How to implement SPIM in net core (nRF5340) - No SPI signal detedted
Hi there,
I have a problem to implement the SPIM in the Network core. I cannot detect any signal from SPI_SCK & SPI_MOSI by oscilloscope and logic analyzer (no signal from other two pins SS & MISO either)
Is there anything I need to configure to enable the SPIM in Network node?
I flashed the "empty_app_core" example code to the App core
And I wrote a simple code to test the SPIM functionality (signal output in SCK and MOSI)
It is the main.c for network core.
//main on SPI master
#include <zephyr.h>
#include "nrf.h"
#include <nrfx_spim.h>
#include <string.h>
#include <logging/log.h>
#define LOG_MODULE_NAME spi_master
LOG_MODULE_REGISTER(LOG_MODULE_NAME, LOG_LEVEL_DBG);
static const nrfx_spim_t net_spim = NRFX_SPIM_INSTANCE(0);
#define APP_SPIM_CS_PIN (9)
#define APP_SPIM_SCK_PIN (7)
#define APP_SPIM_MISO_PIN (6)
#define APP_SPIM_MOSI_PIN (5)
void net_spi_init(void){
	nrfx_spim_config_t spim_config =
	NRFX_SPIM_DEFAULT_CONFIG(APP_SPIM_SCK_PIN, APP_SPIM_MOSI_PIN, APP_SPIM_MISO_PIN, APP_SPIM_CS_PIN);
    // spim_config.frequency = NRF_SPIM_FREQ_1M;
    // spim_config.mode      = NRF_SPIM_MODE_1;
    // spim_config.bit_order = NRF_SPIM_BIT_ORDER_MSB_FIRST;
    if (NRFX_SUCCESS != nrfx_spim_init(&net_spim, &spim_config, NULL, NULL)) {
		LOG_DBG("Init Failed\n");
		return;
void main(void)
	LOG_DBG("SPIM example\n");
    net_spi_init();
    int i = 0;
    uint8_t writeReg_array[5] = "12345";
    uint8_t reg_data[5] = "00000";
    while(1){
        nrfx_spim_xfer_desc_t xfer_desc;
        xfer_desc.p_tx_buffer = writeReg_array;
        xfer_desc.tx_length = 5;
        xfer_desc.p_rx_buffer = NULL;
        xfer_desc.rx_length = 0;
        nrfx_spim_xfer(&net_spim,&xfer_desc,0);
        k_sleep(K_MSEC(1000));
        i++;
        LOG_DBG("SPIM write test %d\n",i);
And the prj.conf file
CONFIG_SERIAL=y
CONFIG_LOG=y
CONFIG_HEAP_MEM_POOL_SIZE=4096
CONFIG_SPI=y
CONFIG_NRFX_SPIM=y
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_NRFX_SPIM0=y
CONFIG_RTT_CONSOLE=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
I can see the log in RTT viewer
00> *** Booting Zephyr OS build v2.7.99-ncs1-1  ***
00>
00> [00:00:00.421,936] <dbg> spi_master.main: SPIM example
00>
00> [00:00:01.422,058] <dbg> spi_master.main: SPIM write test 1
00>
00> [00:00:02.422,210] <dbg> spi_master.main: SPIM write test 2
00>
00> [00:00:03.422,332] <dbg> spi_master.main: SPIM write test 3
00>
00> [00:00:04.422,454] <dbg> spi_master.main: SPIM write test 4
00>
00> [00:00:05.422,576] <dbg> spi_master.main: SPIM write test 5
00>
00> [00:00:06.422,698] <dbg> spi_master.main: SPIM write test 6
00>
00> [00:00:07.422,821] <dbg> spi_master.main: SPIM write test 7
00>
00> [00:00:08.422,943] <dbg> spi_master.main: SPIM write test 8
00>
00> [00:00:09.423,065] <dbg> spi_master.main: SPIM write test 9
However, there is no signal output from SCK and MOSI pin.
SDK version: nRF Connect toolchain v1.9.0
    Try removing CONFIG_SPI=y and add an overlay file which disables uart0.
  • Hi
    Thanks for your quick reply.
    I did the modification in prj.conf
    CONFIG_SERIAL=y
    CONFIG_LOG=y
    # CONFIG_SPI=y  #remove
    CONFIG_NRFX_SPIM=y
    CONFIG_NRFX_SPIM0=y
    And created a nrf5340_cpunet.overlay under the same directory of prj.conf.
    &uart0 {
    	status = "disabled";
    However, it doesn't work either. No SPI signal is detected.
  • Are you building for a custom board named nrf5340_cpunet?
    If you are building for the nrf5340dk_nrf5340_cpunet board, the overlay file should have the same name.
    Make sure that it is selected as an overlay in the build log.
  • Yeah. Currently, we use nrf5340dk for early edge development. I changed the overlay file's name to "nrf5340dk_nrf5340_cpunet".
    I also disabled all the uart functions in Kconfig, and save the changes to both prj.conf and build/zephyr/.conf files
  • I have a question about the nrf5340dk_nrf5340_cpunet.dts and nrf5340dk_nrf5340_cpunet.overlay files.
    I see the content in nrf5340dk_nrf5340_cpunet.dts will be overwritten by nrf5340dk_nrf5340_cpunet.overlay.
    And I found that there is a pinset definition for all four SPI pins in nrf5340dk_nrf5340_cpunet.dts file.
    arduino_spi: &spi0 {
    	/* Cannot be used together with uart0. */
    	/* status = "okay"; */
    	sck-pin = <47>;
    	miso-pin = <46>;
    	mosi-pin = <45>;
    	cs-gpios = <&arduino_header 16 GPIO_ACTIVE_LOW>; /* D10 */
    Do I need to overwrite those pins value in my .overlay file?
    Also, if I set up the SPI pins in my main.c file, should I modify the overlay file to make these two pins setting the same?
    For example, if I set the SPI pins in main.c as:
    #define NET_SPIM_CS_PIN (41)
    #define NET_SPIM_SCK_PIN (39)
    #define NET_SPIM_MISO_PIN (38)
    #define NET_SPIM_MOSI_PIN (37)
    	NRFX_SPIM_DEFAULT_CONFIG(NET_SPIM_SCK_PIN, NET_SPIM_MOSI_PIN, NET_SPIM_MISO_PIN, NET_SPIM_CS_PIN);
    		return;
    Do I need to add the pin setting in nrf5340dk_nrf5340_cpunet.overlay file? like this
    &spi0 {
    	status = "okay";
    	sck-pin = <39>;
    	miso-pin = <38>;
    	mosi-pin = <37>;
    Thank you
