Cant get it to program
Installed the toolchain, installed VS Code, and I think its all linked, but when I try to run even the most basic hello world program it just keeps throwing this error
boards/arm/nrf5340dk_nrf5340/Kconfig.defconfig:61: error: couldn't parse 'default $(dt_chosen_reg_size_hex,$(DT_CHOSEN_Z_CODE_PARTITION))': macro expanded to blank string
Is there a dedicated IDE that integrates everything into a single package like the Arduino IDE or MPLAB IDE?
R
    Have you checked if any of the fixes in Common fixes for nRF Connect SDK build problems helps?
    If this does not help, please provide the following information:
    • How you installed the SDK and toolchain (with Toolchain Manager or manually).
    • The nRF Connect SDK version.
    • How you are trying to build the sample. Since you mention VS Code I assume you are using this, but I am interested to know if you are
      • Creating a new application from the Hello World sample.
      • Adding the existing Hello World sample to applications.
      • Building with the 'Build' action in the nRF Connect tab or by using the terminal in VS Code (with 'west build ...')
    • What do you select as the target board? It seems like you are selecting nRF5340 DK, but which of the following build targets:
      • nrf5340dk_nrf5340_cpuapp
      • nrf5340dk_nrf5340_cpuapp_ns
      • nrf5340dk_nrf5340_cpunet
    • The complete output log when building and getting the error.
    We do not have a dedicated IDE like this, but the closest would be to use VS Code with our nRF Connect extensions for VS Code. I recommend taking a look at our video tutorials for this extension on YouTube. You can find the playlist here: https://www.youtube.com/playlist?list=PLx_tBuQ_KSqEt7NK-H7Lu78lT2OijwIMl.
    Marte
  • I downloaded the nrf connect for desktop to install the toolchains
    Its the latest SDK version
    I created a new Hello World example which seems to use non-standard C (printk)
    I use the build action button instead of the terminal
    I am using the nrf5340dk_nrf5340_cpuapp
    The complete error
    #include errors detected based on information provided by the configurationProvider setting. Squiggles are disabled for this translation unit (/Users/macbook/Documents/NRF/hello_world/src/main.c).
    cannot open source file "zephyr.h"
    cannot open source file "sys/printk.h"
    "Launching GDB: /opt/nordic/ncs/v1.9.0/toolchain/bin/arm-none-eabi-gdb -q --interpreter=mi2 /Users/macbook/Documents/NRF/hello_world/build/zephyr/zephyr.hex
    Set "showDevDebugOutput": true in your "launch.json" to see verbose GDB transactions here. Helpful to debug issues or report problems
    Reading symbols from /Users/macbook/Documents/NRF/hello_world/build/zephyr/zephyr.hex...
    (No debugging symbols found in /Users/macbook/Documents/NRF/hello_world/build/zephyr/zephyr.hex)
    WARNING: Cortex-Debug will deprecate use of GDB version 8. Please upgrade to version 9+
    Launching gdb-server: /Applications/SEGGER/JLink/JLinkGDBServerCLexe -singlerun -nogui -if swd -port 50000 -swoport 50001 -telnetport 50002 -device nRF5340_xxAA_APP -select usb=1050023354 -rtos /Applications/SEGGER/JLink/GDBServer/RTOSPlugin_Zephyr.dylib
    Please check TERMINAL tab (gdb-server) for output from /Applications/SEGGER/JLink/JLinkGDBServerCLexe
    0x000012b2 in ?? ()
    Program stopped, probably due to a reset and/or halt issued by debugger
    add symbol table from file "/Users/macbook/Documents/NRF/hello_world/build/zephyr/zephyr.elf"
    (y or n) [answered Y; input not from terminal]
    Reading symbols from /Users/macbook/Documents/NRF/hello_world/build/zephyr/zephyr.elf...
    Resetting target
    Resetting target
    Temporary breakpoint 1, main () at /Users/macbook/Documents/NRF/hello_world/src/main.c:12
    warning: Source file is more recent than executable.
    12 while(1)
    Program
    received signal SIGTRAP, Trace/breakpoint trap.
    ?? () at /opt/nordic/ncs/v1.9.0/zephyr/arch/arm/core/aarch32/cpu_idle.S:107
    107 cpsie i
    Can you upload the support information from VS Code? Open Command Palette in VS Code and write nRF Connect: Generate Support Information. When you select this the information will be generated in the output terminal. Copy it and upload it here by going to Insert > Code, and paste the information there.
    Marte
  • IMPORTANT: The data below could contain sensitive or confidential information about your environment.
    For help and support, visit the Nordic DevZone at devzone.nordicsemi.com/.
    "platform": {
    "os": "darwin",
    "osVersion": "Darwin Kernel Version 21.2.0: Sun Nov 28 20:28:54 PST 2021; root:xnu-8019.61.5~1/RELEASE_X86_64",
    "osKernel": "21.2.0",
    "vscode": "1.64.2",
    "electron": "13.5.2",
    "node": "v14.16.0"
    "system": {
    "date": "2022-02-28T12:23:29.312Z",
    "vscodeRoot": "/Applications/Visual Studio Code.app/Contents/Resources/app",
    "vscodeUptime": "01:06:12",
    "osUptime": "04:40:46",
    "cpu": {
    "model": "Intel(R) Core(TM) i5-5675R CPU @ 3.10GHz",
    "speed": "3100 MHz",
    "count": 2
    "memory": {
    "total": "16.00 GB",
    "free": "1.66 GB"
    "workspace": {
    "name": "hello_world",
    "workspaceFile": null,
    "folders": [
    "/Users/macbook/Documents/NRF/hello_world"
    "extensions": {
    "internal": {
    "version": "2022.1.192",
    "path": "/Users/macbook/.vscode/extensions/nordic-semiconductor.nrf-connect-2022.1.192",
    "isActive": true
    "version": "2022.1.30",
    "path": "/Users/macbook/.vscode/extensions/nordic-semiconductor.nrf-terminal-2022.1.30",
    "isActive": true
    "nordic-semiconductor.devicetree": null,
    "nordic-semiconductor.kconfig": null
    "external": {
    "marus25.cortex-debug": "1.2.2",
    "ms-vscode.cpptools": "1.8.4",
    "ms-vscode.js-debug": "1.64.3",
    "ms-vscode.js-debug-companion": "1.0.15",
    "ms-vscode.references-view": "0.0.81",
    "ms-vscode.vscode-js-profile-table": "0.0.18",
    "cschlosser.doxdocgen": "1.4.0",
    "jeff-hykin.better-cpp-syntax": "1.15.13",
    "ms-vscode-remote.remote-containers": "0.217.4",
    "ms-vscode-remote.remote-ssh": "0.74.0",
    "ms-vscode-remote.remote-ssh-edit": "0.74.0",
    "ms-vscode-remote.remote-wsl": "0.64.2",
    "ms-vscode.cmake-tools": "1.9.2",
    "ms-vscode.cpptools-extension-pack": "1.1.0",
    "ms-vscode.cpptools-themes": "1.0.0",
    "twxs.cmake": "0.0.17"
    "tools": {
    "/Applications/SEGGER/JLink/JLinkExe": "7.62a",
    "/usr/local/bin/nrfjprog": "10.15.2",
    "/opt/nordic/ncs/v1.9.0/toolchain/bin/cmake": "3.21.1",
    "/opt/nordic/ncs/v1.9.0/toolchain/bin/west": "0.12.0",
    "/opt/nordic/ncs/v1.9.0/toolchain/bin/python3": "3.9.6",
    "/opt/nordic/ncs/v1.9.0/toolchain/bin/ninja": "1.10.2",
    "/opt/nordic/ncs/v1.9.0/toolchain/bin/gperf": "3.1",
    "/opt/nordic/ncs/v1.9.0/toolchain/bin/dtc": "1.6.1",
    "/opt/nordic/ncs/v1.9.0/toolchain/bin/arm-none-eabi-gcc": "9-2019-q4-major",
    "/opt/nordic/ncs/v1.9.0/toolchain/bin/gn": "1975",
    "/opt/nordic/ncs/v1.9.0/toolchain/bin/git": "2.32.0"
    "connectedDevices": [
    "id": "1050023354"
    "config": {
    "topdir": "/opt/nordic/ncs/v1.9.0",
    "toolchain": {
    "path": "/opt/nordic/ncs/v1.9.0/toolchain"
    "ozonePath": "",
    "applications": [
    "jlink": {
    "rtosPlugin": ""
    "kconfig": {
    "interface": "kconfig"
    "welcome": {
    "showOnStartup": false
    "west": {
    "env": {
    "$base": "terminal"
    "boardRoots": [
    "${workspaceFolder}"
    "enableTelemetry": false
    "terminalMode": "character"
    "nordic-semiconductor.devicetree": {
    "modules": [
    "${zephyrBase}",
    "${zephyrBase}/../nrf",
    "zephyr": "",
    "ctxFile": "",
    "defaultBoard": ""
    "nordic-semiconductor.kconfig": {
    "root": "",
    "env": {},
    "cfiles": true,
    "disable": false,
    "zephyr": {
    "base": ""
    "python": "",
    "liveValue": true
    "marus25.cortex-debug": {
    "armToolchainPath": null,
    "armToolchainPrefix": "arm-none-eabi",
    "gdbPath": null,
    "objdumpPath": null,
    "JLinkGDBServerPath": null,
    "openocdPath": null,
    "pyocdPath": null,
    "PEGDBServerPath": null,
    "stutilPath": null,
    "stlinkPath": null,
    "stm32cubeprogrammer": null,
    "enableTelemetry": true,
    "flattenAnonymous": false,
    "registerUseNaturalFormat": true,
    "variableUseNaturalFormat": true,
    "dbgServerLogfile": null,
    "showDevDebugOutput": "none"
    "environment": {
    "westExe": "/opt/nordic/ncs/v1.9.0/toolchain/bin/west",
    "westEnv": {
    "ELECTRON_RUN_AS_NODE": "1",
    "GIT_EXEC_PATH": "/opt/nordic/ncs/v1.9.0/toolchain/Cellar/git/2.32.0_1/libexec/git-core",
    "HOME": "/Users/macbook",
    "PATH": "/opt/nordic/ncs/v1.9.0/toolchain/bin:/Library/Frameworks/Python.framework/Versions/3.7/bin:/Library/Frameworks/Python.framework/Versions/3.10/bin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin",
    "ZEPHYR_BASE": "/opt/nordic/ncs/v1.9.0/zephyr",
    "GNUARMEMB_TOOLCHAIN_PATH": "/opt/nordic/ncs/v1.9.0/toolchain",
    "ZEPHYR_TOOLCHAIN_VARIANT": "gnuarmemb",
    "USER": "macbook"
    "toolchainPath": "/opt/nordic/ncs/v1.9.0/toolchain",
    "toolchainBinPath": "/opt/nordic/ncs/v1.9.0/toolchain/bin",
    "toolchainVersion": "1.9.0"
    "terminal": {
    "shell": null,
    "defaultProfile": null
    I do not see any issues from this information, as everything seems to be as it should. However, there was a similar issue on Mac here: https://devzone.nordicsemi.com/f/nordic-q-a/84209/failed-to-compile-non-secure-boards. Can you try downgrading VS Code to version 1.62.3? Make sure to install the Intel Chip version of VS Code, and not Universal or Apple Silicon. Also try upgrading Python to v3.10.2.
    Did you make any changes to the example, or is it exactly like the Hello World example from Zephyr?
    RM said:
    The complete error
    Can you upload the complete build output? By this I mean starting with 'west build ...' and everything that comes after when it tries to build.
    Did you try any of the tests or fixes in the guide I linked?
    Marte
