nRF52805 OTA DFU not working
Hi
I'm using nRF52805 to realize the DFU function using the buttonless_dfu example project. I follow the instruction of this and use commands in this discussion.
After flashing the hex file into the nRF52805, I can see the Bluetooth signal on the nRF Connect app. But in iOS, it shows this device does not support DFU (attached image below). In Android, it allows me to do the DFU but when I upload the program zip file, it just connects to DFUTARG and stops there.
I have attached my hex file for OTA and commands used for creating these files. Can anyone please help me with this? I am not sure which step is wrong. Thanks in advance
OTA_DFU.zip
    You are using the nRF5 SDK, right?
    Do you see the same services in both iOS and Android?
    Does the log from nRF Connect for Android say anything? Can you paste the log here?
    What does your DFU image contain? What sort of upgrade are you trying to do? Is it just an application, or is it a softdevice upgrade?
    Edvin
  • Hi Edvin,
    Yes, I'm using nRF5 SDK.
    I see different services in iOS. In iOS, it is "Services: Device information".
    The log showed one error "Error 8 (0x8): GATT CONN TIMEOUT". I have attached the log from "nordic_buttonless" and from "DFETARG" here.
    nRF Connect, 2022-02-17
    Nordic_Buttonless (C4:32:0D:4D:4A:1D)
    V	14:02:53.058	Connecting to C4:32:0D:4D:4A:1D...
    D	14:02:53.058	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
    D	14:02:55.028	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
    D	14:02:55.040	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I	14:02:55.040	Connected to C4:32:0D:4D:4A:1D
    V	14:02:55.060	Discovering services...
    D	14:02:55.060	gatt.discoverServices()
    I	14:02:55.454	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    D	14:02:55.535	[Callback] Services discovered with status: 0
    I	14:02:55.535	Services discovered
    V	14:02:55.557	Generic Access (0x1800)
    - Device Name [R W] (0x2A00)
    - Appearance [R] (0x2A01)
    - Peripheral Preferred Connection Parameters [R] (0x2A04)
    - Central Address Resolution [R] (0x2AA6)
    Generic Attribute (0x1801)
    - Service Changed [I] (0x2A05)
       Client Characteristic Configuration (0x2902)
    Secure DFU Service (0xFE59)
    - Buttonless DFU [I W] (8ec90003-f315-4f60-9fb8-838830daea50)
    D	14:02:55.558	gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
    I	14:02:55.625	Connection parameters updated (interval: 48.75ms, latency: 0, timeout: 5000ms)
    I	14:03:00.456	Connection parameters updated (interval: 150.0ms, latency: 0, timeout: 4000ms)
    V	14:05:36.911	[DFU] DFU service started
    V	14:05:36.912	[DFU] Opening file...
    I	14:05:39.982	[DFU] Firmware file opened successfully
    V	14:05:39.983	[DFU] Connecting to DFU target...
    D	14:05:39.984	[DFU] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferredPhy = LE_1M | LE_2M)
    I	14:05:40.021	[DFU] Connected to C4:32:0D:4D:4A:1D
    V	14:05:40.023	[DFU] Discovering services...
    D	14:05:40.023	[DFU] gatt.discoverServices()
    I	14:05:40.032	[DFU] Services discovered
    D	14:05:40.059	[DFU] wait(1000)
    W	14:05:41.049	[DFU] Application with buttonless update found
    V	14:05:41.050	[DFU] Jumping to the DFU Bootloader...
    V	14:05:41.050	[DFU] Enabling indications for 8ec90003-f315-4f60-9fb8-838830daea50
    D	14:05:41.050	[DFU] gatt.setCharacteristicNotification(8ec90003-f315-4f60-9fb8-838830daea50, true)
    D	14:05:41.050	[DFU] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x02-00)
    I	14:05:41.111	[DFU] Data written to descr.8ec90003-f315-4f60-9fb8-838830daea50, value (0x): 02-00
    V	14:05:41.111	[DFU] Notifications enabled for 8ec90003-f315-4f60-9fb8-838830daea50
    A	14:05:41.111	[DFU] Indications enabled
    D	14:05:41.112	[DFU] wait(1000)
    V	14:05:42.133	[DFU] Writing to characteristic 8ec90003-f315-4f60-9fb8-838830daea50
    D	14:05:42.133	[DFU] gatt.writeCharacteristic(8ec90003-f315-4f60-9fb8-838830daea50)
    A	14:05:42.178	[DFU] Enter bootloader sent (Op Code = 1)
    I	14:05:42.178	[DFU] Notification received from 8ec90003-f315-4f60-9fb8-838830daea50, value (0x): 20-01-01
    A	14:05:42.178	[DFU] Response received (Op Code = 1, Status = 1)
    D	14:05:46.362	[Callback] Connection state changed with status: 8 and new state: DISCONNECTED (0)
    E	14:05:46.363	Error 8 (0x8): GATT CONN TIMEOUT
    I	14:05:46.363	Disconnected
    I	14:05:46.364	[DFU] Disconnected by the remote device
    D	14:05:46.397	[DFU] gatt.refresh() (hidden)
    D	14:05:46.397	[DFU] gatt.disconnect()
    D	14:05:46.397	[DFU] gatt.close()
    V	14:05:46.397	[DFU] Scanning for the DFU Bootloader...
    D	14:05:46.397	[Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
    D	14:05:46.403	[DFU] [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
    I	14:05:46.500	[DFU] DFU Bootloader found with address C4:32:0D:4D:4A:1E
    V	14:05:46.514	[DFU] DFU service started
    I	14:05:46.514	[DFU] Firmware file opened successfully
    D	14:05:46.514	[DFU] wait(1000)
    D	14:05:47.514	[DFU] wait(1000)
    V	14:05:48.524	[DFU] Connecting to DFU target...
    D	14:05:48.563	[DFU] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferredPhy = LE_1M | LE_2M)
    I	14:05:48.689	[DFU] Connected to C4:32:0D:4D:4A:1E
    V	14:05:48.689	[DFU] Discovering services...
    D	14:05:48.689	[DFU] gatt.discoverServices()
    D	14:05:48.936	[DFU] [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
    I	14:05:49.488	[DFU] Services discovered
    D	14:05:49.489	[DFU] wait(1000)
    V	14:05:50.486	[DFU] Requesting new MTU...
    D	14:05:50.486	[DFU] gatt.requestMtu(517)
    I	14:05:50.514	[DFU] MTU changed to: 247
    V	14:05:50.514	[DFU] Enabling notifications for 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:50.514	[DFU] gatt.setCharacteristicNotification(8ec90001-f315-4f60-9fb8-838830daea50, true)
    D	14:05:50.514	[DFU] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
    I	14:05:50.524	[DFU] Data written to descr.8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 01-00
    V	14:05:50.524	[DFU] Notifications enabled for 8ec90001-f315-4f60-9fb8-838830daea50
    A	14:05:50.525	[DFU] Notifications enabled
    D	14:05:50.525	[DFU] wait(1000)
    V	14:05:51.612	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:51.612	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:51.612	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 06-01
    I	14:05:51.612	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-06-01-00-02-00-00-00-00-00-00-00-00-00-00
    A	14:05:51.612	[DFU] Command object info received (Max size = 512, Offset = 0, CRC = 00000000)
    I	14:05:51.612	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 02-00-00
    I	14:05:51.612	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-02-01
    A	14:05:51.612	[DFU] Packet Receipt Notif disabled (Op Code = 2, Value = 0)
    I	14:05:51.612	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 01-01-8D-00-00-00
    I	14:05:51.623	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-01-01
    A	14:05:51.623	[DFU] Command object created
    V	14:05:51.623	[DFU] Writing to characteristic 8ec90002-f315-4f60-9fb8-838830daea50
    D	14:05:51.623	[DFU] gatt.writeCharacteristic(8ec90002-f315-4f60-9fb8-838830daea50)
    I	14:05:51.623	[DFU] Data written to 8ec90002-f315-4f60-9fb8-838830daea50, value (0x): 12-8A-01-0A-44-08-01-12-40-08-01-10-34-1A-02-83-02-20-00-28-00-30-00-38-9C-99-03-42-24-08-03-12-20-C3-0C-99-56-96-BA-81-E5-22-28-73-55-72-80-D3-72-2F-EC-1D-BA-29-42-70-F5-86-7E-94-49-19-A3-2C-A8-48-00-52-04-08-01-12-00-10-00-1A-40-61-C0-09-08-32-2B-7D-4B-C0-BD-B5-70-45-E4-2C-1F-58-CD-37-03-07-2D-CA-B0-00-31-4B-8A-BA-2C-1A-F8-55-11-BE-A8-B5-F0-6D-AC-04-A7-E1-52-4C-27-A3-1C-24-DF-C8-29-A3-57-2D-B0-FB-B7-99-4A-C0-69-76-85
    A	14:05:51.624	[DFU] Command object sent (CRC = 9986FC44)
    V	14:05:51.625	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:51.625	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:51.638	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 03
    I	14:05:51.647	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-03-01-8D-00-00-00-44-FC-86-99
    A	14:05:51.648	[DFU] Checksum received (Offset = 141, CRC = 9986FC44)
    V	14:05:51.648	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:51.648	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:51.663	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 04
    I	14:05:51.830	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-04-01
    A	14:05:51.830	[DFU] Command object executed
    V	14:05:51.831	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:51.831	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:51.844	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 06-02
    I	14:05:51.859	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-06-01-00-10-00-00-00-00-00-00-00-00-00-00
    A	14:05:51.860	[DFU] Data object info received (Max size = 4096, Offset = 0, CRC = 00000000)
    V	14:05:51.894	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:51.894	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:51.980	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-01-01
    I	14:05:51.980	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-01-01
    A	14:05:51.981	[DFU] Data object (1/13) created
    D	14:05:51.981	[DFU] wait(400)
    A	14:05:52.382	[DFU] Uploading firmware...
    V	14:05:52.382	[DFU] Sending firmware to characteristic 8ec90002-f315-4f60-9fb8-838830daea50...
    V	14:05:52.458	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:52.458	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:52.715	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 03
    I	14:05:52.728	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-03-01-00-10-00-00-18-47-54-EC
    A	14:05:52.729	[DFU] Checksum received (Offset = 4096, CRC = EC544718)
    V	14:05:52.729	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:52.729	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:52.744	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 04
    I	14:05:52.758	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-04-01
    A	14:05:52.758	[DFU] Data object executed
    V	14:05:52.758	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:52.759	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:52.774	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 01-02-00-10-00-00
    I	14:05:52.788	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-01-01
    A	14:05:52.789	[DFU] Data object (2/13) created
    D	14:05:52.789	[DFU] wait(400)
    A	14:05:53.190	[DFU] Uploading firmware...
    V	14:05:53.190	[DFU] Sending firmware to characteristic 8ec90002-f315-4f60-9fb8-838830daea50...
    V	14:05:53.264	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:53.264	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:53.498	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 03
    I	14:05:53.509	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-03-01-00-20-00-00-41-86-47-86
    A	14:05:53.510	[DFU] Checksum received (Offset = 8192, CRC = 86478641)
    V	14:05:53.510	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:53.510	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:53.555	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 04
    I	14:05:53.556	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-04-01
    A	14:05:53.556	[DFU] Data object executed
    V	14:05:53.556	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:53.557	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:53.570	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 01-02-00-10-00-00
    I	14:05:53.584	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-01-01
    A	14:05:53.584	[DFU] Data object (3/13) created
    D	14:05:53.584	[DFU] wait(400)
    A	14:05:53.985	[DFU] Uploading firmware...
    V	14:05:53.985	[DFU] Sending firmware to characteristic 8ec90002-f315-4f60-9fb8-838830daea50...
    V	14:05:54.077	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:54.077	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:54.484	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-03-01-00-30-00-00-20-A3-FA-8B
    I	14:05:54.484	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-03-01-00-30-00-00-20-A3-FA-8B
    A	14:05:54.484	[DFU] Checksum received (Offset = 12288, CRC = 8BFAA320)
    V	14:05:54.484	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:54.484	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:54.484	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 04
    I	14:05:54.484	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-04-01
    A	14:05:54.484	[DFU] Data object executed
    I	14:05:54.484	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 01-02-00-10-00-00
    I	14:05:54.484	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-01-01
    A	14:05:54.484	[DFU] Data object (4/13) created
    D	14:05:54.484	[DFU] wait(400)
    A	14:05:54.793	[DFU] Uploading firmware...
    V	14:05:54.793	[DFU] Sending firmware to characteristic 8ec90002-f315-4f60-9fb8-838830daea50...
    V	14:05:54.889	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:54.889	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:55.191	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 03
    I	14:05:55.203	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-03-01-00-40-00-00-67-F1-2F-55
    A	14:05:55.204	[DFU] Checksum received (Offset = 16384, CRC = 552FF167)
    V	14:05:55.204	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:55.205	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:55.234	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 04
    I	14:05:55.249	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-04-01
    A	14:05:55.249	[DFU] Data object executed
    V	14:05:55.249	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:55.250	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:55.264	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 01-02-00-10-00-00
    I	14:05:55.279	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-01-01
    A	14:05:55.279	[DFU] Data object (5/13) created
    D	14:05:55.279	[DFU] wait(400)
    A	14:05:55.679	[DFU] Uploading firmware...
    V	14:05:55.680	[DFU] Sending firmware to characteristic 8ec90002-f315-4f60-9fb8-838830daea50...
    V	14:05:55.745	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:55.745	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:55.995	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 03
    I	14:05:55.995	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-03-01-00-50-00-00-A4-BE-70-A0
    A	14:05:55.995	[DFU] Checksum received (Offset = 20480, CRC = A070BEA4)
    V	14:05:55.995	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:55.995	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:56.027	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 04
    I	14:05:56.027	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-04-01
    A	14:05:56.027	[DFU] Data object executed
    V	14:05:56.027	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:56.027	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:56.107	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 01-02-00-10-00-00
    I	14:05:56.107	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-01-01
    A	14:05:56.107	[DFU] Data object (6/13) created
    D	14:05:56.107	[DFU] wait(400)
    A	14:05:56.475	[DFU] Uploading firmware...
    V	14:05:56.476	[DFU] Sending firmware to characteristic 8ec90002-f315-4f60-9fb8-838830daea50...
    V	14:05:56.529	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:56.529	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:56.809	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-03-01-00-60-00-00-92-95-4D-5B
    I	14:05:56.810	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-03-01-00-60-00-00-92-95-4D-5B
    A	14:05:56.810	[DFU] Checksum received (Offset = 24576, CRC = 5B4D9592)
    V	14:05:56.810	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:56.810	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:56.823	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 04
    I	14:05:56.838	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-04-01
    A	14:05:56.838	[DFU] Data object executed
    V	14:05:56.838	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:56.838	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:56.854	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 01-02-00-10-00-00
    I	14:05:56.884	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-01-01
    A	14:05:56.884	[DFU] Data object (7/13) created
    D	14:05:56.884	[DFU] wait(400)
    A	14:05:57.286	[DFU] Uploading firmware...
    V	14:05:57.286	[DFU] Sending firmware to characteristic 8ec90002-f315-4f60-9fb8-838830daea50...
    V	14:05:57.322	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:57.322	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:57.605	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 03
    I	14:05:57.605	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-03-01-00-70-00-00-70-B0-DC-29
    A	14:05:57.605	[DFU] Checksum received (Offset = 28672, CRC = 29DCB070)
    V	14:05:57.605	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:57.605	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:57.638	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 04
    I	14:05:57.638	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-04-01
    A	14:05:57.638	[DFU] Data object executed
    V	14:05:57.638	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:57.638	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:57.671	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 01-02-00-10-00-00
    I	14:05:57.671	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-01-01
    A	14:05:57.671	[DFU] Data object (8/13) created
    D	14:05:57.671	[DFU] wait(400)
    A	14:05:58.083	[DFU] Uploading firmware...
    V	14:05:58.083	[DFU] Sending firmware to characteristic 8ec90002-f315-4f60-9fb8-838830daea50...
    V	14:05:58.086	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:58.086	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:58.382	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 03
    I	14:05:58.382	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-03-01-00-80-00-00-6F-7B-80-62
    A	14:05:58.382	[DFU] Checksum received (Offset = 32768, CRC = 62807B6F)
    V	14:05:58.382	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:58.382	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:58.397	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 04
    I	14:05:58.397	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-04-01
    A	14:05:58.397	[DFU] Data object executed
    V	14:05:58.397	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:58.397	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:58.429	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 01-02-00-10-00-00
    I	14:05:58.429	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-01-01
    A	14:05:58.429	[DFU] Data object (9/13) created
    D	14:05:58.429	[DFU] wait(400)
    A	14:05:58.838	[DFU] Uploading firmware...
    V	14:05:58.838	[DFU] Sending firmware to characteristic 8ec90002-f315-4f60-9fb8-838830daea50...
    V	14:05:58.886	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:58.887	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:59.153	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 03
    I	14:05:59.153	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-03-01-00-90-00-00-AF-89-EB-74
    A	14:05:59.153	[DFU] Checksum received (Offset = 36864, CRC = 74EB89AF)
    V	14:05:59.153	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:59.153	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:59.168	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 04
    I	14:05:59.186	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-04-01
    A	14:05:59.186	[DFU] Data object executed
    V	14:05:59.186	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:59.186	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:59.202	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 01-02-00-10-00-00
    I	14:05:59.222	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-01-01
    A	14:05:59.222	[DFU] Data object (10/13) created
    D	14:05:59.222	[DFU] wait(400)
    A	14:05:59.632	[DFU] Uploading firmware...
    V	14:05:59.632	[DFU] Sending firmware to characteristic 8ec90002-f315-4f60-9fb8-838830daea50...
    V	14:05:59.672	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:59.672	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:59.923	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 03
    I	14:05:59.928	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-03-01-00-A0-00-00-97-52-A4-98
    A	14:05:59.928	[DFU] Checksum received (Offset = 40960, CRC = 98A45297)
    V	14:05:59.928	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:59.928	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:59.943	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 04
    I	14:05:59.957	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-04-01
    A	14:05:59.957	[DFU] Data object executed
    V	14:05:59.958	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:05:59.958	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:59.973	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 01-02-00-10-00-00
    I	14:05:59.988	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-01-01
    A	14:05:59.988	[DFU] Data object (11/13) created
    D	14:05:59.988	[DFU] wait(400)
    A	14:06:00.389	[DFU] Uploading firmware...
    V	14:06:00.389	[DFU] Sending firmware to characteristic 8ec90002-f315-4f60-9fb8-838830daea50...
    V	14:06:00.446	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:06:00.446	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:06:00.695	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 03
    I	14:06:00.707	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-03-01-00-B0-00-00-C5-68-6F-F3
    A	14:06:00.707	[DFU] Checksum received (Offset = 45056, CRC = F36F68C5)
    V	14:06:00.707	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:06:00.707	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:06:00.722	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 04
    I	14:06:00.737	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-04-01
    A	14:06:00.737	[DFU] Data object executed
    V	14:06:00.737	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:06:00.737	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:06:00.753	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 01-02-00-10-00-00
    I	14:06:00.767	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-01-01
    A	14:06:00.767	[DFU] Data object (12/13) created
    D	14:06:00.767	[DFU] wait(400)
    A	14:06:01.167	[DFU] Uploading firmware...
    V	14:06:01.167	[DFU] Sending firmware to characteristic 8ec90002-f315-4f60-9fb8-838830daea50...
    V	14:06:01.207	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:06:01.207	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:06:01.489	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 03
    I	14:06:01.502	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-03-01-00-C0-00-00-DC-EC-36-A3
    A	14:06:01.502	[DFU] Checksum received (Offset = 49152, CRC = A336ECDC)
    V	14:06:01.502	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:06:01.502	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:06:01.517	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 04
    I	14:06:01.532	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-04-01
    A	14:06:01.532	[DFU] Data object executed
    V	14:06:01.532	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:06:01.532	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:06:01.547	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 01-02-9C-0C-00-00
    I	14:06:01.565	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-01-01
    A	14:06:01.565	[DFU] Data object (13/13) created
    D	14:06:01.565	[DFU] wait(400)
    A	14:06:01.962	[DFU] Uploading firmware...
    V	14:06:01.962	[DFU] Sending firmware to characteristic 8ec90002-f315-4f60-9fb8-838830daea50...
    V	14:06:01.998	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:06:01.998	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:06:02.209	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 03
    I	14:06:02.209	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-03-01-9C-CC-00-00-F8-89-DE-46
    A	14:06:02.209	[DFU] Checksum received (Offset = 52380, CRC = 46DE89F8)
    V	14:06:02.209	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
    D	14:06:02.209	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:06:02.237	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 04
    I	14:06:02.657	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-04-01
    A	14:06:02.657	[DFU] Data object executed
    A	14:06:02.657	[DFU] Upload completed in 10791 ms
    I	14:06:03.070	[DFU] Disconnected by the remote device
    D	14:06:03.070	[DFU] gatt.refresh() (hidden)
    D	14:06:03.070	[DFU] gatt.disconnect()
    D	14:06:03.070	[DFU] gatt.close()
    D	14:06:03.124	[DFU] wait(1400)
    D	14:06:03.160	[DFU] [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
    D	14:06:04.481	gatt.close()
    D	14:06:04.482	wait(200)
    V	14:06:04.683	Connecting to C4:32:0D:4D:4A:1D...
    D	14:06:04.683	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
    D	14:06:05.232	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
    D	14:06:05.241	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I	14:06:05.241	Connected to C4:32:0D:4D:4A:1D
    V	14:06:05.260	Discovering services...
    D	14:06:05.260	gatt.discoverServices()
    I	14:06:05.672	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    D	14:06:05.743	[Callback] Services discovered with status: 0
    I	14:06:05.743	Services discovered
    V	14:06:05.757	Generic Access (0x1800)
    D	14:06:05.757	gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
    I	14:06:05.855	Connection parameters updated (interval: 48.75ms, latency: 0, timeout: 5000ms)
    I	14:06:11.136	Connection parameters updated (interval: 150.0ms, latency: 0, timeout: 4000ms)
    DfuTarg (C4:32:0D:4D:4A:1E)
    D	14:05:48.688	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
    V	14:05:48.938	Connecting to C4:32:0D:4D:4A:1E...
    D	14:05:48.939	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, opportunistic = true, preferred PHY = LE 1M) (hidden)
    D	14:05:48.950	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I	14:05:48.950	Connected to C4:32:0D:4D:4A:1E
    V	14:05:49.009	Discovering services...
    D	14:05:49.009	gatt.discoverServices()
    I	14:05:49.400	Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 6000ms)
    D	14:05:49.476	[Callback] Services discovered with status: 0
    I	14:05:49.476	Services discovered
    V	14:05:49.498	Generic Access (0x1800)
    - DFU Packet [WNR] (8ec90002-f315-4f60-9fb8-838830daea50)
    - DFU Control Point [N W] (8ec90001-f315-4f60-9fb8-838830daea50)
    I	14:05:49.540	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    I	14:05:49.622	Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 6000ms)
    D	14:06:03.064	[Callback] Connection state changed with status: 19 and new state: DISCONNECTED (0)
    W	14:06:03.064	Connection terminated by peer (status 19)
    I	14:06:03.064	Disconnected
    D	14:06:03.124	[Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
    For now, I just use the example ble_app_buttonless_dfu in the ble_peripheral folder. I would like to upgrade the application firmware in the future. But I have not reached that far yet. I just flash the merged file and it does not work as DFU. Please see my attached hex file in the initial post. Maybe you can try that hex file and see whether it work or not?
  • What do you see if you press the "Client" tab in iOS? What I wanted to see is whether the iphone has cached some old services, or if it sees the buttonless_dfu service.
    Usually at this point I would ask you to try to enable logging on the nRF, especially since it looks like the nRF Disconnects. However, the nRF52805 is very limited on flash, so I don't think you would be able to do so.
    I was able to test using nrfutil, nRF Connect for Desktop -> Bluetooth Low Energy and nRF Connect for iOS, and I managed to perform the DFU on all three using the SD, BL, BL-settings and APP that you provided. (I don't have an Android phone to test with).
    What HW are you running on?
    Do you have the possibility to test using either nrfutil or nRF Connect for Desktop (requires an additional DK/Dongle).
    I didn't manage to get your merged file to work (It didn't advertise on my end), but I flashed the bootloader-settings.hex, nordic_buttonless_dfu.hex, s112_nrf52_7.2.0_softdevice.hex and secure_bootloader.hex, and the attached dfu_test.zip file:
    1780.dfu_test.zip
    which is generated using the command:
    nrfutil pkg generate --application nordic_buttonless_dfu.hex --application-version 4 --sd-req 0x0103 --hw-version 52 --key-file private.key dfu_test.zip
    What nrfutil version do you use?
    And again, what does it say under the "client" tab on the iPhone?
    Edvin
  • Hi Edvin
    Yes, the iPhone showed the old service that I uploaded before.
    But I do clean the chip every time I flash the buttonless dfu example using this command.
    nrfjprog --eraseall -f NRF52
    I am not sure what HW you ask for. I am using my own customized nRF52805 board and using nRF 52 DK as the media to flash the firmware into nRF52805. The SDK I am using is nRF5_SDK_17.1.0_ddde560 and s112_nrf52_7.2.0_softdevice. For generating DFU zip file I used the command --hw-version 52. The whole command is
    nrfutil pkg generate --hw-version 52 --application-version 1 --application customize_app.hex --sd-req 0x0103 --key-file private.key customize_app.zip
    Since the board is customized so that i made some changes in secure_bootloader and ble_app_buttonless_dfu shown below:
    This is the extra setting for secure_bootloader. I enable the buttonless and disable the DFU_button
    // <o> NRF_SDH_CLOCK_LF_SRC  - SoftDevice clock source.
    // <0=> NRF_CLOCK_LF_SRC_RC
    // <1=> NRF_CLOCK_LF_SRC_XTAL
    // <2=> NRF_CLOCK_LF_SRC_SYNTH
    #define NRF_SDH_CLOCK_LF_SRC 0
    // <o> NRF_SDH_CLOCK_LF_RC_CTIV - SoftDevice calibration timer interval.
    #define NRF_SDH_CLOCK_LF_RC_CTIV 16
    // <o> NRF_SDH_CLOCK_LF_RC_TEMP_CTIV - SoftDevice calibration timer interval under constant temperature.
    // <i> How often (in number of calibration intervals) the RC oscillator shall be calibrated
    // <i>  if the temperature has not changed.
    #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2
    // <o> NRF_SDH_CLOCK_LF_ACCURACY  - External clock accuracy used in the LL to compute timing.
    // <0=> NRF_CLOCK_LF_ACCURACY_250_PPM
    // <1=> NRF_CLOCK_LF_ACCURACY_500_PPM
    // <2=> NRF_CLOCK_LF_ACCURACY_150_PPM
    // <3=> NRF_CLOCK_LF_ACCURACY_100_PPM
    // <4=> NRF_CLOCK_LF_ACCURACY_75_PPM
    // <5=> NRF_CLOCK_LF_ACCURACY_50_PPM
    // <6=> NRF_CLOCK_LF_ACCURACY_30_PPM
    // <7=> NRF_CLOCK_LF_ACCURACY_20_PPM
    // <8=> NRF_CLOCK_LF_ACCURACY_10_PPM
    // <9=> NRF_CLOCK_LF_ACCURACY_5_PPM
    // <10=> NRF_CLOCK_LF_ACCURACY_2_PPM
    // <11=> NRF_CLOCK_LF_ACCURACY_1_PPM
    #define NRF_SDH_CLOCK_LF_ACCURACY 1
    // <e> NRF_BL_DFU_ENTER_METHOD_BUTTON - Enter DFU mode on button press.
    #define NRF_BL_DFU_ENTER_METHOD_BUTTON 0
    // <q> NRF_BL_DFU_ENTER_METHOD_BUTTONLESS  - Enter DFU mode when the Boolean enter_buttonless_dfu in DFU settings is true.
    #define NRF_BL_DFU_ENTER_METHOD_BUTTONLESS 1
    // <i> Whether to check the incoming version against the version of the existing app and/or
    // <i> the incoming SoftDevice requirements against the existing SoftDevice.
    // <i> This applies to application updates, and possibly to SoftDevice updates.
    // <i> Disabling this causes the checks to always ignore the incoming firmware version and
    // <i> to ignore the SoftDevice requirements if the first requirement is 0.
    // <i> This does not apply the bootloader updates. If the bootloader depends on the SoftDevice
    // <i> e.g. for BLE transport, this does not apply to SoftDevice updates.
    // <i> See @ref lib_bootloader_dfu_validation for more information.
    // <i> When signed updates are required, version checking should always be enabled.
    #define NRF_DFU_APP_DOWNGRADE_PREVENTION 0
    Below is my setting about ble_app_buttonless_dfu. Mainly about clock setting.
    // <o> NRFX_CLOCK_CONFIG_LF_SRC  - LF Clock Source
    // <0=> RC
    // <1=> XTAL
    // <2=> Synth
    // <131073=> External Low Swing
    // <196609=> External Full Swing
    #define NRFX_CLOCK_CONFIG_LF_SRC 0
    // <o> CLOCK_CONFIG_LF_SRC  - LF Clock Source
    // <0=> RC
    // <1=> XTAL
    // <2=> Synth
    #define CLOCK_CONFIG_LF_SRC 0
    I have one nRF 52 DK but I am not sure how to test the DFU using nrfutil or nRF Connect for Desktop. Could you give me any link about testing, please?
    I have tried the process in this link. So instead of merging hex files altogether. I just flashed in softdevice and secure bootloader. I did see the DFUTARG and successfully upload the ble_app_buttonless_dfu zip file and see a new application. However, after successfully uploading the zip file, I cannot use DFU just like I flashed the merge file, while I suppose in the ble_app_buttonless_dfu application, I should still be able to use DFU(I tried the zip you attached as well. the same result). So I think the secure_bootloader is alright. But it is not properly merged with the application so we cannot see DFU in the mobile end?
    my nrfutil version 6.1.3
    Really thank you for your help.
    Best regards
    Jeremy
  • Hello Jeremy,
    It is the phone that stores the services. So even though they do not exist on the nRF, the phone still thinks they are there.
    Try to disable bluetooth properly from the iphone's settings menu (not just the pull up menu from home screen), and wait a couple of minutes before turning it back on. Sometimes this helps the phone forget the old services.
    To use either nrfutil or nRF Connect for Desktop for DFU, you need an extra nRF52 DK or nRF52 Dongle. Perhaps you can use the one you already have, but you need to detatch the debugger from your custom nRF52805 board when doing so, so that the computer can use the nRF52 on the DK.
    I agree that it sounds like the bootloader is working, but there is something about the application, then. However, on my end I was able to run DFU after flashing BL-settings, BL, APP and SD (using an nRF52805 board).
    To perform the DFU using nrfutil, first I connected two boards, one as the nRF52805 debugger, and the other as the nrfutil connectivity board. I started by erasing both devices using "nrfjprog -e"
    First I flashed the 805 using:
    nrfjprog --program bootloader-settings.hex --verify
    nrfjprog --program nordic_buttonless_dfu.hex --verify
    nrfjprog --program s112_nrf52_7.2.0_softdevice.hex --verify
    nrfjprog --program secure_bootloader.hex --verify
    nrfjprog --reset
    And then, to perform the DFU, use the command:
    nrfutil dfu ble -pkg dfu_test.zip -ic NRF52 -p COM5 -n "Nordic_Buttonless_" -f
    (COM5 refers to the COM port where the connectivity bard is connected. So not the DK that the debugger for the nRF52805 is connected).
    The .zip packet is the one that I sent in the previous reply.
    Try that, and let me know what it says.
