Re-installing nRF Connect SDK
How do I remove nRF Connect SDK from Windows before re-installing?
And are there something that needs to be done, if you have used cmake and Visual Studio Code for other projects?
I installed the tools via nRF Connect Desktop / Toolchain Manager in a project directory, but it looked like the paths got too long. Then I uninstalled the stuff via nRF Connect Desktop / Toolchain Manager, uninstalled the nRF Connect Desktop, removed the stuff from the project directory and rebooted. Then I re-installed everything at C:/ncs, but when I try to do something, it still defaults to the deleted project directory.
Also, when I tried (after re-install) to create the shell_bt_nus from an example and into another folder, I got the ELF-files (ARM code), but the Visual Studio Code shows errors:
    "resource": "/C:/Users/ett15110/Documents/Projects/xxxy/test/shell_bt_nus/src/main.c",
    "owner": "C/C++",
    "code": "1696",
    "severity": 8,
    "message": "cannot open source file \"alloca.h\" (dependency of \"logging/log.h\")",
    "source": "C/C++",
    "startLineNumber": 17,
    "startColumn": 1,
    "endLineNumber": 17,
    "endColumn": 25
    "resource": "/C:/Users/ett15110/Documents/Projects/xxx/test/shell_bt_nus/src/main.c",
    "owner": "C/C++",
    "code": "1696",
    "severity": 8,
    "message": "cannot open source file \"alloca.h\" (dependency of \"zephyr.h\")",
    "source": "C/C++",
    "startLineNumber": 11,
    "startColumn": 1,
    "endLineNumber": 11,
    "endColumn": 20
    "owner": "C/C++",
    "code": "1696",
    "severity": 8,
    "message": "#include errors detected. Consider updating your compile_commands.json or includePath. Squiggles are disabled for this translation unit (C:\\Users\\ett15110\\Documents\\Projects\\xxx\\test\\shell_bt_nus\\src\\main.c).",
    "source": "C/C++",
    "startColumn": 1,
    "endColumn": 20
The first two seems to happen, because __GNUC__ seems to not been defined.
And in the target folder it generated .vscode-file with this content:
    "configurations": [
            "name": "Win32",
            "includePath": [
                "${workspaceFolder}/**"
            "defines": [
                "_DEBUG",
                "UNICODE",
                "_UNICODE"
            "windowsSdkVersion": "10.0.19041.0",
            "compilerPath": "C:/Program Files (x86)/Microsoft Visual Studio/2019/BuildTools/VC/Tools/MSVC/14.29.30037/bin/Hostx64/x64/cl.exe",
            "cStandard": "c17",
            "cppStandard": "c++17",
            "intelliSenseMode": "windows-msvc-x64",
            "compileCommands": "${workspaceFolder}/build/compile_commands.json",
            "configurationProvider": "nrf-connect"
    "version": 4
I don't think it should use that compiler for anything.
It also found some errors from code for other HW!
Is there a way to "make clean"? I didn't find any.
  • Yes. The configuration doesn't let go of the old setups even if everything is uninstalled and re-installed, and a new example is created with different version of nRF Connect SDK (tried with 1.9.0 instead of earlier 1.9.1).
    I'll get back tomorrow with some screenshots.
    Demo-effect hit. Now it suddenly found the right SDK-version. Let's see when I re-install 1.9.1 tomorrow...
    I already removed everything, and there are quite some screenshots about stuff left behind. That might help the uninstaller writers.
    I have a 1.5MB zip-file of screen captures (16 of them). I wonder how to get them to you.
    Initial errors
    Configuration errors
    Errors after intellisense configuration
    About half the time, when you create a new application from an example, it asks if it can configure
    the intellisense. When it configures, there "missing h-files" complaints mostly disappear,
    but it still shows errors. The SW, however, compiles.
    Intellisense configuration
    Board error and changes watcher notification
    Software still compiles, suggesting that tha errors are false artefacts by the Visual Studio Code
    The problem is, if it doesn't compile, how to tell which errors are the real errors and which
    are false artefacts by Visual Studio Code / Intellisense.
    Stuff left behind after uninstall
    The 1.9.1-version is being installed.
  • The 1.9.1 is installed, and the 1.9.0 hounts again.
    After all those old stuff removal followed by reboot, it still finds that old setting somewhere.
    Five more screenshots about reinstallation and creating an application from an example.
    Created application from an example. It offers 1.9.0, but I select 1.9.1
    (Where did it find the 1.9.0?)
    Extension conflict
    I clicked "Show conflicting extensions"
    After restarting the change watcher, it, again, suggests using c:\ncs\v1.9.0\zephyr.
    I clicked "Change" and selected v1.9.1
    Had to restart the change watcher, because touching the snipping tool made
    the notification disappear without selection.
    Then I restarted changes watcher again, and again it suggests c:\ncs\v1.9.0\zephyr.
    Note, that there is no folder c:\ncs\v1.9.0 any more. Only c:\ncs\v1.9.1.
  • It looks like I could only upload one image file per reply.
    Well, here's nRF_Studio_VSCode_17.JPG at least.
  • Hmm, maybe the stuff left after uninstall can be better listed in text.
    These are listed after 1.9.1 was installed, but the same stuff was left behind when the 1.9.0 was uninstalled.
    I removed manually everything that looked like something to do with nRF Connect Desktop or nRF Connect SDK, but when I installed 1.9.1, it still found some old settings. I, obviously, didn't find them all.
    ett15110@ETTRE253067 MINGW64 ~/.nrfconnect-apps
    $ ls -a
    ./ pc-nrfconnect-linkmonitor.svg
    ../ pc-nrfconnect-ppk.svg
    apps.json pc-nrfconnect-programmer.svg
    external/ pc-nrfconnect-rssi.svg
    local/ pc-nrfconnect-toolchain-manager.svg
    node_modules/ pc-nrfconnect-tracecollector-preview.svg
    pc-nrfconnect-ble.svg pc-nrfconnect-tracecollector.svg
    pc-nrfconnect-dtm.svg updates.json
    pc-nrfconnect-gettingstarted.svg
    ett15110@ETTRE253067 MINGW64 ~/.vscode/extensions
    $ ls -a
    .obsolete
    austin.code-gnu-global-0.2.2/
    cschlosser.doxdocgen-1.4.0/
    marus25.cortex-debug-1.2.2/
    ms-vscode-remote.remote-containers-0.224.3/
    ms-vscode-remote.remote-ssh-0.76.1/
    ms-vscode-remote.remote-ssh-edit-0.76.1/
    ms-vscode-remote.remote-wsl-0.64.2/
    ms-vscode.cmake-tools-1.10.4/
    ms-vscode.cmake-tools-1.9.2/
    ms-vscode.cpptools-1.8.4/
    ms-vscode.cpptools-extension-pack-1.1.0/
    ms-vscode.cpptools-themes-1.0.0/
    nordic-semiconductor.nrf-connect-2022.3.104/
    nordic-semiconductor.nrf-devicetree-2022.3.68/
    nordic-semiconductor.nrf-kconfig-2022.1.78/
    nordic-semiconductor.nrf-terminal-2022.3.16/
    trond-snekvik.gnu-mapfiles-1.1.0/
    twxs.cmake-0.0.17/
    ett15110@ETTRE253067 MINGW64 ~/AppData/Local/nrfconnect-updater
    $ ls -a
    ./ ../ installer.exe*
    ett15110@ETTRE253067 MINGW64 ~/AppData/Roaming/nrfconnect
    $ ls -a
    ./ Preferences
    ../ 'Session Storage'/
    .updaterId TransportSecurity
    Cache/ blob_storage/
    'Code Cache'/ logs/
    Cookies 'nRF Connect for Desktop'/
    Cookies-journal pc-nrfconnect-launcher.json
    Dictionaries/ pc-nrfconnect-shared.json
    GPUCache/ pc-nrfconnect-toolchain-manager/
    'Local Storage'/ pc-nrfconnect-toolchain-manager.json
    'Network Persistent State' settings.json
    ett15110@ETTRE253067 MINGW64 ~/AppData/Roaming/Code/CachedExtensionVSIXs
    $ ls -a
    jeff-hykin.better-cpp-syntax-1.15.13
    ms-vscode.cpptools-1.5.1
    ms-vscode.cpptools-1.8.4-win32-x64
    twxs.cmake-0.0.17
    ett15110@ETTRE253067 MINGW64 ~/AppData/Roaming/Code/Workspaces/1647582940206
    $ cat workspace.json
    "folders": [
    "name": "shell_bt_nus",
    "path": "C:\\ncs_test\\shell_bt_nus"
    ett15110@ETTRE253067 MINGW64 ~/AppData/Roaming/Code/User
    $ cat settings.json
    "nrf-connect.welcome.showOnStartup": true,
    "nrf-connect.topdir": "${nrf-connect.sdk:1.9.1}",
    "nrf-connect.toolchain.path": "${nrf-connect.toolchain:1.9.1}",
    "nrf-connect.enableTelemetry": false,
    "cmake.configureOnOpen": true
    $ cat storage.json
    "telemetry.machineId": "9f43b368088c07bb0806bdaee446a8bcf15f6536b5a999a19a571b13c0c213d8",
    "theme": "vs-dark",
    "themeBackground": "#1e1e1e",
    "pickerWorkingDir": "C:\\ncs_test\\shell_bt_nus",
    "windowsState": {
    "lastActiveWindow": {
    "folder": "file:///c%3A/ncs_test/shell_bt_nus",
    "backupPath": "C:\\Users\\ett15110\\AppData\\Roaming\\Code\\Backups\\abfe5d0f9e442f578000ba79076f26d5",
    "uiState": {
    "mode": 0,
    "x": 448,
    "y": 156,
    "width": 1024,
    "height": 768
    "openedWindows": []
    "windowSplash": {
    "baseTheme": "vs-dark",
    "colorInfo": {
    "foreground": "#cccccc",
    "background": "#1e1e1e",
    "editorBackground": "#1e1e1e",
    "titleBarBackground": "#3c3c3c",
    "activityBarBackground": "#333333",
    "sideBarBackground": "#252526",
    "statusBarBackground": "#007acc",
    "statusBarNoFolderBackground": "#68217a"
    "layoutInfo": {
    "sideBarSide": "left",
    "editorPartMinWidth": 220,
    "titleBarHeight": 30,
    "activityBarWidth": 48,
    "sideBarWidth": 300,
    "statusBarHeight": 22,
    "windowBorder": false
  • Hi
    The .zip file can be uploaded here on DevZone, by choosing Insert -> Image/Video/File, and then pressing the Upload button to upload a file from your computer.
    If the .zip file is too large try to upload, try splitting it up into multiple files. A lot of these error messages you report seem to be error codes produced by VS code that can be ignored, and we are already working on improving the nRF Connect extension to not report many of these, as it more than anything causes a lot of confusion.
    Simon
