- I'm trying to run the light_zc example on Linux VM running on MAC.
- I've loaded the Zigbee NCP firmware on a dongle on MAC
- I'm running the light coordinator example on Linux
- When I run the application, it just sits there
Any ideas on what I can try?
with simple gateway I get "aborted"
Same with the coordinator
In the case in your first reply was the light coordinator able to create a network so that the light bulb could join? It would also be useful if you could run a sniffer to look at traffic on the channel the coordinator is trying to create the network, because then you will see if the coordinator actually creates a network or not. You can use nRF Sniffer for 802.15.4 for this.
It is hard to say what the issue is without looking at the log, so please upload the log from the NCP host. You should find it in ncp_host_v2.1.1, and it should be called simple_gw.log and light_zc.log.
Marte
