Softdevice - WDT event not occurring when it hangs
I am using nRF52833 based BE33 (Celium Devices) and using nRF52SDK17.0.2. I am trying to implement WDT and expecting to occur its event when the module becomes hang or any unexpected error occurred. I am purposely written the code where BLE is advertising and after every 1 second I am trying to update BLE advertise data below is the code that does this.
void advertising_update(uint8_t loadcellnumber,uint8_t loadcell_data[])
uint32_t err;
  err=  sd_ble_gap_adv_stop(m_advertising.adv_handle);
    APP_ERROR_CHECK(err);
    switch(loadcellnumber){
    case 1:{
      loadcellData[0]=loadcell_data[0];
      loadcellData[1]=loadcell_data[1];
      loadcellData[2]=loadcell_data[2];
      loadcellData[3]=loadcell_data[3];
    case 2:{
      loadcellData[4]=loadcell_data[0];
      loadcellData[5]=loadcell_data[1];
      loadcellData[6]=loadcell_data[2];
      loadcellData[7]=loadcell_data[3];
    case 3:{
      loadcellData[8]=loadcell_data[0];
      loadcellData[9]=loadcell_data[1];
      loadcellData[10]=loadcell_data[2];
      loadcellData[11]=loadcell_data[3];
advertising_init();
advertising_start();
WDT code in main.c
#include "nrf_drv_wdt.h"
nrf_drv_wdt_channel_id m_channel_id;
//Configure WDT.
    nrf_drv_wdt_config_t config = NRF_DRV_WDT_DEAFULT_CONFIG;
    err_code = nrf_drv_wdt_init(&config, wdt_event_handler);
    err_code = nrf_drv_wdt_channel_alloc(&m_channel_id);
    nrf_drv_wdt_enable();
for (;;)
       idle_state_handle();
       nrf_drv_wdt_feed();
I have added below in sdk_config.h file:
// <e> NRFX_WDT_ENABLED - nrfx_wdt - WDT peripheral driver
#ifndef NRFX_WDT_ENABLED
#define NRFX_WDT_ENABLED 1
// <o> NRFX_WDT_CONFIG_BEHAVIOUR  - WDT behavior in CPU SLEEP or HALT mode
// <1=> Run in SLEEP, Pause in HALT
// <8=> Pause in SLEEP, Run in HALT
// <9=> Run in SLEEP and HALT
// <0=> Pause in SLEEP and HALT
#ifndef NRFX_WDT_CONFIG_BEHAVIOUR
#define NRFX_WDT_CONFIG_BEHAVIOUR 1
// <o> NRFX_WDT_CONFIG_RELOAD_VALUE - Reload value in ms  <1-131072000>
#ifndef NRFX_WDT_CONFIG_RELOAD_VALUE
#define NRFX_WDT_CONFIG_RELOAD_VALUE 20000
// <o> NRFX_WDT_CONFIG_NO_IRQ  - Remove WDT IRQ handling from WDT driver
// <0=> Include WDT IRQ handling
// <1=> Remove WDT IRQ handling
#ifndef NRFX_WDT_CONFIG_NO_IRQ
#define NRFX_WDT_CONFIG_NO_IRQ 0
// <o> NRFX_WDT_CONFIG_IRQ_PRIORITY  - Interrupt priority
// <0=> 0 (highest)
// <1=> 1
// <2=> 2
// <3=> 3
// <4=> 4
// <5=> 5
// <6=> 6
// <7=> 7
#ifndef NRFX_WDT_CONFIG_IRQ_PRIORITY
#define NRFX_WDT_CONFIG_IRQ_PRIORITY 6
// <e> NRFX_WDT_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRFX_WDT_CONFIG_LOG_ENABLED
#define NRFX_WDT_CONFIG_LOG_ENABLED 0
// <o> NRFX_WDT_CONFIG_LOG_LEVEL  - Default Severity level
// <0=> Off
// <1=> Error
// <2=> Warning
// <3=> Info
// <4=> Debug
#ifndef NRFX_WDT_CONFIG_LOG_LEVEL
#define NRFX_WDT_CONFIG_LOG_LEVEL 3
// <o> NRFX_WDT_CONFIG_INFO_COLOR  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef NRFX_WDT_CONFIG_INFO_COLOR
#define NRFX_WDT_CONFIG_INFO_COLOR 0
// <o> NRFX_WDT_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef NRFX_WDT_CONFIG_DEBUG_COLOR
#define NRFX_WDT_CONFIG_DEBUG_COLOR 0
// </e>
When when I try to connect to BLE from nRF connect App immediately after 1 seconds below error occurs.
<info> app: GATT ATT MTU on connection 0x0 changed to 247.
<error> app: ERROR 8 [NRF_ERROR_INVALID_STATE] at /home/neeraj/Applications/EmbeddedStudio_ARM_Nordic_v568_linux_x64/nRF5SDK1702d674dde/nRF5_SDK_17.0.2_d674dde/examples/peripheral/iotians_device_loadcell/IG_BLE.c:524 (line number 524 is line number 5 in above example)
PC at: 0x0002B885
<error> app: End of error report
Here was I expecting that the WDT event should occur but it was not.
Please help me. Am I expecting wrong? Please correct me if I am wrong.
Thanks and regards,
Neeraj Dhekale
  • Hello Simon,
    Have you set the NRFX_WDT_CONFIG_LOG_ENABLED and NRF_LOG_ENABLED configs to 1 in sdk_config.h?
    Yes, NRFX_WDT_CONFIG_LOG_ENABLED and NRF_LOG_ENABLED are set to 1.
    If you want, I can attach the source code folder here. Will that be ok?
    Thanks and regards,
    Neeraj Dhekale
  • Yes, that's fine. Please do, and I'll try to find out why the logging isn't occurring. You never seemed to answer this question from a few replies ago: Have you added any logging to confirm that a wdt_event_handler event is happening or not? If you don't print anything there, you won't see it in your logging output either.
    Simon
  • Hello Simonr,
    I have tried to print the below line in the wdt_event_handler event function. You can find it in the attached example as well as my reply on 16 March 2022
    printf("wdt_event_handler");
    wdt.zip
    Thanks and regards,
    Neeraj Dhekale
  • Hi again Neeraj
    Okay, after trying on my end, we can see that the wdt_event_handler() you have is never called, but if you set a breakpoint on I.E. line 62 of nrfx_wdt.c you can see that the watchdog is triggered when the watchdog times out. But you can't add printing here as it won't be prioritized during a watchdog timeout.
    Simon
  • Hello Simonr,
    Thanks for your reply.
    Okay
    Okay, how can I make the below condition true to be able to call m_wdt_event_handler() function?
    if (nrf_wdt_event_check(NRF_WDT_EVENT_TIMEOUT))
            m_wdt_event_handler();
            nrf_wdt_event_clear(NRF_WDT_EVENT_TIMEOUT);
    When I check the definition of NRF_WDT_EVENT_TIMEOUT I found below in nrf_wdt.h file.
    typedef enum
        NRF_WDT_EVENT_TIMEOUT = offsetof(NRF_WDT_Type, EVENTS_TIMEOUT), /**< Event from WDT time-out. */
    } nrf_wdt_event_t;
    Where I can do this below process?
    here should be an event that occurs (can be used to set controller into emergency mode and transmits necessary data only to indicate something went wrong with sensor) and then reboot itself.
    Thanks and regards,
    Neeraj Dhekale
