Hello Devzone Community,
My name is Ted, and I am some way along development of Zephyr based firmware, running on an nRF9160 based custom board. I'm looking to put the board, including LTE modem and application processor of the 9160 SiP into its lowest, deepest sleep modes. I have found some posts somewhat related to this question -- 59007 "put-m33-mcu-in-nrf9160-sleep-mode", 66112 "best-possible-strategy-for-deep-sleep-and-awakening", 52450 "nrf9160-low-power-modes---entering-and-measuring-current" and a few additional posts -- but none of them answers key questions I am facing and not finding answers to among Devzone and other Nordic and third party documentations.
There are also some stale links in some of the above posts as they are sometimes two and three years old as of 2022 March.
My Zephyr based application is at this point multi-threaded, and I began by building on a combination of ncs v1.6,1 (Zephyr v2.6.0) sample apps "blinky", "hello_world" and "aws_iot". In hindsight I now understand that there were multiple threads running before I created additional ones. These include Zephyr's implementing the main() function in a thread, and the idle thread. A census of threads is important, and so too that my application has so far used Zephyr's preferred console UART, uart0 and a second UART, uart2 for a separate custom command line interface. From the above posts I understand that to reach the very lowest power consumption, where the 9160 application processor is fully powered down, I need to set in prj.conf the symbol CONFIG_SERIAL=n. One post mentions that `mcuboot` and `spm` firmware modules must also be assured to have their prj.conf files disable serial port use and logging. But I am having trouble locating the prj.conf file for Nordic's ncs/nrf/modules/mcuboot application. There's no instance of CONFIG_SERIAL in this sub-project or application element of the larger SDK. Am I correct here that there is not logging and not serial port use in mcuboot?
The other question I have stems from the multiple times I find mention to be sure and disable serial ports in Zephyr apps by setting CONFIG_SERIAL=n. This is a compile time option. I find that other parts of current firmware app stop working with this sole change CONFIG_SERIAL=y to CONFIG_SERIAL=n. This does not make sense to me. Does this setting turn off a portion of high speed clocks of the ARM Cortex-M33 which are also needed by on chip I2C peripherals? When configuring no serial in prj.conf, my firmware gives no sign of life and Nordic's Power Profiler II continues to show about 700uA current draw, in spite of code that turns off the LTE modem via at_cmd_write().
In a post I made to CircuitDojo at community.jaredwolff.com the lead engineer there shared a code excerpt which he explained can, assuming driver support, dynamically turn off and on UART devices on a Zephyr supported processor. This method is also mentioned in Devzone post 81744 from around 2021 December. Last question I have, not answered by these more recent posts, can a run time UART setting to state PM_DEVICE_STATE_SUSPENDED
permit the nRF9160 to draw its ultimately lowest spec'd current of about 1.4uA?
Fair amount of detail here, and I try to keep it short. Thanks ahead of time for any insight Nordic Team and community can offer to my request for help!
- Ted
