nRF9160 Using UART with printf without all the debugging outputs from Zephyr
How do I use printf to output my own messages, and read incoming data, from a UART port that is separate from Zephyr's debugging outputs? This UART line will be connected to another microcontroller for custom commands.
Here is what I have so far:
I want printf messages to be directed to the UART0 port for my program to talk to another device. I also want to be able to read the incoming messages.
Here is my code that works:
while (1) {
		char *s = console_getline();
		printf("Here's your string: %s\n", s);
However, with the above code, I also get what appears to be debug outputs from Zephyr being put on my UART0 line. For example, when the device starts up, I get a bunch of debug messages, etc. Also, any printk() messages are also on UART0.
I thought I could get around this by modifying the kconfig settings (via kconfig or guiconfig). I tried disabling things like the kernal boot banner, logging, etc, but the settings are reset to the defaults after rebuilding the project.
    You can enable the Logging module of Zephyr by adding #include <logging/log.h> to e.g. main.c and the following lines to prj.conf
    # Configure logger
    CONFIG_LOG=y
    CONFIG_USE_SEGGER_RTT=n
    CONFIG_LOG_BACKEND_UART=y
    CONFIG_LOG_DEFAULT_LEVEL=4
    There are four severity levels available in the system: error, warning, info and debug.
    In your main.c add the following lines just before your main loop.
    #define LOG_MODULE_NAME app
    LOG_MODULE_REGISTER(LOG_MODULE_NAME);
    In you application you should be able to replace e.g the printk() with LOG_INF() for debug/logging information.
    This should provide you with the following output
    Let me know how that works for you
  • This did not fix my problem, unfortunately.
    Just to clear up any confusion, this is what I'm seeing as the device starts up:
    *** Booting Zephyr OS build v2.7.99-ncs1-1  ***
    I: Starting bootloader
    I: Primary image: magic=bad, swap_type=0x0, copy_done=0x2, image_ok=0x2
    I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Boot source: none
    I: Swap type: none
    I: Bootloader chainload address offset: 0x10000
    I: Jumping to the first image slot
    Flash regions..Domain..Permissions
    00 03 0x00000 0x20000 .Secure..rwxl
    04 31 0x20000 0x100000 .Non-Secure.rwxl
    Non-secure callable region 0 placed in flash region 3 with size 32.
    SRAM region..Domain..Permissions
    00 03 0x00000 0x08000 .Secure..rwxl
    04 31 0x08000 0x40000 .Non-Secure.rwxl
    Peripheral..Domain..Status
    00 NRF_P0               Non-Secure.OK
    01 NRF_CLOCK            Non-Secure.OK
    02 NRF_RTC0             Non-Secure.OK
    03 NRF_RTC1             Non-Secure.OK
    04 NRF_NVMC             Non-Secure.OK
    05 NRF_UARTE1           Non-Secure.OK
    06 NRF_UARTE2           Secure..SKIP
    07 NRF_TWIM2            Non-Secure.OK
    08 NRF_SPIM3            Non-Secure.OK
    09 NRF_TIMER0           Non-Secure.OK
    10 NRF_TIMER1           Non-Secure.OK
    11 NRF_TIMER2           Non-Secure.OK
    12 NRF_SAADC            Non-Secure.OK
    13 NRF_PWM0             Non-Secure.OK
    14 NRF_PWM1             Non-Secure.OK
    15 NRF_PWM2             Non-Secure.OK
    16 NRF_PWM3             Non-Secure.OK
    17 NRF_WDT              Non-Secure.OK
    18 NRF_IPC              Non-Secure.OK
    19 NRF_VMC              Non-Secure.OK
    20 NRF_FPU              Non-Secure.OK
    21 NRF_EGU0             Non-Secure.OK
    22 NRF_EGU1             Non-Secure.OK
    23 NRF_EGU2             Non-Secure.OK
    24 NRF_EGU3             Non-Secure.OK
    25 NRF_EGU4             Non-Secure.OK
    26 NRF_EGU5             Non-Secure.OK
    27 NRF_DPPIC            Non-Secure.OK
    28 NRF_REGULATORS       Non-Secure.OK
    29 NRF_PDM              Non-Secure.OK
    30 NRF_I2S              Non-Secure.OK
    31 NRF_GPIOTE1          Non-Secure.OK
    SPM: NS image at 0x20200
    SPM: NS MSP at 0x20015338
    SPM: NS reset vector at 0x25ec1
    SPM: prepare to jump to Non-Secure image.
    I don't want any of these messages on my UART 0 port. I only want messages that I send using printf() function in my code only.
    Here is what I want to see during device startup:
    // nothing, but I had to put something here since the code block wont let me post without any text.
  • Ok, I see. You could use e.g. RTT for logs. See RTT chapter in Logging in nRF Connect SDK. To turn off the "boot banner" you can add CONFIG_BOOT_BANNER=n.
    Also, please see the Zephyr Logging API.
  • I added the following to my prj.conf file:
    CONFIG_LOG=y
    CONFIG_LOG_MODE_MINIMAL=y
    CONFIG_LOG_BACKEND_UART=n
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_LOG_BACKEND_RTT=y
    But it had no effect. Boot banner and all the Zephyr start-up messages are still present on UART0.
  • Are there any updates on this? Again, I want to silence all outputs to the UART0, and only transmit data I send out via a printf() function.
