Hi
We are trying to connect to connect to a MINEW MS88SF23 SoC from our nRF52833 DK.
For all tests, nRF power source switch is set to VDD, nRF ONLY switch is set to DEFAULT, and the power switch is set to ON. The DK is powered by USB from a Windows 10 laptop.
We have done a few attempts.
Attempt 1:
We are powering the external board from one of the VDD ports on the development kit (red cable).
Running the command "nrfjprog --memrd 0x10000060 --n 8 -f NRF52" as suggested here produced the same DEVICEID whether the external SoC was connected to the Debug Out P19 10-pin connector or not.
We checked continuity from the board to the pins on the external SoC and it was OK. We also checked that there was a voltage differance between the VDD and GND wires (i think it was 2.9V) but the instant I did the measurement the DK disconnected from the computer. Then the voltage between the pins dropped to 1.6V. We also have a CR 2032 battery on the DK, so I assume it was the power source now that the USB power dissapeared. I don't understand why the DK disconnected because of a voltage measurement with a multimeter.
Attempt 2:
We attempted to solder SB47 on the DK to power the SoC directly from the 10-pin P19 connector. Then tried these two newly wired MINEW chips (excuse the bad wiring)
Result was:
ERROR: No debuggers were discovered
Attempt 3:
We put a 3V CR 2032 battery in for the external SoC and used a DK that did not have SB47 soldered.
For the SoC pictured to the right in Attempt 2, we got the following:
ERROR: Unable to connect to a debugger.ERROR: [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
For the one to the left we got:
nrfjprog --memrd 0x10000060 --n 8 -f NRF52 --log
ERROR: [SeggerBackend] - 10 second timeout elapsed, no time left to wait for debug port to power up.
ERROR: nrfjprog failed for an unknown reason. Run the same command again with
ERROR: argument --log, contact Nordic Semiconductor and provide the generated
ERROR: log.log file to them.
Which produced the following log:
For the one on the right we got:
which produced the following log:
[2022-Apr-07 13:55:47] [ info] --------------------------------------------------------------------------------
[2022-Apr-07 13:55:47] [ info] C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.exe --memrd 0x10000060 --n 8 -f NRF52 --log
[2022-Apr-07 13:55:47] [ info] nrfjprog version 10.15.4 external
[2022-Apr-07 13:55:47] [ info] Load library at C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
[2022-Apr-07 13:55:47] [ info] Library loaded, loading member functions.
[2022-Apr-07 13:55:47] [ info] Member functions succesfully loaded.
[2022-Apr-07 13:55:47] [debug] [ Client] - open
[2022-Apr-07 13:55:47] [debug] [ Client] - start
[2022-Apr-07 13:55:47] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 574b1724-487f-4053-ad76-90555eb75790.
[2022-Apr-07 13:55:47] [trace] [ Client] - Command open executed for 110 milliseconds with result 0
[2022-Apr-07 13:55:47] [debug] [ Client] - enum_emu_snr
[2022-Apr-07 13:55:47] [trace] [ Client] - Command enum_emu_con_info executed for 15 milliseconds with result 0
[2022-Apr-07 13:55:47] [debug] [ Client] - connect_to_emu_with_snr
[2022-Apr-07 13:55:47] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
[2022-Apr-07 13:55:47] [debug] [ JLink] - Logger sink registered in JLink logger
[2022-Apr-07 13:55:47] [debug] [ nRF52] - open
[2022-Apr-07 13:55:47] [debug] [ nRF52] - just_check_family
[2022-Apr-07 13:55:47] [debug] [SeggerBackend] - open_dll
[2022-Apr-07 13:55:47] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[2022-Apr-07 13:55:47] [ info] [SeggerBackend] - Load library at C:\Program Files (x86)\SEGGER\JLink\JLink_x64.dll.
[2022-Apr-07 13:55:47] [ info] [SeggerBackend] - Library loaded, loading member functions.
[2022-Apr-07 13:55:47] [ info] [SeggerBackend] - Member functions succesfully loaded.
[2022-Apr-07 13:55:47] [debug] [SeggerBackend] - dll_version
[2022-Apr-07 13:55:47] [ info] [SeggerBackend] - Segger dll version 7.58.b loaded.
[2022-Apr-07 13:55:47] [trace] [ Worker] - Command open executed for 10 milliseconds with result 0
[2022-Apr-07 13:55:47] [debug] [ nRF52] - enum_emu_con_info
[2022-Apr-07 13:55:47] [debug] [SeggerBackend] - is_connected_to_emu
[2022-Apr-07 13:55:47] [debug] [SeggerBackend] - enum_emu_con_info
[2022-Apr-07 13:55:47] [trace] [ Worker] - Command enum_emu_con_info executed for 7 milliseconds with result 0
[2022-Apr-07 13:55:47] [debug] [ nRF52] - connect_to_emu_with_snr
[2022-Apr-07 13:55:47] [debug] [SeggerBackend] - connect_to_emu_with_snr
[2022-Apr-07 13:55:47] [debug] [SeggerBackend] - ---just_enum_emu_snr
[2022-Apr-07 13:55:47] [debug] [SeggerBackend] - ---just_get_num_emus
[2022-Apr-07 13:55:47] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
[2022-Apr-07 13:55:47] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
[2022-Apr-07 13:55:47] [debug] [SeggerBackend] - Segger logging enabled.
[2022-Apr-07 13:55:47] [trace] [ JLink] - Firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Feb 2 2021 16:47:20
[2022-Apr-07 13:55:47] [trace] [ JLink] - Hardware: V1.00
[2022-Apr-07 13:55:47] [trace] [ JLink] - S/N: 685371889
[2022-Apr-07 13:55:47] [trace] [ JLink] - OEM: SEGGER
[2022-Apr-07 13:55:47] [trace] [ JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
[2022-Apr-07 13:55:47] [trace] [ JLink] - TELNET listener socket opened on port 19021
[2022-Apr-07 13:55:47] [trace] [ JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
[2022-Apr-07 13:55:47] [trace] [ JLink] - WEBSRV Webserver running on local port 19080
[2022-Apr-07 13:55:47] [trace] [ JLink] - - 75.614ms returns "O.K."
[2022-Apr-07 13:55:47] [trace] [ JLink] - JLINK_HasError()
[2022-Apr-07 13:55:47] [trace] [ JLink] - JLINK_Lock()
[2022-Apr-07 13:55:47] [trace] [ JLink] - JLINK_GetHWStatus(...)
[2022-Apr-07 13:55:47] [trace] [ JLink] - - 0.294ms returns 0
[2022-Apr-07 13:55:47] [trace] [ JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
[2022-Apr-07 13:55:47] [trace] [ JLink] - - 0.003ms returns 0x01
[2022-Apr-07 13:55:47] [trace] [ JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
[2022-Apr-07 13:55:47] [trace] [ JLink] - - 0.003ms returns 0x00
[2022-Apr-07 13:55:47] [trace] [ JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
[2022-Apr-07 13:55:47] [trace] [ JLink] - - 0.008ms returns 0x00
[2022-Apr-07 13:55:47] [trace] [ JLink] - JLINK_SetHookUnsecureDialog
[2022-Apr-07 13:55:47] [trace] [ JLink] - JLINK_SetHookUnsecureDialog(...)
[2022-Apr-07 13:55:47] [trace] [ JLink] - - 0.014ms returns 0
[2022-Apr-07 13:55:47] [trace] [ JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
[2022-Apr-07 13:55:47] [trace] [ JLink] - - 1.413ms returns 0x00
[2022-Apr-07 13:55:47] [trace] [ JLink] - JLINK_SetSpeed(2000)
[2022-Apr-07 13:55:47] [trace] [ JLink] - - 0.185ms
[2022-Apr-07 13:55:47] [trace] [ JLink] - JLINK_GetSN()
[2022-Apr-07 13:55:47] [trace] [ JLink] - - 0.006ms returns 685371889
[2022-Apr-07 13:55:47] [debug] [SeggerBackend] - read_debug_port_idr
[2022-Apr-07 13:55:47] [debug] [SeggerBackend] - read_debug_port_register
[2022-Apr-07 13:55:47] [debug] [SeggerBackend] - ---just_read_debug_port_register
[2022-Apr-07 13:55:47] [debug] [SeggerBackend] - coresight_configure
[2022-Apr-07 13:55:47] [trace] [ JLink] - JLINK_CORESIGHT_Configure()
[2022-Apr-07 13:55:47] [trace] [ JLink] - - 101.116ms returns 0
[2022-Apr-07 13:55:47] [debug] [SeggerBackend] - ---just_select_debug_port_register
[2022-Apr-07 13:55:47] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
[2022-Apr-07 13:55:47] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2022-Apr-07 13:55:47] [trace] [ JLink] - - 1.259ms returns -1
[2022-Apr-07 13:55:47] [error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
[2022-Apr-07 13:55:47] [debug] [SeggerBackend] - ---just_abort_debug_action
[2022-Apr-07 13:55:47] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
[2022-Apr-07 13:55:47] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[2022-Apr-07 13:55:47] [trace] [ JLink] - - 1.406ms returns -1
[2022-Apr-07 13:55:47] [trace] [ JLink] - - 1.140ms returns -1
[2022-Apr-07 13:55:47] [trace] [ JLink] - - 1.171ms returns -1
[2022-Apr-07 13:55:47] [trace] [ JLink] - - 1.099ms returns -1
[2022-Apr-07 13:55:47] [trace] [ JLink] - - 1.210ms returns -1
[2022-Apr-07 13:55:47] [trace] [ JLink] - - 1.236ms returns -1
[2022-Apr-07 13:55:47] [trace] [ JLink] - - 1.179ms returns -1
[2022-Apr-07 13:55:47] [trace] [ JLink] - - 1.175ms returns -1
[2022-Apr-07 13:55:47] [trace] [ JLink] - - 1.200ms returns -1
[2022-Apr-07 13:55:47] [trace] [ JLink] - - 1.337ms returns -1
[2022-Apr-07 13:55:47] [trace] [ JLink] - - 1.277ms returns -1
[2022-Apr-07 13:55:47] [trace] [ JLink] - - 1.430ms returns -1
[2022-Apr-07 13:55:47] [trace] [ JLink] - - 1.336ms returns -1
[2022-Apr-07 13:55:47] [trace] [ JLink] - - 1.347ms returns -1
[2022-Apr-07 13:55:47] [trace] [ Client] - Command connect_to_emu_with_snr executed for 343 milliseconds with result -102
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.371ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - JLINK_HasError()
[2022-Apr-07 13:55:48] [error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
[2022-Apr-07 13:55:48] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.096ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.242ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.154ms returns -1
[2022-Apr-07 13:55:48] [debug] [SeggerBackend] - ---just_abort_debug_action
[2022-Apr-07 13:55:48] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.142ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.177ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.160ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.350ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.315ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.193ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.209ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.253ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.329ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.304ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.164ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 0.359ms
[2022-Apr-07 13:55:48] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 342 milliseconds with result -102
[2022-Apr-07 13:55:48] [debug] [ nRF52] - close
[2022-Apr-07 13:55:48] [debug] [SeggerBackend] - is_connected_to_emu
[2022-Apr-07 13:55:48] [trace] [ JLink] - JLINK_IsOpen()
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 0.068ms returns 0x01
[2022-Apr-07 13:55:48] [trace] [ JLink] - JLINK_Lock()
[2022-Apr-07 13:55:48] [debug] [SeggerBackend] - close
[2022-Apr-07 13:55:48] [debug] [SeggerBackend] - disconnect_from_emu
[2022-Apr-07 13:55:48] [debug] [SeggerBackend] - ---just_disconnect_from_emu
[2022-Apr-07 13:55:48] [debug] [SeggerBackend] - is_connected_to_device
[2022-Apr-07 13:55:48] [trace] [ JLink] - JLINK_IsConnected()
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 0.160ms returns FALSE
[2022-Apr-07 13:55:48] [debug] [SeggerBackend] - ---just_is_debug_region_powered
[2022-Apr-07 13:55:48] [debug] [SeggerBackend] - ---just_read_debug_port_register
[2022-Apr-07 13:55:48] [debug] [SeggerBackend] - ---just_select_debug_port_register
[2022-Apr-07 13:55:48] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.206ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.336ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.325ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.275ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.318ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.311ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.273ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.130ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.173ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.198ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.110ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.102ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.200ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.120ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.184ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.158ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.194ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.313ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.148ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.094ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.080ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.100ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.108ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.090ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 1.099ms returns -1
[2022-Apr-07 13:55:48] [trace] [ JLink] - - 0.067ms
[2022-Apr-07 13:55:48] [trace] [ JLink] - JLINK_Close()
[2022-Apr-07 13:55:48] [trace] [ Client] - Command close executed for 123 milliseconds with result 0
[2022-Apr-07 13:55:48] [debug] [ Client] - terminate
[2022-Apr-07 13:55:48] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
[2022-Apr-07 13:55:48] [debug] [SeggerBackend] - Segger Backend closed.
[2022-Apr-07 13:55:48] [debug] [ nRF52] - nRF family DLL closed
[2022-Apr-07 13:55:48] [trace] [ Worker] - Command close executed for 123 milliseconds with result 0
[2022-Apr-07 13:55:48] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
[2022-Apr-07 13:55:48] [trace] [ Worker] - Executed 5 commands for 482 milliseconds
[2022-Apr-07 13:55:48] [debug] [ Client] - Worker process exited with code: 0
[2022-Apr-07 13:55:48] [debug] [ Client] - Child process terminated with result 0
[2022-Apr-07 13:55:48] [trace] [ Client] - Executed 5 commands for 591 milliseconds
What can we do to get closer to being able to connect to the external SoC? The MINEW chips have been used succesfully for a previous master's thesis before using the method in Attempt 1 (but the previous users might have failed to mention something for us)
