when use the DF of central and peripheral,i don't use the antenna array,but i set,there is no out put,what is this problem?
I use the zephyr version 3.0.9 for DF.i use the both boards nrf52833dk.i set the antenna array including antenna_num,antenna_patterns,and antenna_ref(pdu_antenna).
both file example are here.one is C:\Users\Administrator\zephyrproject\zephyr\samples\bluetooth\direction_finding_peripheral.another is C:\Users\Administrator\zephyrproject\zephyr\samples\bluetooth\direction_finding_central
the next is my confuguration.Firstly,i chnage the nrf52833dk_nrf52833 .overlay file in central.The antenna numbers is 16.
 * Copyright (c) 2022 Nordic Semiconductor ASA
&radio {
	status = "okay";
	/* This is a number of antennas that are available on antenna matrix
	 * designed by Nordic. For more information see README.rst.
	/*dfe-antenna-num = <12>;*/
	dfe-antenna-num = <16>;
	/* This is a setting that enables antenna 12 (in antenna matrix designed
	 * by Nordic) for Rx PDU. For more information see README.rst.
	/*dfe-pdu-antenna = <0x0>;*/
	/* These are GPIO pin numbers that are provided to
	 * Radio peripheral. The pins will be acquired by Radio to
	 * drive antenna switching when AoA is enabled.
	 * Pin numbers are selected to drive switches on antenna matrix
	dfegpio0-gpios = <&gpio0 3 0>;
	dfegpio1-gpios = <&gpio0 4 0>;
	dfegpio2-gpios = <&gpio0 28 0>;
	dfegpio3-gpios = <&gpio0 29 0>;
them i chnage the antenna_partterns in main.c file.
#if defined(CONFIG_BT_DF_CTE_RX_AOA)
/*切换顺序,1,2,3,4,5,6,7,8,9,10,11,12    12根天线  */
/*static const uint8_t ant_patterns[] = { 0x1, 0x2, 0x3, 0x4, 0x5, 0x6, 0x7, 0x8, 0x9, 0xA };*/
/*切换顺序,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16    16根天线  */
static const uint8_t ant_patterns[] = { 0x0, 0x8, 0x4, 0xC, 0x2, 0xA, 0x6, 0xE,
			           0x1, 0x9, 0x5, 0xD, 0x3, 0xB, 0x7, 0xF };
#endif /* CONFIG_BT_DF_CTE_RX_AOA */
i also use the jlink_RTT for debug.
so i add the cofiguration in prg.conf file.
#RTT log
CONFIG_USE_SEGGER_RTT=y
CONFIG_RTT_CONSOLE=y
CONFIG_UART_CONSOLE=n
Then there are cnetral and peripheral output.
Central ie here.
00> [DEVICE]: 2E:94:E2:6F:B0:09 (random), AD evt type 3, Tx Pwr: 127, RSSI -63  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> --- 12 messages dropped ---
00> [DEVICE]: 70:7F:98:CA:58:AC (random), AD evt type 3, Tx Pwr: 127, RSSI -57  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: 7C:1A:F7:A7:12:0F (random), AD evt type 0, Tx Pwr: 127, RSSI -70  C:1 S:1 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: 7C:1A:F7:A7:12:0F (random), AD evt type 4, Tx Pwr: 127, RSSI -69  C:1 S:1 D:0 SR:1 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: 07:70:87:63:82:1E (random), AD evt type 3, Tx Pwr: 127, RSSI -67  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: CB:54:B9:46:AC:76 (random), AD evt type 3, Tx Pwr: 127, RSSI -82  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> 5
00>
00> [DEVICE]: 4F:A8:BD:F9:59:50 (random), AD evt type 4, Tx Pwr: 127, RSSI -53  C:1 S:1 D:0 SR:1 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> --- 22 messages dropped ---
00> [DEVICE]: 3A:22:E2:FF:55:2F (public), AD evt type 4, Tx Pwr: 127, RSSI -76  C:1 S:1 D:0 SR:1 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: 2A:DC:47:B4:68:5E (random), AD evt type 3, Tx Pwr: 127, RSSI -62  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: 34:5C:9E:BA:11:A1 (random), AD evt type 3, Tx Pwr: 127, RSSI -57  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: 20:97:88:23:62:86 (random), AD evt type 3, Tx Pwr: 127, RSSI -88  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00>
00> [DEVICE]: 6E:2A:15:B7:E6:1A (random), AD evt type 0, Tx Pwr: 127, RSSI -60  C:1 S:1 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: 6E:2A:15:B7:E6:1A (random), AD evt type 4, Tx Pwr: 127, RSSI -60  C:1 S:1 D:0 SR:1 E:0 Prim: LE 1M, Se5
00>
00> [DEVICE]: E6:BA:B9:9D:37:78 (random), AD evt type 3, Tx Pwr: 127, RSSI -57  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> --- 13 messages dropped ---
00> [DEVICE]: 2A:DC:47:B4:68:5E (random), AD evt type 3, Tx Pwr: 127, RSSI -47  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: CB:54:B9:46:AC:76 (random), AD evt type 3, Tx Pwr: 127, RSSI -86  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: 4F:A8:BD:F9:59:50 (random), AD evt type 0, Tx Pwr: 127, RSSI -60  C:1 S:1 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: 4F:A8:BD:F9:59:50 (random), AD evt type 4, Tx Pwr: 127, RSSI -60  C:1 S:1 D:0 SR:1 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: 34:5C:9E:BA:11:A1 (random), AD evt type 3, Tx Pwr: 127, RSSI -58  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: 7A:39:27:1B:CD:AB (random), AD evt type 0, Tx Pwr: 127, RSSI -78  C:1 S:1 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: 51:DA:[DEVICE]: 07:70:87:63:82:1E (random), AD evt type 3, Tx Pwr: 127, RSSI -59  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> --- 9 messages dropped ---
00> [DEVICE]: E6:BA:B9:9D:37:78 (random), AD evt type 3, Tx Pwr: 127, RSSI -57  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000[DEVICE]: 1B:96:2D:AC:6B:19 (random), AD evt type 3, Tx Pwr: 127, RSSI -53  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> --- 10 messages dropped ---
00> [DEVICE]: FA:0D:AC:D8:7B:0D (public), AD evt type 0, Tx Pwr: 127, RSSI -86  C:1 S:1 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000[DEVICE]: 14:15:D3:3D:3E:52 (random), AD evt type 3, Tx Pwr: 127, RSSI -78  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: 1B:96:2D:AC:6B:19 (random), AD evt type 3, Tx Pwr: 127, RSSI -55  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: E7:D0:A9:51:8B:6A (random), AD evt type 3, Tx Pwr: 127, RSSI -91  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: DE:86:9B:6D:43:F0 (random), AD evt type 0, Tx Pwr: 127, RSSI -35  C:1 S:1 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: DE:86:9B:6D:43:F0 (random), AD evt type 4, Tx Pwr: 127, RSSI -35 DF Conn App C:1 S:1 D[DEVICE]: DE:86:9B:6D:43:F0 (random), AD evt type 0, Tx Pwr: 127, RSSI -34  C:1 S:1 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> --- 15 messages dropped ---
00> [DEVICE]: DE:86:9B:6D:43:F0 (random), AD evt type 4, Tx Pwr: 127, RSSI -34 DF Conn App C:1 S:1 D:0 SR:1 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00>
00> [DEVICE]: FA:0D:AC:D8:7B:0D (public), AD evt type 4, Tx Pwr: 127, RSSI -87  C:1 S:1 D:0 SR:1 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: D4:73:12:3A:9E:8E (random), AD evt type 0, Tx Pwr: 127, RSSI -61  C:1 S:1 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: 1B:96:2D:AC:6B:19 (random), AD evt type 3, Tx Pwr: 127, RSSI -57  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: 2A:DC:47:B4:68:5E (random), AD evt type 3, Tx Pwr: 127, RSSI -61  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: 34:5C:9E:BA:11:A1 (random), AD evt type 3, Tx Pwr: 127, RSSI -54  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, [DEVICE]: 6E:2A:15:B7:E6:1A (random), AD evt type 4, Tx Pwr: 127, RSSI -54  C:1 S:1 D:0 SR:1 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> --- 7 messages dropped ---
00> [DEVICE]: 07:70:87:63:82:1E (random), AD evt type 3, Tx Pwr: 127, RSSI -66  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: FA:0D:AC:D8:7B:0D (public), AD evt type 4, Tx Pwr: 127, RSSI -85  C:1 S:1 D:0 SR:1 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: 2E:94:E2:6F:B0:09 (random), AD evt type 3, Tx Pwr: 127, RSSI -70  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: 7C:1A:F7:A7:12:0F (random), AD evt type 0, Tx Pwr: 127, RSSI -74  C:1 S:1 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: 7C:1A:F7:A7:12:0F (random), AD evt type 4, Tx Pwr: 127, RSSI -73  C:1 S:1 D:0 SR:1 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> 5
00>
00> [DEVICE]: 3A:22:E2:FF:55:2F (public), AD evt type 0, Tx Pwr: 127, RSSI -79  C:1 S:1 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: DE:86:9B:6D:43:F0 (random), AD evt type 0, Tx Pwr: 127, RSSI -38  C:1 S:1 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: DE:86:9B:6D:43:F0 (random), AD evt type 4, Tx Pwr: 127, RSSI -37 DF Conn App C:1 S:1 D:0 SR:1 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: 51:DA:93:DC:BC:1F (random), AD evt type 3, Tx Pwr: 127, RSSI -57  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: 1B:96:2D:AC:6B:19 (random), AD evt type 3, Tx Pwr: 127, RSSI -56  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: 70:7F:98:CA:58:AC (random), AD evt type 3, Tx Pwr: 127, RSSI -54  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: FA:0D:AC:D8:7B:0D (public), AD evt type 0, Tx Pwr: 127, RSSI -82  C:1 S:1 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: 6E:2A:15:B7:E6:1A (random), AD evt type 0, Tx Pwr: 127, RSSI -56  C:1 5
00>
00> [DEVICE]: 6E:2A:15:B7:E6:1A (random), AD evt type 4, Tx Pwr: 127, RSSI -56  C:1 S:1 D:0 SR:1 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: 07:70:87:63:82:1E (random), AD evt type 3, Tx Pwr: 127, RSSI -53  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: DE:86:9B:6D:43:F0 (random), AD evt type 4, Tx Pwr: 127, RSSI -35 DF Conn App C:1 S:1 D:0 SR:1 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: CB:54:B9:46:AC:76 (random), AD evt type 3, Tx Pwr: 127, RSSI -70  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: 2D:D1:CF:4F:44:22 (random), AD evt type 3, Tx Pwr: 127, RSSI -86  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00> [DEVICE]: 51:DA:93:DC:BC:1F (random), AD evt type 3, Tx Pwr: 127, RSSI -54  C:0 S:0 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000 (0 ms), SID: 255
00>
00>
00> [DEVICE]: 7A:39:27:1B:CD:AB (random), AD evt type 0, Tx Pwr: 127, RSSI -89  C:1 S:1 D:0 SR:0 E:0 Prim: LE 1M, Secn: No packets, Interval: 0x0000
(Connection lost)
Peripheral is here.
00> *** Booting Zephyr OS build zephyr-v3.0.0-2055-g736520a4fef6  ***
00>
00> [    0.383178] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
00> [    0.383178] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
00> [    0.383209] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 3.0 Build 99
00> [    0.383972] <inf> bt_hci_core: Identity: DE:86:9B:6D:43:F0 (random)
00> [    0.383972] <inf> bt_hci_core: HCI: version 5.3 (0x0c) revision 0x0000, manufacturer 0x05f1
00> [    0.384002] <inf> bt_hci_core: LMP: version 5.3 (0x0c) subver 0xffff
00> Bluetooth initialized
00>
00> Advertising successfully started
00>
The four gpio are always zero by Logical Anylazey.
what is thia problem?
  • In general see:
    https://devzone.nordicsemi.com/f/nordic-q-a/79814/aoa-aod-using-nrf52833/330276#330276
    In specific on how to control the gpios used for antenna array:
    https://devzone.nordicsemi.com/f/nordic-q-a/83857/ncs-1-8-direction_finding_connectionless_rx-aoa-can-t-work/348715#348715
    My suggestion is to build the Direction finding connectionless locator as-is without any modifications first to ensure that gpios toggle as expected, after this you can start to do modifications one by one.
    Kenneth
  • ok,i try as you suggest.In the default setsetting,i can get the iq sample form my Tx.i only change the configuration about the antenna array.The antenna _num and antenna_partterns,because i use 16 antenna array.
    i only chnage the overlay file in nrf52833dk_nrf52833.overlay and change some configuration in main.c file.
    The overlay file have been changed as follow.
    &radio {
    	status = "okay";
    The main.c file have been changed as here.
    but this problem i also meet in connection.so i think it is design problem.
    because it can't more than 16 antennae,so i do some test about both design.
    another problem in connectionless have err code -22.The link is here.
    i wait for your solution abot this,because i can get what this problem is.Thanks for your reply.
  • i use the default configuration,i can get the iq sample.i use the NCS 1.9.1.
    The next is my RTT log.
    The Central is here.
    [DEVICE]: 21:96:6C:1E:CB:69 (random), AD evt type 3, AD data len 29, RSSI -80
    [DEVICE]: 70:61:EE:22:88:0C (public), AD evt type 0, AD data len 21, RSSI -75
    [AD]: 1 data_len 1
    [AD]: 255 data_len 6
    [AD]: 3 data_len 4
    [AD]: 25 data_len 2
    [DEVICE]: 14:15:D3:3D:3E:52 (random), AD evt type 3, AD data len 30, RSSI -89
    [DEVICE]: 71:D1:E4:4C:43:A6 (random), AD evt type 3, AD data len 31, RSSI -57
    [DEVICE]: FA:0D:AC:D8:7B:0D (public), AD evt type 0, AD data len 29, RSSI -89
    [AD]: 1 data_len 1
    [AD]: 22 data_len 24
    [DEVICE]: 0D:21:6D:C2:DB:3D (random), AD evt type 3, AD data len 28, RSSI -57
    [DEVICE]: 70:61:EE:22:88:0C (public), AD evt type 0, AD data len 21, RSSI -74
    [AD]: 1 data_len 1
    [AD]: 3 data_len 4
    [AD]: 25 data_len 2
    [DEVICE]: 70:61:EE:22:88:0C (public), AD evt type 4, AD data len 10, RSSI -74
    [DEVICE]: 47:E3:97:88:53:3F (random), AD evt type 3, AD data len 31, RSSI -53
    [DEVICE]: 14:15:D3:3D:3E:52 (random), AD evt type 3, AD data len 30, RSSI -80
    [DEVICE]: 70:61:EE:22:88:0C (public), AD evt type 0, AD data len 21, RSSI -70
    [AD]: 1 data_len 1
    [AD]: 3 data_len 4
    [AD]: 25 data_len 2
    [DEVICE]: 64:6C:2F:8F:6E:A6 (random), AD evt type 0, AD data len 18, RSSI -64
    [AD]: 1 data_len 1
    [AD]: 10 data_len 1
    [AD]: 255 data_len 10
    [DEVICE]: 21:96:6C:1E:CB:69 (random), AD evt type 3, AD data len 29, RSSI -81
    [DEVICE]: 32:73:80:E1:71:49 (random), AD evt type 3, AD data len 31, RSSI -62
    [DEVICE]: 3C:B4:3F:6B:1D:76 (random), AD evt type 3, AD data len 31, RSSI -67
    [DEVICE]: 2B:66:26:D3:FB:E2 (random), AD evt type 3, AD data len 31, RSSI -55
    [DEVICE]: 2B:B7:DF:8D:D8:C5 (random), AD evt type 3, AD data len 31, RSSI -53
    [AD]: 1 data_len 1
    [AD]: 3 data_len 4
    [AD]: 25 data_len 2
    [DEVICE]: 70:61:EE:22:88:0C (public), AD evt type 4, AD data len 10, RSSI -70
    [DEVICE]: 21:96:6C:1E:CB:69 (random), AD evt type 3, AD data len 29, RSSI -70
    [DEVICE]: 32:73:80:E1:71:49 (random), AD evt type 3, AD data len 31, RSSI -63
    [DEVICE]: 2B:66:26:D3:FB:E2 (random), AD evt type 3, AD data len 31, RSSI -64
    [DEVICE]: 2B:B7:DF:8D:D8:C5 (random), AD evt type 3, AD data len 31, RSSI -57
    [AD]: 1 data_len 1
    [AD]: 3 data_len 4
    [AD]: 25 data_len 2
    [DEVICE]: 00:14:BE:60:20:C1 (public), AD evt type 0, AD data len 15, RSSI -53
    [AD]: 1 data_len 1
    [AD]: 2 data_len 2
    [AD]: 9 data_len 6
    [DEVICE]: 00:14:BE:60:20:C1 (public), AD evt type 4, AD data len 0, RSSI -53
    [DEVICE]: 14:15:D3:3D:3E:52 (random), AD evt type 3, AD data len 30, RSSI -76
    [DEVICE]: 47:E3:97:88:53:3F (random), AD evt type 3, AD data len 31, RSSI -55
    [DEVICE]: 2B:B7:DF:8D:D8:C5 (random), AD evt type 3, AD data len 31, RSSI -60
    [DEVICE]: 3A:22:E2:FF:55:2F (public), AD evt type 0, AD data len 29, RSSI -76
    [AD]: 1 data_len 1
    [DEVICE]: 3A:22:E2:FF:55:2F (public), AD evt type 4, AD data len 11, RSSI -76
    [DEVICE]: 14:15:D3:3D:3E:52 (random), AD evt type 3, AD data len 30, RSSI -88
    [AD]: 1 data_len 1
    [AD]: 3 data_len 4
    [AD]: 25 data_len 2
    [DEVICE]: 47:E3:97:88:53:3F (random), AD evt type 3, AD data len 31, RSSI -61
    [AD]: 1 data_len 1
    [AD]: 3 data_len 4
    [AD]: 25 data_len 2
    [DEVICE]: 70:61:EE:22:88:0C (public), AD evt type 4, AD data len 10, RSSI -69
    [AD]: 1 data_len 1
    [AD]: 3 data_len 4
    [AD]: 25 data_len 2
    [AD]: 1 data_len 1
    [AD]: 3 data_len 4
    [AD]: 25 data_len 2
    [DEVICE]: 14:15:D3:3D:3E:52 (random), AD evt type 3, AD data len 30, RSSI -87
    [DEVICE]: 75:E1:45:66:48:EF (random), AD evt type 0, AD data len 17, RSSI -89
    [AD]: 1 data_len 1
    [AD]: 10 data_len 1
    [AD]: 255 data_len 9
    [DEVICE]: 2B:66:26:D3:FB:E2 (random), AD evt type 3, AD data len 31, RSSI -56
    [DEVICE]: 3A:22:E2:FF:55:2F (public), AD evt type 0, AD data len 29, RSSI -72
    [AD]: 1 data_len 1
    [DEVICE]: 3A:22:E2:FF:55:2F (public), AD evt type 4, AD data len 11, RSSI -71
    [AD]: 1 data_len 1
    [AD]: 3 data_len 4
    [AD]: 25 data_len 2
    [DEVICE]: 71:D1:E4:4C:43:A6 (random), AD evt type 3, AD data len 31, RSSI -54
    [DEVICE]: 3C:B4:3F:6B:1D:76 (random), AD evt type 3, AD data len 31, RSSI -64
    [DEVICE]: 3A:22:E2:FF:55:2F (public), AD evt type 0, AD data len 29, RSSI -84
    [AD]: 1 data_len 1
    [DEVICE]: 3A:22:E2:FF:55:2F (public), AD evt type 4, AD data len 11, RSSI -83
    [AD]: 1 data_len 1
    [AD]: 3 data_len 4
    [AD]: 25 data_len 2
    [DEVICE]: 64:6C:2F:8F:6E:A6 (random), AD evt type 0, AD data len 18, RSSI -61
    [AD]: 1 data_len 1
    [AD]: 10 data_len 1
    [DEVICE]: 64:6C:2F:8F:6E:A6 (random), AD evt type 4, AD data len 0, RSSI -61
    [DEVICE]: 71:D1:E4:4C:43:A6 (random), AD evt type 3, AD data len 31, RSSI -59
    [DEVICE]: 47:E3:97:88:53:3F (random), AD evt type 3, AD data len 31, RSSI -57
    [DEVICE]: 47:E3:97:88:53:3F (random), AD evt type 3, AD data len 31, RSSI -60
    [DEVICE]: 70:61:EE:22:88:0C (public), AD evt type 0, AD data len 21, RSSI -76
    [AD]: 1 data_len 1
    [AD]: 3 data_len 4
    [AD]: 25 data_len 2
    [DEVICE]: 70:61:EE:22:88:0C (public), AD evt type 4, AD data len 10, RSSI -75
    [DEVICE]: 14:15:D3:3D:3E:52 (random), AD evt type 3, AD data len 30, RSSI -77
    [DEVICE]: 2B:B7:DF:8D:D8:C5 (random), AD evt type 3, AD data len 31, RSSI -61
    [DEVICE]: 2B:66:26:D3:FB:E2 (random), AD evt type 3, AD data len 31, RSSI -60
    [AD]: 1 data_len 1
    [AD]: 3 data_len 4
    [AD]: 25 data_len 2
    [DEVICE]: 3A:22:E2:FF:55:2F (public), AD evt type 0, AD data len 29, RSSI -77
    [AD]: 1 data_len 1
    [AD]: 1 data_len 1
    [AD]: 3 data_len 4
    [AD]: 25 data_len 2
    [DEVICE]: 3A:22:E2:FF:55:2F (public), AD evt type 0, AD data len 29, RSSI -71
    [AD]: 1 data_len 1
    [DEVICE]: 70:61:EE:22:88:0C (public), AD evt type 0, AD data len 21, RSSI -71
    [AD]: 1 data_len 1
    [AD]: 3 data_len 4
    [AD]: 25 data_len 2
    [DEVICE]: 4A:17:18:10:9A:87 (random), AD evt type 0, AD data len 18, RSSI -79
    [AD]: 1 data_len 1
    [AD]: 10 data_len 1
    [DEVICE]: 4A:17:18:10:9A:87 (random), AD evt type 4, AD data len 21, RSSI -78
    [AD]: 1 data_len 1
    [AD]: 3 data_len 4
    [AD]: 25 data_len 2
    [AD]: 1 data_len 1
    [AD]: 10 data_len 1
    [DEVICE]: 2B:B7:DF:8D:D8:C5 (random), AD evt type 3, AD data len 31, RSSI -52
    [DEVICE]: 70:61:EE:22:88:0C (public), AD evt type 0, AD data len 21, RSSI -69
    [AD]: 1 data_len 1
    [AD]: 3 data_len 4
    [AD]: 25 data_len 2
    [DEVICE]: 2B:B7:DF:8D:D8:C5 (random), AD evt type 3, AD data len 31, RSSI -56
    [DEVICE]: 4A:17:18:10:9A:87 (random), AD evt type 0, AD data len 18, RSSI -78
    [AD]: 1 data_len 1
    [AD]: 10 data_len 1
    [DEVICE]: 4A:17:18:10:9A:87 (random), AD evt type 4, AD data len 21, RSSI -77
    [DEVICE]: 2B:66:26:D3:FB:E2 (random), AD evt type 3, AD data len 31, RSSI -63
    [DEVICE]: 71:D1:E4:4C:43:A6 (random), AD evt type 3, AD data len 31, RSSI -60
    [AD]: 1 data_len 1
    [AD]: 3 data_len 4
    [AD]: 25 data_len 2
    [DEVICE]: 70:61:EE:22:88:0C (public), AD evt type 4, AD data len 10, RSSI -73
    [DEVICE]: 9C:19:C2:41:F1:35 (public), AD evt type 0, AD data len 30, RSSI -91
    [AD]: 1 data_len 1
    [AD]: 2 data_len 4
    [AD]: 9 data_len 19
    [AD]: 1 data_len 1
    [AD]: 3 data_len 4
    [AD]: 25 data_len 2
    [DEVICE]: 3C:B4:3F:6B:1D:76 (random), AD evt type 3, AD data len 31, RSSI -58
    [AD]: 1 data_len 1
    [AD]: 3 data_len 4
    [AD]: 25 data_len 2
    [AD]: 1 data_len 1
    [DEVICE]: 3C:B4:3F:6B:1D:76 (random), AD evt type 3, AD data len 31, RSSI -65
    [AD]: 1 data_len 1
    [AD]: 3 data_len 4
    [AD]: 25 data_len 2
    [AD]: 1 data_len 1
    [AD]: 10 data_len 1
    [DEVICE]: DE:86:9B:6D:43:F0 (random), AD evt type 0, AD data len 8, RSSI -55
    [AD]: 1 data_len 1
    [AD]: 39 data_len 3
    Connected: DE:86:9B:6D:43:F0 (random)
    Enable receiving of CTE...
    success. CTE receive enabled.
    Request CTE from peer device...
    success. CTE request enabled.
    CTE[DE:86:9B:6D:43:F0 (random)]: samples count 4, cte type AOA, slot durations: 2 [us], packet status CRC not OK, CTE Info OK, RSSI -720
    IQ sample content :
    sample[0] = I:-5 Q:-32
    sample[1] = I:31 Q:-3
    sample[2] = I:0 Q:32
    sample[3] = I:-31 Q:-3
    CTE[DE:86:9B:6D:43:F0 (random)]: samples count 4, cte type AOA, slot durations: 2 [us], packet status CRC not OK, CTE Info OK, RSSI -730
    IQ sample content :
    sample[0] = I:4 Q:-32
    sample[1] = I:31 Q:5
    sample[2] = I:-10 Q:29
    sample[3] = I:-30 Q:-11
    CTE[DE:86:9B:6D:43:F0 (random)]: samples count 45, cte type AOA, slot durations: 2 [us], packet status CRC OK, RSSI -730
    IQ sample content :
    sample[0] = I:-22 Q:4
    sample[1] = I:-3 Q:-22
    sample[2] = I:21 Q:1
    sample[3] = I:-2 Q:21
    sample[4] = I:-22 Q:-4
    sample[5] = I:4 Q:-22
    sample[6] = I:20 Q:5
    sample[7] = I:-9 Q:19
    sample[8] = I:7 Q:2
    sample[9] = I:-16 Q:-2
    sample[10] = I:-35 Q:-20
    sample[11] = I:-33 Q:36
    sample[12] = I:27 Q:-8
    sample[13] = I:-7 Q:-1
    sample[14] = I:9 Q:17
    sample[15] = I:-4 Q:-5
    sample[16] = I:-2 Q:-5
    sample[17] = I:12 Q:-59
    sample[18] = I:13 Q:-15
    sample[19] = I:-5 Q:-8
    sample[20] = I:11 Q:9
    sample[21] = I:17 Q:34
    sample[22] = I:45 Q:-18
    sample[23] = I:-28 Q:-8
    sample[24] = I:4 Q:4
    sample[25] = I:-1 Q:-21
    sample[26] = I:0 Q:5
    sample[27] = I:-2 Q:6
    sample[28] = I:-42 Q:44
    sample[29] = I:-19 Q:6
    sample[30] = I:1 Q:9
    sample[31] = I:-4 Q:-16
    sample[32] = I:2 Q:-41
    sample[33] = I:-48 Q:-13
    sample[34] = I:18 Q:20
    sample[35] = I:-1 Q:-6
    sample[36] = I:-12 Q:16
    sample[37] = I:2 Q:-5
    sample[38] = I:3 Q:-5
    sample[39] = I:59 Q:-15
    sample[40] = I:19 Q:1
    sample[41] = I:4 Q:-8
    sample[42] = I:-4 Q:14
    sample[43] = I:-23 Q:32
    sample[44] = I:36 Q:34
    CTE[DE:86:9B:6D:43:F0 (random)]: samples count 45, cte type AOA, slot durations: 2 [us], packet status CRC OK, RSSI -640
    IQ sample content :
    sample[0] = I:15 Q:2
    sample[1] = I:-15 Q:-4
    sample[2] = I:15 Q:3
    sample[3] = I:-16 Q:-5
    sample[4] = I:16 Q:4
    sample[5] = I:-16 Q:-5
    sample[6] = I:15 Q:5
    sample[7] = I:-15 Q:-6
    sample[8] = I:-9 Q:2
    sample[9] = I:-9 Q:1
    sample[10] = I:-19 Q:-1
    sample[11] = I:-9 Q:24
    sample[12] = I:1 Q:-11
    sample[13] = I:-1 Q:2
    sample[14] = I:4 Q:-4
    sample[15] = I:-2 Q:1
    sample[16] = I:-2 Q:1
    sample[17] = I:-18 Q:12
    sample[18] = I:-15 Q:-7
    sample[19] = I:-7 Q:-7
    sample[20] = I:-6 Q:-8
    sample[21] = I:-10 Q:-16
    sample[22] = I:-25 Q:5
    sample[23] = I:9 Q:-3
    sample[24] = I:-2 Q:1
    sample[25] = I:5 Q:2
    sample[26] = I:-2 Q:0
    sample[27] = I:-3 Q:-1
    sample[28] = I:-21 Q:-9
    sample[29] = I:-1 Q:-18
    sample[30] = I:3 Q:-9
    sample[31] = I:2 Q:-8
    sample[32] = I:7 Q:-17
    sample[33] = I:-15 Q:-21
    sample[34] = I:7 Q:7
    sample[35] = I:-2 Q:-3
    sample[36] = I:-1 Q:5
    sample[37] = I:-1 Q:-2
    sample[38] = I:-1 Q:-2
    sample[39] = I:-2 Q:-22
    sample[40] = I:14 Q:-9
    sample[41] = I:9 Q:-2
    sample[42] = I:8 Q:-2
    sample[43] = I:17 Q:0
    sample[44] = I:9 Q:-25
    CTE[DE:86:9B:6D:43:F0 (random)]: samples count 45, cte type AOA, slot durations: 2 [us], packet status CRC OK, RSSI -770
    IQ sample content :
    sample[0] = I:-21 Q:7
    sample[1] = I:22 Q:-8
    sample[2] = I:-22 Q:7
    sample[3] = I:21 Q:-6
    sample[4] = I:-23 Q:5
    sample[5] = I:22 Q:-5
    sample[6] = I:-22 Q:6
    sample[7] = I:21 Q:-6
    sample[8] = I:-6 Q:-3
    sample[9] = I:9 Q:-11
    sample[10] = I:33 Q:-25
    sample[11] = I:-25 Q:-35
    sample[12] = I:8 Q:20
    sample[13] = I:0 Q:-5
    sample[14] = I:-5 Q:17
    sample[15] = I:0 Q:-4
    sample[16] = I:1 Q:-3
    sample[17] = I:18 Q:-44
    sample[18] = I:16 Q:-12
    sample[19] = I:-1 Q:-6
    sample[20] = I:14 Q:4
    sample[21] = I:38 Q:16
    sample[22] = I:17 Q:-38
    sample[23] = I:-14 Q:20
    sample[24] = I:4 Q:-1
    sample[25] = I:-18 Q:5
    sample[26] = I:3 Q:1
    sample[27] = I:3 Q:0
    sample[28] = I:47 Q:0
    sample[29] = I:17 Q:9
    sample[30] = I:4 Q:-4
    sample[31] = I:2 Q:14
    sample[32] = I:2 Q:42
    sample[33] = I:41 Q:-2
    sample[34] = I:-24 Q:-3
    sample[35] = I:2 Q:3
    sample[36] = I:-13 Q:-14
    sample[37] = I:1 Q:3
    sample[38] = I:1 Q:2
    sample[39] = I:22 Q:42
    sample[40] = I:0 Q:18
    sample[41] = I:3 Q:1
    sample[42] = I:-11 Q:9
    sample[43] = I:-34 Q:23
    sample[44] = I:23 Q:35
    CTE[DE:86:9B:6D:43:F0 (random)]: samples count 1, cte type AOA, slot durations: 2 [us], packet status CRC not OK, CTE Info OK, RSSI -630
    IQ sample content :
    sample[0] = I:-8 Q:-8
    IQ sample content :
    CTE[DE:86:9B:6D:43:F0 (random)]: samples count 1, cte type AOA, slot durations: 2 [us], packet status CRC not OK, CTE Info OK, RSSI -620
    IQ sample content :
    CTE[DE:86:9B:6D:43:F0 (random)]: samples count 45, cte type AOA, slot durations: 2 [us], packet status CRC OK, RSSI -620
    IQ sample content :
    sample[0] = I:0 Q:-5
    sample[1] = I:-1 Q:5
    sample[2] = I:0 Q:-6
    sample[3] = I:-1 Q:5
    sample[4] = I:0 Q:-6
    sample[5] = I:-1 Q:4
    sample[6] = I:0 Q:-6
    sample[7] = I:-1 Q:5
    sample[8] = I:-5 Q:8
    sample[9] = I:8 Q:-3
    sample[10] = I:13 Q:-5
    sample[11] = I:-4 Q:0
    sample[12] = I:-2 Q:6
    sample[13] = I:4 Q:-2
    sample[14] = I:-1 Q:2
    sample[15] = I:4 Q:-1
    sample[16] = I:4 Q:-1
    sample[17] = I:22 Q:-9
    sample[18] = I:-1 Q:3
    sample[19] = I:-11 Q:0
    sample[20] = I:6 Q:6
    sample[21] = I:9 Q:10
    sample[22] = I:-2 Q:-4
    sample[23] = I:-7 Q:2
    sample[24] = I:3 Q:2
    sample[25] = I:-2 Q:1
    sample[26] = I:2 Q:3
    sample[27] = I:2 Q:3
    sample[28] = I:17 Q:16
    sample[29] = I:-5 Q:0
    sample[30] = I:-6 Q:-9
    sample[31] = I:-3 Q:8
    sample[32] = I:-4 Q:13
    sample[33] = I:2 Q:-4
    sample[34] = I:-5 Q:-5
    sample[35] = I:-1 Q:4
    sample[36] = I:-3 Q:-2
    sample[37] = I:-2 Q:3
    sample[38] = I:-2 Q:3
    sample[39] = I:-5 Q:24
    sample[40] = I:-4 Q:-3
    sample[41] = I:5 Q:-9
    sample[42] = I:-9 Q:1
    sample[43] = I:-14 Q:5
    sample[44] = I:3 Q:0
    CTE[DE:86:9B:6D:43:F0 (random)]: samples count 1, cte type AOA, slot durations: 2 [us], packet status CRC not OK, CTE Info OK, RSSI -580
    IQ sample content :
    sample[0] = I:-9 Q:10
    CTE[DE:86:9B:6D:43:F0 (random)]: samples count 45, cte type AOA, slot durations: 2 [us], packet status CRC OK, RSSI -580
    IQ sample content :
    sample[0] = I:-2 Q:13
    sample[1] = I:0 Q:-14
    sample[2] = I:-2 Q:13
    sample[3] = I:1 Q:-14
    sample[4] = I:-3 Q:12
    sample[5] = I:2 Q:-14
    sample[6] = I:-3 Q:13
    sample[7] = I:2 Q:-14
    sample[8] = I:10 Q:-8
    sample[9] = I:-12 Q:-2
    sample[10] = I:-9 Q:-10
    sample[11] = I:0 Q:-3
    sample[12] = I:3 Q:-10
    sample[13] = I:-4 Q:5
    sample[14] = I:4 Q:7
    sample[15] = I:-5 Q:3
    sample[16] = I:-6 Q:3
    sample[17] = I:-28 Q:5
    sample[18] = I:2 Q:-4
    sample[19] = I:11 Q:3
    sample[20] = I:-2 Q:-13
    sample[21] = I:4 Q:-13
    sample[22] = I:1 Q:-1
    sample[23] = I:10 Q:-2
    sample[24] = I:-7 Q:-2
    sample[25] = I:-4 Q:7
    sample[26] = I:-6 Q:-3
    sample[27] = I:-6 Q:-4
    sample[28] = I:-18 Q:-24
    sample[29] = I:4 Q:-1
    sample[30] = I:1 Q:11
    sample[31] = I:8 Q:-9
    sample[32] = I:12 Q:-4
    sample[33] = I:1 Q:1
    sample[34] = I:6 Q:7
    sample[35] = I:-2 Q:-7
    sample[36] = I:-9 Q:0
    sample[37] = I:0 Q:-7
    sample[38] = I:-1 Q:-7
    sample[39] = I:11 Q:-27
    sample[40] = I:2 Q:2
    sample[41] = I:-10 Q:7
    sample[42] = I:12 Q:1
    sample[43] = I:9 Q:9
    sample[44] = I:-1 Q:1
    CTE[DE:86:9B:6D:43:F0 (random)]: samples count 1, cte type AOA, slot durations: 2 [us], packet status CRC not OK, CTE Info OK, RSSI -570
    IQ sample content :
    sample[0] = I:8 Q:-6
    IQ sample content :
    CTE[DE:86:9B:6D:43:F0 (random)]: samples count 1, cte type AOA, slot durations: 2 [us], packet status CRC not OK, CTE Info OK, RSSI -590
    IQ sample content :
    CTE[DE:86:9B:6D:43:F0 (random)]: samples count 1, cte type AOA, slot durations: 2 [us], packet status CRC not OK, CTE Info OK, RSSI -600
    IQ sample content :
    CTE[DE:86:9B:6D:43:F0 (random)]: samples count 1, cte type AOA, slot durations: 2 [us], packet status CRC not OK, CTE Info OK, RSSI -610
    IQ sample content :
    IQ sample content :
    IQ sample content :
    IQ sample content :
    IQ sample content :
    IQ sample content :
    IQ sample content :
    IQ sample content :
    CTE[DE:86:9B:6D:43:F0 (random)]: samples count 1, cte type AOA, slot durations: 2 [us], packet status CRC not OK, CTE Info OK, RSSI -520
    IQ sample content :
    IQ sample content :
    CTE[DE:86:9B:6D:43:F0 (random)]: samples count 45, cte type AOA, slot durations: 2 [us], packet status CRC OK, RSSI -520
    IQ sample content :
    sample[0] = I:-4 Q:-4
    sample[1] = I:4 Q:3
    sample[2] = I:-4 Q:-4
    sample[3] = I:3 Q:4
    sample[4] = I:-4 Q:-5
    sample[5] = I:3 Q:3
    sample[6] = I:-4 Q:-4
    sample[7] = I:3 Q:4
    sample[8] = I:2 Q:11
    sample[9] = I:4 Q:3
    sample[10] = I:1 Q:3
    sample[11] = I:2 Q:2
    sample[12] = I:-3 Q:5
    sample[13] = I:-3 Q:-2
    sample[14] = I:-10 Q:1
    sample[15] = I:-3 Q:-2
    sample[16] = I:-2 Q:-2
    sample[17] = I:1 Q:-12
    sample[18] = I:-4 Q:6
    sample[19] = I:-9 Q:6
    sample[20] = I:-2 Q:4
    sample[21] = I:-2 Q:3
    sample[22] = I:-1 Q:3
    sample[23] = I:-6 Q:0
    sample[24] = I:-1 Q:-3
    sample[25] = I:-6 Q:-9
    sample[26] = I:0 Q:-3
    sample[27] = I:0 Q:-3
    sample[28] = I:11 Q:-5
    sample[29] = I:-7 Q:0
    sample[30] = I:-11 Q:-4
    sample[31] = I:-5 Q:1
    sample[32] = I:-4 Q:0
    sample[33] = I:-4 Q:1
    sample[34] = I:-4 Q:-5
    sample[35] = I:2 Q:-2
    sample[36] = I:4 Q:-10
    sample[37] = I:2 Q:-2
    sample[38] = I:2 Q:-1
    sample[39] = I:8 Q:8
    sample[40] = I:-5 Q:-6
    sample[41] = I:-3 Q:-11
    sample[42] = I:-4 Q:-4
    sample[43] = I:-3 Q:-3
    sample[44] = I:-3 Q:-3
    CTE[DE:86:9B:6D:43:F0 (random)]: samples count 45, cte type AOA, slot durations: 2 [us], packet status CRC OK, RSSI -510
    IQ sample content :
    sample[1] = I:-1 Q:4
    sample[2] = I:1 Q:-5
    sample[3] = I:-2 Q:3
    sample[4] = I:0 Q:-5
    sample[6] = I:1 Q:-5
    sample[7] = I:-2 Q:4
    sample[8] = I:-8 Q:9
    sample[9] = I:-3 Q:5
    sample[10] = I:0 Q:5
    sample[11] = I:-2 Q:4
    sample[12] = I:-4 Q:2
    sample[13] = I:-1 Q:-3
    sample[14] = I:-7 Q:-8
    sample[15] = I:-1 Q:-3
    sample[16] = I:-1 Q:-3
    sample[17] = I:10 Q:-8
    sample[18] = I:-9 Q:3
    sample[19] = I:-13 Q:-4
    sample[20] = I:-6 Q:0
    sample[21] = I:-4 Q:2
    sample[22] = I:-4 Q:0
    sample[23] = I:-4 Q:-2
    sample[24] = I:1 Q:-2
    sample[25] = I:3 Q:-11
    sample[26] = I:1 Q:-2
    sample[27] = I:1 Q:-2
    sample[28] = I:10 Q:5
    sample[29] = I:-6 Q:-7
    sample[30] = I:-5 Q:-11
    sample[31] = I:-5 Q:-5
    sample[32] = I:-4 Q:-1
    sample[33] = I:-4 Q:-4
    sample[34] = I:-1 Q:-5
    sample[35] = I:2 Q:0
    sample[36] = I:9 Q:-2
    sample[37] = I:2 Q:0
    sample[38] = I:1 Q:1
    sample[39] = I:-2 Q:12
    sample[40] = I:1 Q:-9
    sample[41] = I:6 Q:-9
    sample[42] = I:1 Q:-6
    sample[43] = I:-1 Q:-5
    sample[44] = I:1 Q:-5
    IQ sample content :
    The Peripheral is here.
    *** Booting Zephyr OS build v2.7.99-ncs1-1  ***
    [00:00:00.385,375] <inf> bt_hci_core: HW Platform: Nordic SemiconductoConnected
    Set CTE transmission params...success.
    Set CTE response enable...success.
    r (0x0002)
    [00:00:00.385,406] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
    [00:00:00.385,406] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0        x00) Version 2.7 Build 99
    [00:00:00.386,108] <inf> bt_hci_core: Identity: DE:86:9B:6D:43:F0 (random)
    [00:00:00.386,138] <inf> bt_hci_core: HCI: version 5.3 (0x0c) revision 0x0000, m        anufacturer 0x05f1
    [00:00:00.386,138] <inf> bt_hci_core: LMP: version 5.3 (0x0c) subver 0xffff
    Disconnected (reason 0x08)
    Connected
    Connected
    Connected
    Connected
    Connected
    Connected
    Connected
    Connected
    what else information do you want to get?it may be helpful for you.thanks.
