TF-M vs SPM Feature Comparison
I am doing some research on building applications for a nRF9160 DK for an evaluation project we working on. One part that I am unclear on is whether to choose to build with SPM or TF-M. I am having difficulty finding information on the features supported by each implementation. I found this discussion on the long term plans for the two components (SPM will eventually be replaced by TF-M), but did not see any details about the current differences between the two other than TF-M support is experimental still.
My questions are:
Is there a feature comparison somewhere?
Are there any current estimates as when SPM might be deprecated in favor of TF-M?
If we use SPM for building an application, is it possible to upgrade later on to a TF-M-based one via OTA?
Eric
    I don't think there is one yet. You can basically think of SPM as a subset of TF-M. SPM just sets all peripherals to non-secure before jumping to the non-secure image. TF-M is meant to do a whole lot more. I suggest you read more about it here.
    SPM will not be deprecated, at least that's not the plan. But TF-M will be production ready at some point, although I can't tell you when exactly that will happen.
    In theory it should work, as the SPM/TF-M are merged into one image before DFU is performed. There can be some issues with compatibility between MCUboot and TF-M.
  • Awesome, thank you for the correction/clarification on SPM vs TF-M.
