I am using NRF_LOG_INFO to debug. But in my debug terminal It will show only NRF_LOG_INFO that used in main.c only. In another .c file not show NRF_LOG_INFO
^^ I solved this problem
Follow this thread here
Im using libuarte so I need to enable in sdk_config.h
#define NRF_LIBUARTE_CONFIG_LOG_ENABLED 1
I am happy to hear that you were able to resolve this issue! :)
You will indeed need to enable the logging and logger level for each module that you would like to receive loggings from - this is done in the sdk_config.h as you have already found out.
Please do not hesitate to open another ticket if you should encounter any other issues or questions in the future!
Karl
