SOFTDEVICE: ASSERTION FAILED PC=0x00000A60
Application details:
I have a datalogger application that samples data every second. It uses the following modules:
TWIM0 -> To communicate with external RTC clock via I2C.
TWIM1 -> To send data to external display via I2C.
SPIM2 -> To get data from an external ADC with sensor.
QSPI -> To save data to an external memory.
I use BLE central to scan and connect to another custom peripheral device using long range PHY. I send all the data every 10 mins to this device which works as a router.
Everything works correctly most of the time. The application continues to sample when the data is being sent simultaneously.
Issue:
I get a SOFTDEVICE: ASSERTION FAILED that happens inconsistently about 5 to 10 times a day when the BLE central is sending the data. You can see the call stack and PC in the attached picture.
I am using nRF SDK v16.0.0 with s140_nrf52_7.0.1_softdevice. Could you please help me with this issue?
  • Also, yes I did not break or step while in debug. The debugger paused on its own, I have no break points set in code.
    I also tried using APP_IRQ_PRIORITY_LOW_MID for UART0. This gave me the same error as APP_IRQ_PRIORITY_MID at 0x00020D48.
    That is good to know, as _PRIO_APP_LOW_MID is lower priority than _PRIO_SD_LOW. If you don't have any other higher application interrupts, we can ignore those going forward.
    In a nutshell you get this assert on the central device (datalogger), which has a single link in the central role, right? Is that the only role this device has or does it also maintain other connections, scan and/or advertise while in the connection?
    You write that you see this more with increased distance to the peer (router). Have you confirmed that this is consistent?  What happens on your central device if the throughput is lower than you normally would need (for instance caused by packet drops)?
    I discussed this with the SoftDevice team and they have some questions:
    • Which LFCLK source are you using? LFXO or LFRC? What is your clock configuration (NRF_SDH_CLOCK_LF_* defines in sdk_config.h)?
    • Do you buy any chance use high duty cycle directed advertising? (I see no indication of that in what you have written, but we fixed a bug related to that in SoftDevice 7.1 which has some similarities).
  • Hi Einar,
    Yes, the datalogger has a single link in the central role. It also acts as a peripheral device using 1MBPS PHY, advertising at 1 second. The peripheral and central role can be simultaneous. When the error occurred the peripheral was in advertising state. I have also seen the error occur with the advertising disabled.
    Yes, I have confirmed the error occurs with distance (more than 3 tests).
    I have done a distance test with 3 dataloggers and 1 router. During this test I tried increased distances of up to 100 meters. There were a quite a few packet drops (I saw the failure to communicate via BLE at the router end). Only one of the dataloggers had a reset.
    As far as the LFCLK goes, I use the LFXO.
    // Low frequency clock source to be used by the SoftDevice
    #define NRF_CLOCK_LFCLKSRC                                 \
            .source = NRF_CLOCK_LF_SRC_XTAL,                   \
            .rc_ctiv = 0,                                      \
            .rc_temp_ctiv = 0,                                 \
            .xtal_accuracy = NRF_CLOCK_LF_XTAL_ACCURACY_20_PPM \
    No, I do not use high duty cycle directed advertising.
    On a side note, I do have a few app_timers running. I used to get NRF_ERROR_NO_MEM error from timer_req_schedule() in app_timer2.c. This error use to happen in similar intermittency as the softdevice assert. I was getting this error before the softdevice error showed up. I enabled APP_TIMER_WITH_PROFILER in the sdk_config.h and I stopped getting this error. I am not sure but does this have something to do with this issue. I also increased the APP_TIMER_CONFIG_OP_QUEUE_SIZE to 50. I donot get the NRF_ERROR_NO_MEM issue anymore.
    I have attached the sdk_config.h file.
    Thanks for the information. I have discussed this with the SoftDevice team and they have some more questions in order to hopefully better understand the situation:
    1. Does the link use S2 or S8 encoding?
    2. Are there any data length updates?
    3. Are only the datalogger an nRF, or are both device types nRF devices, and both nRF52840 with SDK 16 and S140 7.0.1?
    4. Can you make a sniffer trace of the connection, preferably including what happens up to you get the assert? In that case it would be good to have the sniffer close to the asserting device (datalogger) to get the timings to match as good as possible with what is seen by the asserting device.
    This should be independent of the SoftDevice, so I do not immediately see a connection. But we will keep it in mind.
  • Hi Einar,
    1. I am not sure what encoding it uses, where can I find this information?
    2. Please see the log below for successful connection:
    [00:00:52.665,649] <info> app: m_ble_central_connect
    [00:00:52.666,564] <info> app: Display-> BLE: 6. CONNECT!
    [00:00:52.674,621] <info> app: scan_start() -> 1
    [00:00:53.330,627] <info> app: scan_evt_handler() -> Connected RSSI = -45
    [00:00:53.330,688] <info> app: on_ble_central_evt() -> Connected, handle: 0.
    [00:00:53.395,019] <info> app: PM_EVT_CONN_SEC_PARAMS_REQ
    [00:00:53.395,141] <info> app: PM_EVT_CONN_SEC_START
    [00:00:53.395,202] <info> app: PM_EVT_SLAVE_SECURITY_REQ
    [00:00:53.484,802] <info> app: gatt_evt_handler() -> GATT ATT MTU on connection 0x0 changed to 247.
    [00:00:53.484,924] <info> app: on_ble_central_evt() -> Current MTU: 247
    [00:00:53.516,418] <info> app: PM_EVT_CONN_SEC_PARAMS_REQ
    [00:00:54.034,729] <info> peer_manager_handler: Connection secured: role: Central, conn_handle: 0, procedure: Bonding
    [00:00:54.034,973] <info> app: PM_EVT_CONN_SEC_SUCCEEDED
    [00:00:54.035,034] <info> app: on_ble_central_evt() -> BLE_GAP_EVT_AUTH_STATUS: status=0x0 bond=0x1 lv4: 0 kdist_own:0x3 kdist_peer:0x3
    [00:00:54.039,611] <info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Bonding data, action: Update
    [00:00:54.039,672] <info> app: PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
    [00:00:54.041,564] <info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Peer rank, action: Update
    [00:00:54.041,564] <info> app: PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
    [00:00:54.043,518] <info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Local database, action: Update
    [00:00:54.043,579] <info> app: PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
    [00:00:54.054,870] <info> app: ble_trs_c_evt_handler() -> Discovery complete.
    [00:00:54.054,870] <info> app: PM_EVT_CONN_SEC_PARAMS_REQ
    [00:00:54.054,992] <info> app: PM_EVT_CONN_SEC_START
    [00:00:54.055,114] <info> app: ble_trs_c_evt_handler() -> Connected TRS Service.
    [00:00:54.056,457] <info> app: scan_start() -> 0
    [00:00:54.474,304] <info> peer_manager_handler: Connection secured: role: Central, conn_handle: 0, procedure: Encryption
    [00:00:54.474,304] <info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Peer rank, action: Update, no change
    [00:00:54.474,365] <info> app: PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
    [00:00:54.474,365] <info> app: PM_EVT_CONN_SEC_SUCCEEDED
    [00:00:58.553,955] <info> app: on_ble_central_evt() -> Parameters update success.
    [00:01:04.067,260] <info> app: on_ble_central_evt() -> BLE_GATTC_EVT_WRITE_CMD_TX_COMPLETE
    [00:01:04.120,300] <info> app: on_ble_central_evt() -> BLE_GATTC_EVT_WRITE_CMD_TX_COMPLETE
    [00:01:04.136,779] <info> app: m_peripherals_capacitor_sample
    [00:01:04.140,258] <info> app: m_ble_central_txrx
    [00:01:04.141,174] <info> app: Display-> BLE: 7. TXRX!
    [00:01:04.157,226] <info> app: on_ble_central_evt() -> BLE_GATTC_EVT_WRITE_CMD_TX_COMPLETE
    [00:01:04.180,053] <info> app: on_ble_central_evt() -> BLE_GATTC_EVT_WRITE_CMD_TX_COMPLETE
    [00:01:04.240,905] <info> app: on_ble_central_evt() -> BLE_GATTC_EVT_WRITE_CMD_TX_COMPLETE
    [00:01:07.653,930] <info> app: m_peripherals_capacitor_sample
    [00:01:07.657,409] <info> app: m_ble_central_disconnect
    [00:01:07.658,325] <info> app: Display-> BLE: 8. DISCON!
    [00:01:07.696,960] <info> app: ble_trs_c_evt_handler() -> Disconnected.
    [00:01:07.696,960] <info> app: on_ble_central_evt() -> Disconnected, handle: 0, reason: 0x16
    3. Both datalogger and router are nRF52840 with SDK 16 and S140 7.0.1.
    4. I'm not sure if I can get a sniffer trace for coded PHY using the nrf52840dk_dongle. Is there a way I can do this?
