I have an application where I need to count clock cycles on a GPIO input. I'm configuring a GPIOTE channel N to generate an IN EVENT on rising edge of an input GPIO PIN (the clock signal) and then publishing the IN EVENT to a DPPI channel that is triggering the COUNT TASK of a TIMER that is configured in Counter mode.
This implementation works perfectly as long as the clock is not too high in frequency. For example, when the clock is 48 kHz my counter accurately counts the clock cycles. At higher frequencies (e.g. 3 MHz) the Counter is only capturing about 2/3 of the clock cycles. At much higher frequencies (e.g. 12 MHz), the Counter doesn't capture any clock cycles.
In the nRF5340 product spec, the GPIOTE section references a spec for minimum hold time when operating in Low-Latency mode (tGPIOTE,HOLD,LL) but the Electrical Specification section for the GPIOTE module is empty.
My question is what is the value of tGPIOTE,HOLD,LL? Or alternately, what is the maximum frequency of an input signal in order to reliably generate the IN EVENT in the GPIOTE module?
Thank you
Kevin Doss, Shure, Inc.
