Hi, i am using nrf9160 with jio nbiot which supports nidd protocol. Which code sample i should use for testing nidd?
Okay let me confirm with JIO team.
Hi, I spoke with JIO team. they are saying they have their own NIDD based JPP(JioThings Proprietary Protocol ) for sending and receiving data. I have to integrate this NIDD based protocol into Nrf9160 modem shell example(if that's work for this purpose).
What does the JioThings Proprietary Protocol need to run? Difficult for me to tell what you need to start based JioThings Proprietary Protocol. You will need to provide more details.
Here is an example to configure NIDD in MoSH, using shell command link:mosh:~$ link
Usage: link <subcommand> [options]
Subcommands:
status: Show status of the current connection (no options)
settings: Option to print or reset all persistent
link subcmd settings.
coneval: Get connection evaluation parameters (no options)
defcont: Set custom default PDP context config.
Persistent between the sessions.
Effective when going to normal mode.
defcontauth: Set custom authentication parameters for
the default PDP context. Persistent between the sessions.
connect: Connect to given apn by creating and activating a new PDP
context
disconnect: Disconnect from given apn by deactivating and destroying
a PDP context
rsrp: Subscribe/unsubscribe for RSRP signal info
ncellmeas: Start/stop neighbor cell measurements
msleep: Subscribe/unsubscribe for modem sleep notifications
tau: Subscribe/unsubscribe for modem TAU pre-warning notifications
funmode: Set/read functional modes of the modem
sysmode: Set/read system modes of the modem
Persistent between the sessions. Effective when
nmodeat: Set custom AT commmands that are run when going to normal
mode
nmodeauto: Enabling/disabling of automatic connecting and going to
normal mode after the bootup. Persistent between the sessions.
Has impact after the bootup
edrx: Enable/disable eDRX with default or with custom parameters
psm: Enable/disable Power Saving Mode (PSM) with
mosh:~$ link defcont
Usage: link defcont --enable [options] | --disable | --read
Options:
-r, --read, Read and print current config
-d, --disable, Disable custom config for default PDP context
-e, --enable, Enable custom config for default PDP context
-a, --apn, [str] Set default Access Point Name
-f, --family, [str] Address family: 'ipv4v6' (default), 'ipv4', 'ipv6',
'non-ip'
mosh:~$ link funmode --pwroff
Network registration status: not registered
mosh:~$ link defcont -e -a "non-ip.apn" -f "non-ip"
link defcont enabled
mosh:~$ link funmode --normal
Functional mode set successfully: normal
Network registration status: Connected - home network
etc etc
mosh:~$ sock connect -f packet -t raw
Socket open and connect family=3, type=3, port=0, bind_port=0, pdn_cid=0, address=
Socket created socket_id=0, fd=4
mosh:~$ sock send -d foodata2 -i 0
Socket data send:
foodata2
RRC mode: Connected
RRC mode: Idle
Øyvind
Hi, as you have mentioned for connecting to modem using NIDD we can use link defcont -e -a "non-ip.apn" -f "non-ip" for connecting purpose. i want hard code this in my code.please direct correct portion of code
Hi, any update on this?
