Hi
I want to measure the battery lithium, this battery is the principal source (3.7v 300mh), the maximum voltage is 4.2 when the charge is full,
i'm using this code for to read the analog input y calculate the battery level
this is for to init
void saadc_callback_handler(nrf_drv_saadc_evt_t const * p_event)
void saadc_init(void)
ret_code_t err_code;
nrf_saadc_channel_config_t channel_config = NRFX_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN3);
err_code = nrf_drv_saadc_init(NULL, saadc_callback_handler);
err_code = nrfx_saadc_channel_init(0,&channel_config);
i am using the voltage devisor R1=1k and R2 =10k
log_init();
saadc_init();
nrf_saadc_value_t adc_val;
NRF_LOG_INFO("APPlication Started!!");
while (1)
nrfx_saadc_sample_convert(0,&adc_val);
valueVoltaje = (adc_val * 4.2f / 1024)*0.91;// 1.07 calculo del parametro a utilizar para captura de voltaje de la bateria
porcentaje = (valueVoltaje/4.2f)*100;
i have a problem with the voltage calculating, its not the same multimeter measurement
i have no idea if i need to change some parameter or where I can see other example
this is the circuit
thank you and regards
sorry my English is not good
