I need twoADC channels. I tried to configure using :
CONFIG_ADC= y in prj file,
&adc{
#io-channel-cells = < 0x2 >;
}; in overlay file .. the compile error appears as shown in atteched iamge.
Gulzar Singh
&adc{
Gulzar Singh
1. In the adc.h, if #define BUFFER_SIZE 2 right or wrong to sample 2 analog channels ? If in future, 3 chhannels are required, may I set #define BUFFER_SIZE 3.
The buffer size should be set to N*number of enabled channels, as SCAN mode will sample each channel subsequently and put the result in the RAM buffer as described here: https://infocenter.nordicsemi.com/topic/ps_nrf5340/saadc.html?cp=3_0_0_6_28_4_3#saadc_operationmodes_scan. If you set a buffer size that does not match the number of enabled channels, you will miss samples, or samples will be stored in the buffer in non-deterministic order.
2. In the main file, I adc instantiated by binding and then, set up channels using err = adc_channel_setup() .. function. Is it proper way ?
yes it is.
3. '' #if defined (CONFIG_BOARD_BMS_NRF5340_CPUAPP)
NRF_SAADC->TASKS_CALIBRATEOFFSET = 1''
this task will start offset auto-calibration in SAADC peripheral.
4. I wrote two sample functions, as in adc.c. Is this proper way to add to sequence ? If, wrong any where, may you make changes and attached corrected code file ?
It is ok. I have added a sample code where 2 channels are used. you can look at this as reference.
* Copyright (c) 2018 Nordic Semiconductor ASA
* Copyright (c) 2016 Intel Corporation
#include <drivers/adc.h>
#include <zephyr.h>
#include <ztest.h>
#if defined(CONFIG_SHIELD_MIKROE_ADC_CLICK)
#define ADC_DEVICE_NAME DT_LABEL(DT_INST(0, microchip_mcp3204))
#define ADC_RESOLUTION 12
#define ADC_GAIN ADC_GAIN_1
#define ADC_REFERENCE ADC_REF_EXTERNAL0
#define ADC_ACQUISITION_TIME ADC_ACQ_TIME_DEFAULT
#define ADC_1ST_CHANNEL_ID 0
#define ADC_2ND_CHANNEL_ID 1
#elif defined(CONFIG_BOARD_NRF51DK_NRF51422)
#include <hal/nrf_adc.h>
#define ADC_DEVICE_NAME DT_LABEL(DT_INST(0, nordic_nrf_adc))
#define ADC_RESOLUTION 10
#define ADC_GAIN ADC_GAIN_1_3
#define ADC_REFERENCE ADC_REF_INTERNAL
#define ADC_1ST_CHANNEL_INPUT NRF_ADC_CONFIG_INPUT_2
#define ADC_2ND_CHANNEL_ID 2
#define ADC_2ND_CHANNEL_INPUT NRF_ADC_CONFIG_INPUT_3
#elif defined(CONFIG_BOARD_NRF21540DK_NRF52840) || \
defined(CONFIG_BOARD_NRF52DK_NRF52832) || \
defined(CONFIG_BOARD_NRF52840DK_NRF52840) || \
defined(CONFIG_BOARD_RAK4631_NRF52840) || \
defined(CONFIG_BOARD_RAK5010_NRF52840) || \
defined(CONFIG_BOARD_NRF52840DONGLE_NRF52840) || \
defined(CONFIG_BOARD_NRF52840_BLIP) || \
defined(CONFIG_BOARD_NRF52840_PAPYR) || \
defined(CONFIG_BOARD_NRF52833DK_NRF52833) || \
defined(CONFIG_BOARD_BL652_DVK) || \
defined(CONFIG_BOARD_BL653_DVK) || \
defined(CONFIG_BOARD_BL654_DVK) || \
defined(CONFIG_BOARD_BL654_SENSOR_BOARD) || \
defined(CONFIG_BOARD_DEGU_EVK) || \
defined(CONFIG_BOARD_ADAFRUIT_FEATHER_NRF52840) || \
defined(CONFIG_BOARD_RUUVI_RUUVITAG) || \
defined(CONFIG_BOARD_BT510) || \
defined(CONFIG_BOARD_PINNACLE_100_DVK) || \
defined(CONFIG_BOARD_ARDUINO_NANO_33_BLE) || \
defined(CONFIG_BOARD_UBX_BMD300EVAL_NRF52832) || \
defined(CONFIG_BOARD_UBX_BMD330EVAL_NRF52810) || \
defined(CONFIG_BOARD_UBX_BMD340EVAL_NRF52840) || \
defined(CONFIG_BOARD_UBX_BMD345EVAL_NRF52840) || \
defined(CONFIG_BOARD_UBX_BMD360EVAL_NRF52811) || \
defined(CONFIG_BOARD_UBX_BMD380EVAL_NRF52840) || \
defined(CONFIG_BOARD_UBX_EVKANNAB1_NRF52832) || \
defined(CONFIG_BOARD_UBX_EVKNINAB1_NRF52832) || \
defined(CONFIG_BOARD_UBX_EVKNINAB3_NRF52840) || \
defined(CONFIG_BOARD_UBX_EVKNINAB4_NRF52833) || \
defined(CONFIG_BOARD_BT610)
#include <hal/nrf_saadc.h>
#define ADC_DEVICE_NAME DT_LABEL(DT_INST(0, nordic_nrf_saadc))
#define ADC_GAIN ADC_GAIN_1_6
#define ADC_ACQUISITION_TIME ADC_ACQ_TIME(ADC_ACQ_TIME_MICROSECONDS, 10)
#define ADC_1ST_CHANNEL_INPUT NRF_SAADC_INPUT_AIN1
#define ADC_2ND_CHANNEL_INPUT NRF_SAADC_INPUT_AIN2
#elif defined(CONFIG_BOARD_FRDM_K22F)
#define ADC_DEVICE_NAME DT_LABEL(DT_INST(0, nxp_kinetis_adc16))
#define ADC_1ST_CHANNEL_ID 14
#define ADC_1ST_CHANNEL_INPUT 0
#elif defined(CONFIG_BOARD_FRDM_K64F)
#elif defined(CONFIG_BOARD_FRDM_K82F)
#define ADC_1ST_CHANNEL_ID 15
#elif defined(CONFIG_BOARD_FRDM_KL25Z)
#define ADC_1ST_CHANNEL_ID 12
#elif defined(CONFIG_BOARD_FRDM_KW41Z)
#define ADC_1ST_CHANNEL_ID 3
#elif defined(CONFIG_BOARD_HEXIWEAR_K64)
#define ADC_1ST_CHANNEL_ID 16
#define ADC_1ST_CHANNEL_ID 26
#elif defined(CONFIG_BOARD_HEXIWEAR_KW40Z)
#elif defined(CONFIG_BOARD_SAM_E70_XPLAINED) || \
defined(CONFIG_BOARD_SAM_V71_XULT)
#define ADC_DEVICE_NAME DT_LABEL(DT_INST(0, atmel_sam_afec))
#elif defined(CONFIG_SOC_FAMILY_SAM0)
#include <soc.h>
#define ADC_DEVICE_NAME DT_LABEL(DT_INST(0, atmel_sam0_adc))
#define ADC_1ST_CHANNEL_INPUT ADC_INPUTCTRL_MUXPOS_SCALEDIOVCC_Val
#elif defined(CONFIG_BOARD_NUCLEO_F091RC) || \
defined(CONFIG_BOARD_NUCLEO_F103RB) || \
defined(CONFIG_BOARD_NUCLEO_F207ZG) || \
defined(CONFIG_BOARD_STM32F3_DISCO) || \
defined(CONFIG_BOARD_STM32L562E_DK) || \
defined(CONFIG_BOARD_NUCLEO_L552ZE_Q) || \
defined(CONFIG_BOARD_NUCLEO_F401RE) || \
defined(CONFIG_BOARD_NUCLEO_F429ZI) || \
defined(CONFIG_BOARD_NUCLEO_F746ZG) || \
defined(CONFIG_BOARD_NUCLEO_G071RB) || \
defined(CONFIG_BOARD_NUCLEO_L073RZ) || \
defined(CONFIG_BOARD_NUCLEO_WB55RG) || \
defined(CONFIG_BOARD_NUCLEO_L152RE) || \
defined(CONFIG_BOARD_OLIMEX_STM32_H103) || \
defined(CONFIG_BOARD_96B_AEROCORE2) || \
defined(CONFIG_BOARD_STM32F103_MINI) || \
defined(CONFIG_BOARD_STM32_MIN_DEV_BLUE) || \
defined(CONFIG_BOARD_STM32_MIN_DEV_BLACK) || \
defined(CONFIG_BOARD_WAVESHARE_OPEN103Z) || \
defined(CONFIG_BOARD_RONOTH_LODEV) || \
defined(CONFIG_BOARD_STM32L496G_DISCO)
#define ADC_DEVICE_NAME DT_LABEL(DT_INST(0, st_stm32_adc))
#elif defined(CONFIG_BOARD_NUCLEO_F302R8) || \
defined(CONFIG_BOARD_NUCLEO_G474RE) || \
defined(CONFIG_BOARD_NUCLEO_L412RB_P)
/* Some F3 series SOCs do not have channel 0 connected to an external GPIO. */
#elif defined(CONFIG_BOARD_NUCLEO_L476RG) || \
defined(CONFIG_BOARD_BLACKPILL_F411CE) || \
defined(CONFIG_BOARD_BLACKPILL_F401CE) || \
defined(CONFIG_BOARD_NUCLEO_L4R5ZI) || \
defined(CONFIG_BOARD_MIKROE_CLICKER_2)
#elif defined(CONFIG_BOARD_DISCO_L475_IOT1)
#define ADC_1ST_CHANNEL_ID 5
#elif defined(CONFIG_BOARD_B_U585I_IOT02A)
#elif defined(CONFIG_BOARD_NUCLEO_H743ZI) || \
defined(CONFIG_BOARD_NUCLEO_H753ZI)
#define ADC_RESOLUTION 16
#elif defined(CONFIG_BOARD_TWR_KE18F)
#define ADC_DEVICE_NAME DT_LABEL(DT_INST(0, nxp_kinetis_adc12))
#elif defined(CONFIG_BOARD_MEC15XXEVB_ASSY6853) || \
defined(CONFIG_BOARD_MEC1501MODULAR_ASSY6885)
#define ADC_DEVICE_NAME DT_LABEL(DT_INST(0, microchip_xec_adc))
#define ADC_1ST_CHANNEL_ID 4
#define ADC_2ND_CHANNEL_ID 5
#elif defined(CONFIG_BOARD_LPCXPRESSO55S69_CPU0) || \
defined(CONFIG_BOARD_LPCXPRESSO55S28) || \
defined(CONFIG_BOARD_MIMXRT1170_EVK_CM7) || \
defined(CONFIG_BOARD_MIMXRT685_EVK)
#define ADC_DEVICE_NAME DT_LABEL(DT_INST(0, nxp_lpc_lpadc))
#elif defined(CONFIG_BOARD_NPCX7M6FB_EVB) || \
defined(CONFIG_BOARD_NPCX9M6F_EVB)
#define ADC_DEVICE_NAME DT_LABEL(DT_INST(0, nuvoton_npcx_adc))
#elif defined(CONFIG_BOARD_CC3220SF_LAUNCHXL) || \
defined(CONFIG_BOARD_CC3235SF_LAUNCHXL)
#define ADC_DEVICE_NAME DT_LABEL(DT_INST(0, ti_cc32xx_adc))
#elif defined(CONFIG_BOARD_IT8XXX2_EVB)
#define ADC_DEVICE_NAME DT_LABEL(DT_INST(0, ite_it8xxx2_adc))
#define ADC_RESOLUTION 3
#elif defined(CONFIG_BOARD_MIMXRT1050_EVK) || \
defined(CONFIG_BOARD_MIMXRT1050_EVK_QSPI) || \
defined(CONFIG_BOARD_MIMXRT1064_EVK) || \
defined(CONFIG_BOARD_MIMXRT1060_EVK) || \
defined(CONFIG_BOARD_MIMXRT1024_EVK) || \
defined(CONFIG_BOARD_MIMXRT1010_EVK) || \
defined(CONFIG_BOARD_MIMXRT1015_EVK) || \
defined(CONFIG_BOARD_MIMXRT1020_EVK)
#define ADC_DEVICE_NAME DT_LABEL(DT_INST(0, nxp_mcux_12b1msps_sar))
#elif defined(CONFIG_BOARD_NATIVE_POSIX)
#define ADC_DEVICE_NAME DT_LABEL(DT_INST(0, zephyr_adc_emul))
#else
#error "Unsupported board."
/* Invalid value that is not supposed to be written by the driver. It is used
* to mark the sample buffer entries as empty. If needed, it can be overriden
* for a particular board by providing a specific definition above.
#if !defined(INVALID_ADC_VALUE)
#define INVALID_ADC_VALUE SHRT_MIN
#define BUFFER_SIZE 6
static ZTEST_BMEM int16_t m_sample_buffer[BUFFER_SIZE];
static const struct adc_channel_cfg m_1st_channel_cfg = {
.gain = ADC_GAIN,
.reference = ADC_REFERENCE,
.acquisition_time = ADC_ACQUISITION_TIME,
.channel_id = ADC_1ST_CHANNEL_ID,
#if defined(CONFIG_ADC_CONFIGURABLE_INPUTS)
.input_positive = ADC_1ST_CHANNEL_INPUT,
#if defined(ADC_2ND_CHANNEL_ID)
static const struct adc_channel_cfg m_2nd_channel_cfg = {
.gain = ADC_GAIN,
.channel_id = ADC_2ND_CHANNEL_ID,
.input_positive = ADC_2ND_CHANNEL_INPUT,
#endif /* defined(ADC_2ND_CHANNEL_ID) */
const struct device *get_adc_device(void)
return device_get_binding(ADC_DEVICE_NAME);
static const struct device *init_adc(void)
int i, ret;
const struct device *adc_dev = device_get_binding(ADC_DEVICE_NAME);
zassert_not_null(adc_dev, "Cannot get ADC device");
ret = adc_channel_setup(adc_dev, &m_1st_channel_cfg);
zassert_equal(ret, 0,
"Setting up of the first channel failed with code %d", ret);
ret = adc_channel_setup(adc_dev, &m_2nd_channel_cfg);
"Setting up of the second channel failed with code %d", ret);
for (i = 0; i < BUFFER_SIZE; ++i) {
m_sample_buffer[i] = INVALID_ADC_VALUE;
return adc_dev;
static void check_samples(int expected_count)
int i;
TC_PRINT("Samples read: ");
for (i = 0; i < BUFFER_SIZE; i++) {
int16_t sample_value = m_sample_buffer[i];
TC_PRINT("0x%04x ", sample_value);
if (i < expected_count) {
zassert_not_equal(INVALID_ADC_VALUE, sample_value,
"[%u] should be filled", i);
} else {
zassert_equal(INVALID_ADC_VALUE, sample_value,
"[%u] should be empty", i);
TC_PRINT("\n");
* test_adc_sample_one_channel
static int test_task_one_channel(void)
int ret;
const struct adc_sequence sequence = {
.channels = BIT(ADC_1ST_CHANNEL_ID),
.buffer = m_sample_buffer,
.buffer_size = sizeof(m_sample_buffer),
.resolution = ADC_RESOLUTION,
const struct device *adc_dev = init_adc();
if (!adc_dev) {
return TC_FAIL;
ret = adc_read(adc_dev, &sequence);
zassert_equal(ret, 0, "adc_read() failed with code %d", ret);
check_samples(1);
return TC_PASS;
void test_adc_sample_one_channel(void)
zassert_true(test_task_one_channel() == TC_PASS, NULL);
* test_adc_sample_two_channels
static int test_task_two_channels(void)
int ret;
.channels = BIT(ADC_1ST_CHANNEL_ID) |
BIT(ADC_2ND_CHANNEL_ID),
if (!adc_dev) {
return TC_FAIL;
check_samples(2);
return TC_PASS;
void test_adc_sample_two_channels(void)
zassert_true(test_task_two_channels() == TC_PASS, NULL);
#else
ztest_test_skip();
* test_adc_asynchronous_call
#if defined(CONFIG_ADC_ASYNC)
struct k_poll_signal async_sig;
static int test_task_asynchronous_call(void)
int ret;
const struct adc_sequence_options options = {
.extra_samplings = 4,
/* Start consecutive samplings as fast as possible. */
.interval_us = 0,
.options = &options,
struct k_poll_event async_evt =
K_POLL_EVENT_INITIALIZER(K_POLL_TYPE_SIGNAL,
K_POLL_MODE_NOTIFY_ONLY,
&async_sig);
if (!adc_dev) {
return TC_FAIL;
ret = adc_read_async(adc_dev, &sequence, &async_sig);
zassert_equal(ret, 0, "adc_read_async() failed with code %d", ret);
ret = k_poll(&async_evt, 1, K_MSEC(1000));
zassert_equal(ret, 0, "k_poll failed with error %d", ret);
check_samples(1 + options.extra_samplings);
return TC_PASS;
#endif /* defined(CONFIG_ADC_ASYNC) */
void test_adc_asynchronous_call(void)
zassert_true(test_task_asynchronous_call() == TC_PASS, NULL);
#else
ztest_test_skip();
* test_adc_sample_with_interval
static uint32_t my_sequence_identifier = 0x12345678;
static void *user_data = &my_sequence_identifier;
static enum adc_action sample_with_interval_callback(const struct device *dev,
const struct adc_sequence *sequence,
uint16_t sampling_index)
if (sequence->options->user_data != &my_sequence_identifier) {
user_data = sequence->options->user_data;
return ADC_ACTION_FINISH;
TC_PRINT("%s: sampling %d\n", __func__, sampling_index);
return ADC_ACTION_CONTINUE;
static int test_task_with_interval(void)
int ret;
.interval_us = 100 * 1000UL,
.callback = sample_with_interval_callback,
.user_data = user_data,
if (!adc_dev) {
return TC_FAIL;
zassert_equal(user_data, sequence.options->user_data,
"Invalid user data: %p, expected: %p",
user_data, sequence.options->user_data);
return TC_PASS;
void test_adc_sample_with_interval(void)
zassert_true(test_task_with_interval() == TC_PASS, NULL);
* test_adc_repeated_samplings
static uint8_t m_samplings_done;
static enum adc_action repeated_samplings_callback(const struct device *dev,
++m_samplings_done;
TC_PRINT("%s: done %d\n", __func__, m_samplings_done);
if (m_samplings_done == 1U) {
check_samples(2);
#else
check_samples(1);
/* After first sampling continue normally. */
} else {
check_samples(4);
#else
check_samples(2);
* The second sampling is repeated 9 times (the samples are
* written in the same place), then the sequence is finished
* prematurely.
if (m_samplings_done < 10) {
return ADC_ACTION_REPEAT;
} else {
static int test_task_repeated_samplings(void)
int ret;
.callback = repeated_samplings_callback,
* This specifies that 3 samplings are planned. However,
* the callback function above is constructed in such way
* that the first sampling is done normally, the second one
* is repeated 9 times, and then the sequence is finished.
* Hence, the third sampling will not take place.
.extra_samplings = 2,
.interval_us = 0,
#else
if (!adc_dev) {
return TC_FAIL;
return TC_PASS;
void test_adc_repeated_samplings(void)
zassert_true(test_task_repeated_samplings() == TC_PASS, NULL);
* test_adc_invalid_request
static int test_task_invalid_request(void)
int ret;
.resolution = 0, /* intentionally invalid value */
if (!adc_dev) {
return TC_FAIL;
zassert_not_equal(ret, 0, "adc_read() unexpectedly succeeded");
zassert_not_equal(ret, 0, "adc_read_async() unexpectedly succeeded");
* Make the sequence parameters valid, now the request should succeed.
sequence.resolution = ADC_RESOLUTION;
check_samples(1);
return TC_PASS;
void test_adc_invalid_request(void)
zassert_true(test_task_invalid_request() == TC_PASS, NULL);
5. I called adc sampling functions in repeatitive timer. Is the result of adc from AIN0 and AIN1 be avaialble at same index or at different indices in p_sample_buffer[]
Indexes will be different if both channels are enabled at once and scan mode are used. p_sample_buffer[] will have different values.
Kazi Afroza Sultana
Hi, I tested the program in the attached file. AN0 and AN1 channels configured to sample two anlaog Inputs. The AN0 channel is sampled very well and the ADC result is avaialbale at index 0 of the buffer. The result of AN1 should be available at index 1 of buffer, but remains zero. Please, have a look at the code. If, you test it with any variable voltage at AN0 and AN1, will be better to verify.
#include <zephyr.h>
#include <device.h>
#define ADC_1ST_CHANNEL_INPUT NRF_SAADC_INPUT_AIN0
#define ADC_2ND_CHANNEL_INPUT NRF_SAADC_INPUT_AIN1
const struct device *adc_dev;
.gain = ADC_GAIN,
.gain = ADC_GAIN,
int err;
static int p_sample_buffer[BUFFER_SIZE];
static int adc_sample1(void)
int ret;
.buffer = p_sample_buffer,
.buffer_size = sizeof(p_sample_buffer),
if (!adc_dev) {
return -1;
if (ret) {
// printk("adc_read() failed with code %d\n", ret);
for (int i = 0; i < BUFFER_SIZE; i++) {
// printk("ADC raw value: %d\n", p_sample_buffer[i]);
return ret;
static int adc_sample2(void)
int ret;
.channels = BIT(ADC_2ND_CHANNEL_ID),
if (!adc_dev) {
return -1;
if (ret) {
return ret;
void main()
//ADC setup
if (!adc_dev) {
printk("device_get_binding ADC (=%s) failed\n", ADC_DEVICE_NAME);
err = adc_channel_setup(adc_dev, &m_1st_channel_cfg);
if (err) {
printk("Error in adc AIN0 setup: %d\n", err);
err = adc_channel_setup(adc_dev, &m_2nd_channel_cfg);
if (err) {
printk("Error in adc AIN1 setup: %d\n", err);
NRF_SAADC->TASKS_CALIBRATEOFFSET = 1;
#else
#error "Choose supported board or add new board for the application"
while(1)
{int arr, var1,var2;
err = adc_sample1();
var1 = p_sample_buffer[0];
err = adc_sample2();
var2 = p_sample_buffer[1];
Hello Gulzar,
Sorry for the late reply; I was in sick leave.
How does your overlay file look like?
zephyr,user {
/* adjust channel number according to pinmux in board.dts */
io-channels = <&adc 0>, <&adc 1>;
