Re-installing nRF Connect SDK
How do I remove nRF Connect SDK from Windows before re-installing?
And are there something that needs to be done, if you have used cmake and Visual Studio Code for other projects?
I installed the tools via nRF Connect Desktop / Toolchain Manager in a project directory, but it looked like the paths got too long. Then I uninstalled the stuff via nRF Connect Desktop / Toolchain Manager, uninstalled the nRF Connect Desktop, removed the stuff from the project directory and rebooted. Then I re-installed everything at C:/ncs, but when I try to do something, it still defaults to the deleted project directory.
Also, when I tried (after re-install) to create the shell_bt_nus from an example and into another folder, I got the ELF-files (ARM code), but the Visual Studio Code shows errors:
    "resource": "/C:/Users/ett15110/Documents/Projects/xxxy/test/shell_bt_nus/src/main.c",
    "owner": "C/C++",
    "code": "1696",
    "severity": 8,
    "message": "cannot open source file \"alloca.h\" (dependency of \"logging/log.h\")",
    "source": "C/C++",
    "startLineNumber": 17,
    "startColumn": 1,
    "endLineNumber": 17,
    "endColumn": 25
    "resource": "/C:/Users/ett15110/Documents/Projects/xxx/test/shell_bt_nus/src/main.c",
    "owner": "C/C++",
    "code": "1696",
    "severity": 8,
    "message": "cannot open source file \"alloca.h\" (dependency of \"zephyr.h\")",
    "source": "C/C++",
    "startLineNumber": 11,
    "startColumn": 1,
    "endLineNumber": 11,
    "endColumn": 20
    "owner": "C/C++",
    "code": "1696",
    "severity": 8,
    "message": "#include errors detected. Consider updating your compile_commands.json or includePath. Squiggles are disabled for this translation unit (C:\\Users\\ett15110\\Documents\\Projects\\xxx\\test\\shell_bt_nus\\src\\main.c).",
    "source": "C/C++",
    "startColumn": 1,
    "endColumn": 20
The first two seems to happen, because __GNUC__ seems to not been defined.
And in the target folder it generated .vscode-file with this content:
    "configurations": [
            "name": "Win32",
            "includePath": [
                "${workspaceFolder}/**"
            "defines": [
                "_DEBUG",
                "UNICODE",
                "_UNICODE"
            "windowsSdkVersion": "10.0.19041.0",
            "compilerPath": "C:/Program Files (x86)/Microsoft Visual Studio/2019/BuildTools/VC/Tools/MSVC/14.29.30037/bin/Hostx64/x64/cl.exe",
            "cStandard": "c17",
            "cppStandard": "c++17",
            "intelliSenseMode": "windows-msvc-x64",
            "compileCommands": "${workspaceFolder}/build/compile_commands.json",
            "configurationProvider": "nrf-connect"
    "version": 4
I don't think it should use that compiler for anything.
It also found some errors from code for other HW!
Is there a way to "make clean"? I didn't find any.
  • I try to add the files here.
    nRF_Connect_cap_1-6.zipnRF_Connect_cap_17-21.zip
    Initial errors
    Configuration errors
    Errors after Intellisense configuration
    About half the time, when you create a new application from an example, it asks if it can configure
    the Intellisense. When it configures, there "missing h-files" complaints mostly disappear,
    but it still shows errors. The SW, however, compiles.
    Board error and changes watcher notification
    Software still compiles, suggesting that the errors are false artefacts by the Visual Studio Code
    The problem is, if it doesn't compile, how to tell which errors are the real errors and which
    are false artefacts by Visual Studio Code / Intellisense.
    Stuff left behind after uninstall - left out, listed in text form at the end of this file.
    Created application from an example. It offers 1.9.0, but I select 1.9.1
    (Where did it find the 1.9.0?)
    Extension conflict
    I clicked "Show conflicting extensions"
    After restarting the change watcher, it, again, suggests using c:\ncs\v1.9.0\zephyr.
    I clicked "Change" and selected v1.9.1
    Had to restart the change watcher, because touching the snipping tool made
    the notification disappear without selection.
    Then I restarted changes watcher again, and again it suggests 1.9.0 (right lower corner) even if
    only 1.9.1 is installed. (Where the heck did it find the old setting after all the cleanup?)
    ett15110@ETTRE253067 MINGW64 ~/.nrfconnect-apps
    $ ls -a
    ./                                pc-nrfconnect-linkmonitor.svg
    ../                               pc-nrfconnect-ppk.svg
    apps.json                         pc-nrfconnect-programmer.svg
    external/                         pc-nrfconnect-rssi.svg
    local/                            pc-nrfconnect-toolchain-manager.svg
    node_modules/                     pc-nrfconnect-tracecollector-preview.svg
    pc-nrfconnect-ble.svg             pc-nrfconnect-tracecollector.svg
    pc-nrfconnect-dtm.svg             updates.json
    pc-nrfconnect-gettingstarted.svg
    ett15110@ETTRE253067 MINGW64 ~/.vscode/extensions
    $ ls -a
    .obsolete
    austin.code-gnu-global-0.2.2/
    cschlosser.doxdocgen-1.4.0/
    marus25.cortex-debug-1.2.2/
    ms-vscode-remote.remote-containers-0.224.3/
    ms-vscode-remote.remote-ssh-0.76.1/
    ms-vscode-remote.remote-ssh-edit-0.76.1/
    ms-vscode-remote.remote-wsl-0.64.2/
    ms-vscode.cmake-tools-1.10.4/
    ms-vscode.cmake-tools-1.9.2/
    ms-vscode.cpptools-1.8.4/
    ms-vscode.cpptools-extension-pack-1.1.0/
    ms-vscode.cpptools-themes-1.0.0/
    nordic-semiconductor.nrf-connect-2022.3.104/
    nordic-semiconductor.nrf-devicetree-2022.3.68/
    nordic-semiconductor.nrf-kconfig-2022.1.78/
    nordic-semiconductor.nrf-terminal-2022.3.16/
    trond-snekvik.gnu-mapfiles-1.1.0/
    twxs.cmake-0.0.17/
    ett15110@ETTRE253067 MINGW64 ~/AppData/Local/nrfconnect-updater
    $ ls -a
    ./  ../  installer.exe*
    ett15110@ETTRE253067 MINGW64 ~/AppData/Roaming/nrfconnect
    $ ls -a
     ./                          Preferences
     ../                        'Session Storage'/
     .updaterId                  TransportSecurity
     Cache/                      blob_storage/
    'Code Cache'/                logs/
     Cookies                    'nRF Connect for Desktop'/
     Cookies-journal             pc-nrfconnect-launcher.json
     Dictionaries/               pc-nrfconnect-shared.json
     GPUCache/                   pc-nrfconnect-toolchain-manager/
    'Local Storage'/             pc-nrfconnect-toolchain-manager.json
    'Network Persistent State'   settings.json
    ett15110@ETTRE253067 MINGW64 ~/AppData/Roaming/Code/CachedExtensionVSIXs
    $ ls -a
    jeff-hykin.better-cpp-syntax-1.15.13
    ms-vscode.cpptools-1.5.1
    ms-vscode.cpptools-1.8.4-win32-x64
    twxs.cmake-0.0.17
    ett15110@ETTRE253067 MINGW64 ~/AppData/Roaming/Code/Workspaces/1647582940206
    $ cat workspace.json
            "folders": [
                            "name": "shell_bt_nus",
                            "path": "C:\\ncs_test\\shell_bt_nus"
    ett15110@ETTRE253067 MINGW64 ~/AppData/Roaming/Code/User
    $ cat settings.json
        "nrf-connect.welcome.showOnStartup": true,
        "nrf-connect.topdir": "${nrf-connect.sdk:1.9.1}",
        "nrf-connect.toolchain.path": "${nrf-connect.toolchain:1.9.1}",
        "nrf-connect.enableTelemetry": false,
        "cmake.configureOnOpen": true
    $ cat storage.json
        "telemetry.machineId": "9f43b368088c07bb0806bdaee446a8bcf15f6536b5a999a19a571b13c0c213d8",
        "theme": "vs-dark",
        "themeBackground": "#1e1e1e",
        "pickerWorkingDir": "C:\\ncs_test\\shell_bt_nus",
        "windowsState": {
            "lastActiveWindow": {
                "folder": "file:///c%3A/ncs_test/shell_bt_nus",
                "backupPath": "C:\\Users\\ett15110\\AppData\\Roaming\\Code\\Backups\\abfe5d0f9e442f578000ba79076f26d5",
                "uiState": {
                    "mode": 0,
                    "x": 448,
                    "y": 156,
                    "width": 1024,
                    "height": 768
            "openedWindows": []
        "windowSplash": {
            "baseTheme": "vs-dark",
            "colorInfo": {
                "foreground": "#cccccc",
                "background": "#1e1e1e",
                "editorBackground": "#1e1e1e",
                "titleBarBackground": "#3c3c3c",
                "activityBarBackground": "#333333",
                "sideBarBackground": "#252526",
                "statusBarBackground": "#007acc",
                "statusBarNoFolderBackground": "#68217a"
            "layoutInfo": {
                "sideBarSide": "left",
                "editorPartMinWidth": 220,
                "titleBarHeight": 30,
                "activityBarWidth": 48,
                "sideBarWidth": 300,
                "statusBarHeight": 22,
                "windowBorder": false
  • Any idea what's wrong in my setup? Or what more do I need to clean up to make a clean re-install?
  • Hi again
    The files you have listed in text:
    In .nrfconnect-apps/ this only seems to be data from the nRF Connect for Desktop apps, so these aren't related to the nRF Connect SDK Toolchain manager. The /nrfconnect-updater/ includes files for the nRFConnect for Desktop application itself, like the installer and probably uninstaller. Same goes for /Roaming/nrfconnect/.
    The files in /.vscode/extensions/ are extensions installed by Visual Studio code, and are not managed by the toolchain manager either. Same goes for the CachedExtensionVSIXs and workspace folders you've added. These are not affected by the toolchain manager.
    Regarding the error codes from your screenshots, these seem for the most part okay to ignore. The way you'll see that something is wrong while compiling/building you'll get an error message in the terminal where the building is done, and it should refer to what problems in the "Problems" tab to look at.
    Simon
  • I guess, the nRF Connect for Desktop configures the nRF Connect SDK Toolchain manager wrong?
    And some Nordic SW somewhere generated those Visual Studio Code configurations.
    And after cleaning up all the stuff listed, the nRF Connect to VS Code finds (and keeps offering) the old nRF Connect SDK version (and some other old settings as well).
    I think that means, that the install/uninstall doesn't quite work. And since you are encouraged to use nRF Connect for Desktop for installing the environment, I think that makes the nRF Connect Desktop, nRF Connect SDK Toolchain manager and nRF Connect SDK sort of bundled. A new user (probably), like me, can't really make a difference about which installer/SDK is responsible of what.
    Anyway, I guess, I just need to ignore all errors shown by the VS Code and just look at the error in the compilation terminal window, or use SES.
    (And the file changes watcher still keeps crashing.)
  • I just wonder...
    Is there a way to get he VS Code version to work properly? I don't seem to be able to clean my systen to be able to do clean (re-)install.
    And I wonder if the fact that I have other development environments installed too, that use the VS Code in a different way, somehow messes with the nRF Connect SDK VS Code settings?
