how to do a connectable BLE with beacon
hello everyone,
in my project i need to advertise the sensor data as well as connecting the BLE TAG . in detail i am using nrf52810 with mpu6050 and i want read the accelerometer and Gyro-meter , battery data which i need to advertise in the nrf connect mobile application and also whenever necessary i want to connect BLE and change the angle of Gyro-meter since i am using ble_app_template example source code and i could not advertise the data please help me to resolve this problem . for more information please find the below attachment of my code .
thank you.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include <math.h>
#include <stdio.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "fds.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "bsp_btn_ble.h"
#include "sensorsim.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "ble_cus.h"
#define DEVICE_NAME                     "vendor"                       /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME               "temp"                   /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL                #include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nrf.h"
#include "ble.h"
#include "fds.h"
#define DEVICE_NAME                     "Nordic_Template"                       /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME               "NordicSemiconductor"                   /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL                1600                                     /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
//#define APP_ADV_DURATION                18000                                   /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.1 seconds). */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.2 second). */
#define SLAVE_LATENCY                   0                                       /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                   /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                  /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
#define NOTIFICATION_INTERVAL           APP_TIMER_TICKS(1000)
#define SEC_PARAM_BOND                  1                                       /**< Perform bonding. */
#define SEC_PARAM_MITM                  0                                       /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                  0                                       /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS              0                                       /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
#define SEC_PARAM_OOB                   0                                       /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                       /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                      /**< Maximum encryption key size. */
#define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
char a[10];
NRF_BLE_GATT_DEF(m_gatt);
NRF_BLE_QWR_DEF(m_qwr);                                                         /**< GATT module instance. */
BLE_CUS_DEF(m_cus);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                             /**< Advertising module instance. */
APP_TIMER_DEF(m_notification_timer_id);
static uint8_t m_custom_value = 0;
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
/* YOUR_JOB: Declare all services structure your application is using
 *  BLE_XYZ_DEF(m_xyz);
// YOUR_JOB: Use UUIDs for service(s) used in your application.
static ble_uuid_t m_adv_uuids[] =                                               /**< Universally unique service identifiers. */
    {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE},
    {CUSTOM_SERVICE_UUID_BASE, BLE_UUID_TYPE_BLE },
APP_TIMER_DEF(m_adv_data_update_timer);
#define ADV_DATA_UPDATE_INTERVAL        APP_TIMER_TICKS(1000)
#define MANUF_PAYLOAD_1                 0x4E    // N
#define MANUF_PAYLOAD_2                 0x4F    // O
#define MANUF_PAYLOAD_3                 0x52    // R
#define MANUF_PAYLOAD_4                 0x44    // D
#define MANUF_PAYLOAD_5                 0x49    // I
#define MANUF_PAYLOAD_6                 0x43    // C
#define PAYLOAD_SIZE                    21
#define TOP_INDEX                       0
#define APP_COMPANY_IDENTIFIER          0x0059                                  /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
#define LED   NRF_GPIO_PIN_MAP(0,18)
static ble_advdata_t                    new_advdata;
static uint8_t manufacturing_data_payload_list [] =
    0x02, 0x01, 0x06, 0x03, 0x03, 0x34, 0x12, 0x0d, 0x16, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
    //MANUF_PAYLOAD_1,
    //MANUF_PAYLOAD_2,
    //MANUF_PAYLOAD_3,
    //MANUF_PAYLOAD_4,
    //MANUF_PAYLOAD_5,
    //MANUF_PAYLOAD_6
static void advertising_start(bool erase_bonds);
#include "nrf.h"
#include "nrf_drv_gpiote.h"
#include "boards.h"
int f_flag=0;
int s_flag=0;
#define BUT   NRF_GPIO_PIN_MAP(0,14)
//00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
#include <stdio.h>
#include "boards.h"
#include "nrf_drv_twi.h"
#include "mpu6050.h"
/* TWI instance ID. */
#define TWI_INSTANCE_ID     0 // create a ID constant
// create a handle which will point to TWI instance, in this case its TWI_0
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
// a function to initialize the twi(i2c)
void twi_init(void)
  ret_code_t err_code; // a variable to hold error code
// Create a struct with configurations and pass the values to these configurations.
  const nrf_drv_twi_config_t twi_config = {
    .scl                = 17, // scl connected to pin 22, you can change it to any other pin
    .sda                = 16, // sda connected to pin 23, you can change it to any other pin
    .frequency          = NRF_DRV_TWI_FREQ_100K, // set the communication speed to 100K, we can select 250k or 400k as well
    .interrupt_priority = APP_IRQ_PRIORITY_HIGH, // Interrupt priority is set to high, keep in mind to change it if you are using a soft-device
    .clear_bus_init     = false // automatic bus clearing
  err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL); // initialize the twi
  APP_ERROR_CHECK(err_code); // check if any error occured during initialization
  nrf_drv_twi_enable(&m_twi); // enable the twi comm so that its ready to communicate with the sensor
//0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
//buzz
#define buz   NRF_GPIO_PIN_MAP(0,3)
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in] line_num   Line number of the failing ASSERT call.
 * @param[in] file_name  File name of the failing ASSERT call.
static void adv_data_update_timer_handler(void * p_context)
    ble_advdata_manuf_data_t    manuf_data;
    new_advdata.p_manuf_specific_data = &manuf_data;
    static uint8_t payload_index = 0;
    NRF_LOG_INFO("Updating advertising data!");
    manuf_data.company_identifier = APP_COMPANY_IDENTIFIER;
    manuf_data.data.p_data = manufacturing_data_payload_list + payload_index;
    manuf_data.data.size = PAYLOAD_SIZE;
    err_code = ble_advertising_advdata_update(&m_advertising, &new_advdata, NULL);
    if(payload_index == TOP_INDEX)
        payload_index = 0;
        payload_index++;
    NRF_LOG_INFO("Advertising data updated!");
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    switch (p_evt->evt_id)
        case PM_EVT_BONDED_PEER_CONNECTED:
            NRF_LOG_INFO("Connected to a previously bonded device.");
        } break;
        case PM_EVT_CONN_SEC_SUCCEEDED:
            NRF_LOG_INFO("Connection secured: role: %d, conn_handle: 0x%x, procedure: %d.",
                         ble_conn_state_role(p_evt->conn_handle),
                         p_evt->conn_handle,
                         p_evt->params.conn_sec_succeeded.procedure);
        } break;
        case PM_EVT_CONN_SEC_FAILED:
            /* Often, when securing fails, it shouldn't be restarted, for security reasons.
             * Other times, it can be restarted directly.
             * Sometimes it can be restarted, but only after changing some Security Parameters.
             * Sometimes, it cannot be restarted until the link is disconnected and reconnected.
             * Sometimes it is impossible, to secure the link, or the peer device does not support it.
             * How to handle this error is highly application dependent. */
        } break;
        case PM_EVT_CONN_SEC_CONFIG_REQ:
            // Reject pairing request from an already bonded peer.
            pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
            pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
        } break;
        case PM_EVT_STORAGE_FULL:
            // Run garbage collection on the flash.
            err_code = fds_gc();
            if (err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
                // Retry.
        } break;
            advertising_start(false);
        } break;
        case PM_EVT_PEER_DATA_UPDATE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error);
        } break;
        case PM_EVT_PEER_DELETE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error);
        } break;
        case PM_EVT_PEERS_DELETE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error);
        } break;
        case PM_EVT_ERROR_UNEXPECTED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
        } break;
        case PM_EVT_CONN_SEC_START:
        case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
        case PM_EVT_PEER_DELETE_SUCCEEDED:
        case PM_EVT_LOCAL_DB_CACHE_APPLIED:
        case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
            // This can happen when the local DB has changed.
        case PM_EVT_SERVICE_CHANGED_IND_SENT:
        case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
/**@brief Function for handling the Battery measurement timer timeout.
 * @details This function will be called each time the battery level measurement timer expires.
 * @param[in] p_context  Pointer used for passing some arbitrary information (context) from the
 *                       app_start_timer() call to the timeout handler.
static void notification_timeout_handler(void * p_context)
    UNUSED_PARAMETER(p_context);
    // Increment the value of m_custom_value before nortifing it.
    m_custom_value++;
    err_code = ble_cus_custom_value_update(&m_cus, m_custom_value);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    // Initialize timer module.
    err_code = app_timer_init();
    // Create timers.
    err_code = app_timer_create(&m_notification_timer_id, APP_TIMER_MODE_REPEATED, notification_timeout_handler);
    err_code = app_timer_create(&m_adv_data_update_timer,
                                  adv_data_update_timer_handler);
    /* YOUR_JOB: Create any timers to be used by the application.
                 Below is an example of how to create a timer.
                 For every new timer needed, increase the value of the macro APP_TIMER_MAX_TIMERS by
                 one.
       err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
       APP_ERROR_CHECK(err_code); */
       //ret_code_t err_code;
//static void timers_init(void)
//    ret_code_t err_code;
//    err_code = app_timer_init();
//    APP_ERROR_CHECK(err_code);
//    err_code = app_timer_create(&m_adv_data_update_timer,
//                                  APP_TIMER_MODE_REPEATED,
//                                  adv_data_update_timer_handler);
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    /* YOUR_JOB: Use an appearance value matching the application's use case.
       err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the YYY Service events.
 * YOUR_JOB implement a service handler function depending on the event the service you are using can generate
 * @details This function will be called for all YY Service events which are passed to
 *          the application.
 * @param[in]   p_yy_service   YY Service structure.
 * @param[in]   p_evt          Event received from the YY Service.
static void on_yys_evt(ble_yy_service_t     * p_yy_service,
                       ble_yy_service_evt_t * p_evt)
    switch (p_evt->evt_type)
        case BLE_YY_NAME_EVT_WRITE:
            APPL_LOG("[APPL]: charact written with value %s. ", p_evt->params.char_xx.value.p_str);
            // No implementation needed.
/**@brief Function for handling the Custom Service Service events.
 * @details This function will be called for all Custom Service events which are passed to
 *          the application.
 * @param[in]   p_cus_service  Custom Service structure.
 * @param[in]   p_evt          Event received from the Custom Service.
static void on_cus_evt(ble_cus_t     * p_cus_service,
                       ble_cus_evt_t * p_evt)
    switch(p_evt->evt_type)
        case BLE_CUS_EVT_NOTIFICATION_ENABLED:
             err_code = app_timer_start(m_notification_timer_id, NOTIFICATION_INTERVAL, NULL);
        case BLE_CUS_EVT_NOTIFICATION_DISABLED:
            err_code = app_timer_stop(m_notification_timer_id);
        case BLE_CUS_EVT_CONNECTED:
        case BLE_CUS_EVT_DISCONNECTED:
        nrf_ble_qwr_init_t  qwr_init = {0};
        ble_cus_init_t      cus_init = {0};
         // Initialize CUS Service init structure to zero.
        cus_init.evt_handler                = on_cus_evt;
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.cccd_write_perm);
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.write_perm);
        err_code = ble_cus_init(&m_cus, &cus_init);
    /* YOUR_JOB: Add code to initialize the services used by the application.
       ble_xxs_init_t                     xxs_init;
       ble_yys_init_t                     yys_init;
       // Initialize XXX Service.
       memset(&xxs_init, 0, sizeof(xxs_init));
       xxs_init.evt_handler                = NULL;
       xxs_init.is_xxx_notify_supported    = true;
       xxs_init.ble_xx_initial_value.level = 100;
       err_code = ble_bas_init(&m_xxs, &xxs_init);
       // Initialize YYY Service.
       memset(&yys_init, 0, sizeof(yys_init));
       yys_init.evt_handler                  = on_yys_evt;
       yys_init.ble_yy_initial_value.counter = 0;
       err_code = ble_yy_service_init(&yys_init, &yy_init);
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
/**@brief Function for handling a Connection Parameters error.
/**@brief Function for starting timers.
//static void application_timers_start(void)
       err_code = app_timer_start(m_adv_data_update_timer,
                                    ADV_DATA_UPDATE_INTERVAL,
                                    NULL);
    // Prepare wakeup buttons.
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising.");
        case BLE_ADV_EVT_IDLE:
            //sleep_mode_enter();
    ret_code_t err_code = NRF_SUCCESS;
            NRF_LOG_INFO("Disconnected.");
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected.");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
 * @param[in]   event   Event generated when button is pressed.
static void bsp_event_handler(bsp_event_t event)
    switch (event)
        case BSP_EVENT_SLEEP:
            break; // BSP_EVENT_SLEEP
        case BSP_EVENT_DISCONNECT:
            break; // BSP_EVENT_DISCONNECT
        case BSP_EVENT_WHITELIST_OFF:
            break; // BSP_EVENT_KEY_0
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;//continues advertising
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    //init.config.ble_adv_fast_timeout  = APP_ADV_DURATION;
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
        nrf_pwr_mgmt_run();
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
        ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
int power=0;
void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
     int counter=0;
      _Bool repeat=0;
      uint32_t error_code;
    //nrf_drv_gpiote_out_toggle(PIN_OUT);
    if(f_flag==1 || s_flag==1)
      nrf_gpio_pin_clear(LED);
      f_flag=0;
      s_flag=0;
      nrf_gpio_pin_clear(buz);
      ags_init();
      manufacturing_data_payload_list[16]=0x00;
      manufacturing_data_payload_list[17]=0x00;
      manufacturing_data_payload_list[18]=0x00;
      manufacturing_data_payload_list[19]=0x00;
      manufacturing_data_payload_list[20]=0x00;
      // adv_time=adv_time_m0;
    else if (f_flag==0)
      f_flag=1;
      nrf_gpio_pin_set(LED);
      //s_flag=1;
      //nrf_gpio_pin_set(buz);
      manufacturing_data_payload_list[20]=0x02;
      //ags_init();
      // adv_time=adv_time_m1;
      ////nrf_drv_gpiote_out_toggle(PIN_OUT);
      //while(nrf_gpio_pin_read(BUT)==0 )
      //        counter++;
      //        if(counter>10000000&&power==0)
      //            power=1;
      //            counter=0;
      //            uint32_t err_code;
      //            //  error_code= sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
      //            //   //m_conn_handle = BLE_CONN_HANDLE_INVALID ;
      //            ////  APP_ERROR_CHECK(error_code);
      //            error_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_IDLE);
      //            // //  APP_ERROR_CHECK(error_code);
      //            error_code= sd_ble_gap_adv_stop(m_advertising.adv_handle);
      //            //nrf_gpio_pin_set(LED_RED);
      //            //nrf_delay_ms(100);
      //            //nrf_gpio_pin_clear(LED_RED);
      //            nrf_gpio_cfg_sense_set(BUT,NRF_GPIO_PIN_SENSE_LOW);
      //            sd_app_evt_wait();
      //            repeat=1;
      //            //sd_power_system_off();
      //            break;
      //        else if(counter>10000000&&power==1)
      //            //nrf_gpio_cfg_sense_set(BUTTON,NRF_GPIO_PIN_SENSE_LOW);
      //            counter=0;
      //            power=0;
      //            repeat=1;
      //            uint32_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
      //            //for(int i=0;i<2;i++)
      //            //    nrf_gpio_pin_set(LED_RED);
      //            //    nrf_delay_ms(100);
      //            //    nrf_gpio_pin_clear(LED_RED);
      //            break;
      //if(counter<10000000&&power==0)
      // while(nrf_gpio_pin_read(BUTTON)==0);
 * @brief Function for configuring: PIN_IN pin for input, PIN_OUT pin for output,
 * and configures GPIOTE to give an interrupt on pin change.
static void gpio_init(void)
    nrf_drv_gpiote_init();
    //nrf_drv_gpiote_out_config_t out_config = GPIOTE_CONFIG_OUT_SIMPLE(false);
    //err_code = nrf_drv_gpiote_out_init(PIN_OUT, &out_config);
    //APP_ERROR_CHECK(err_code);
    nrf_drv_gpiote_in_config_t in_config = NRFX_GPIOTE_CONFIG_IN_SENSE_HITOLO(true);
    in_config.pull = NRF_GPIO_PIN_PULLUP;
    err_code = nrf_drv_gpiote_in_init(BUT, &in_config, in_pin_handler);
    nrf_drv_gpiote_in_event_enable(BUT, true);
//999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999
/**@brief Function for application main entry.
    int gyr1[2];
    int gyr2[2];
    int fall=10000;
     bool erase_bonds;
     nrf_gpio_cfg_output(LED);
    // Initialize.
    gpio_init();
    log_init();
    timers_init();
    //buttons_leds_init(&erase_bonds);
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    peer_manager_init();
    // Start execution.
    NRF_LOG_INFO("Template example started.");
    application_timers_start();
    advertising_start(erase_bonds);
    // Enter main loop.
    //initialize the logger
    //APP_ERROR_CHECK(NRF_LOG_INIT(NULL));
    //NRF_LOG_DEFAULT_BACKENDS_INIT();
    //create arrays which will hold x,y & z co-ordinates values of acc and gyro
    static int16_t AccValue[3], GyroValue[3];
    //bsp_board_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS); // initialize the leds and buttons
    twi_master_init(); // initialize the twi
    //twi_init();
    ret_code_t err_code; // a variable to hold error code value
    uint8_t address = 0x68; // address of the sensor
    uint8_t sample_data = 0x00; // sample data initialized with 0 value.
    err_code = nrf_drv_twi_rx(&m_twi, address, &sample_data, sizeof(sample_data));
    if(err_code == NRF_SUCCESS) // if reading data was successful
        printf("Successfully detected a device at address: 0x%x", address); // let the users know its working
        a[0]=address;
    nrf_delay_ms(1000); // give some delay
    ags_init();
    nrf_delay_ms(200);
    printf("Reading Values from ACC & GYRO"); // display a message to let the user know that the device is starting to read the values
    nrf_delay_ms(200);
    ags_ReadAcc(&AccValue[0], &AccValue[1], &AccValue[2]);
    double acc1= sqrt((AccValue[0]*AccValue[0])+(AccValue[1]*AccValue[1])+(AccValue[2]*AccValue[2]));
    ags_ReadGyro(&GyroValue[0], &GyroValue[1], &GyroValue[2]);
    gyr1[0]=GyroValue[2];
    //uint8_t temp = ags_register_read(ags_ADDRESS, ags_PWR_MGMT0, 1);        // make sure not to disturb reserved bit values
    //ags_register_write( ags_PWR_MGMT0, temp | 0x0f);
    //int count_acc=0;
    nrf_gpio_cfg_output(buz);
    // Enter main loop.
    while (true)
        ags_init();
        //count_acc++;
        //nrf_delay_ms(2000);
        if(ags_ReadAcc(&AccValue[0], &AccValue[1], &AccValue[2]) == true) // Read acc value from mpu6050 internal registers and save them in the array
          //printf("\r\nACC Values:  x = %d  y = %d  z = %d\r\n", AccValue[0], AccValue[1], AccValue[2]); // display the read values
          manufacturing_data_payload_list[11]=100;
          manufacturing_data_payload_list[12]=AccValue[0]/80;
          manufacturing_data_payload_list[13]=AccValue[1]/80;
          manufacturing_data_payload_list[14]=AccValue[2]/80;
          manufacturing_data_payload_list[15]=0x00;
            printf("Reading ACC values Failed!!!"); // if reading was unsuccessful then let the user know about it
        //if(s_flag==1)
        //    if(ags_ReadGyro(&GyroValue[0], &GyroValue[1], &GyroValue[2]) == true) // Read acc value from mpu6050 internal registers and save them in the array
        //      //printf("\r\nACC Values:  x = %d  y = %d  z = %d\r\n", AccValue[0], AccValue[1], AccValue[2]); // display the read values
        //      manufacturing_data_payload_list[16]=GyroValue[0]/80;
        //      manufacturing_data_payload_list[17]=GyroValue[1]/80;
        //      manufacturing_data_payload_list[18]=GyroValue[2]/80;
        //      manufacturing_data_payload_list[19]=0x00;
        double acc2= sqrt((AccValue[0]*AccValue[0])+(AccValue[1]*AccValue[1])+(AccValue[2]*AccValue[2]));
        //printf("fall: 0x%x", AccValue[1]);
        if((AccValue[1]<=-1000 || AccValue[1]>=1000))//count_acc==10000 &&
            //ags_register_write( ags_PWR_MGMT0, temp | 0x0F);                        // enable gyro and accel in low noise mode
            if(ags_ReadGyro(&GyroValue[0], &GyroValue[1], &GyroValue[2]) == true) // read the gyro values from mpu6050's internal registers and save them in another array
                gyr2[0]=GyroValue[2];
                if(gyr1[0]>gyr2[0])
                    if(gyr1[0]-gyr2[0]>10000)
                        s_flag=1;
                        manufacturing_data_payload_list[20]=0x01;
                    if(gyr2[0]-gyr1[0]>10000)
                        s_flag=1;
                //if(()) || (gyr2[0](gyr1[0]-1000)))
                //    f_flag==1;
        //int acc1=16;
        //double acc=0;
        //acc=sqrt(acc1);
        if(s_flag==1 || f_flag==1 && acc2>acc1)
              //printf("\r\nGYRO Values: x = %d  y = %d  z = %d\r\n", GyroValue[0], GyroValue[1], GyroValue[2]); // display then values
              printf("Reading GYRO values Failed!!!");
