Hi, i am using nrf9160 with jio nbiot which supports nidd protocol. Which code sample i should use for testing nidd?
There is no sample targeting NIDD specifically. We do have a the modem shell sample which allows you to test this. Have a look at my answers in this ticket.
Øyvind
Hi, They have their own protocol for sending and receiving data over nbiot nidd. is there any base code or sample is required for that? i.e. top of base code or sample code I will implement their protocol for sending and receiving
As mentioned in the ticket I've linked to, you can use the nRF9160: Modem Shell, or you can have a look at the nRF9160: PDN sample which is based on the PDN library.
The +CGDCONT AT Command allows you to define APN as non-ip.
I will need more information in order to support you more on the path of NIDD.
Øyvind
Hi, JIO have their own protocol for sending data to cloud. Data from nrf9160 goes to their cloud using their API implementation and from their cloud it will be re directed to our cloud i.e. AWS, Azure etc. To implement their API, what are the minimum things is required from nrf9160 side?
I'm not aware of the JIO protocol, it is difficult for me to tell what is required. I assume the libraries that we use is sufficient for that usage.
