I work with win10 laptop, Toolchain nrf Connect SDK 1.6.1 on a nrf5340dk. I use peripheral_uart sample.
I follow the guide:
https://devzone.nordicsemi.com/guides/nrf-connect-sdk-guides/b/software/posts/ncs-dfu
It's work well.
* Copyright (c) 2018 Nordic Semiconductor ASA
/** @file
* @brief Nordic UART Bridge Service (NUS) sample
#include <zephyr/types.h>
#include <zephyr.h>
#include <drivers/uart.h>
#include <device.h>
#include <soc.h>
#include <bluetooth/bluetooth.h>
#include <bluetooth/uuid.h>
#include <bluetooth/gatt.h>
#include <bluetooth/hci.h>
#include <bluetooth/services/nus.h>
#include <dk_buttons_and_leds.h>
#include <settings/settings.h>
#include <stdio.h>
#include <logging/log.h>
#include <mgmt/mcumgr/smp_bt.h>
#include "os_mgmt/os_mgmt.h"
#include "img_mgmt/img_mgmt.h"
#define LOG_MODULE_NAME peripheral_uart
LOG_MODULE_REGISTER(LOG_MODULE_NAME);
#define STACKSIZE CONFIG_BT_NUS_THREAD_STACK_SIZE
#define PRIORITY 7
#define DEVICE_NAME CONFIG_BT_DEVICE_NAME
#define DEVICE_NAME_LEN (sizeof(DEVICE_NAME) - 1)
#define RUN_STATUS_LED DK_LED1
#define RUN_LED_BLINK_INTERVAL 1000
#define CON_STATUS_LED DK_LED2
#define KEY_PASSKEY_ACCEPT DK_BTN1_MSK
#define KEY_PASSKEY_REJECT DK_BTN2_MSK
#define UART_BUF_SIZE CONFIG_BT_NUS_UART_BUFFER_SIZE
#define UART_WAIT_FOR_BUF_DELAY K_MSEC(50)
#define UART_WAIT_FOR_RX CONFIG_BT_NUS_UART_RX_WAIT_TIME
static K_SEM_DEFINE(ble_init_ok, 0, 1);
static struct bt_conn *current_conn;
static struct bt_conn *auth_conn;
static const struct device *uart;
static struct k_work_delayable uart_work;
struct uart_data_t {
void *fifo_reserved;
uint8_t data[UART_BUF_SIZE];
uint16_t len;
static K_FIFO_DEFINE(fifo_uart_tx_data);
static K_FIFO_DEFINE(fifo_uart_rx_data);
static const struct bt_data ad[] = {
BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
static const struct bt_data sd[] = {
//BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_NUS_VAL),
0x84, 0xaa, 0x60, 0x74, 0x52, 0x8a, 0x8b, 0x86,
0xd3, 0x4c, 0xb7, 0x1d, 0x1d, 0xdc, 0x53, 0x8d),
static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
ARG_UNUSED(dev);
static uint8_t *current_buf;
static size_t aborted_len;
static bool buf_release;
struct uart_data_t *buf;
static uint8_t *aborted_buf;
switch (evt->type) {
case UART_TX_DONE:
if ((evt->data.tx.len == 0) ||
(!evt->data.tx.buf)) {
return;
if (aborted_buf) {
buf = CONTAINER_OF(aborted_buf, struct uart_data_t,
data);
aborted_buf = NULL;
aborted_len = 0;
} else {
buf = CONTAINER_OF(evt->data.tx.buf, struct uart_data_t,
data);
k_free(buf);
buf = k_fifo_get(&fifo_uart_tx_data, K_NO_WAIT);
if (!buf) {
return;
if (uart_tx(uart, buf->data, buf->len, SYS_FOREVER_MS)) {
LOG_WRN("Failed to send data over UART");
case UART_RX_RDY:
buf = CONTAINER_OF(evt->data.rx.buf, struct uart_data_t, data);
buf->len += evt->data.rx.len;
buf_release = false;
if (buf->len == UART_BUF_SIZE) {
k_fifo_put(&fifo_uart_rx_data, buf);
} else if ((evt->data.rx.buf[buf->len - 1] == '\n') ||
(evt->data.rx.buf[buf->len - 1] == '\r')) {
current_buf = evt->data.rx.buf;
buf_release = true;
uart_rx_disable(uart);
case UART_RX_DISABLED:
buf = k_malloc(sizeof(*buf));
if (buf) {
buf->len = 0;
} else {
LOG_WRN("Not able to allocate UART receive buffer");
k_work_reschedule(&uart_work, UART_WAIT_FOR_BUF_DELAY);
return;
uart_rx_enable(uart, buf->data, sizeof(buf->data),
UART_WAIT_FOR_RX);
case UART_RX_BUF_REQUEST:
if (buf) {
buf->len = 0;
uart_rx_buf_rsp(uart, buf->data, sizeof(buf->data));
} else {
case UART_RX_BUF_RELEASED:
buf = CONTAINER_OF(evt->data.rx_buf.buf, struct uart_data_t,
data);
if (buf_release && (current_buf != evt->data.rx_buf.buf)) {
k_free(buf);
current_buf = NULL;
case UART_TX_ABORTED:
if (!aborted_buf) {
aborted_buf = (uint8_t *)evt->data.tx.buf;
aborted_len += evt->data.tx.len;
data);
uart_tx(uart, &buf->data[aborted_len],
buf->len - aborted_len, SYS_FOREVER_MS);
static void uart_work_handler(struct k_work *item)
if (buf) {
buf->len = 0;
} else {
return;
uart_rx_enable(uart, buf->data, sizeof(buf->data), UART_WAIT_FOR_RX);
static int uart_init(void)
int err;
struct uart_data_t *rx;
uart = device_get_binding(DT_LABEL(DT_NODELABEL(uart0)));
if (!uart) {
return -ENXIO;
rx = k_malloc(sizeof(*rx));
if (rx) {
rx->len = 0;
} else {
return -ENOMEM;
k_work_init_delayable(&uart_work, uart_work_handler);
err = uart_callback_set(uart, uart_cb, NULL);
if (err) {
return err;
return uart_rx_enable(uart, rx->data, sizeof(rx->data), 50);
static void connected(struct bt_conn *conn, uint8_t err)
if (err) {
LOG_ERR("Connection failed (err %u)", err);
return;
LOG_INF("Connected %s", log_strdup(addr));
current_conn = bt_conn_ref(conn);
dk_set_led_on(CON_STATUS_LED);
LOG_INF("Disconnected: %s (reason %u)", log_strdup(addr), reason);
if (auth_conn) {
bt_conn_unref(auth_conn);
auth_conn = NULL;
if (current_conn) {
bt_conn_unref(current_conn);
current_conn = NULL;
dk_set_led_off(CON_STATUS_LED);
#ifdef CONFIG_BT_NUS_SECURITY_ENABLED
static void security_changed(struct bt_conn *conn, bt_security_t level,
enum bt_security_err err)
if (!err) {
LOG_INF("Security changed: %s level %u", log_strdup(addr),
level);
} else {
LOG_WRN("Security failed: %s level %u err %d", log_strdup(addr),
level, err);
static struct bt_conn_cb conn_callbacks = {
.connected = connected,
.disconnected = disconnected,
.security_changed = security_changed,
#if defined(CONFIG_BT_NUS_SECURITY_ENABLED)
static void auth_passkey_display(struct bt_conn *conn, unsigned int passkey)
LOG_INF("Passkey for %s: %06u", log_strdup(addr), passkey);
static void auth_passkey_confirm(struct bt_conn *conn, unsigned int passkey)
auth_conn = bt_conn_ref(conn);
LOG_INF("Press Button 1 to confirm, Button 2 to reject.");
static void auth_cancel(struct bt_conn *conn)
LOG_INF("Pairing cancelled: %s", log_strdup(addr));
static void pairing_confirm(struct bt_conn *conn)
bt_conn_auth_pairing_confirm(conn);
LOG_INF("Pairing confirmed: %s", log_strdup(addr));
static void pairing_complete(struct bt_conn *conn, bool bonded)
LOG_INF("Pairing completed: %s, bonded: %d", log_strdup(addr),
bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
LOG_INF("Pairing failed conn: %s, reason %d", log_strdup(addr),
reason);
static struct bt_conn_auth_cb conn_auth_callbacks = {
.passkey_display = auth_passkey_display,
.passkey_confirm = auth_passkey_confirm,
.cancel = auth_cancel,
.pairing_confirm = pairing_confirm,
.pairing_complete = pairing_complete,
.pairing_failed = pairing_failed
#else
static struct bt_conn_auth_cb conn_auth_callbacks;
static void bt_receive_cb(struct bt_conn *conn, const uint8_t *const data,
uint16_t len)
int err;
char addr[BT_ADDR_LE_STR_LEN] = {0};
bt_addr_le_to_str(bt_conn_get_dst(conn), addr, ARRAY_SIZE(addr));
LOG_INF("Received data from: %s", log_strdup(addr));
for (uint16_t pos = 0; pos != len;) {
struct uart_data_t *tx = k_malloc(sizeof(*tx));
if (!tx) {
LOG_WRN("Not able to allocate UART send data buffer");
return;
/* Keep the last byte of TX buffer for potential LF char. */
size_t tx_data_size = sizeof(tx->data) - 1;
if ((len - pos) > tx_data_size) {
tx->len = tx_data_size;
} else {
tx->len = (len - pos);
memcpy(tx->data, &data[pos], tx->len);
pos += tx->len;
/* Append the LF character when the CR character triggered
* transmission from the peer.
if ((pos == len) && (data[len - 1] == '\r')) {
tx->data[tx->len] = '\n';
tx->len++;
err = uart_tx(uart, tx->data, tx->len, SYS_FOREVER_MS);
if (err) {
k_fifo_put(&fifo_uart_tx_data, tx);
static struct bt_nus_cb nus_cb = {
.received = bt_receive_cb,
void error(void)
dk_set_leds_state(DK_ALL_LEDS_MSK, DK_NO_LEDS_MSK);
while (true) {
/* Spin for ever */
k_sleep(K_MSEC(1000));
static void num_comp_reply(bool accept)
if (accept) {
bt_conn_auth_passkey_confirm(auth_conn);
LOG_INF("Numeric Match, conn %p", (void *)auth_conn);
} else {
bt_conn_auth_cancel(auth_conn);
LOG_INF("Numeric Reject, conn %p", (void *)auth_conn);
auth_conn = NULL;
void button_changed(uint32_t button_state, uint32_t has_changed)
uint32_t buttons = button_state & has_changed;
if (auth_conn) {
if (buttons & KEY_PASSKEY_ACCEPT) {
num_comp_reply(true);
if (buttons & KEY_PASSKEY_REJECT) {
num_comp_reply(false);
static void configure_gpio(void)
int err;
err = dk_buttons_init(button_changed);
if (err) {
LOG_ERR("Cannot init buttons (err: %d)", err);
err = dk_leds_init();
if (err) {
LOG_ERR("Cannot init LEDs (err: %d)", err);
void main(void)
int blink_status = 0;
int err = 0;
configure_gpio();
err = uart_init();
if (err) {
error();
printk("build time: " __DATE__ " " __TIME__ "\n");
os_mgmt_register_group();
img_mgmt_register_group();
smp_bt_register();
bt_conn_cb_register(&conn_callbacks);
if (IS_ENABLED(CONFIG_BT_NUS_SECURITY_ENABLED)) {
bt_conn_auth_cb_register(&conn_auth_callbacks);
err = bt_enable(NULL);
if (err) {
error();
LOG_INF("Bluetooth initialized");
k_sem_give(&ble_init_ok);
if (IS_ENABLED(CONFIG_SETTINGS)) {
settings_load();
err = bt_nus_init(&nus_cb);
if (err) {
LOG_ERR("Failed to initialize UART service (err: %d)", err);
return;
err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad), sd,
ARRAY_SIZE(sd));
if (err) {
LOG_ERR("Advertising failed to start (err %d)", err);
printk("Starting Nordic UART service example\n");
for (;;) {
dk_set_led(RUN_STATUS_LED, (++blink_status) % 2);
k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
void ble_write_thread(void)
/* Don't go any further until BLE is initialized */
k_sem_take(&ble_init_ok, K_FOREVER);
for (;;) {
/* Wait indefinitely for data to be sent over bluetooth */
struct uart_data_t *buf = k_fifo_get(&fifo_uart_rx_data,
K_FOREVER);
if (bt_nus_send(NULL, buf->data, buf->len)) {
LOG_WRN("Failed to send data over BLE connection");
k_free(buf);
K_THREAD_DEFINE(ble_write_thread_id, STACKSIZE, ble_write_thread, NULL, NULL,
NULL, PRIORITY, 0, 0);
But now, I need to use a private MCUBoot Key like on this ticket:
I created the priv.pem file with opennssl:
-----BEGIN EC PRIVATE KEY-----
MHcCAQEEIFOsF97yRp38uZW7PJbvFAwK1Uivv6VzIA7Kw79z3Am+oAoGCCqGSM49
AwEHoUQDQgAEHYxvVXgkcjwdhVkUDEDJ7EdLO5HAdiwDLCHXcS5uH41mMAbp8rDI
Ykb+splDuAQFsxV8sxuXZYW2zg3jb4+vxg==
-----END EC PRIVATE KEY-----
I put priv.pem in my repertory:
D:\elect\projets_nordic_D\dfu_peripheral_uart_private_key
I created the mcuboot.conf:
I modified the prj.conf:
I modified the CmakeList.txt:
# Copyright (c) 2018 Nordic Semiconductor
cmake_minimum_required(VERSION 3.13.1)
if (EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/mcuboot.conf")
list(APPEND mcuboot_OVERLAY_CONFIG
endif()
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(NONE)
# NORDIC SDK APP START
target_sources(app PRIVATE
src/main.c
# NORDIC SDK APP END
zephyr_library_include_directories(.)
But when I build it with west I this following "fatal error":
FATAL ERROR: command exited with status 1: 'D:\elect\ncs\v1.6.1\toolchain\opt\bin\cmake.EXE' --build 'D:\elect\projets_nordic_D\dfu_peripheral_uart_private_key\build'
NCS repositories are not yet cloned here. To do so run the following command:
git-bash -c "ncsmgr init-ncs"
Microsoft Windows [version 10.0.19044.1586]
(c) Microsoft Corporation. Tous droits réservés.
C:\Users\elect\AppData\Local\Temp>d:
D:\elect\ncs\v1.6.1>cd D:\elect\projets_nordic_D\dfu_peripheral_uart_private_key
D:\elect\projets_nordic_D\dfu_peripheral_uart_private_key>west build -b nrf5340dk_nrf5340_cpuapp
Including boilerplate (Zephyr base): D:/elect/ncs/v1.6.1/zephyr/cmake/app/boilerplate.cmake
-- Application: D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key
-- Using NCS Toolchain 1.6.1 for building. (D:/elect/ncs/v1.6.1/toolchain/cmake)
-- Zephyr version: 2.6.0-rc1 (D:/elect/ncs/v1.6.1/zephyr), build: v2.6.0-rc1-ncs1
-- Found Python3: D:/elect/ncs/v1.6.1/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Found west (found suitable version "0.11.0", minimum required is "0.7.1")
-- Board: nrf5340dk_nrf5340_cpuapp
-- Cache files will be written to: D:/elect/ncs/v1.6.1/zephyr/.cache
-- Found dtc: D:/elect/ncs/v1.6.1/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (D:/elect/ncs/v1.6.1/toolchain/opt)
-- Found BOARD.dts: D:/elect/ncs/v1.6.1/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp.dts
-- Generated zephyr.dts: D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/zephyr/include/generated/device_extern.h
Parsing D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/Kconfig
Loaded configuration 'D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/zephyr/.config'
No change to configuration in 'D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/zephyr/.config'
No change to Kconfig header in 'D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Found assembler: D:/elect/ncs/v1.6.1/toolchain/opt/bin/arm-none-eabi-gcc.exe
=== child image b0 - begin ===
Including boilerplate (Zephyr base (cached)): D:/elect/ncs/v1.6.1/zephyr/cmake/app/boilerplate.cmake
-- Application: D:/elect/ncs/v1.6.1/nrf/samples/bootloader
-- Generated zephyr.dts: D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/b0/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/b0/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/b0/zephyr/include/generated/device_extern.h
Parsing D:/elect/ncs/v1.6.1/zephyr/Kconfig
Loaded configuration 'D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/b0/zephyr/.config'
No change to configuration in 'D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/b0/zephyr/.config'
No change to Kconfig header in 'D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/b0/zephyr/include/generated/autoconf.h'
CMake Warning at ../../subsys/bootloader/CMakeLists.txt:21 (message):
--- WARNING: When using the immutable bootloader on ---
--- this SoC, the UICR must be erased when flashing. ---
--- E.g. by calling 'west flash --erase' ---
-- Configuring done
-- Generating done
-- Build files have been written to: D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/b0
=== child image b0 - end ===
Adding 'hci_rpmsg' firmware as child image since CONFIG_BT_RPMSG_NRF53 is set to 'y'
=== child image hci_rpmsg - CPUNET begin ===
-- Application: D:/elect/ncs/v1.6.1/zephyr/samples/bluetooth/hci_rpmsg
-- Board: nrf5340dk_nrf5340_cpunet
-- Found BOARD.dts: D:/elect/ncs/v1.6.1/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpunet.dts
-- Generated zephyr.dts: D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/hci_rpmsg/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/hci_rpmsg/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/hci_rpmsg/zephyr/include/generated/device_extern.h
Loaded configuration 'D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/hci_rpmsg/zephyr/.config'
No change to configuration in 'D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/hci_rpmsg/zephyr/.config'
No change to Kconfig header in 'D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/hci_rpmsg/zephyr/include/generated/autoconf.h'
=== child image b0n - CPUNET (inherited) begin ===
-- Application: D:/elect/ncs/v1.6.1/nrf/samples/nrf5340/netboot
-- Generated zephyr.dts: D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/hci_rpmsg/b0n/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/hci_rpmsg/b0n/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/hci_rpmsg/b0n/zephyr/include/generated/device_extern.h
Parsing D:/elect/ncs/v1.6.1/nrf/samples/nrf5340/netboot/Kconfig
Loaded configuration 'D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/hci_rpmsg/b0n/zephyr/.config'
No change to configuration in 'D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/hci_rpmsg/b0n/zephyr/.config'
No change to Kconfig header in 'D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/hci_rpmsg/b0n/zephyr/include/generated/autoconf.h'
CMake Warning at D:/elect/ncs/v1.6.1/zephyr/CMakeLists.txt:1607 (message):
-- Configuring done
-- Generating done
-- Build files have been written to: D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/hci_rpmsg/b0n
=== child image b0n - CPUNET (inherited) end ===
-- libmetal version: 1.0.0 (D:/elect/ncs/v1.6.1/zephyr/samples/bluetooth/hci_rpmsg)
-- Build type:
-- Host: Windows/AMD64
-- Target: Generic/arm
-- Machine: cortexm
-- open-amp version: 1.0.0 (D:/elect/ncs/v1.6.1/modules/lib/open-amp/open-amp)
-- Machine: cortexm
-- C_FLAGS : -Wall -Wextra
-- Configuring done
-- Generating done
=== child image hci_rpmsg - CPUNET end ===
=== child image mcuboot - begin ===
-- Application: D:/elect/ncs/v1.6.1/bootloader/mcuboot/boot/zephyr
-- Found devicetree overlay: D:/elect/ncs/v1.6.1/bootloader/mcuboot/boot/zephyr/dts.overlay
-- Generated zephyr.dts: D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/mcuboot/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/mcuboot/zephyr/include/generated/device_extern.h
Parsing D:/elect/ncs/v1.6.1/bootloader/mcuboot/boot/zephyr/Kconfig
Loaded configuration 'D:/elect/ncs/v1.6.1/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_defconfig'
Merged configuration 'D:/elect/ncs/v1.6.1/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration 'D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/mcuboot.conf'
Configuration saved to 'D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/mcuboot/zephyr/.config'
Kconfig header saved to 'D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/mcuboot/zephyr/include/generated/autoconf.h'
MCUBoot bootloader key file: /elect/projets_nordic_D/dfu_peripheral_uart_private_key/priv.pem
-- Configuring done
-- Generating done
-- Build files have been written to: D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/mcuboot
=== child image mcuboot - end ===
-- libmetal version: 1.0.0 (D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key)
-- Build type:
-- Machine: cortexm
-- Looking for include file stdatomic.h
-- Looking for include file stdatomic.h - found
-- Machine: cortexm
-- Looking for include file fcntl.h
-- Looking for include file fcntl.h - found
-- Configuring done
-- Generating done
[0/313] Generating extra provision key files
[17/313] Creating public key from private key used for signing
[21/313] Performing build step for 'mcuboot_subimage'
[245/252] Linking C executable zephyr\zephyr_prebuilt.elf
FAILED: zephyr/zephyr_prebuilt.elf zephyr/zephyr_prebuilt.map
cmd.exe /C "cd . && D:\elect\ncs\v1.6.1\toolchain\opt\bin\arm-none-eabi-gcc.exe zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj -o zephyr\zephyr_prebuilt.elf -Wl,-T zephyr/linker_zephyr_prebuilt.cmd -Wl,-Map=D:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/mcuboot/zephyr/zephyr_prebuilt.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a zephyr/lib/libc/minimal/liblib__libc__minimal.a zephyr/lib/posix/liblib__posix.a zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/flash/libdrivers__flash.a zephyr/drivers/serial/libdrivers__serial.a modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a modules/mbedtls/libmodules__mbedtls.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -L"d:/elect/ncs/v1.6.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/thumb/v8-m.main/nofp" -LD:/elect/projets_nordic_D/dfu_peripheral_uart_private_key/build/mcuboot/zephyr -lgcc zephyr/arch/common/libisr_tables.a D:/elect/ncs/v1.6.1/nrfxlib/crypto/nrf_cc312_platform/lib/cortex-m33/soft-float/no-interrupts/libnrf_cc312_platform_0.9.10.a -mcpu=cortex-m33 -mthumb -mabi=aapcs -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -no-pie -Wl,-X -Wl,-N -Wl,--orphan-handling=warn && cmd.exe /C "cd /D D:\elect\projets_nordic_D\dfu_peripheral_uart_private_key\build\mcuboot\zephyr && D:\elect\ncs\v1.6.1\toolchain\opt\bin\cmake.exe -E echo ""
d:/elect/ncs/v1.6.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: app/libapp.a(main.c.obj): in function `main':
D:/elect/ncs/v1.6.1/bootloader/mcuboot/boot/zephyr/main.c:583: undefined reference to `pcd_lock_ram'
d:/elect/ncs/v1.6.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: app/libapp.a(loader.c.obj): in function `boot_validated_swap_type':
D:/elect/ncs/v1.6.1/bootloader/mcuboot/boot/bootutil/src/loader.c:828: undefined reference to `pcd_network_core_update'
d:/elect/ncs/v1.6.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: app/libapp.a(keys.c.obj):(.rodata.bootutil_keys+0x0): undefined reference to `rsa_pub_key'
d:/elect/ncs/v1.6.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: app/libapp.a(keys.c.obj):(.rodata.bootutil_keys+0x4): undefined reference to `rsa_pub_key_len'
collect2.exe: error: ld returned 1 exit status
[278/313] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
FAILED: modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build mcuboot/zephyr/zephyr.hex mcuboot/zephyr/zephyr.elf
cmd.exe /C "cd /D D:\elect\projets_nordic_D\dfu_peripheral_uart_private_key\build\mcuboot && D:\elect\ncs\v1.6.1\toolchain\opt\bin\cmake.exe --build . --"
[282/313] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
Could you help to understand the error and make MCUBoot private key working ?
Rob
