Softdevice - WDT event not occurring when it hangs
I am using nRF52833 based BE33 (Celium Devices) and using nRF52SDK17.0.2. I am trying to implement WDT and expecting to occur its event when the module becomes hang or any unexpected error occurred. I am purposely written the code where BLE is advertising and after every 1 second I am trying to update BLE advertise data below is the code that does this.
void advertising_update(uint8_t loadcellnumber,uint8_t loadcell_data[])
uint32_t err;
  err=  sd_ble_gap_adv_stop(m_advertising.adv_handle);
    APP_ERROR_CHECK(err);
    switch(loadcellnumber){
    case 1:{
      loadcellData[0]=loadcell_data[0];
      loadcellData[1]=loadcell_data[1];
      loadcellData[2]=loadcell_data[2];
      loadcellData[3]=loadcell_data[3];
    case 2:{
      loadcellData[4]=loadcell_data[0];
      loadcellData[5]=loadcell_data[1];
      loadcellData[6]=loadcell_data[2];
      loadcellData[7]=loadcell_data[3];
    case 3:{
      loadcellData[8]=loadcell_data[0];
      loadcellData[9]=loadcell_data[1];
      loadcellData[10]=loadcell_data[2];
      loadcellData[11]=loadcell_data[3];
advertising_init();
advertising_start();
WDT code in main.c
#include "nrf_drv_wdt.h"
nrf_drv_wdt_channel_id m_channel_id;
//Configure WDT.
    nrf_drv_wdt_config_t config = NRF_DRV_WDT_DEAFULT_CONFIG;
    err_code = nrf_drv_wdt_init(&config, wdt_event_handler);
    err_code = nrf_drv_wdt_channel_alloc(&m_channel_id);
    nrf_drv_wdt_enable();
for (;;)
       idle_state_handle();
       nrf_drv_wdt_feed();
I have added below in sdk_config.h file:
// <e> NRFX_WDT_ENABLED - nrfx_wdt - WDT peripheral driver
#ifndef NRFX_WDT_ENABLED
#define NRFX_WDT_ENABLED 1
// <o> NRFX_WDT_CONFIG_BEHAVIOUR  - WDT behavior in CPU SLEEP or HALT mode
// <1=> Run in SLEEP, Pause in HALT
// <8=> Pause in SLEEP, Run in HALT
// <9=> Run in SLEEP and HALT
// <0=> Pause in SLEEP and HALT
#ifndef NRFX_WDT_CONFIG_BEHAVIOUR
#define NRFX_WDT_CONFIG_BEHAVIOUR 1
// <o> NRFX_WDT_CONFIG_RELOAD_VALUE - Reload value in ms  <1-131072000>
#ifndef NRFX_WDT_CONFIG_RELOAD_VALUE
#define NRFX_WDT_CONFIG_RELOAD_VALUE 20000
// <o> NRFX_WDT_CONFIG_NO_IRQ  - Remove WDT IRQ handling from WDT driver
// <0=> Include WDT IRQ handling
// <1=> Remove WDT IRQ handling
#ifndef NRFX_WDT_CONFIG_NO_IRQ
#define NRFX_WDT_CONFIG_NO_IRQ 0
// <o> NRFX_WDT_CONFIG_IRQ_PRIORITY  - Interrupt priority
// <0=> 0 (highest)
// <1=> 1
// <2=> 2
// <3=> 3
// <4=> 4
// <5=> 5
// <6=> 6
// <7=> 7
#ifndef NRFX_WDT_CONFIG_IRQ_PRIORITY
#define NRFX_WDT_CONFIG_IRQ_PRIORITY 6
// <e> NRFX_WDT_CONFIG_LOG_ENABLED - Enables logging in the module.
#ifndef NRFX_WDT_CONFIG_LOG_ENABLED
#define NRFX_WDT_CONFIG_LOG_ENABLED 0
// <o> NRFX_WDT_CONFIG_LOG_LEVEL  - Default Severity level
// <0=> Off
// <1=> Error
// <2=> Warning
// <3=> Info
// <4=> Debug
#ifndef NRFX_WDT_CONFIG_LOG_LEVEL
#define NRFX_WDT_CONFIG_LOG_LEVEL 3
// <o> NRFX_WDT_CONFIG_INFO_COLOR  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef NRFX_WDT_CONFIG_INFO_COLOR
#define NRFX_WDT_CONFIG_INFO_COLOR 0
// <o> NRFX_WDT_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
// <0=> Default
// <1=> Black
// <2=> Red
// <3=> Green
// <4=> Yellow
// <5=> Blue
// <6=> Magenta
// <7=> Cyan
// <8=> White
#ifndef NRFX_WDT_CONFIG_DEBUG_COLOR
#define NRFX_WDT_CONFIG_DEBUG_COLOR 0
// </e>
When when I try to connect to BLE from nRF connect App immediately after 1 seconds below error occurs.
<info> app: GATT ATT MTU on connection 0x0 changed to 247.
<error> app: ERROR 8 [NRF_ERROR_INVALID_STATE] at /home/neeraj/Applications/EmbeddedStudio_ARM_Nordic_v568_linux_x64/nRF5SDK1702d674dde/nRF5_SDK_17.0.2_d674dde/examples/peripheral/iotians_device_loadcell/IG_BLE.c:524 (line number 524 is line number 5 in above example)
PC at: 0x0002B885
<error> app: End of error report
Here was I expecting that the WDT event should occur but it was not.
Please help me. Am I expecting wrong? Please correct me if I am wrong.
Thanks and regards,
Neeraj Dhekale
  • Hi
    The problem seems to be that your device doesn't go into an endless loop once it's done counting. If you see the default watchdog sample, after the LEDs are "done" turning on, the device goes to Idle mode, waiting for either the watchdog to be fed (by a button press) or for the watchdog to trig a reset.
    I don't think you can add a printf() function to the WDT event handler as the max amount of time we can spend in a WDT interrupt is two clock cycles before the reset occurs, so once it is triggered, it won't be able to print anything before the reset is done.
    Simon
  • Hello Simonr,
    How to switch this in emergency mode? Or do you mean it is not possible?
    if there is any error or stuck in execution and if WDT does not get the feed, there should be an event that occurs (can be used to set controller into emergency mode and transmits necessary data only to indicate something went wrong with sensor) and then reboot itself.
    Thanks and regards,
    Neeraj Dhekale
  • I have tried to call NVIC_SetPriority(WDT_IRQn, 0);
    Did you make sure to run this line after "softdevice enable"? Otherwise, the Softdevice will detect that you have assigned a reserved int priority and raise an assert.
    I can also try to debug this here if you are able to share a minimal version of your project.
