Static Passkey didn't pop out input passkey window
Dear all,
I have struggled this problem over a week.
I am working on our product, which need to prevent other strangers to connect to our device. After search on the Nordic Q&A, I decided to use static passkey. But when I connected to " nRF Connect " on the PC, the device just connected immediately without popping out any window to input passkey.
What I use:
  • Chip: nRF52832
  • SDK: 15.2.0
  • Board: Custom Board
  • Base example: ble_app_template (Modified a lot. Since I need to add many other functions.)
Here as below are what I done so far:
  1. From this post I knew that  Glucose Application example may helped.
    I set the static in the peer_manager_init()
    #define SEC_PARAM_BOND                  1                                       /**< Perform bonding. */
    #define SEC_PARAM_MITM                  1                                       /**< Man In The Middle protection not required. */
    #define SEC_PARAM_LESC                  0                                       /**< LE Secure Connections not enabled. */
    #define SEC_PARAM_KEYPRESS              0                                       /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_DISPLAY_ONLY                    /**< No I/O capabilities. */
    #define SEC_PARAM_OOB                   0                                       /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE          7                                       /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE          16                                      /**< Maximum encryption key size. */
    /**@brief Function for the Peer Manager initialization.
    static void peer_manager_init(void)
        ret_code_t           err_code;
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
    		///////// what I change ////////////
    		uint8_t passkey[] = "123456";
    		ble_opt_t ble_opt;
    		ble_opt.gap_opt.passkey.p_passkey = &passkey[0];
    		err_code = sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &ble_opt);
  2. Reference to Glucose example, I also do some changes in advertising_init()
        init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance      = true;
        init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;		// BLE_GAP_ADV_FLAG_LE_GENERAL_DISC_MODE
        init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    		err_code = app_timer_create(&m_advertising_timer,
    												        APP_TIMER_MODE_REPEATED,
    												        advertising_timer_handler);
  3. Above steps didn't work. So I found this post, modified the gap_params_init()
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
    		///////// what I change //////////////
        BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM(&sec_mode);	  //BLE_GAP_CONN_SEC_MODE_SET_OPEN(&sec_mode);
    		// custom device name
    		if(record_read(CUSTOM_NAME_FILE_ID, CUSTOM_NAME_LENGTH_RECORD_ID, &custom_name_length)){
    				//nrf_gpio_pin_clear(LED_RED_PIN);
    				char devname_with_addr[custom_name_length];
    				record_read(CUSTOM_NAME_FILE_ID, CUSTOM_NAME_RECORD_ID, custom_name_from_fds);
    				memcpy(devname_with_addr, custom_name_from_fds, custom_name_length);
    																							(const uint8_t *)devname_with_addr,
    																							strlen(devname_with_addr));
    		else{
                                              (const uint8_t *)DEFAULT_DEVICE_NAME,
                                              strlen(DEFAULT_DEVICE_NAME));
Hope someone can give me some advice (ಥ﹏ಥ)
Below is my whole ble connection code
#include "System.h"
#include "m_coms_btle.h"
#include "m_coms_btle_cfg.h"
#include "m_button.h"
/* m_coms_btle.c */
#include "ADS1231_spi.h"
#include "m_bat_meas.h"
#include "m_fds.h"
#include "m_pwr_mgmt.h"
/*  BLE  */
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "sensorsim.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
/*  Service  */
#include "ble_bas.h"
//#include "ble_nus.h"
#define ADVERTISING_LED_INTERVAL 1000
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
// NUS Service
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                               /**< BLE NUS service instance. */
BLE_BAS_DEF(m_bas);
NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
BLE_ADVERTISING_DEF(m_advertising);                                             /**< Advertising module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                         /**< Context for the Queued Write module.*/
APP_TIMER_DEF(m_advertising_timer);
uint32_t custom_name_length;
uint32_t custom_name_from_fds[3];
static ble_advertising_init_t init;
static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;                   /**< Advertising handle used to identify an advertising set. */
static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];                    /**< Buffer for storing an encoded advertising set. */
static uint8_t m_enc_scan_response_data[BLE_GAP_ADV_SET_DATA_SIZE_MAX];         /**< Buffer for storing an encoded scan data. */
/**@brief Struct that contains pointers to the encoded advertising data. */
static ble_gap_adv_data_t m_adv_data =
    .adv_data =
        .p_data = m_enc_advdata,
        .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
    .scan_rsp_data =
        .p_data = m_enc_scan_response_data,
/* YOUR_JOB: Declare all services structure your application is using
 *  BLE_XYZ_DEF(m_xyz);
// YOUR_JOB: Use UUIDs for service(s) used in your application.
static ble_uuid_t m_adv_uuids[] =                                               /**< Universally unique service identifiers. */
    {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
 *@brief GAP initialization.
 *@details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
void gap_devname_default(void)
		file_delete(CUSTOM_NAME_FILE_ID);
		system_suspend_mode_enter(true);
extern struct TrxEvt send_temp;
void gap_custom_device_name_set(uint8_t * name_char, uint8_t name_length){
		ble_advdata_t advdata;
		ble_gap_adv_params_t adv_params;
    sd_ble_gap_adv_stop(m_adv_handle);
		custom_name_length = name_length;
		memcpy(custom_name_from_fds, name_char, name_length);
		uint16_t size;
		uint8_t dataArray[10];
		sprintf((char *)dataArray, "%d", name_length);
		size = sizeof(name_length);
		send_temp.data = dataArray;
		send_temp.len = &size;
		ble_nus_send(send_temp);
		record_write(CUSTOM_NAME_FILE_ID, CUSTOM_NAME_LENGTH_RECORD_ID, &custom_name_length,  1);
		record_write(CUSTOM_NAME_FILE_ID, CUSTOM_NAME_RECORD_ID, custom_name_from_fds, custom_name_length);
void advertising_stop(void)
			ret_code_t err_code = sd_ble_gap_adv_stop(m_advertising.adv_handle);
		else{
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
		err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
    //err_code = bsp_indication_set(BSP_INDICATE_IDLE);
    //APP_ERROR_CHECK(err_code);
    // Prepare wakeup buttons.
    //err_code = bsp_btn_ble_sleep_mode_prepare();
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising.");
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
static void advertising_timer_handler(void * p_context)
		nrf_gpio_pin_toggle(LED_BLUE_PIN);
 *@brief Initialize Queued Write Module.
 *@details
#if  NRF_MODULE_ENABLED(NRF_BLE_QWR)
    APP_ERROR_HANDLER(nrf_error);
static void qwr_init(void)
		uint32_t       err_code;
    nrf_ble_qwr_init_t qwr_init;
		memset(&qwr_init, 0, sizeof(qwr_init));
 *@brief Initialize Battery services.
 *@details
#if NRF_MODULE_ENABLED(BLE_BAS)
void ble_battery_level_update(uint8_t battery_level)
		ble_bas_battery_level_update(&m_bas,battery_level,m_conn_handle);
static void bas_init(void)
		uint32_t       err_code;
    ble_bas_init_t bas_init;
    // Initialize Battery Service.
    memset(&bas_init, 0, sizeof(bas_init));
    // Here the sec level for the Battery Service can be changed/increased.
    bas_init.bl_rd_sec        = SEC_OPEN;
    bas_init.bl_cccd_wr_sec   = SEC_OPEN;
    bas_init.bl_report_rd_sec = SEC_OPEN;
    bas_init.evt_handler          = NULL;
    bas_init.support_notification = true;
    bas_init.p_report_ref         = NULL;
    bas_init.initial_batt_level   = 100;
    err_code = ble_bas_init(&m_bas, &bas_init);
 *@brief Initialize NUS services.
 *@details
void ble_nus_send(const struct TrxEvt evt){
		uint32_t err_code;
		err_code = ble_nus_data_send(&m_nus, evt.data, evt.len, m_conn_handle);
#if NRF_MODULE_ENABLED(BLE_NUS)
void Jmex_nus_init(void (*nus_handler)(ble_nus_evt_t * p_evt)){
		uint32_t       err_code;
    ble_nus_init_t nus_init;
    // Initialize NUS Service.
    nus_init.data_handler = nus_handler;
		qwr_init();
		bas_init();
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
/**@brief Function for handling a Connection Parameters error.
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
            advertising_start(false);
		ble_opt_t ble_opt;
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
void advertising_start(bool erase_bonds)
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
        err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
		err_code = app_timer_start(m_advertising_timer, APP_TIMER_TICKS(ADVERTISING_LED_INTERVAL), NULL);
    ret_code_t err_code = NRF_SUCCESS;
            NRF_LOG_INFO("Disconnected.");
						ADS1231_stop();
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected.");
						// check calibration status
						check_calibrated(0);
						// battery test
						app_timer_stop(m_advertising_timer);
						nrf_gpio_pin_set(LED_BLUE_PIN);
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
void ble_stack_init(void)
    uint32_t ram_start = 0;
    // Enable BLE stack.
void ble_stack_params_init(void){
		// Initialize GAP parameters.
    gap_params_init();
	  // Initialize GATT parameters.
    gatt_init();
		// Default advertising setting.
		advertising_init();
		// Initialize BLE services.
    services_init();
		// Initialize connection parameters.
    conn_params_init();
		// Initialize peer manager.
	  peer_manager_init();
