFIG_STACK_SENTINEL=y
    CONFIG_NEWLIB_LIBC=y
    CONFIG_RING_BUFFER=y
    # Segger RTT
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_RTT_CONSOLE=y
    CONFIG_UART_CONSOLE=n
    CONFIG_LOG_BACKEND_RTT=y
    CONFIG_LOG_BACKEND_UART=n
    # Network
    CONFIG_NETWORKING=y
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_NATIVE=n
    # Modem library
    CONFIG_NRF_MODEM_LIB=y
    # Align the max FD entry to NRF_MODEM_MAX_SOCKET_COUNT(8)
    CONFIG_POSIX_MAX_FDS=8
    # Enable below for modem trace
    CONFIG_NRF_MODEM_LIB_TRACE_ENABLED=y
    # Use GPIO
    CONFIG_GPIO=y
    CONFIG_GPIO_NRFX=y
    CONFIG_GPIO_NRF_P0=y
    # UART interface
    CONFIG_SERIAL=y
    CONFIG_UART_ASYNC_API=y
    CONFIG_NRFX_TIMER2=y
    # Stacks and heaps
    CONFIG_MAIN_STACK_SIZE=4096
    CONFIG_HEAP_MEM_POOL_SIZE=16384
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    # Device power management
    CONFIG_PM_DEVICE=y
    # FOTA
    CONFIG_HTTP_PARSER_URL=y
    CONFIG_FOTA_DOWNLOAD=y
    CONFIG_FOTA_DOWNLOAD_PROGRESS_EVT=y
    CONFIG_DFU_TARGET=y
    CONFIG_DOWNLOAD_CLIENT=y
    CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
    CONFIG_BOOTLOADER_MCUBOOT=y
    CONFIG_IMG_MANAGER=y
    # FLASH
    CONFIG_FLASH=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_FLASH_MAP=y
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    CONFIG_IMG_ERASE_PROGRESSIVELY=y
    # Settings
    CONFIG_SETTINGS=y
    CONFIG_SETTINGS_FCB=y
    CONFIG_FCB=y
    # nRF Cloud
    CONFIG_CLOUD_API=y
    CONFIG_NRF_CLOUD_MQTT=y
    CONFIG_NRF_CLOUD_FOTA=n
    CONFIG_NRF_CLOUD_AGPS=y
    CONFIG_NRF_CLOUD_PGPS=y
    CONFIG_NRF_CLOUD_CELL_POS=y
    CONFIG_NRF_CLOUD_LOG_LEVEL_INF=y
    CONFIG_DATE_TIME=y
    CONFIG_MODEM_INFO=y
    CONFIG_MODEM_INFO_ADD_DATE_TIME=n
    CONFIG_AT_MONITOR=y
    CONFIG_MODEM_JWT=y
    # Use "nrf-<IMEI>" as the default device_id format
    # Use "<device_uuid>" as the device_id format by below
    #CONFIG_NRF_CLOUD_CLIENT_ID_SRC_INTERNAL_UUID=y
    # SLM-specific configurations
    CONFIG_SLM_CUSTOMIZED=n
    CONFIG_SLM_LOG_LEVEL_INF=y
    CONFIG_SLM_EXTERNAL_XTAL=n
    CONFIG_SLM_START_SLEEP=n
    # Use UART_0 (when working with PC terminal)
    CONFIG_UART_0_NRF_HW_ASYNC_TIMER=2
    # Use UART_2 (when working with external MCU)
    #CONFIG_SLM_CONNECT_UART_2=y
    #CONFIG_UART_2_NRF_HW_ASYNC_TIMER=2
    # nRF Cloud based location services
    CONFIG_SLM_AGPS=y
    CONFIG_SLM_PGPS=y
    CONFIG_SLM_CELL_POS=y
  • , I repeated the sequence of commands you indicated (LTE Link Monitor):
    2022-02-16T13:26:44.856Z DEBUG modem >> AT+CFUN?
    2022-02-16T13:26:44.896Z DEBUG modem << +CFUN: 0
    2022-02-16T13:26:44.929Z DEBUG modem << OK
    2022-02-16T13:26:45.719Z DEBUG modem >> AT
    2022-02-16T13:26:45.739Z DEBUG modem << OK
    2022-02-16T13:26:51.255Z DEBUG modem >> AT
    2022-02-16T13:26:51.277Z DEBUG modem << OK
    2022-02-16T13:26:51.757Z DEBUG modem >> AT+CFUN?
    2022-02-16T13:26:51.778Z DEBUG modem << +CFUN: 0
    2022-02-16T13:26:51.801Z DEBUG modem << OK
    2022-02-16T13:26:56.640Z DEBUG modem >> AT+CFUN?
    2022-02-16T13:26:56.667Z DEBUG modem << +CFUN: 0
    2022-02-16T13:26:56.692Z DEBUG modem << OK
    2022-02-16T13:26:57.182Z DEBUG modem >> AT
    2022-02-16T13:26:57.196Z DEBUG modem << OK
    2022-02-16T13:27:07.526Z DEBUG modem >> AT
    2022-02-16T13:27:07.548Z DEBUG modem << OK
    2022-02-16T13:27:07.941Z DEBUG modem >> AT+CFUN?
    2022-02-16T13:27:07.958Z DEBUG modem << +CFUN: 0
    2022-02-16T13:27:07.982Z DEBUG modem << OK
    2022-02-16T13:27:49.671Z DEBUG modem >> AT%XSYSTEMMODE=1,0,1,0
    2022-02-16T13:27:49.692Z DEBUG modem << OK
    2022-02-16T13:27:55.110Z DEBUG modem >> AT%XMAGPIO=1,0,0,1,1,1574,1577
    2022-02-16T13:27:55.128Z DEBUG modem << OK
    2022-02-16T13:28:00.293Z DEBUG modem >> AT%XCOEX0
    2022-02-16T13:28:00.310Z DEBUG modem << OK
    2022-02-16T13:28:04.693Z DEBUG modem >> AT+CEREG=5
    2022-02-16T13:28:04.708Z DEBUG modem << OK
    2022-02-16T13:28:09.239Z DEBUG modem >> AT+CPSMS=1
    2022-02-16T13:28:09.260Z DEBUG modem << OK
    2022-02-16T13:28:14.237Z DEBUG modem >> AT+CFUN=1
    2022-02-16T13:28:14.286Z DEBUG modem << OK
    2022-02-16T13:28:15.352Z DEBUG modem << +CEREG: 2,"026F","00332520",7
    2022-02-16T13:28:18.502Z DEBUG modem << +CEREG: 5,"026F","00332520",7,,,"00011110","11100000"
    2022-02-16T13:28:22.861Z DEBUG modem >> AT+COPS=3,2
    2022-02-16T13:28:22.873Z DEBUG modem << OK
    2022-02-16T13:28:27.830Z DEBUG modem >> AT+COPS?
    2022-02-16T13:28:27.846Z DEBUG modem << +COPS: 0,2,"42502",7
    2022-02-16T13:28:27.862Z DEBUG modem << OK
    2022-02-16T13:28:32.701Z DEBUG modem >> AT%XCBAND
    2022-02-16T13:28:32.717Z DEBUG modem << %XCBAND: 3
    2022-02-16T13:28:32.731Z DEBUG modem << OK
    2022-02-16T13:28:37.886Z DEBUG modem >> AT+CGDCONT?
    2022-02-16T13:28:37.905Z DEBUG modem << +CGDCONT: 0,"IP","IBASIS.IOT","10.160.137.247",0,0
    2022-02-16T13:28:37.928Z DEBUG modem << OK
    2022-02-16T13:28:43.775Z DEBUG modem >> AT+CGACT?
    2022-02-16T13:28:43.795Z DEBUG modem << +CGACT: 0,1
    2022-02-16T13:28:43.803Z DEBUG modem << OK
    2022-02-16T13:28:50.852Z DEBUG modem >> AT#XNRFCLOUD=1
    2022-02-16T13:28:50.870Z DEBUG modem << OK
    2022-02-16T13:28:57.596Z DEBUG modem >> AT
    2022-02-16T13:28:57.607Z DEBUG modem << OK
    2022-02-16T13:29:07.605Z DEBUG modem >> AT#XNRFCLOUD=1
    2022-02-16T13:29:07.616Z DEBUG modem << ERROR
    2022-02-16T13:29:07.620Z ERROR Error: AT#XNRFCLOUD=1
     failed
    From J-Link RTT Viewer:
    [00:00:00.243,835] <inf> slm: Serial LTE Modem
    [00:00:00.331,024] <inf> slm_at_host: at_host init done
    [00:02:54.398,712] <err> slm_gnss: Cloud connection failed, error: -11
  • Thanks for providing the information! As you can see the cloud connection failed providing error -11. From the Newlib errno.h, this means
    #define	EAGAIN 11	/* No more processes */
    This could be due the fact that you are calling AT#XNRFCLOUD=1 one more time. I reproduced the issue here:
    2022-02-18T08:33:01.664Z DEBUG modem >> AT+CFUN?
    2022-02-18T08:33:01.688Z DEBUG modem << +CFUN: 0
    2022-02-18T08:33:01.690Z DEBUG modem << OK
    2022-02-18T08:33:13.058Z DEBUG modem >> AT%XSYSTEMMODE=1,0,1,0
    2022-02-18T08:33:13.074Z DEBUG modem << OK
    2022-02-18T08:33:19.524Z DEBUG modem >> AT%XMAGPIO=1,0,0,1,1,1574,1577
    2022-02-18T08:33:19.540Z DEBUG modem << OK
    2022-02-18T08:33:27.844Z DEBUG modem >> AT%XCOEX0
    2022-02-18T08:33:27.860Z DEBUG modem << OK
    2022-02-18T08:33:36.409Z DEBUG modem >> AT+CEREG=5
    2022-02-18T08:33:36.422Z DEBUG modem << OK
    2022-02-18T08:33:43.154Z DEBUG modem >> AT+CPSMS=1
    2022-02-18T08:33:43.167Z DEBUG modem << OK
    2022-02-18T08:33:49.091Z DEBUG modem >> AT+CFUN=1
    2022-02-18T08:33:49.136Z DEBUG modem << OK
    2022-02-18T08:33:50.289Z DEBUG modem << +CEREG: 2,"7AA9","01172803",7
    2022-02-18T08:33:51.262Z DEBUG modem << +CEREG: 1,"7AA9","01172803",7,,,"00001010","11000001"
    2022-02-18T08:33:51.272Z DEBUG modem >> AT+COPS=3,2
    2022-02-18T08:33:51.278Z DEBUG modem << OK
    2022-02-18T08:33:51.283Z DEBUG modem >> AT+COPS?
    2022-02-18T08:33:51.291Z DEBUG modem << +COPS: 0,2,"24201",7
    2022-02-18T08:33:51.293Z DEBUG modem << OK
    2022-02-18T08:33:51.300Z DEBUG modem >> AT%XCBAND
    2022-02-18T08:33:51.307Z DEBUG modem << %XCBAND: 20
    2022-02-18T08:33:51.308Z DEBUG modem << OK
    2022-02-18T08:33:51.317Z DEBUG modem >> AT+CGDCONT?
    2022-02-18T08:33:51.333Z DEBUG modem << +CGDCONT: 0,"IPV4V6","telenor.iot","10.119.104.241 2A02:2121:0088:996D:0000:0052:6F23:C901",0,0
    2022-02-18T08:33:51.334Z DEBUG modem << OK
    2022-02-18T08:33:51.339Z DEBUG modem >> AT+CGACT?
    2022-02-18T08:33:51.346Z DEBUG modem << +CGACT: 0,1
    2022-02-18T08:33:51.351Z DEBUG modem <<
    2022-02-18T08:33:51.352Z DEBUG modem << OK
    2022-02-18T08:34:05.481Z DEBUG modem >> AT#XNRFCLOUD=1
    2022-02-18T08:34:05.487Z DEBUG modem << OK
    2022-02-18T08:34:09.752Z DEBUG modem << #XNRFCLOUD: 1,0
    2022-02-18T08:34:12.065Z DEBUG modem >> AT
    2022-02-18T08:34:12.070Z DEBUG modem << OK
    2022-02-18T08:34:18.195Z DEBUG modem >> AT#XNRFCLOUD=1
    2022-02-18T08:34:18.201Z DEBUG modem << ERROR
    2022-02-18T08:34:18.201Z ERROR Error: AT#XNRFCLOUD=1
     failed
    This
    That said, you might be seeing issues with the SIM card (iBasis). Not all networks fully support iBasis e.g. limited coverage in the UK. Where are you located? Could you try with another SIM from a local provider?
