Build and Run with SEGGER Embedded Studio (SES) v6.20a on nRF5 SDK 17.1.0 and S140 7.2.0 on nRF52840
Hi DevZone,
I have recently updated:
  • nRF5 SDK to 17.1.0 from 15.3.0
  • S140 to 7.2.0 from 6.1.1
  • SES to v6.20a from 4.16
The SoftDevice now fails to initialize when using the "Build and Run" option with SES.
The code initializes without issue if I:
  • Use Programmer v2.3.3 from nRF Connect for Desktop v3.10.0
  • If I Power Cycle the hardware after each flash of the .hex files
  • If I "Build and Debug" with SES
Is this a known issue, and could it potentially be a timing issue?
Code that fails:
void ble_stack_init(void)
    ret_code_t err_code;
    uint32_t ram_start = 0;
    err_code = nrf_sdh_ble_default_cfg_set(BLE_CONN_CFG_TAG, &ram_start);
    // Enable BLE stack.
//    // NO OBSERVERS AT THIS POINT
//    // Register a handler for BLE events.
//    NRF_SDH_BLE_OBSERVER(m_ble_observer, APP_BLE_OBSERVER_PRIO, ble_evt_handler, NULL);
Specifically the call to nrf_sdh_enable_request() returns with error code NRF_ERROR_INVALID_STATE (0x00000008).
This should mean that the SoftDevice is already initialized when reading the documentation. However, preceding the nrf_sdh_enable_request() call with a nrf_sdh_is_enabled()
tells me that it is not.
Comparing with example projects:
I have compared to the example projects given in SDK 17.1.0, and the initialization code for the BLE stack seems unchanged between versions 17.1.0 and 15.3.0.
Also, I have tried building and running the peripheral example from SDK 17.1.0 "usbd_ble_uart_freertos" both on our hardware and an nRF52840-DK, which fails with the same error code.
So, even with code directly from the SDK and on multiple hardware the issue is the same.
Thanks in advance.
Br. Casper
  • Hello Casper,
    I am terribly sorry. For some reason, I have missed the "build and run". Looking at this ticket now, that is actually quite embarrassing. I guess I just read it as "build and run", as in build it, and flash it, and one way to do so is to press "F5", which I usually do.
    I see that in SDK 17.1.0, this seems to happen with the ble_app_hrs_freertos example as well.
    However, I can only see it using the "build and run" button from SES. Not when compiling with SES, and then flashing using e.g. nrfjprog. I am not completely sure what's happening, but I suspect it has to do with the clock. I see that if I comment out your "nrf_drv_clock_init()", then it hardfaults once, and then starts running normally. I suggest that you keep the nrf_drv_clock_init(), but use something other than SES to flash your application, or use the run and debug.
    Seeing as this only is triggered in SES, I am not sure it will be a huge issue. If you mean otherwise, I can contact our softdevice team and try to figure out why the softdevice is not starting, but I suspect there is just some timing issue between the program and the reset being issued by SES.
    Edvin
  • Hi Edvin,
    Sorry for getting back to you so late.
    I would like to ask your SoftDevice team what they think about this, and if they think it could potentially be a symptom of some larger problem, or if we should not worry about it?
    Do you know where I can can get in contact with the SoftDevice team?
    Br. Casper
  • That would be through me.
    I can ask them, but please be aware that they are currently working on the Softdevice Controller, which is the BLE stack for the nRF Connect SDK, so it may take some more time than usual to get an answer.
    Just to clarify, you have not seen this using any other method than the "build and run" with Segger Embedded Studio, right?
    BR,
    Edvin
  • Ok.
    Yes, we have only experienced this after using "Build and Run."
    Maybe it is an important detail that rolling back SES to v4.16 removes issue.
    Casper Kronborg Pedersen said:
    We then tried rolling back SES all the way to 4.16. This makes the files I sent you work, as well as our two projects that are being ported.
    Br. Casper
