I'm using app_ble_uart example using nrf52810 for nrf52810 UART RX & TX pins are (P0.15 - P0.14) while configuring using i got a problem with RX transmission ,when i changed to Rx pin as p0.15 the nrf52810 module is not working.
I have some questions:
If i just change only (TX pin to P0.14) NRF52810 module is going to powered on its advertising the ble and it only transmitting the data .when if i change RX pin also even the NRF52810 module not going to powered on .
Here i changed the TX and RX pin in my code
static void uart_init(void)
uint32_t err_code;
.rx_pin_no = 15,
.tx_pin_no = 14,
.rts_pin_no = RTS_PIN_NUMBER,
.cts_pin_no = CTS_PIN_NUMBER,
.use_parity = false,
#if defined (UART_PRESENT)
.baud_rate = NRF_UART_BAUDRATE_115200
#else
.baud_rate = NRF_UARTE_BAUDRATE_115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
}Hi,
There is nothing special about P0.14 and P0.15, so we must look further to understand what is happening. Tw0 important questions:
_bhanu said:not working like its not going to "powered on" .
What exactly do you mean by this? Have you debugged to see which state the device is in?
HI,
Do you use any of the two pins for anything else in your firmware?
I didn't use those pins for any other purpose i only only used for TX & RX in my firmware.
How are this pins connected physically on your HW?
i connected TX pin of HW connected to FTDI to see weather the communication happens or not.
when i mention RX pin as P0.15 the ble was not advertising and moreover which data i given to transmit is also not doing. this problem I'm facing only when i mention RX pin as P0.15
_bhanu said:i connected TX pin of HW connected to FTDI to see weather the communication happens or not.
Can you share your schematics so that we can see if those pins are also connected to something else?
_bhanu said:when i mention RX pin as P0.15 the ble was not advertising and moreover which data i given to transmit is also not doing. this problem I'm facing only when i mention RX pin as P0.15
That is quite high-level, then. Have you tried to debug? What does that tell you? Are any APP_ERROR_CHECK's hit or something else?
